diff --git a/module2/ressources/gitlab.org b/module2/ressources/gitlab.org index f83fb379788b0e6e6570a5152c7c5c402632efb8..9936655685a07702d3eeb2710280b8bba601ff7f 100644 --- a/module2/ressources/gitlab.org +++ b/module2/ressources/gitlab.org @@ -12,11 +12,7 @@ ignored in a first step* *as we have closely integrated Jupyter and GitLab in the context of this MOOC.* So far, you only used git via the web interface from the GitLab we -deployed for the MOOC. - -#+BEGIN_CENTER -https://app-learninglab.inria.fr/gitlab/ -#+END_CENTER +deployed for the MOOC: https://app-learninglab.inria.fr/gitlab/ If you access this link from the FUN platform, you do not have to authenticate and you can readily read and modify all your files. This @@ -165,4 +161,97 @@ video: #+BEGIN_EXPORT html #+END_EXPORT +* Using Git through the command line to synchronize your local files with Gitlab +This section describes a generic (through the command line) way to +synchronize your local files with Gitlab. You will not need this if +you follow the Jupyter course. If you follow the Rstudio course, all +these operations can be done through Rstudio and you may want to read +[[file:rstudio.org][the corresponding instructions]]. If you follow the Org-Mode course, all +these operations can be done through Magit and you may want to read +[[file:emacs_orgmode.org][the corresponding instructions]]. + +Here are other ways to learn Git through the command line: +- The [[http://swcarpentry.github.io/git-novice/][Software Carpentry git tutorial]] +- The (freely available) Pro Git book ([[https://git-scm.com/book/en/v2][in English]] or [[https://git-scm.com/book/fr/v2][in + French]]). Reading the first two chapters is enough to get a good start. +- [[https://learngitbranching.js.org/][Learn Git Branching]] will allow to interactively learn Git and to + understand with branches. + +Now, let's start! +1. Obtain the repository URL + [[file:gitlab_images/adresse_depot.png]] +2. Cloning the repository + #+begin_src shell :results output :exports both + cd /the/directory/where/you/want/to/clone/your/repository + git clone https://app-learninglab.inria.fr/gitlab/xxx/mooc-rr.git + #+end_src + Alternatively, you may want to indicate now your login although I + rather suggest you follow the /Remembering your password locally/ + instructions: + #+begin_src shell :results output :exports both + git clone https://xxx@app-learninglab.inria.fr/gitlab/xxx/mooc-rr.git + #+end_src + Now a directory =mooc-rr= has been created on your computer. +3. Inspect the repository + #+begin_src shell :results output :exports both + cd mooc-rr + ls # (Unix) + dir # (Windows) + #+end_src +4. Synchronizing to GitLab + + You should indicate which files to track (=git add=) and commit them + locally (=git commit=) before they can be transfered (=git push=) to + GitLab. The =git status= will indicate you whether files are + tracked/modified/committed/... + + Let's assume you just created a `fichier.txt` file on the top of + the =mooc-rr= directory. + + #+begin_src shell :results output :exports both + git status + #+end_src + + [[file:gitlab_images/status1.png]] + + #+begin_src shell :results output :exports both + git add fichier.txt + git status + #+end_src + + [[file:gitlab_images/status2.png]] + + #+begin_src shell :results output :exports both + git commit -m "message commit" + #+end_src + + [[file:gitlab_images/commit_git.png]] + + #+begin_src shell :results output :exports both + git status + #+end_src + + [[file:gitlab_images/status3.png]] + + The file can then be transfered to GitLab: + #+begin_src shell :results output :exports both + git push + #+end_src + + At this point, git will as you about your login/password unless + you followed the previous /Remembering your password locally/ instructions. + + N.B.: you will not be allowed to propagate your modifications to + GitLab if other modifications (e.g., from someone else) have been + propagated in between + + [[file:gitlab_images/rejected.png]] +5. Synchronizing from Gitlab: to avoid the previous problem, you need + to fetch the remote GitLab modifications first and apply them + locally. + #+begin_src shell :results output :exports both + git pull + #+end_src + Only then will you be able to =git push=. + diff --git a/module2/ressources/gitlab_images/adresse_depot.png b/module2/ressources/gitlab_images/adresse_depot.png new file mode 100644 index 0000000000000000000000000000000000000000..684b44f96d93fa06e11b78c5d76463ff8a655c2d Binary files /dev/null and b/module2/ressources/gitlab_images/adresse_depot.png differ diff --git a/module2/ressources/gitlab_images/commit_git.png b/module2/ressources/gitlab_images/commit_git.png new file mode 100644 index 0000000000000000000000000000000000000000..385eb8708fdfa232085837fcf84a2a7a116ecc1a Binary files /dev/null and b/module2/ressources/gitlab_images/commit_git.png differ diff --git a/module2/ressources/gitlab_images/rejected.png b/module2/ressources/gitlab_images/rejected.png new file mode 100644 index 0000000000000000000000000000000000000000..f0e11660cc7439173cd1bf6826521b2de1e6205e Binary files /dev/null and b/module2/ressources/gitlab_images/rejected.png differ diff --git a/module2/ressources/gitlab_images/status1.png b/module2/ressources/gitlab_images/status1.png new file mode 100644 index 0000000000000000000000000000000000000000..136e7f3209260ddcadf9adc2ca1017408fb4cde4 Binary files /dev/null and b/module2/ressources/gitlab_images/status1.png differ diff --git a/module2/ressources/gitlab_images/status2.png b/module2/ressources/gitlab_images/status2.png new file mode 100644 index 0000000000000000000000000000000000000000..df173fd9cb58700f8f19587eb3f432868ad503b8 Binary files /dev/null and b/module2/ressources/gitlab_images/status2.png differ diff --git a/module2/ressources/gitlab_images/status3.png b/module2/ressources/gitlab_images/status3.png new file mode 100644 index 0000000000000000000000000000000000000000..1e8d388d9eb8d2f7fb3f7fccb82bf0f45d49e504 Binary files /dev/null and b/module2/ressources/gitlab_images/status3.png differ
