diff --git a/module4/ressources/resources.org b/module4/ressources/resources.org index 6139e4f617ad13566be0410c5ee76f5ef7610599..3f4e254483070d04693eeea10dc026066bdea6ef 100644 --- a/module4/ressources/resources.org +++ b/module4/ressources/resources.org @@ -83,7 +83,11 @@ hash) will not be stored in the cell. This is not really a problem and is the price to pay for running git from within the notebook itself. * Getting information about Python(3) libraries ** Getting the list of installed packages and their version -https://stackoverflow.com/questions/20180543/how-to-check-version-of-python-modules +This topic is discussed on [[https://stackoverflow.com/questions/20180543/how-to-check-version-of-python-modules][StackOverflow]]. When using =pip= (the Python +package installer) within a shell command, it is easy to query the +version of all installed packages (note that on your system, you may +have to use either =pip= or =pip3= depending on how it is named and which +versions of Python are available on your machine. #+begin_src shell :results output :exports both pip3 freeze #+end_src @@ -109,6 +113,10 @@ wcwidth==0.1.7 webencodings==0.5 #+end_example +Once you know which packages are installed, you can easily get +additional information about a given package and in particular check +whether it was installed "locally" through pip or whether it is +installed system-wide. Again, in a shell command: #+begin_src shell :results output :exports both pip3 show pandas echo " " @@ -138,14 +146,12 @@ Location: /home/alegrand/.local/lib/python3.6/site-packages Requires: patsy, pandas #+end_example -#+begin_src python :results output :exports both - -#+end_src - ** How to list imported modules? -Inspiring from [[https://stackoverflow.com/questions/4858100/how-to-list-imported-modules][StackOverflow]], here is a simple function that lists -loaded package (that have a =__version__= attribute, which is -unfortunately not completely standard). +Without resorting to pip (that will list all available packages), you +may want to know which modules are loaded in a Python session as well +as their version. Inspiring from [[https://stackoverflow.com/questions/4858100/how-to-list-imported-modules][StackOverflow]], here is a simple +function that lists loaded package (that have a =__version__= attribute, +which is unfortunately not completely standard). #+begin_src python :results output :exports both def print_imported_modules(): @@ -204,9 +210,9 @@ pip3 freeze > requirements.txt # to obtain the list of packages with their versi pip3 install -r requirements.txt # to install the previous list of packages, possibly on an other machine #+end_src -If you want to have several installed python environments, you may +If you want to have several installed Python environments, you may want to use [[https://docs.pipenv.org/][Pipenv]]. I doubt it allows to track correctly FORTRAN or C -dynamic libraries that are wrapped by Python. +dynamic libraries that are wrapped by Python though. * Getting information about R libraries The best way seems to be to rely on the =devtools= package. @@ -267,3 +273,23 @@ Packages ---------------------------------------------------------------------- Some actually advocate that [[https://github.com/ropensci/rrrpkg][writing a reproducible research compendium can be done by writing an R package]]. Those of you willing to have a clean R dependency management should thus have a look at [[https://rstudio.github.io/packrat/][Packrat]]. + +Finally, it is good to know that there is a built-in R command +(=installed.packages=) allowing to retrieve and list the details of all +packages installed. +#+begin_src R :results table :session *R* :exports both :colnames yes +head(installed.packages()) +#+end_src + +#+RESULTS: +| Package | LibPath | Version | Priority | Depends | Imports | LinkingTo | Suggests | Enhances | License | License_is_FOSS | License_restricts_use | OS_type | MD5sum | NeedsCompilation | Built | | +|-------------------------------------------------------------+-------------------------------------------------+---------------------------------------------------------+-------------+----------------------------------------------------------+----------------------------------------------------------------+-----------+---------------+---------------------------------------+---------------------------+---------------+---------------------+--------+--------+------------------+-------+-------| +| BH | /home/alegrand/R/x86_64-pc-linux-gnu-library/3.5 | 1.66.0-1 | nil | nil | nil | nil | nil | nil | BSL-1.0 | nil | nil | nil | nil | no | 3.5.1 | | +| Formula | /home/alegrand/R/x86_64-pc-linux-gnu-library/3.5 | 1.2-3 | nil | R (>= 2.0.0), stats | nil | nil | nil | nil | GPL-2 | GPL-3 | nil | nil | nil | nil | no | 3.5.1 | +| Hmisc | /home/alegrand/R/x86_64-pc-linux-gnu-library/3.5 | 4.1-1 | nil | lattice, survival (>= 2.40-1), Formula, ggplot2 (>= 2.2) | methods, latticeExtra, cluster, rpart, nnet, acepack, foreign, | | | | | | | | | | | | +| gtable, grid, gridExtra, data.table, htmlTable (>= 1.11.0), | | | | | | | | | | | | | | | | | +| viridis, htmltools, base64enc | nil | chron, rms, mice, tables, knitr, ff, ffbase, plotly (>= | | | | | | | | | | | | | | | +| 4.5.6) | nil | GPL (>= 2) | nil | nil | nil | nil | yes | 3.5.1 | | | | | | | | | +| Matrix | /home/alegrand/R/x86_64-pc-linux-gnu-library/3.5 | 1.2-14 | recommended | R (>= 3.2.0) | methods, graphics, grid, stats, utils, lattice | nil | expm, MASS | MatrixModels, graph, SparseM, sfsmisc | GPL (>= 2) | file LICENCE | nil | nil | nil | nil | yes | 3.5.1 | +| StanHeaders | /home/alegrand/R/x86_64-pc-linux-gnu-library/3.5 | 2.17.2 | nil | nil | nil | nil | RcppEigen, BH | nil | BSD_3_clause + file LICENSE | nil | nil | nil | nil | yes | 3.5.1 | | +| acepack | /home/alegrand/R/x86_64-pc-linux-gnu-library/3.5 | 1.4.1 | nil | nil | nil | nil | testthat | nil | MIT + file LICENSE | nil | nil | nil | nil | yes | 3.5.1 | |
