diff --git a/src/Python3/challenger_Python_org.org b/src/Python3/challenger_Python_org.org new file mode 100644 index 0000000000000000000000000000000000000000..87b6b6d1976744e8be0d5f055e14c7661077a078 --- /dev/null +++ b/src/Python3/challenger_Python_org.org @@ -0,0 +1,342 @@ +* Chalenger - Emacs - Python - Windows 7 64 bits + +** Risk Analysis of the Space Shuttle: Pre-Challenger Prediction of Failure + + In this document we reperform some of the analysis provided in + /Risk Analysis of the Space Shuttle: Pre-Challenger Prediction of + Failure/ by /Siddhartha R. Dalal, Edward B. Fowlkes, Bruce Hoadley/ + published in /Journal of the American Statistical Association/, Vol. 84, + No. 408 (Dec., 1989), pp. 945-957 and available at + http://www.jstor.org/stable/2290069. + + On the fourth page of this article, they indicate that the maximum + likelihood estimates of the logistic regression using only temperature + are: *$\hat{\alpha}$ = 5.085* and *$\hat{\beta}$ = -0.1156* and their + asymptotic standard errors are *$s_{\hat{\alpha}}$ = 3.052* and + *$s_{\hat{\beta}}$ = 0.047*. The Goodness of fit indicated for this model was + *$G^2$ = 18.086* with *21* degrees of freedom. Our goal is to reproduce + the computation behind these values and the Figure 4 of this article, + possibly in a nicer looking way. + +*** Technical information on the computer on which the analysis is run + + We will be using the Python 3 language using the pandas, statsmodels, + and numpy library. + + #+begin_src python :results output :session :exports both +def print_imported_modules(): + import sys + for name, val in sorted(sys.modules.items()): + if(hasattr(val, '__version__')): + print(val.__name__, val.__version__) +# else: +# print(val.__name__, "(unknown version)") +def print_sys_info(): + import sys + import platform + print(sys.version) + print(platform.uname()) + +import numpy as np +import pandas as pd +import matplotlib.pyplot as plt +import statsmodels.api as sm +import seaborn as sns + +print_sys_info() +print_imported_modules() + #+end_src + + #+RESULTS: + #+begin_example +Python 3.7.0 (v3.7.0:1bf9cc5093, Jun 27 2018, 04:59:51) [MSC v.1914 64 bit (AMD64)] on win32 +Type "help", "copyright", "credits" or "license" for more information. +3.7.0 (v3.7.0:1bf9cc5093, Jun 27 2018, 04:59:51) [MSC v.1914 64 bit (AMD64)] +uname_result(system='Windows', node='MGDONDON', release='7', version='6.1.7601', machine='AMD64', processor='Intel64 Family 6 Model 94 Stepping 3, GenuineIntel') +IPython 6.5.0 +IPython.core.release 6.5.0 +_csv 1.0 +_ctypes 1.1.0 +decimal 1.70 +argparse 1.1 +backcall 0.1.0 +colorama 0.3.9 +csv 1.0 +ctypes 1.1.0 +cycler 0.10.0 +dateutil 2.7.3 +decimal 1.70 +decorator 4.3.0 +distutils 3.7.0 +ipykernel 4.8.2 +ipykernel._version 4.8.2 +ipython_genutils 0.2.0 +ipython_genutils._version 0.2.0 +ipywidgets 7.4.0 +ipywidgets._version 7.4.0 +jedi 0.12.1 +json 2.0.9 +jupyter_client 5.2.3 +jupyter_client._version 5.2.3 +jupyter_core 4.4.0 +jupyter_core.version 4.4.0 +kiwisolver 1.0.1 +logging 0.5.1.2 +matplotlib 2.2.3 +matplotlib.backends.backend_agg 2.2.3 +numpy 1.15.0 +numpy.core 1.15.0 +numpy.core.multiarray 3.1 +numpy.lib 1.15.0 +numpy.linalg._umath_linalg b'0.1.5' +numpy.matlib 1.15.0 +pandas 0.23.4 +_libjson 1.33 +parso 0.3.1 +patsy 0.5.0 +patsy.version 0.5.0 +pickleshare 0.7.4 +platform 1.0.8 +prompt_toolkit 1.0.15 +pygments 2.2.0 +pyparsing 2.2.0 +pytz 2018.5 +re 2.2.1 +scipy 1.1.0 +scipy._lib.decorator 4.0.5 +scipy._lib.six 1.2.0 +scipy.fftpack._fftpack b'$Revision: $' +scipy.fftpack.convolve b'$Revision: $' +scipy.integrate._dop b'$Revision: $' +scipy.integrate._ode $Id$ +scipy.integrate._odepack 1.9 +scipy.integrate._quadpack 1.13 +scipy.integrate.lsoda b'$Revision: $' +scipy.integrate.vode b'$Revision: $' +scipy.interpolate._fitpack 1.7 +scipy.interpolate.dfitpack b'$Revision: $' +scipy.linalg 0.4.9 +scipy.linalg._fblas b'$Revision: $' +scipy.linalg._flapack b'$Revision: $' +scipy.linalg._flinalg b'$Revision: $' +scipy.ndimage 2.0 +scipy.optimize._cobyla b'$Revision: $' +scipy.optimize._lbfgsb b'$Revision: $' +scipy.optimize._minpack 1.10 +scipy.optimize._nnls b'$Revision: $' +scipy.optimize._slsqp b'$Revision: $' +scipy.optimize.minpack2 b'$Revision: $' +scipy.signal.spline 0.2 +scipy.sparse.linalg.eigen.arpack._arpack b'$Revision: $' +scipy.sparse.linalg.isolve._iterative b'$Revision: $' +scipy.special.specfun b'$Revision: $' +scipy.stats.mvn b'$Revision: $' +scipy.stats.statlib b'$Revision: $' +seaborn 0.9.0 +seaborn.external.husl 2.1.0 +seaborn.external.six 1.10.0 +six 1.11.0 +statsmodels 0.9.0 +statsmodels.__init__ 0.9.0 +traitlets 4.3.2 +traitlets._version 4.3.2 +urllib.request 3.7 +zlib 1.0 +zmq 17.1.2 +zmq.sugar 17.1.2 +zmq.sugar.version 17.1.2 + #+end_example + +*** Loading and inspecting data + + Let's start by reading data. + + #+begin_src python :results output :session :exports both +data = pd.read_csv("https://app-learninglab.inria.fr/gitlab/moocrr-session1/moocrr-reproducibility-study/raw/master/data/shuttle.csv") +print(data) + #+end_src + + #+RESULTS: + #+begin_example + Date Count Temperature Pressure Malfunction + 0 4/12/81 6 66 50 0 + 1 11/12/81 6 70 50 1 + 2 3/22/82 6 69 50 0 + 3 11/11/82 6 68 50 0 + 4 4/04/83 6 67 50 0 + 5 6/18/82 6 72 50 0 + 6 8/30/83 6 73 100 0 + 7 11/28/83 6 70 100 0 + 8 2/03/84 6 57 200 1 + 9 4/06/84 6 63 200 1 + 10 8/30/84 6 70 200 1 + 11 10/05/84 6 78 200 0 + 12 11/08/84 6 67 200 0 + 13 1/24/85 6 53 200 2 + 14 4/12/85 6 67 200 0 + 15 4/29/85 6 75 200 0 + 16 6/17/85 6 70 200 0 + 17 7/2903/85 6 81 200 0 + 18 8/27/85 6 76 200 0 + 19 10/03/85 6 79 200 0 + 20 10/30/85 6 75 200 2 + 21 11/26/85 6 76 200 0 + 22 1/12/86 6 58 200 1 + #+end_example + + We know from our previous experience on this data set that filtering + data is a really bad idea. We will therefore process it as such. + + #+begin_src python :results file :session :var matplot_lib_filename=(org-babel-temp-file "figure" ".png") :exports both +%matplotlib inline +pd.set_option('mode.chained_assignment',None) # this removes a useless warning from pandas + +data["Frequency"]=data.Malfunction/data.Count +data.plot(x="Temperature",y="Frequency",kind="scatter",ylim=[0,1]) +plt.grid(True) +plt.tight_layout() + +plt.savefig(matplot_lib_filename) +matplot_lib_filename + #+end_src + + #+RESULTS: + [[file:c:/Users/dondon/AppData/Local/Temp/babel-aNPFF5/figureFG8KBj.png]] + +*** Logistic regression + + Let's assume O-rings independently fail with the same probability + which solely depends on temperature. A logistic regression should + allow us to estimate the influence of temperature. + + #+begin_src python :results output :session :exports both +import statsmodels.api as sm + +data["Success"]=data.Count-data.Malfunction +data["Intercept"]=1 + +logmodel=sm.GLM(data['Frequency'], data[['Intercept','Temperature']], + family=sm.families.Binomial(sm.families.links.logit)).fit() + +print(logmodel.summary()) + #+end_src + + #+RESULTS: + #+begin_example +Generalized Linear Model Regression Results +============================================================================== +Dep. Variable: Frequency No. Observations: 23 +Model: GLM Df Residuals: 21 +Model Family: Binomial Df Model: 1 +Link Function: logit Scale: 1.0000 +Method: IRLS Log-Likelihood: -3.9210 +Date: Mon, 12 Nov 2018 Deviance: 3.0144 +Time: 13:13:31 Pearson chi2: 5.00 +No. Iterations: 6 Covariance Type: nonrobust +=============================================================================== + coef std err z P>|z| [0.025 0.975] +------------------------------------------------------------------------------- +Intercept 5.0850 7.477 0.680 0.496 -9.570 19.740 +Temperature -0.1156 0.115 -1.004 0.316 -0.341 0.110 +=============================================================================== + #+end_example + +The maximum likelyhood estimator of the intercept and of Temperature + are thus *$\hat{\alpha}$ = 5.0850* and *$\hat{\beta}$ = -0.1156*. This *corresponds* + to the values from the article of Dalal /et al./ The standard errors are + /$s_{\hat{\alpha}}$ = 7.477/ and /$s_{\hat{\beta}}$ = 0.115/, which is *different* from + the *3.052* and *0.04702* reported by Dallal /et al./ The deviance is + /3.01444/ with *21* degrees of freedom. I cannot find any value similar + to the Goodness of fit (*$G^2$ = 18.086*) reported by Dalal /et al./ There + seems to be something wrong. Oh I know, I haven't indicated that my + observations are actually the result of 6 observations for each rocket + launch. Let's indicate these weights (since the weights are always the + same throughout all experiments, it does not change the estimates of + the fit but it does influence the variance estimates). + + #+begin_src python :results output :session :exports both +logmodel=sm.GLM(data['Frequency'], data[['Intercept','Temperature']], + family=sm.families.Binomial(sm.families.links.logit), + var_weights=data['Count']).fit() + +print(logmodel.summary()) + #+end_src + + #+RESULTS: + #+begin_example +Generalized Linear Model Regression Results +============================================================================== +Dep. Variable: Frequency No. Observations: 23 +Model: GLM Df Residuals: 21 +Model Family: Binomial Df Model: 1 +Link Function: logit Scale: 1.0000 +Method: IRLS Log-Likelihood: -23.526 +Date: Mon, 12 Nov 2018 Deviance: 18.086 +Time: 13:13:39 Pearson chi2: 30.0 +No. Iterations: 6 Covariance Type: nonrobust +=============================================================================== + coef std err z P>|z| [0.025 0.975] +------------------------------------------------------------------------------- +Intercept 5.0850 3.052 1.666 0.096 -0.898 11.068 +Temperature -0.1156 0.047 -2.458 0.014 -0.208 -0.023 +=============================================================================== + #+end_example + + Good, now I have recovered the asymptotic standard errors + *$s_{\hat{\alpha}}$ = 3.052* and *$s_{\hat{\beta}}$ = 0.047*. The Goodness of fit + (Deviance) indicated for this model is *$G^2$ = 18.086* with *21* degrees + of freedom (Df Residuals). + + *I have therefore managed to fully replicate the results of the Dalal + /et al./ article*. + +*** Predicting failure probability + + The temperature when launching the shuttle was 31°F. Let's try to + estimate the failure probability for such temperature using our model: + + #+begin_src python :results file :session :var matplot_lib_filename=(org-babel-temp-file "figure" ".png") :exports both +%matplotlib inline +data_pred = pd.DataFrame({'Temperature': np.linspace(start=30, stop=90, num=121), 'Intercept': 1}) +data_pred['Frequency'] = logmodel.predict(data_pred) +data_pred.plot(x="Temperature",y="Frequency",kind="line",ylim=[0,1]) +plt.scatter(x=data["Temperature"],y=data["Frequency"]) +plt.grid(True) + +plt.savefig(matplot_lib_filename) +matplot_lib_filename + #+end_src + + #+RESULTS: + [[file:c:/Users/dondon/AppData/Local/Temp/babel-aNPFF5/figure51z7PH.png]] + + This figure is very similar to the Figure 4 of Dalal /et al./ *I have + managed to replicate the Figure 4 of the Dalal /et al./ article.* + +** Computing and plotting uncertainty + +Following the documentation of +[Seaborn](https://seaborn.pydata.org/generated/seaborn.regplot.html), +I use regplot. + +#+begin_src python :results file :session :var matplot_lib_filename=(org-babel-temp-file "figure" ".png") :exports both +sns.set(color_codes=True) +plt.xlim(30,90) +plt.ylim(0,1) +sns.regplot(x='Temperature', y='Frequency', data=data, logistic=True) +plt.show() + +plt.savefig(matplot_lib_filename) +matplot_lib_filename +#+end_src + +#+RESULTS: +[[file:c:/Users/dondon/AppData/Local/Temp/babel-aNPFF5/figurebq7jid.png]] + +**I think I have managed to correctly compute and plot the uncertainty + of my prediction.** Although the shaded area seems very similar to + [the one obtained by with + R](https://app-learninglab.inria.fr/gitlab/moocrr-session1/moocrr-reproducibility-study/raw/5c9dbef11b4d7638b7ddf2ea71026e7bf00fcfb0/challenger.pdf), + I can spot a few differences (e.g., the blue point for temperature + 63 is outside)... Could this be a numerical error ? Or a difference + in the statistical method ? It is not clear which one is "right".
