From 31adfd85a4ccb07412f41c0fae5049c1c2e01d8a Mon Sep 17 00:00:00 2001 From: Arnaud Legrand Date: Thu, 25 Oct 2018 11:33:48 +0200 Subject: [PATCH] Merge these two files to ease contributors' life. --- README.md | 28 ++++++++++++++++++++++++++-- results.md | 28 ---------------------------- 2 files changed, 26 insertions(+), 30 deletions(-) delete mode 100644 results.md diff --git a/README.md b/README.md index 73c73b7..266cca3 100644 --- a/README.md +++ b/README.md @@ -27,6 +27,30 @@ R*](challenger.pdf). your favourite language and an other language you do not know yet. - A [Jupyter Python3 notebook](src/Python3/challenger.ipynb) - An [Rmarkdown document](src/R/challenger.Rmd) -2. Then **update the [meta-study result table available - here](results.md) with your own results**. +2. Then **update the following table with your own results by + indicating in each column:**. + - Language: R, Python3, Julia, Perl, C... + - Language version: + - Main libraries: please indicate the versions of all the loaded + libraries + - Operating System: Linux, Mac OS X, Windows, Android, ... along with + its version + - $`\hat{\alpha}`$ and $`\hat{\beta}`$: Identical, Similar, Different, +Non functional (expected values are $`5.085`$ and $`-0.1156`$) + - $`s_{\hat{\alpha}}`$ and $`s_{\hat{\beta}}`$: Identical, Similar, + Different, Non functional (expected values are $`3.052`$ and $`0.047`$) + - $`G^2`$ and degree of freedom: Identical, Similar, Different, Non + functional (expected values are $`18.086`$ and $`21`$). + - Figure: Similar, Different, Non functional, Did not succeed + - Confidence region: Identical (to [the one obtained with R](challenger.pdf)), Similar, Quite Different, Did not succeed + +| Language | Language version | Main libraries | Operating System | $`\hat{\alpha}= 5.085`$ $`\hat{\beta} = -0.1156`$ | $`s_{\hat{\alpha}} = 3.052`$ $`s_{\hat{\beta}} = 0.047`$ | $`G^{2} = 18.086`$ $`dof = 21`$ | Figure | Confidence Region | Link to the document | +| -------- | ---------------- | ------------------------------------------------------------- | --------------------------- | ---------------------------- | --------------------------------- | ---------------- | --------- | ----------------- | ----------------------------------------------------------------- | +| **R** | | | | | | | | | | +| R | 3.5.1 | ggplot2 3.0.0 | Debian GNU/Linux buster/sid | Identical | Identical | Identical | Identical | Identical | [challenger.Rmd](src/R/challenger.Rmd) and [challenger.pdf](src/R/challenger_debian_alegrand.pdf) | +| R | 3.5.1 | ggplot2 3.0.0 rmarkdown 1.8 | Windows 7 32 bits | Identical | Identical | Identical | Identical | Identical | [challenger_Windows_32bits.pdf](src/R/challenger_R_Rmd_Windows_32bits.pdf) | +| **Python**| | | | | | | | | | +| Python | 3.6.5rc1 | statsmodels 0.9.0 numpy 1.13.3 pandas 0.22.0 matplotlib 2.1.2 | Linux Ubuntu 4.4.0-116-generic | Identical | Identical | Identical | Identical | Similar | [challenger.ipynb](src/Python3/challenger.ipynb) and [challenger.pdf](src/Python3/challenger_ubuntuMOOC_alegrand.pdf) | +| **SAS** | | | | | | | | | | +| SAS | 9.4 | | Windows 7 | Identical | Identical | Identical | Identical | Identical | [challenger_SAS_ipynb.ipynb](src/SAS/challenger_SAS_ipynb.ipynb) and [challenger_SAS_ipynb.pdf](src/SAS/challenger_SAS_ipynb.pdf)| diff --git a/results.md b/results.md deleted file mode 100644 index e2401d3..0000000 --- a/results.md +++ /dev/null @@ -1,28 +0,0 @@ -Update the following table with your own results by indicating in each -column: - -- Language: R, Python3, Julia, Perl, C... -- Language version: -- Main libraries: please indicate the versions of all the loaded - libraries -- Operating System: Linux, Mac OS X, Windows, Android, ... along with - its version -- $`\hat{\alpha}`$ and $`\hat{\beta}`$: Identical, Similar, Different, - Non functional (expected values are $`5.085`$ and $`-0.1156`$) -- $`s_{\hat{\alpha}}`$ and $`s_{\hat{\beta}}`$: Identical, Similar, - Different, Non functional (expected values are $`3.052`$ and $`0.047`$) -- $`G^2`$ and degree of freedom: Identical, Similar, Different, Non - functional (expected values are $`18.086`$ and $`21`$). -- Figure: Similar, Different, Non functional, Did not succeed -- Confidence region: Identical (to [the one obtained with R](challenger.pdf)), Similar, Quite Different, Did not succeed - -| Language | Language version | Main libraries | Operating System | $`\hat{\alpha}= 5.085`$ $`\hat{\beta} = -0.1156`$ | $`s_{\hat{\alpha}} = 3.052`$ $`s_{\hat{\beta}} = 0.047`$ | $`G^{2} = 18.086`$ $`dof = 21`$ | Figure | Confidence Region | Link to the document | -| -------- | ---------------- | ------------------------------------------------------------- | --------------------------- | ---------------------------- | --------------------------------- | ---------------- | --------- | ----------------- | ----------------------------------------------------------------- | -| **R** | | | | | | | | | | -| R | 3.5.1 | ggplot2 3.0.0 | Debian GNU/Linux buster/sid | Identical | Identical | Identical | Identical | Identical | [challenger.Rmd](src/R/challenger.Rmd) and [challenger.pdf](src/R/challenger_debian_alegrand.pdf) | -| R | 3.5.1 | ggplot2 3.0.0 rmarkdown 1.8 | Windows 7 32 bits | Identical | Identical | Identical | Identical | Identical | [challenger_Windows_32bits.pdf](src/R/challenger_R_Rmd_Windows_32bits.pdf) | -| **Python**| | | | | | | | | | -| Python | 3.6.5rc1 | statsmodels 0.9.0 numpy 1.13.3 pandas 0.22.0 matplotlib 2.1.2 | Linux Ubuntu 4.4.0-116-generic | Identical | Identical | Identical | Identical | Similar | [challenger.ipynb](src/Python3/challenger.ipynb) and [challenger.pdf](src/Python3/challenger_ubuntuMOOC_alegrand.pdf) | -| **SAS** | | | | | | | | | | -| SAS | 9.4 | | Windows 7 | Identical | Identical | Identical | Identical | Identical | [challenger_SAS_ipynb.ipynb](src/SAS/challenger_SAS_ipynb.ipynb) and [challenger_SAS_ipynb.pdf](src/SAS/challenger_SAS_ipynb.pdf)| - -- 2.18.1
