From f4f3b55f07e6d54f26ebd10c6be6fad57a5b6f78 Mon Sep 17 00:00:00 2001 From: Arnaud Legrand Date: Wed, 29 Aug 2018 16:37:25 +0200 Subject: [PATCH] Regenerate files --- module2/ressources/jupyter.html | 68 ++++++++++++++++----------------- 1 file changed, 34 insertions(+), 34 deletions(-) diff --git a/module2/ressources/jupyter.html b/module2/ressources/jupyter.html index 9527eec..ccecf1d 100644 --- a/module2/ressources/jupyter.html +++ b/module2/ressources/jupyter.html @@ -4,31 +4,31 @@
Table of Contents
Additional Jupyter resources or tricks
Tips and tricks
Tips and tricks
The following webpage lists several Jupyter tricks (in particular, it illustrates many Ipython magic commands) that should improve your @@ -38,9 +38,9 @@ now).
Running R and Python in the same notebook
The best solution to this is to install rpy2. On my machine, I have installed the python3-rpy2 debian package with apt-get install. E.g., @@ -88,9 +88,9 @@ plot(df)
Exporting a notebook
Obviously, you can convert to html or pdf using the using the File > Download as > HTML (or PDF) menu option. This can also be done from @@ -117,20 +117,20 @@ taste.
Installing Jupyter on your own machine
Installing jupyter
Installing jupyter
Follow these instructions if you wish to have a similar Jupyter environment on you own machine.
-First, download and install Anaconda latest version. We use Anaconda version 4.5.4 on our server .
-Anaconda includes Python, the Jupyter Notebook, and other commonly used packages for scientific computing and data science. +First, download and install Miniconda latest version. We use Miniconda version 4.5.4 on our server .
+Miniconda is a light version of Anaconda which includes Python, the Jupyter Notebook, and other commonly used packages for scientific computing and data science.
@@ -151,9 +151,9 @@ jupyter notebook
Exporting your notebooks with latex
Here is what I had to install on my recent debian machine to make sure the notebook export via latex works: @@ -166,9 +166,9 @@ sudo apt-get install texlive-xetex
Interesting extensions to improve notebook readability
Here are two interesting extensions that can improve readability:
-- 2.18.1
