diff --git a/module2/ressources/emacs_orgmode.html b/module2/ressources/emacs_orgmode.html index 5f2a5f1ae706c67572cb5e2def356baffd09fd31..a35d82afe6e4603e62e6e14c19bd3c682310ae29 100644 --- a/module2/ressources/emacs_orgmode.html +++ b/module2/ressources/emacs_orgmode.html @@ -4,47 +4,47 @@
Table of Contents
@@ -65,13 +65,13 @@ the -
Installing emacs, org-mode, ess, and auctex.
Linux (Debian, Ubuntu)
We provide here only instructions for Debian-based distributions. Feel free to contribute to this document to provide up-to-date information @@ -133,9 +133,9 @@ which is now deprecated.
macOS
macOS
Note: macOS comes with a prehistoric command-line-only version of Emacs located at /usr/bin/emacs. It's best to forget about it.
@@ -190,9 +190,9 @@ in order to make Emacs accessible directly from /Applications.
Windows
Windows
Directory naming conventions
In the following instructions, we refer to your home directory through the (UNIX) ~/ notation. On Windows, your home @@ -218,9 +218,9 @@ means we are referring to C:\Users\yourname\org (resp.
Making R and Python available to the console
When running a command, Windows will look for the command in the directories indicated in the PATH environment variable. If none of @@ -237,9 +237,9 @@ explained -
Installing and configuring Matplotlib (graphic python library)
Open an DOS console and type the following command:
@@ -275,9 +275,9 @@ starting with backend, which amounts to use the default Agg
All platforms: pretty code in HTML export
To have code pretty printing when exporting to HTML, you should install the htmlize package, which is done by opening emacs and @@ -290,9 +290,9 @@ M-x package-install RET htmlize RET # where M-x means pressing the "Esc" key
A simple "reproducible research" emacs configuration
Step 0: Backup and download our configuration
Step 1: Prepare your journal
Create an org/ directory in the top of your home:
@@ -353,9 +355,9 @@ should give a try.
Step 2: Set up Emacs configuration
Copy rr_org/init.el in your ~/.emacs.d/ directory.
@@ -367,9 +369,9 @@ configuration with the following command: emacs -q -l rr_org/init.el
Step 3: Adapt the configuration to your specific needs if required
There are two situations in which it might be necessary to modify init.el: @@ -398,9 +400,9 @@ beginning of the file for instructions.
Step 4: Check whether the installation is working or not
Open a new instance of Emacs and open a foo.org file. Copy the following lines in this file: @@ -431,9 +433,9 @@ is demonstrated in the -
Step 5: Open and play with your journal:
In step 1, you were told to create an journal in ~org/journal.org. First you probably want to make sure this file is @@ -444,9 +446,9 @@ FUN forums.
A stub of a replicable article
This section is illustrated in a video tutorial ("Écrire un article réplicable avec Emacs/Orgmode" in French). Watching it before @@ -510,22 +512,22 @@ chunk of code when exporting.
Emacs tips and tricks
Cheat-sheets
Cheat-sheets
Learning Emacs and Org-Mode can be difficult as there is an inordinate amount of shortcuts. Many people have thus come up with cheat-sheats. Here is a selection in case it helps:
Emacs
Emacs
Org-mode
Org-mode
Video tutorials
Video tutorials
For those of you who prefer video explanations, here is a Youtube channel with many step by step emacs tutorials.
Additional useful emacs packages
Company-mode
Company-mode
Company-mode is a text completion framework for Emacs. It allows to have smart completion in emacs for the most common languages. If you @@ -569,9 +571,9 @@ official Web page: http://company-mode.
Magit
Magit
Magit is an Emacs interface for Git. Its usage is briefly illustrated in the context of this MOOC in a video tutorial ("Utilisation @@ -589,9 +591,9 @@ invoke magit by using C-x g.
