From fbf36f902cc55dba71154e64c4c313a5680ffc06 Mon Sep 17 00:00:00 2001 From: Arnaud Legrand Date: Fri, 29 Mar 2019 20:39:15 +0100 Subject: [PATCH] Fix link --- module2/ressources/emacs_newbie.org | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-) diff --git a/module2/ressources/emacs_newbie.org b/module2/ressources/emacs_newbie.org index 0522f28..4181599 100644 --- a/module2/ressources/emacs_newbie.org +++ b/module2/ressources/emacs_newbie.org @@ -6,9 +6,9 @@ #+PROPERTY: header-args :eval never-export -This document assumes you have installed emacs as explained in -FIXME. All the screenshots in this demo are done under the Windows -operating system but it should look similar on any OS. +This document assumes you have installed emacs as explained [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/954f94ce4f9a4d858d47b41793cc96c8][here]]. All +the screenshots in this demo are done under the Windows operating +system but similar results should be obtained on any OS. * First steps with Emacs as a computationnal environment ** Run Emacs -- 2.18.1
