diff --git a/module2/ressources/jupyter.md b/module2/ressources/jupyter.md
index b68078450d2ec958bfcd8b98bcfc47cc539bd07f..48affe03caaaede67d462314330f0abeb2fa99c2 100644
--- a/module2/ressources/jupyter.md
+++ b/module2/ressources/jupyter.md
@@ -7,22 +7,22 @@ Date: Tue Feb 19 15:42:13 2019
Table of Contents
-- [1. Jupyter tips and tricks](#1-jupyter-tips-and-tricks)
- - [Creating or importing a notebook](#creating-or-importing-a-notebook)
- - [Running R and Python in the same notebook](#running-r-and-python-in-the-same-notebook)
- - [Other languages](#other-languages)
-- [2. Installing and configuring Jupyter on your computer](#2-installing-and-configuring-jupyter-on-your-computer)
+- [1 Jupyter tips and tricks](#1-jupyter-tips-and-tricks)
+ - [1.1 Creating or importing a notebook](#11-creating-or-importing-a-notebook)
+ - [1.2 Running R and Python in the same notebook](#12-running-r-and-python-in-the-same-notebook)
+ - [1.3 Other languages](#13-other-languages)
+- [2 Installing and configuring Jupyter on your computer](#2-installing-and-configuring-jupyter-on-your-computer)
- [2.1 Installing Jupyter](#21-installing-jupyter)
- [2.2 Making sure Jupyter allows you to use R](#22-making-sure-jupyter-allows-you-to-use-r)
- [2.3 Additional tips](#23-additional-tips)
-1. Jupyter tips and tricks
+1 Jupyter tips and tricks
The following [webpage](https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/) lists several Jupyter tricks (in particular, it illustrates many `IPython magic` commands) that should improve your efficiency (note that this blog post is about two years old so some of the tricks may have been integrated in the default behavior of Jupyter now).
-Creating or importing a notebook
+1.1 Creating or importing a notebook
Using the Jupyter environment we deployed for this MOOC will allow to easily access any file from your default GitLab project. There are situations however where you may want to play with other notebooks.
@@ -45,8 +45,8 @@ If your notebook is already in your GitLab project, then simply synchronize by u
3. Then from the top right button, `Upload` the previously downloaded notebook and confirm the upload.
4. Open the freshly uploaded notebook through the Jupyter file manager.
-Running R and Python in the same notebook
+1.2 Running R and Python in the same notebook
`rpy2` package allows to use both languages in the same notebook by:
@@ -72,8 +72,8 @@ Running R and Python in the same notebook
Note that this `%%R` notation indicates that R should be used for the whole cell but an other possibility is to use `%R` to have a single line of R within a python cell.
-Other languages
+1.3 Other languages
Jupyter is not limited to Pytyhon and R. Many other languages are available: [](https://github.com/jupyter/jupyter/wiki/Jupyter-kernels), including non-free languages like SAS, Mathematica, Matlab... Note that the maturity of these kernels differs widely.
@@ -83,8 +83,8 @@ Since the question was asked several times, if you really need to stay with SAS,
Since proprietary software such as SAS cannot easily be inspected, we discourage its use as it hinders reproducibility by essence. But perfection does not exist anyway and using Jupyter literate programming approach allied with systematic control version and environment control will certainly help anyway.
-2. Installing and configuring Jupyter on your computer
+2 Installing and configuring Jupyter on your computer
In this section, we explain how to set up a Jupyter environment on your own computer similar to the one deployed for this MOOC.
diff --git a/module2/ressources/jupyter.org b/module2/ressources/jupyter.org
index 875905f630e98bd05c61c0314eb3afb9cdc3ce89..d3afc5817195ae974717ace6da72f03c2303e1ce 100644
--- a/module2/ressources/jupyter.org
+++ b/module2/ressources/jupyter.org
@@ -7,22 +7,22 @@
#+PROPERTY: header-args :eval never-export
* Table of Contents :TOC:
-- [[#1-jupyter-tips-and-tricks][1. Jupyter tips and tricks]]
- - [[#creating-or-importing-a-notebook][Creating or importing a notebook]]
- - [[#running-r-and-python-in-the-same-notebook][Running R and Python in the same notebook]]
- - [[#other-languages][Other languages]]
-- [[#2-installing-and-configuring-jupyter-on-your-computer][2. Installing and configuring Jupyter on your computer]]
+- [[#1-jupyter-tips-and-tricks][1 Jupyter tips and tricks]]
+ - [[#11-creating-or-importing-a-notebook][1.1 Creating or importing a notebook]]
+ - [[#12-running-r-and-python-in-the-same-notebook][1.2 Running R and Python in the same notebook]]
+ - [[#13-other-languages][1.3 Other languages]]
+- [[#2-installing-and-configuring-jupyter-on-your-computer][2 Installing and configuring Jupyter on your computer]]
- [[#21-installing-jupyter][2.1 Installing Jupyter]]
- [[#22-making-sure-jupyter-allows-you-to-use-r][2.2 Making sure Jupyter allows you to use R]]
- [[#23-additional-tips][2.3 Additional tips]]
-* 1. Jupyter tips and tricks
+* 1 Jupyter tips and tricks
The following [[https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/][webpage]] lists several Jupyter tricks (in particular, it
illustrates many =IPython magic= commands) that should improve your
now).
-** Creating or importing a notebook
+** 1.1 Creating or importing a notebook
@@ -54,7 +54,7 @@ situations however where you may want to play with other notebooks.
manager.
-** Running R and Python in the same notebook
+** 1.2 Running R and Python in the same notebook
=rpy2= package allows to use both languages in the same notebook by:
1. Loading =rpy2=:
#+begin_src python :results output :exports both
@@ -74,7 +74,7 @@ situations however where you may want to play with other notebooks.
Note that this =%%R= notation indicates that R should be used for the whole cell but
an other possibility is to use =%R= to have a single line of R within a
python cell.
-** Other languages
+** 1.3 Other languages
[[https://github.com/jupyter/jupyter/wiki/Jupyter-kernels][https://github.com/jupyter/jupyter/wiki/Jupyter-kernels]], including
@@ -93,7 +93,7 @@ essence. But perfection does not exist anyway and using Jupyter
-* 2. Installing and configuring Jupyter on your computer
+* 2 Installing and configuring Jupyter on your computer
diff --git a/module2/ressources/jupyter_fr.md b/module2/ressources/jupyter_fr.md
index 5346827c90392a79fad884422d1a4175232eca1e..ab3aec145f30e494ac1be3281bbf6f6e43d29c78 100644
--- a/module2/ressources/jupyter_fr.md
+++ b/module2/ressources/jupyter_fr.md
@@ -7,22 +7,22 @@ Date: Tue Feb 19 17:43:42 2019
Table of Contents
-Other languages
diff --git a/module2/ressources/jupyter_fr.org b/module2/ressources/jupyter_fr.org
index 64062656c2975cd60513384e2be271bf08211434..fe3ee074bca643de2ca87def7203bb88d46753ce 100644
--- a/module2/ressources/jupyter_fr.org
+++ b/module2/ressources/jupyter_fr.org
@@ -7,22 +7,22 @@
now).
manager.
1. Loading =rpy2=:
python cell.
-** Other languages
