From 36f2cb05a8e7e9bb13d56a9b65e6f7d1367cac5e Mon Sep 17 00:00:00 2001 From: Arnaud Legrand Date: Wed, 24 Oct 2018 13:11:33 +0200 Subject: [PATCH] Plot uncertainty with Python --- src/Python3/challenger.ipynb | 270 ++++++++++++++++++++--------------- src/Python3/challenger.pdf | Bin 77777 -> 78661 bytes 2 files changed, 157 insertions(+), 113 deletions(-) diff --git a/src/Python3/challenger.ipynb b/src/Python3/challenger.ipynb index 760d11e..9bf774e 100644 --- a/src/Python3/challenger.ipynb +++ b/src/Python3/challenger.ipynb @@ -14,7 +14,7 @@ "In this document we reperform some of the analysis provided in \n", "*Risk Analysis of the Space Shuttle: Pre-Challenger Prediction of Failure* by *Siddhartha R. Dalal, Edward B. Fowlkes, Bruce Hoadley* published in *Journal of the American Statistical Association*, Vol. 84, No. 408 (Dec., 1989), pp. 945-957 and available at http://www.jstor.org/stable/2290069. \n", "\n", - "On the fourth page of this article, they indicate that the maximum likelihood estimates of the logistic regression using only temperature are: $\\hat{\\alpha}$ = **5.085** and $\\hat{\\beta}$ = **-0.1156** and their asymptotic standard errors are $s_{\\hat{\\alpha}}$ = **3.052** and $s_{\\hat{\\beta}}$ = **0.047**. The Goodness of fit indicated for this model was $G^2$ = **18.086** with **21** degrees of freedom. Our goal is to reproduce the computation behind these values and the Figure 4 of this article, possibly in a nicer looking way." + "On the fourth page of this article, they indicate that the maximum likelihood estimates of the logistic regression using only temperature are: $\\hat{\\alpha}=5.085$ and $\\hat{\\beta}=-0.1156$ and their asymptotic standard errors are $s_{\\hat{\\alpha}}=3.052$ and $s_{\\hat{\\beta}}=0.047$. The Goodness of fit indicated for this model was $G^2=18.086$ with 21 degrees of freedom. Our goal is to reproduce the computation behind these values and the Figure 4 of this article, possibly in a nicer looking way." ] }, { @@ -33,86 +33,77 @@ }, { "cell_type": "code", - "execution_count": 8, + "execution_count": 1, "metadata": {}, "outputs": [ { "name": "stdout", "output_type": "stream", "text": [ - "3.6.5rc1 (default, Mar 14 2018, 06:54:23) \n", - "[GCC 7.3.0]\n", - "uname_result(system='Linux', node='icarus', release='4.15.0-2-amd64', version='#1 SMP Debian 4.15.11-1 (2018-03-20)', machine='x86_64', processor='')\n", - "\n", - "IPython 5.5.0\n", - "IPython.core.release 5.5.0\n", - "PIL 4.3.0\n", - "PIL.version 4.3.0\n", + "3.6.4 |Anaconda, Inc.| (default, Jan 16 2018, 18:10:19) \n", + "[GCC 7.2.0]\n", + "uname_result(system='Linux', node='3a716011d2b6', release='4.4.0-116-generic', version='#140-Ubuntu SMP Mon Feb 12 21:23:04 UTC 2018', machine='x86_64', processor='x86_64')\n", + "IPython 6.4.0\n", + "IPython.core.release 6.4.0\n", + "PIL 5.2.0\n", + "PIL.Image 5.2.0\n", + "PIL._version 5.2.0\n", "_csv 1.0\n", "_ctypes 1.1.0\n", "_curses b'2.2'\n", "decimal 1.70\n", "argparse 1.1\n", + "backcall 0.1.0\n", + "cffi 1.11.5\n", "csv 1.0\n", "ctypes 1.1.0\n", - "cvxopt 1.1.9\n", "cycler 0.10.0\n", "dateutil 2.7.3\n", "decimal 1.70\n", "decorator 4.3.0\n", - "distutils 3.6.5rc1\n", + "distutils 3.6.4\n", "ipaddress 1.0\n", "ipykernel 4.8.2\n", "ipykernel._version 4.8.2\n", "ipython_genutils 0.2.0\n", "ipython_genutils._version 0.2.0\n", - "ipywidgets 6.0.0\n", - "ipywidgets._version 6.0.0\n", - "joblib 0.11\n", + "ipywidgets 7.2.1\n", + "ipywidgets._version 7.2.1\n", + "jedi 0.12.1\n", "json 2.0.9\n", "jupyter_client 5.2.3\n", "jupyter_client._version 5.2.3\n", "jupyter_core 4.4.0\n", "jupyter_core.version 4.4.0\n", + "kiwisolver 1.0.1\n", "logging 0.5.1.2\n", - "matplotlib 2.1.1\n", - "matplotlib.backends.backend_agg 2.1.1\n", - "matplotlib.pylab 1.14.5\n", - "numexpr 2.6.5\n", - "numpy 1.14.5\n", - "numpy.core 1.14.5\n", + "matplotlib 2.2.2\n", + "matplotlib.backends.backend_agg 2.2.2\n", + "numpy 1.13.3\n", + "numpy.core 1.13.3\n", "numpy.core.multiarray 3.1\n", "numpy.core.umath b'0.4.0'\n", - "numpy.lib 1.14.5\n", + "numpy.lib 1.13.3\n", "numpy.linalg._umath_linalg b'0.1.5'\n", - "numpy.matlib 1.14.5\n", + "numpy.matlib 1.13.3\n", "optparse 1.5.3\n", "pandas 0.22.0\n", "_libjson 1.33\n", + "parso 0.3.0\n", "patsy 0.5.0\n", "patsy.version 0.5.0\n", - "pexpect 4.2.1\n", + "pexpect 4.6.0\n", "pickleshare 0.7.4\n", - "pkg_resources._vendor.packaging.__about__ 16.8\n", - "pkg_resources._vendor.six 1.10.0\n", - "pkg_resources._vendor.appdirs 1.4.0\n", - "pkg_resources._vendor.packaging 16.8\n", - "pkg_resources._vendor.pyparsing 2.1.10\n", - "pkg_resources._vendor.six 1.10.0\n", "platform 1.0.8\n", "prompt_toolkit 1.0.15\n", - "ptyprocess 0.5.2\n", - "py 1.5.3\n", - "py._vendored_packages.apipkg 1.4\n", - "pytest 3.3.2\n", + "ptyprocess 0.6.0\n", "pygments 2.2.0\n", "pyparsing 2.2.0\n", "pytz 2018.5\n", "re 2.2.1\n", - "scipy 0.19.1\n", - "scipy._lib.decorator 4.3.0\n", + "scipy 1.1.0\n", + "scipy._lib.decorator 4.0.5\n", "scipy._lib.six 1.2.0\n", - "scipy.fftpack 0.4.3\n", "scipy.fftpack._fftpack b'$Revision: $'\n", "scipy.fftpack.convolve b'$Revision: $'\n", "scipy.integrate._dop b'$Revision: $'\n", @@ -140,7 +131,9 @@ "scipy.special.specfun b'$Revision: $'\n", "scipy.stats.mvn b'$Revision: $'\n", "scipy.stats.statlib b'$Revision: $'\n", - "simplejson 3.15.0\n", + "seaborn 0.8.1\n", + "seaborn.external.husl 2.1.0\n", + "seaborn.external.six 1.10.0\n", "six 1.11.0\n", "statsmodels 0.9.0\n", "statsmodels.__init__ 0.9.0\n", @@ -148,9 +141,9 @@ "traitlets._version 4.3.2\n", "urllib.request 3.6\n", "zlib 1.0\n", - "zmq 17.0.0\n", - "zmq.sugar 17.0.0\n", - "zmq.sugar.version 17.0.0\n" + "zmq 17.1.0\n", + "zmq.sugar 17.1.0\n", + "zmq.sugar.version 17.1.0\n" ] } ], @@ -172,7 +165,7 @@ "import pandas as pd\n", "import matplotlib.pyplot as plt\n", "import statsmodels.api as sm\n", - "\n", + "import seaborn as sns\n", "\n", "print_sys_info()\n", "print_imported_modules()" @@ -459,9 +452,9 @@ "outputs": [ { "data": { - "image/png": "iVBORw0KGgoAAAANSUhEUgAAAYUAAAEKCAYAAAD9xUlFAAAABHNCSVQICAgIfAhkiAAAAAlwSFlzAAALEgAACxIB0t1+/AAAADl0RVh0U29mdHdhcmUAbWF0cGxvdGxpYiB2ZXJzaW9uIDIuMS4xLCBodHRwOi8vbWF0cGxvdGxpYi5vcmcvAOZPmwAAGBNJREFUeJzt3XuQnXWd5/H3t5MACYmAxMkwBAQGhpUCJkDLReaSCFqBKpN1AYUtwXEGM1uSskRHYWZdhmGdqpVRmXFlFGRxhC2NXEbIzmaWixAdprgFiOEmTA8gdEDAGCANIemkv/vHefrxpOnLOZ1++vQ5vF9VqZznOb9++vvtp09/+rn070RmIkkSQFerC5AkTR2GgiSpZChIkkqGgiSpZChIkkqGgiSpVFkoRMTVEfFSRDwywvMREV+PiJ6IWBcRR1dViySpMVUeKfwDsHiU508BDin+LQO+WWEtkqQGVBYKmfkT4FejDFkKXJM19wB7RsQ+VdUjSRrb9BZ+7n2B5+qWe4t1LwwdGBHLqB1NMHPmzGP222+/SSmwUQMDA3R1dd7lmU7tCzq3N/tqP5PV25NPPvnLzHzXWONaGQoxzLph59zIzCuBKwG6u7tzzZo1VdbVtNWrV7Nw4cJWlzHhOrUv6Nze7Kv9TFZvEfHzRsa1Mnp7gfpf+ecDz7eoFkkSrQ2FlcA5xV1IxwOvZuZbTh1JkiZPZaePIuL7wEJgbkT0An8JzADIzG8Bq4BTgR7gDeATVdUiSWpMZaGQmWeN8XwC51X1+SVJzevMy/mSpHExFCRJJUNBklQyFCRJJUNBklQyFCRJJUNBklQyFCRJJUNBklQyFCRJJUNBklQyFCRJJUNBklQyFCRJJUNBklQyFCRJJUNBklQyFCRJJUNBklQyFCRJJUNBklQyFCRJJUNBklQyFCRJJUNBklQyFCRJJUNBklQyFCRJJUNBklQyFCRJJUNBklQyFCRJJUNBklQyFCRJJUNBklSqNBQiYnFEPBERPRFx4TDP7x8Rd0bEQxGxLiJOrbIeSdLoKguFiJgGXA6cAhwGnBURhw0Z9kXgusw8CjgT+Puq6pEkja3KI4VjgZ7MfCoztwIrgKVDxiTwjuLxHsDzFdYjSRpDZGY1G444HVicmecWy2cDx2Xm8rox+wC3AnsBuwMnZ+YDw2xrGbAMYN68ecesWLGikprHq6+vj9mzZ7e6jAnXqX1B5/ZmX+1nsnpbtGjRA5nZPda46RXWEMOsG5pAZwH/kJlfjYgTgGsj4vDMHNjhgzKvBK4E6O7uzoULF1ZR77itXr2aqVbTROjUvqBze7Ov9jPVeqvy9FEvsF/d8nzeenroT4DrADLzbmA3YG6FNUmSRlFlKNwPHBIRB0bELtQuJK8cMuZZ4CSAiHgPtVB4ucKaJEmjqCwUMnMbsBy4BXic2l1Gj0bEJRGxpBj2OeCTEfFT4PvAH2VVFzkkSWOq8poCmbkKWDVk3UV1jx8DTqyyBklS4/yLZklSyVCQJJUMBUlSyVCQJJUMBUlSyVCQJJUMBUlSyVCQJJUMBUlSyVCQJJUMBUlSyVCQJJUMBUlSyVCQJJUMBUlSyVCQJJUMBUlSyVCQJJUMBUlSyVCQJJUMBUlSyVCQJJUMBUlSyVCQJJUMBUlSyVCQJJUMBUlSyVCQJJUMBUlSyVCQJJUMBUlSyVCQJJUMBUlSyVCQJJUqDYWIWBwRT0RET0RcOMKYj0TEYxHxaER8r8p6JEmjm97IoIg4PDMfaWbDETENuBz4ANAL3B8RKzPzsboxhwB/DpyYmRsj4jea+RySpInV6JHCtyLivoj4VETs2eDHHAv0ZOZTmbkVWAEsHTLmk8DlmbkRIDNfanDbkqQKRGY2NrD2W/0fA2cA9wHfyczbRhl/OrA4M88tls8GjsvM5XVjbgKeBE4EpgEXZ+b/G2Zby4BlAPPmzTtmxYoVjXU3Sfr6+pg9e3ary5hwndoXdG5v9tV+Jqu3RYsWPZCZ3WMOzMyG/1H7wX0asB54HPgZ8J9GGHsGcFXd8tnA/xwy5p+AHwIzgAOpnWbac7QajjnmmJxq7rzzzlaXUIlO7Suzc3uzr/YzWb0Ba7KBn/MNnT6KiCMj4rIiCN4PfCgz31M8vmyED+sF9qtbng88P8yYmzOzPzOfBp4ADmmkJknSxGv0msI3gAeB383M8zLzQYDMfB744ggfcz9wSEQcGBG7AGcCK4eMuQlYBBARc4HfAZ5qrgVJ0kRp6O4j4FRgc2ZuB4iILmC3zHwjM68d7gMyc1tELAduoXba6erMfDQiLqF2GLOyeO6DEfEYsB34fGZu2MmeJEnj1Ggo3A6cDPQVy7OAW4H3jfZBmbkKWDVk3UV1jxP4bPFPktRijZ4+2i0zBwOB4vGsakqSJLVKo6HwekQcPbgQEccAm6spSZLUKo2ePvoMcH1EDN49tA/w0WpKkiS1SkOhkJn3R8R/AA4FAvhZZvZXWpkkadI1eqQA8F7ggOJjjooIMvOaSqqSJLVEoxPiXQv8NrCW2q2jAAkYCpLUQRo9UugGDituIZUkdahG7z56BPjNKguRJLVeo0cKc4HHIuI+YMvgysxcUklVkqSWaDQULq6yCEnS1NDoLak/joh3A4dk5u0RMYvafEaSpA7S6NTZnwRuAK4oVu1LbYZTSVIHafRC83nU3h3tNYDM/DfA91OWpA7TaChsydr7LAMQEdOp/Z2CJKmDNBoKP46IvwBmRsQHgOuB/1NdWZKkVmg0FC4EXgYeBv6U2nskjPSOa5KkNtXo3UcDwLeLf5KkDtXo3EdPM8w1hMw8aMIrkiS1TDNzHw3aDTgDeOfElyNJaqWGrilk5oa6f+sz82+B91dcmyRpkjV6+ujousUuakcOcyqpSJLUMo2ePvpq3eNtwDPARya8GklSSzV699GiqguRJLVeo6ePPjva85n5tYkpR5LUSs3cffReYGWx/CHgJ8BzVRQlSWqNZt5k5+jM3AQQERcD12fmuVUVJkmafI1Oc7E/sLVueStwwIRXI0lqqUaPFK4F7ouIH1L7y+YPA9dUVpUkqSUavfvoryPin4HfL1Z9IjMfqq4sSVIrNHr6CGAW8Fpm/h3QGxEHVlSTJKlFGn07zr8ELgD+vFg1A/jfVRUlSWqNRo8UPgwsAV4HyMzncZoLSeo4jYbC1sxMiumzI2L36kqSJLVKo6FwXURcAewZEZ8Ebsc33JGkjtPo3UdfKd6b+TXgUOCizLyt0sokSZNuzCOFiJgWEbdn5m2Z+fnM/LNGAyEiFkfEExHRExEXjjLu9IjIiOgeaYwkqXpjhkJmbgfeiIg9mtlwREwDLgdOAQ4DzoqIw4YZNwf4NHBvM9uXJE28Rv+i+U3g4Yi4jeIOJIDM/PQoH3Ms0JOZTwFExApgKfDYkHH/HbgU+LNGi5YkVaPRUPi/xb9m7MuOs6j2AsfVD4iIo4D9MvOfImLEUIiIZcAygHnz5rF69eomS6lWX1/flKtpInRqX9C5vdlX+5lqvY0aChGxf2Y+m5nfHce2Y5h1WbftLuAy4I/G2lBmXglcCdDd3Z0LFy4cRznVWb16NVOtponQqX1B5/ZmX+1nqvU21jWFmwYfRMSNTW67F9ivbnk+8Hzd8hzgcGB1RDwDHA+s9GKzJLXOWKFQ/9v+QU1u+37gkIg4MCJ2Ac7k12/SQ2a+mplzM/OAzDwAuAdYkplrmvw8kqQJMlYo5AiPx5SZ24DlwC3A48B1mfloRFwSEUuaK1OSNBnGutD8uxHxGrUjhpnFY4rlzMx3jPbBmbkKWDVk3UUjjF3YUMWSpMqMGgqZOW2yCpEktV4z76cgSepwhoIkqWQoSJJKhoIkqfS2CYUNfVv46XOvsKFvS6tLkdSEDX1b2Ny/3dfuJHlbhMLNa9dz4pfv4GNX3cuJX76DlWvXt7okSQ0YfO0+/fLrvnYnSceHwoa+LVxw4zre7B9g05ZtvNk/wBduXOdvHdIUV//a3Z7pa3eSdHwo9G7czIyuHduc0dVF78bNLapIUiN87bZGx4fC/L1m0j8wsMO6/oEB5u81s0UVSWqEr93W6PhQ2Hv2rlx62pHsNqOLObtOZ7cZXVx62pHsPXvXVpcmaRT1r91pEb52J0mjb7LT1pYs2JcTD55L78bNzN9rpt9UUpsYfO3ed/dd/OuS3/O1OwneFqEAtd86/IaS2s/es3dl5oxpvn4nScefPpIkNc5QkCSVDAVJUslQkCSVDAVJUslQkCSVDAVJUslQkCSVDAVJUslQkCSVDAVJUslQkCSVDAVJUslQkCSVDAVJUslQkCSVDAVJUslQkCSVDAVJUslQkCSVDAVJUqnSUIiIxRHxRET0RMSFwzz/2Yh4LCLWRcSPIuLdVdYjSRpdZaEQEdOAy4FTgMOAsyLisCHDHgK6M/NI4Abg0qrqkSSNrcojhWOBnsx8KjO3AiuApfUDMvPOzHyjWLwHmF9hPZKkMURmVrPhiNOBxZl5brF8NnBcZi4fYfw3gF9k5peGeW4ZsAxg3rx5x6xYsaKSmserr6+P2bNnt7qMCdepfUHn9mZf7Weyelu0aNEDmdk91rjpFdYQw6wbNoEi4mNAN/CHwz2fmVcCVwJ0d3fnwoULJ6jEibF69WqmWk0ToVP7gs7tzb7az1TrrcpQ6AX2q1ueDzw/dFBEnAz8V+APM3NLhfVIksZQ5TWF+4FDIuLAiNgFOBNYWT8gIo4CrgCWZOZLFdYiSWpAZaGQmduA5cAtwOPAdZn5aERcEhFLimF/A8wGro+ItRGxcoTNSZImQZWnj8jMVcCqIesuqnt8cpWfv51t6NtC78bNzN9rJnvP3nXCxraTTu2rKj0vbmLjG/30vLiJg+fNaXU5alOVhoLG5+a167ngxnXM6Oqif2CAS087kiUL9t3pse2kU/uqykU3Pcw19zzL547YxvmX/YRzTtifS5Ye0eqy1Iac5mKK2dC3hQtuXMeb/QNs2rKNN/sH+MKN69jQ99Zr8M2MbSed2ldVel7cxDX3PLvDumvufpaeFze1qCK1M0NhiunduJkZXTvulhldXfRu3LxTY9tJp/ZVlbXPvdLUemk0hsIUM3+vmfQPDOywrn9ggPl7zdypse2kU/uqyoL99mxqvTQaQ2GK2Xv2rlx62pHsNqOLObtOZ7cZXVx62pHDXmhtZmw76dS+qnLwvDmcc8L+O6w754T9vdiscfFC8xS0ZMG+nHjw3IbuvGlmbDvp1L6qcsnSIzjn+AN4+IF7uP384w0EjZuhMEXtPXvXhn8QNjO2nXRqX1U5eN4cemfNMBC0Uzx9JEkqGQqSpJKhIEkqGQqSpJKhIEkqGQqSpJKhIEkqGQqSpJKhIEkqGQqSpJKhIEkqGQqSpJKhIEkqGQqSpJKhIEkqGQqSpJKhIEkqGQqSpJKhIEkqGQqSpJKhIEkqGQqSpJKhIEkqGQqSpJKhIEkqGQqSpJKhIEkqGQqSpFKloRARiyPiiYjoiYgLh3l+14j4QfH8vRFxQJX1SM3a0LeFnz73Chv6tow6bs3TG/jarU+w5ukNE7bNZsf2vLiJjW/00/PipjHHNqOqepv5/Jv7tzf8NbhhzXMd9zWocrtDTa9qwxExDbgc+ADQC9wfESsz87G6YX8CbMzMgyPiTODLwEerqklqxs1r13PBjeuY0dVF/8AAl552JEsW7PuWcR+76h7u6qmFwdfv6OH3D96ba889fqe22ezYi256mGvueZbPHbGN8y/7CeecsD+XLD1inJ1XX2+zn//T7+nn/C/f0dDXYFCnfA2q3O5wqjxSOBboycynMnMrsAJYOmTMUuC7xeMbgJMiIiqsSWrIhr4tXHDjOt7sH2DTlm282T/AF25c95bf0tY8vaEMhEH/0rNh2COGRrfZ7NieFzft8MMQ4Jq7n93p35arqnc8n3975tvya1DldkcSmVnNhiNOBxZn5rnF8tnAcZm5vG7MI8WY3mL534sxvxyyrWXAsmLxUOCJSooev7nAL8cc1X46tS8Yo7eYMXPW9L32+Z3o6po2uC4HBrZv2/jCk9m/+Y3BddPmzP2tabvvuc/Qj9/++isvbN/0y+fHs81mx3bN2mPv6e941wEA2994lWmz9gBg22svPzPwxqtjn8/aya9Bs2PH8/kH+2rka1CvTb4GE/K92IB3Z+a7xhpU2ekjYLjf+IcmUCNjyMwrgSsnoqgqRMSazOxudR0TrVP7gs7tLSLWbHv1JftqI1Pte7HK00e9wH51y/OB50caExHTgT2AX1VYkyRpFFWGwv3AIRFxYETsApwJrBwyZiXw8eLx6cAdWdX5LEnSmCo7fZSZ2yJiOXALMA24OjMfjYhLgDWZuRL4X8C1EdFD7QjhzKrqqdiUPbW1kzq1L+jc3uyr/Uyp3iq70CxJaj/+RbMkqWQoSJJKhsI4RMQzEfFwRKyNiDXFuosjYn2xbm1EnNrqOpsVEXtGxA0R8bOIeDwiToiId0bEbRHxb8X/e7W6zmaN0Fcn7K9D6+pfGxGvRcRn2n2fjdJXJ+yz8yPi0Yh4JCK+HxG7FTfj3Fvsrx8UN+a0rkavKTQvIp4Buuv/yC4iLgb6MvMrraprZ0XEd4F/ycyrim/MWcBfAL/KzP9RzF+1V2Ze0NJCmzRCX5+hzfdXvWJamfXAccB5tPk+GzSkr0/QxvssIvYF7gIOy8zNEXEdsAo4FfjHzFwREd8CfpqZ32xVnR4pCICIeAfwB9TuCCMzt2bmK+w4Fcl3gf/YmgrHZ5S+Os1JwL9n5s9p8302RH1fnWA6MLP4u6xZwAvA+6lN8wNTYH8ZCuOTwK0R8UAxBceg5RGxLiKubrdDduAg4GXgOxHxUERcFRG7A/My8wWA4v/faGWR4zBSX9De+2uoM4HvF4/bfZ/Vq+8L2nifZeZ64CvAs9TC4FXgAeCVzNxWDOsFqpnprkGGwvicmJlHA6cA50XEHwDfBH4bWEBth3+1hfWNx3TgaOCbmXkU8DrwlunO29BIfbX7/ioVp8SWANe3upaJNExfbb3PihBbChwI/BawO7WfIUO19Jy+oTAOmfl88f9LwA+BYzPzxczcnpkDwLepzRLbTnqB3sy8t1i+gdoP0xcjYh+A4v+XWlTfeA3bVwfsr3qnAA9m5ovFcrvvs0E79NUB++xk4OnMfDkz+4F/BN4H7FmcToLhpwOaVIZCkyJi94iYM/gY+CDwyOCLsPBh4JFW1DdemfkL4LmIOLRYdRLwGDtORfJx4OYWlDduI/XV7vtriLPY8RRLW++zOjv01QH77Fng+IiYFRHBr19jd1Kb5gemwP7y7qMmRcRB1I4OoHZq4nuZ+dcRcS21w9oEngH+dPC8bruIiAXAVcAuwFPU7vboAq4D9qf2TX1GZrbVpIUj9PV12nx/AUTELOA54KDMfLVYtzftv8+G66sTXmN/Re2NxLYBDwHnUruGsAJ4Z7HuY5lZ7durjVajoSBJGuTpI0lSyVCQJJUMBUlSyVCQJJUMBUlSqbJ3XpMmW3Er5o+Kxd8EtlOb4gJqf2C4tSWFjSIi/hhYVfw9hdRy3pKqjjSVZq2NiGmZuX2E5+4Clmfm2ia2N71urhxpQnn6SG8LEfHxiLivmIf/7yOiKyKmR8QrEfE3EfFgRNwSEcdFxI8j4qnB+foj4tyI+GHx/BMR8cUGt/uliLgPODYi/ioi7i/m0f9W1HyU2h9j/aD4+F0iojci9iy2fXxE3F48/lJEXBERt1Gb3G96RHyt+NzrIuLcyf+qqhMZCup4EXE4tWkR3peZC6idNj2zeHoP4NZigsOtwMXUph84A7ikbjPHFh9zNPCfI2JBA9t9MDOPzcy7gb/LzPcCRxTPLc7MHwBrgY9m5oIGTm8dBXwoM88GlgEvZeaxwHupTcy4/3i+PlI9ryno7eBkaj8419SmnGEmtSkUADZn5m3F44eBVzNzW0Q8DBxQt41bMnMjQETcBPwetdfPSNvdyq+nQwE4KSI+D+wGzKU2ZfI/N9nHzZn5ZvH4g8B7IqI+hA6hNq2FNG6Ggt4OArg6M//bDitrM1PW/3Y+AGype1z/+hh68S3H2O7mLC7YFfP4fIPa7KzrI+JL1MJhONv49RH80DGvD+npU5n5I6QJ5OkjvR3cDnwkIuZC7S6lcZxq+WDU3ut5FrU58f+1ie3OpBYyvyxm2D2t7rlNwJy65WeAY4rH9eOGugX41OCUy1F7X+OZTfYkvYVHCup4mflwMTvl7RHRBfQD/4Xm5q2/C/getTd5uXbwbqFGtpuZG6L2PtGPAD8H7q17+jvAVRGxmdp1i4uBb0fEL4D7RqnnCmqzoK4tTl29RC2spJ3iLanSGIo7ew7PzM+0uhapap4+kiSVPFKQJJU8UpAklQwFSVLJUJAklQwFSVLJUJAklf4/GKF1l7kqzyEAAAAASUVORK5CYII=\n", + "image/png": "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\n", "text/plain": [ - "" + "
" ] }, "metadata": {}, @@ -484,7 +477,7 @@ "source": [ "## Logistic regression\n", "\n", - "Let's assume O-rings independently fail with the same probability which solely depends on temperature. A logistic regression should allow us to estimate the influence of temperature." + "Let's assume O-rings indpendently fail with the same probability which solely depends on temperature. A logistic regression should allow us to estimate the influence of temperature." ] }, { @@ -513,10 +506,10 @@ " Method: IRLS Log-Likelihood: -3.9210 \n", "\n", "\n", - " Date: Sun, 23 Sep 2018 Deviance: 3.0144 \n", + " Date: Wed, 24 Oct 2018 Deviance: 3.0144 \n", "\n", "\n", - " Time: 22:50:48 Pearson chi2: 5.00 \n", + " Time: 11:05:55 Pearson chi2: 5.00 \n", "\n", "\n", " No. Iterations: 6 Covariance Type: nonrobust\n", @@ -544,8 +537,8 @@ "Model Family: Binomial Df Model: 1\n", "Link Function: logit Scale: 1.0000\n", "Method: IRLS Log-Likelihood: -3.9210\n", - "Date: Sun, 23 Sep 2018 Deviance: 3.0144\n", - "Time: 22:50:48 Pearson chi2: 5.00\n", + "Date: Wed, 24 Oct 2018 Deviance: 3.0144\n", + "Time: 11:05:55 Pearson chi2: 5.00\n", "No. Iterations: 6 Covariance Type: nonrobust\n", "===============================================================================\n", " coef std err z P>|z| [0.025 0.975]\n", @@ -567,7 +560,8 @@ "data[\"Success\"]=data.Count-data.Malfunction\n", "data[\"Intercept\"]=1\n", "\n", - "logmodel=sm.GLM(data['Frequency'], data[['Intercept','Temperature']], family=sm.families.Binomial(sm.families.links.logit)).fit()\n", + "logmodel=sm.GLM(data['Frequency'], data[['Intercept','Temperature']], \n", + " family=sm.families.Binomial(sm.families.links.logit)).fit()\n", "\n", "logmodel.summary()" ] @@ -576,8 +570,99 @@ "cell_type": "markdown", "metadata": {}, "source": [ - "The maximum likelyhood estimator of the intercept and of Temperature are thus $\\hat{\\alpha}$ = **5.0849** and $\\hat{\\beta}$ = **-0.1156**. This **corresponds** to the values from the article of Dalal *et al.* The standard errors are $s_{\\hat{\\alpha}}$ = **7.477** and $s_{\\hat{\\beta}}$ = **0.115**, which is **different** from the ***3.052*** and ***0.04702*** reported by Dallal *et al.* The deviance is **3.01444** with **21** degrees of freedom. I cannot find any value similar to the Goodness of fit ($G^2$ = ***18.086***) reported by Dalal *et al.*\n", - "**I have therefore managed to partially replicate the results of the Dalal *et al.* article**." + "The maximum likelyhood estimator of the intercept and of Temperature are thus $\\hat{\\alpha}=5.0849$ and $\\hat{\\beta}=-0.1156$. This **corresponds** to the values from the article of Dalal et al. The standard errors are $s_{\\hat{\\alpha}} = 7.477$ and $s_{\\hat{\\beta}} = 0.115$, which is **different** from the $3.052$ and $0.04702$ reported by Dallal et al. The deviance is $3.01444$ with 21 degrees of freedom. I cannot find any value similar to the Goodness of fit ($G^2=18.086$) reported by Dalal et al. There seems to be something wrong. Oh I know, I haven't indicated that my observations are actually the result of 6 observations for each rocket launch. Let's indicate these weights (since the weights are always the same throughout all experiments, it does not change the estimates of the fit but it does influence the variance estimates)." + ] + }, + { + "cell_type": "code", + "execution_count": 5, + "metadata": {}, + "outputs": [ + { + "data": { + "text/html": [ + "\n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "
Generalized Linear Model Regression Results
Dep. Variable: Frequency No. Observations: 23
Model: GLM Df Residuals: 21
Method: IRLS Log-Likelihood: -23.526
Date: Wed, 24 Oct 2018 Deviance: 18.086
Time: 11:05:55 Pearson chi2: 30.0
Intercept 5.0850 3.052 1.666 0.096 -0.898 11.068
Temperature -0.1156 0.047 -2.458 0.014 -0.208 -0.023
" + ], + "text/plain": [ + "\n", + "\"\"\"\n", + " Generalized Linear Model Regression Results \n", + "==============================================================================\n", + "Dep. Variable: Frequency No. Observations: 23\n", + "Model: GLM Df Residuals: 21\n", + "Model Family: Binomial Df Model: 1\n", + "Link Function: logit Scale: 1.0000\n", + "Method: IRLS Log-Likelihood: -23.526\n", + "Date: Wed, 24 Oct 2018 Deviance: 18.086\n", + "Time: 11:05:55 Pearson chi2: 30.0\n", + "No. Iterations: 6 Covariance Type: nonrobust\n", + "===============================================================================\n", + " coef std err z P>|z| [0.025 0.975]\n", + "-------------------------------------------------------------------------------\n", + "Intercept 5.0850 3.052 1.666 0.096 -0.898 11.068\n", + "Temperature -0.1156 0.047 -2.458 0.014 -0.208 -0.023\n", + "===============================================================================\n", + "\"\"\"" + ] + }, + "execution_count": 5, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "logmodel=sm.GLM(data['Frequency'], data[['Intercept','Temperature']], \n", + " family=sm.families.Binomial(sm.families.links.logit),\n", + " var_weights=data['Count']).fit()\n", + "\n", + "logmodel.summary()" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Good, now I have recovered the asymptotic standard errors $s_{\\hat{\\alpha}}=3.052$ and $s_{\\hat{\\beta}}=0.047$.\n", + "The Goodness of fit (Deviance) indicated for this model is $G^2=18.086$ with 21 degrees of freedom (Df Residuals).\n", + "\n", + "**I have therefore managed to fully replicate the results of the Dalal et al. article**." ] }, { @@ -585,19 +670,19 @@ "metadata": {}, "source": [ "## Predicting failure probability\n", - "The temperature when launching the shuttle was 31°F. Let's try to estimate the failure probability for such temperature using our model:" + "The temperature when launching the shuttle was 31°F. Let's try to estimate the failure probability for such temperature using our model.:" ] }, { "cell_type": "code", - "execution_count": 5, + "execution_count": 6, "metadata": {}, "outputs": [ { "data": { - "image/png": "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\n", + "image/png": "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\n", "text/plain": [ - "" + "
" ] }, "metadata": {}, @@ -621,61 +706,21 @@ "scrolled": true }, "source": [ - "This figure is very similar to the Figure 4 of Dalal *et al.* **I have managed to replicate the Figure 4 of the Dalal *et al.* article.**" + "This figure is very similar to the Figure 4 of Dalal et al. **I have managed to replicate the Figure 4 of the Dalal et al. article.**" ] }, { "cell_type": "markdown", "metadata": {}, "source": [ - "No confidence region was given in the original article. I have tried to compute and draw the confidence region in python but I haven't found how to do so. **I have failed so far to obtain the confidence region**. Here are my attempts" + "## Computing and plotting uncertainty" ] }, { - "cell_type": "code", - "execution_count": 6, + "cell_type": "markdown", "metadata": {}, - "outputs": [ - { - "name": "stdout", - "output_type": "stream", - "text": [ - " low up OR\n", - "Intercept -9.569730 19.739685 5.084977\n", - "Temperature -0.341358 0.110156 -0.115601\n" - ] - } - ], "source": [ - "# Inspiring from http://blog.yhat.com/posts/logistic-regression-and-python.html\n", - "# odds ratios and 95% CI\n", - "params = logmodel.params\n", - "conf = logmodel.conf_int()\n", - "conf['OR'] = params\n", - "conf.columns = ['low', 'up', 'OR']\n", - "\n", - "#conf.low.Temperature = conf.OR.Temperature-2*0.047 ## I know my previous estimates of error are wrong. What if I fixed them ?\n", - "#conf.up.Temperature = conf.OR.Temperature+2*0.047\n", - "#conf.low.Intercept = conf.OR.Intercept-2*3.052\n", - "#conf.up.Intercept = conf.OR.Intercept+2*3.052\n", - "\n", - "print(conf)\n", - "def logit_inv(x):\n", - " return(np.exp(x)/(np.exp(x)+1))\n", - "\n", - "data_pred['Prob']=logit_inv(data_pred['Temperature'] * conf.OR.Temperature + conf.OR.Intercept)\n", - "\n", - "# mean_temp = np.mean(data.Temperature)\n", - "# mean_prob_logit = mean_temp * conf.OR.Temperature + conf.OR.Intercept\n", - "# # (np.power((data_pred.Temperature-mean_temp),2) / \n", - "# # ((np.sum(np.power(data_pred.Temperature,2))) - n*(np.power(mean_temp,2))))\n", - "\n", - "data_pred['Prob_low']=logit_inv(np.minimum(\n", - " data_pred['Temperature'] * conf.low.Temperature + conf.low.Intercept/2,\n", - " data_pred['Temperature'] * conf.up.Temperature + conf.low.Intercept/2))\n", - "data_pred['Prob_up']=logit_inv(np.maximum(\n", - " data_pred['Temperature'] * conf.low.Temperature + conf.up.Intercept/2,\n", - " data_pred['Temperature'] * conf.up.Temperature + conf.up.Intercept/2))" + "Following the documentation of [Seaborn](https://seaborn.pydata.org/generated/seaborn.regplot.html), I use regplot." ] }, { @@ -685,9 +730,9 @@ "outputs": [ { "data": { - "image/png": "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\n", + "image/png": "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\n", "text/plain": [ - "" + "
" ] }, "metadata": {}, @@ -695,20 +740,19 @@ } ], "source": [ - "%matplotlib inline\n", - "## http://markthegraph.blogspot.com/2015/05/using-python-statsmodels-for-ols-linear.html\n", - "data_pred.plot(x=\"Temperature\",y=\"Prob\",kind=\"line\",ylim=[0,1])\n", - "plt.fill_between(data_pred.Temperature,data_pred.Prob_low,data_pred.Prob_up,color='#888888', alpha=0.4)\n", - "plt.scatter(x=data[\"Temperature\"],y=data[\"Frequency\"])\n", - "plt.grid(True)" + "sns.set(color_codes=True)\n", + "plt.xlim(30,90)\n", + "plt.ylim(0,1)\n", + "sns.regplot(x='Temperature', y='Frequency', data=data, logistic=True)\n", + "plt.show()" ] }, { - "cell_type": "code", - "execution_count": null, + "cell_type": "markdown", "metadata": {}, - "outputs": [], - "source": [] + "source": [ + "**I think I have managed to correctly compute and plot the uncertainty of my prediction.** Although the shaded area seems very similar to [the one obtained by with R](https://app-learninglab.inria.fr/gitlab/moocrr-session1/moocrr-reproducibility-study/raw/5c9dbef11b4d7638b7ddf2ea71026e7bf00fcfb0/challenger.pdf), I can spot a few differences (e.g., the blue point for temperature 63 is outside)... Could this be a numerical error ? Or a difference in the statistical method ? It is not clear which one is \"right\"." + ] } ], "metadata": { @@ -728,7 +772,7 @@ "name": "python", "nbconvert_exporter": "python", "pygments_lexer": "ipython3", - "version": "3.6.5rc1" + "version": "3.6.4" } }, "nbformat": 4, diff --git a/src/Python3/challenger.pdf b/src/Python3/challenger.pdf index 42d0c7b767ee5cfc25316d2b54503e1f6622a6d0..bdfbe0ac75dd1422de3cf057e27e9a3e63df22e0 100644 GIT binary patch delta 60847 zcmbTdV{~Ofw@yef%ja`1|RMVlf z?x<-XO;7rru7Z;v9C@|KAJZuYSN!SauCR%WERF^7bcs=$1Chp{(@6QVPNdv{%C_I<#)7 zTL$rd(s_sV?cKRoju6J1LQz;J0hwK2Rie=;I}I=lf1G)M5@imAm2Mx42xh>(pwhD5Gi;AZJtYf{OLPAoklvIg4cp$sb8JMX>iTPG8qo*{zPY8 z4b!kZdn@u|?yCAeds38oEO`?f4G++3hyeOrGzVl{V?r**<+Bw92Y(pd4Fapj;0?|HW>&5f)L)d+&voInry8G3`w!eYlLw-O!lTVrn zdWD=k_hZkZQzP4^>m26kQH;ZV!73xr?FkqjNGuZ{jemCNpzCiOy`c`7Y4#nfZMDF; zArd~_+kBVZQbXn;5N+&Lr4+RRw6f z*~W>B=!gcj*D0;J;P@R90$&L_jYHa!qg{V2AcwUN55z~WNyKeTIqPpw{LLT#Zt&vz z^_`|a96s~Ms>k#)`jEJknujF`lD}MD(JD+K0rqQ!cz<^n&+jB#pFWpuI(x-4y`^uh zG!tPb6d7j_T{wycb59w9z?^IpZPJ0}zNqNF_BHlgVrc`AXtU%?9O~88q^y)-Z?K`O zPS8|jHmyevVN5a`GB1!wMCPX{@Bq)J*y$;>5%~%dF2AA6V*^=IE3)6o+lfQS<>8Oj zozg+T)SyzlnUWPVm@iM67dk9+zJ(ifM7f#QwreUQxwQr z$Vo-o9A@ci$cYNB31Oj_2Tj}?1dC>>T@j6@2!T}$LayOMMA$o8kkm2WR|`ao$$`kg+LsFR%YM0S5ArC znnAf-CA_OoMrU|%!a{mZur&es93x`v(byj9sH1j-+#>%q#*j|p$byBKL( z(?)+j{1z zPmw{M^I&P*l$7_;T z&{QS!ZJ+9CUzB=>)h}3U6|9a0GMPLK9J&k>S{zpacn6+0s?AO_SBY9sk^GUC2gq%( zpGL5@YvTH+IYoa0XqADCWfGL|G^$_$maNfG1V0-tUas0`I}OHv4-@$~%x9&u?+td~ z<2WGhYX%-I#XHeG!+1BQpEe)EW+(& z-TTzk!fOAR@Va|9wP7KuaT>b8ZLHw2Q)LMbR+c?)plwo>*RldWERpd1vYEBnWkV8g zver^^rfHWCd#|{`7_L>uTckK?z^slASw4(H-umWaN-R}Fjx#agNWw5Xw|rtZ+6^C z2~WPk9z*#K3suK>!sy*vF_kveqBo1NErq z_D-Obr6*9ct+VsxH`A?@SMW7#5$ecct}iizQ(?6ey5{arbZp`j&ILcozp#sR(u1B! zyG{=^SloqKpv0W2EP(`eBwb7)+*-+^Ds!#pAkQBgCfknOGDm6D1djgaipQ^koMf>Z z)}3UR@z2X8r0t6Ihreu+1y)~O%mA0#G16?bo+2ZXQ8sRZ6qbnOm8Ipxt<< z3ojnT*g`t8?P-Dx!NDF<=PyOs5OYZWa-!KyGqD5>0Ju>j6 zJMGrzy0NU#gpJN>U=qG2H}hP7i8d^q)WCWoXs$ipzFn2_*sNzkRanJ%;B)?c9-R(^ zouvexnFMLtoZ(j7Yn;u%1y zN_@<6P)aendM`R}*hFJJBIHhPn9#_vs-z%_#a3xNN3^!(ziK^z<)>r5NRNh;vqRmw zQ7W;GXA0p~kiLFc5p(0xn3f2eyLX!60dZS4^3pq8$7rHm`M4ijGWf=^Mk`Q7&=fDD>(N#u-V?TR5(n&LoZs2j1i5Xqn8PQ6Z1}aNtEh#y`5LB%v#i|)j;K3V5fLi#nD5E(Naq!~Vlq=Fn1ugh9pI6?~PCRaYMM%Rq1IzhJH)MFuoMgX#tG6X_oDJ|cMXFIm0xou-D7rdSi4fF-S~7n&*>FvBGX)AQG41guQ2!wJK-ryw;fVn8z8H;f%fQIQuwOmc z!*k)jP9jKFgXiE+F2bTaS4%_aCyy)iZl;J!wRs{-EYb=Jk`E6KzEJkuecqr*q&a0| zm%d7WME0P18rgVRb18fB0C@rPrwiGR1MDiZvQYjaql%U}w$5o{Rka>3A-`Uv%7{G` zCNLM4RdULhXlCMTl*IS{@B;I1g(6RxX->i?;tdwK0aGp@J+Ttsh|>#uyZ;W4_FFKl zY78f0RbiabO|5tPYOVdEI>2R^(-HRX%SKUNL%KJGI2We>V^=S-@_M?ZPN#6U$m>C~ zIB(EKq9Tetp@2*``lqF+`-I1BsC)Cl#dUM_Im-Mo&-{mJ-oE$9ofioKgy2+$1>EQ9 ztSBigu7P-V0iUMsoDlU!J^0rGo*{79U_r z&fXTSM$m;!7t0?RsvSmn@~5^!13Mwk05Yt8#^m@bovf>5=h^grMs(3a?zt)fiel3- zjow%6%JlQV*8eKq>yttPbqrMQ72Ilb3ukoT9s_d@Vz5QFEzgtLo0O=>xG|Q1PmeO} zJHxMllGB*dEqz4A=Rl~m#N??qwNDIlD?fwRkl`qK4!tl^N|gF*n!$gKA;qI)+mRM7 z%{&K7SL2#7F&b8c57p)BC42%29G?e+5-Gr_xrT)wrP`4D0`*JYV$yQXmr(`+rsh)P^H>*^%21 zX#$!>_(F)O?59DRjZz4^A=LEE_QmBWB= zb^E)dM1Uw1Mn=Fh*Lyq1FvxKGFbY@%N!`?Wq54Rvvsf<&M64oi^7u&0TCIHP!J-AjVq z6UJ%T1D!`%x{uP%+?j;{LqdOd+2^#yPh&!FJ>P0;#PKU^05of!@Y7-xGzYL8Xc)N< zVb>Sz@@ih2NVxf_9`ma)Pe>inAr@)yb=#Q(;9lX<+BO&3gCHcE4pPbOs|RJ}s8=L) zW*YYJLC)va%Y2LU3~U$n&y>$X9?tr8)LWv687aN(*lk(fcs|Jbebrh)JjWugJ0aP> zMx_9RCSfBrm-yhg&>Ta8tQ=@{-XhZKN!D1Z?h@vpqf+1_p|MVvr9g&16JaLpENz{b zf8H`%$O_6Lcu5i{e8)q?4?&7-RJatKvp$~BA%*qxw?2EZSTAW~p$q7v&V`MR)^NCA zc$H5wKQ~@YNEEFQ#x)9$5z6Cp=C^Yn42=~7bBQHcX;sV3%#m>w>Kq_kE9lnC}^6aY%J%Bdh8W_`!V(#I#h!?`=TR+1qe(a~|FAR$ALV*9q%GV1__cUqbjcK&x8}*W5 zS!UTKPELuTN%sCDFKY!y0Z$QhNtp8d2xUULs(?Cl?s|Eu5Pqr3>f>+mf>;`sM}|kA z`h78M;7Y*ybO}=2B@w4H*$4~o4{Rak_+x+Wbw~0NnKXD9EKu>B?^!I`$Q=sMI4B4f z!Y}{EO(jQrj*$o){G1>6w~lcuAP?yuA6RG0aEP$pq`Mp~wA7CBVrAGY_=`CsZ0S0G zTJuZJmG<~mqeMGN2mZXphOjSz)3ezYrO+_A(Eb?vt=tep`F_tUBdlPMuHe%nh7bU4(R_o~HEfA-@U+Dx@p()vQg^Z962^v=?gE7t&NA0o zO%~6@GQHO6?(w#{`HoaHR2HY7f)>|BjS#nLNnG=t5DpX&M?^pl$`QBWL=pQPw$_b6 z93GVOzib%?3*f&;0`(fFQE8&cpBtTE+RFWjh&4!wzvj#4>ZIeT&Ep3)Csg{D(<6F% zLDx>-AMutTkp>QTokzf{Tz$B?xmmbxdskc|EFeDQ#!ar0%ub8F$b+Un+*LOVHP6R| zJl_}QDVel(6s+x$bdUSv?CSdufG!VwnWug!wX4q-*GUhDJK-RP{no;Nbg|B{FdA|4 zRQXkVLscjnA@|2#baNOyc*<(25Q4eBO=W2$@5hE}0Npk9<^8%L*aE0<^kR}Odr6V} zTNURT=;KrAo(U2Cml%wlN13cldKYnnhASV_a2gJK0<9U-EV=wSLlyn7fs8@W_5_s$KFho*k4W z8F#Zsz5xh$^c{)Dc7mwJM#DIF*Ap$}g4y~iq73kOqn8U2r~+*_*~xfqU8RzKjK%zs%jf1uuz-9x?4u5+>e0F)8-+Wj$ReKP&tW@87?4){ z8Zc8&;9%DZJt{T&4r~-F9kLl+2KsA<0A>P__r^thHI&_8JaTD;v19oBvoU?@9u*n* z^FKu50BvmINg|5rSYmrG_Ei*UGb0rvPK{xtwC|sRBr&wD%roVnTL7T&8gttFWp= zAn8FbAX~ewfhJ8V-JI<{1SscGBCoU*z7wbl#mG|EQiZVJ8B||Qu9{_FiE5FC*@tfQ zco$O$r!;L8k4VaHzAd;3sW4eE4oHS0`Fy}}$sA}*O&A3aB|T={p{L5;LmKtB6WG21 zkO=lE9(9mMT7wBUhg-dhj94m#mWv!MCS$oT>0$h}fWv%ee)Xusu~U_V96n6JsVJ;T z$v*i>mV`6SN+~2!4`8bt2V8qq%eD^t`m>1pA#_^lDK*e{dl$5;WWjbMgKqlCJVUF( z(XT}+j5LLzW8mHf`>#9cV`1Ee)%H5I>ca+XoCq{|npeG7M)^$I}hq%SNTQ zB>>CN778G>B-F%goaroQW@-$jM+x2Q)@+DpnFlQ@J-kdT=zj}G#-OZC*5S^GTW&9s zl&hoBG3bq_MszPJ+Wj3TOP)JMwlq~BZgQiER4KFUUr4IZ+kv{-2=lwLze~f|W)xn^ znBA}5`sF}!W86(=SWMqsL!TF|WggKrDGKa7JuV6NTJBACu=N9kf-z`CR)v$YsoMqu zzRzj|3BRx1#MA##3cyK(_kYr4kMziIXDewQ3?l!M$Rx)%lF&@jd`Vxd;1-YD>kSXV(<$QAe4EEnhVIrtN_(gLjXe+Kd_ z%!G`DUsbCZOadSa8{>cXfaf@twyUByukUcgx>DfNCYz-Gg#;_<5xD7+3@8_TeWHSr zG@*KXl+bT1 zO9B~x=WH#NrP&8bh*42KTV2Gm=zr9=3~M46SBJ1}YbYYdFw@|eg2~I3648ytPXqsu zB-+PMkqTj7t0XluxlJIwmMhy zq9{KLM@uexq|vzz59ows%OMznxaMFBmb9_Y{yoB~5YaA_-!a;Q2;7 zuCztse%kJ5fZXNT|2cP8j}bQ*&+VFA_uy*~%Qd}GmPTAjuG12pJHd_B6L8xa_ybdt z&4^lP!{Ay4hGK^S**qeucsMsZGG45!tSuhQ*&-jIfb{s);Bb;a17^2_!ym}y^mmml zAMNPCgMfiB*TX$=V5REIjwciM$@nv=A`5Q|SCG zUao?%LB=wA$H4-H-#&lO!2fZ5j>NKN>|e?zzhe2^5JWhrE9jjLnGXcKVpM3^`wY(2E&@?U;{TCp&Uh%yN__C9Um3lB= zrfPCG4tsoAK$4ov8fYaAiJGj5M<>96Fzc4`sYAOc`QEdma99;Fp$~LXV6(0sTlFw5 zI!(c|p<@n%KZhSA4UORMLJqyPSb;XVegcr#o5mQ%4vYxmNbM(SaR|57O08yygoMm7 z`dri=rJ-TNgeo9n*ZYs+MTfwEdJ6N+D?=uScsREI$c0|%Q@DFeG4-e3r)6t3m^`oB z1J71!4GE`=?b>WdMFz%;4JB(1jS6DJ%(l-d;+6yQ`tIk&!dP<5@HKQJ z5Z=G_ha&YAnj^Hw(0H0K@{8kN>1MgEo!c#(AM@W|9CkV6B67oo5OpZE*)&q!a?_LD zW;&&Lj-k zGLxIP&D-a$BaPp>Wu$IOOYttFAxk!r!*S;a_>#2@3DUs0FxDkbFvTR;IZ5S2YqNu_ z%Z~tjfxI<-LS5R7 z*HK^6kjg#ltpS*aH&by}Td}B>K+#pcFQ=!{Ib9r!9C3@;EIui&XZXoRN8X$O!npGD zf;{oZYwLycoJ&59D60^kc@8{12fnsC7JTj`>KQPgnk!uLv8C}y3RC7qa6hhJpxq=e zOAFgu0zZk^$IoRO9b^`?Yhl2C;lm8D^YoY>K z!v0dZ6m6g8J8|ZgjpoEI6IQNO$M_c+1c{08H*k?(whF zop=39T`9WOL+ z>DhiIz}jLH^QDMkGEdgCM;QO_Vg*4)NlTNoqDUwYt8Of* zeM)KYV?aQP$+ki;spO+QVHe8^rP8gMXv-xul2MR@c_;nd^;?qvErnUowiR$29Lqq2 zr_v<3?={l_hNSBB%)E}av~19ECu$5xFa$fewBN)>@nSgoT#dvyJhpAd-<6I0I$i=4Fb93lmH!RVlx45AFfn-!Q3x?H0!8N)~gD_*H(6pct&jWx zc%0FCg43@zvvuyPSi5Y+#iKi@oZoU89v%rJ&M|wrVV_tU3EEfn9D@LN?#5ei-MW_+ zeowPDeuW`IJD|50XMIOnZKJy5Vu+@PT#FxcU%@r-f1P`>p} zn_#}T{n6Px3en52CZ9f`-vOh_%`I3)<S+jIPnkhUqGWNU-FQAeX%tsRv!ALfC?umdBR}DpPMfNKNn?M-wCKc8 zP19~9p=iFFYAy|M+2Aunrz}LZ3M;Zd4|rFkIdw|YEi9ZHCA=%C)SHF}hRf5T#FRgr zL_R_sLukTWQD*!O5yL_N(NOf`O-I;D6vN?wB$0$q^uPk5_?9uIFoNf!fF6p%%A|7+ zI6;o&J8d<{{-(rTdjS*Up~ex^04i3QJD`Ywg5jq!!9SU6F$bAL_y|0+PNy$Mg${IU z2L=m;ku3sreA_c*9bq)}XF!)C$TLXJYg>Yl4Y=qpw}$Q829nurEb%(WJNAx!;>s~E zM!h=6In05EYr|e`G&Io5JbU%4D+#NAuex?KNzeh_Wm~Q!a4KCn@}Vw>f`fC3gs?fy zXTJyLMNtN{SNyV791z0g?YdR$b#D*4hebls4Aa(I%|`wfDixJ*cec~HW^`Pnw_v9i zHp7v;Mg5&<9IPu|gx_n<<~1P${5dnm3$dVHDP{-Kz-&^37raKbI%REWY9?PwJhpLT z^yg`+Eay}moK&s8zo@a+zv>mhc6z5_m~SVl?`E3&zUBIb%NylsC{5Uue_}`Ls#Gw_ z8*u>B^#gzX}kOG4}TO&nAYqs)rdJ=LLq2F?C zzp2qxIpC$G^RaU~jmK$_7L}qhb&lCbb=l)B4vzab zY7*u;#XEWZ<)%v<9PtbbmAWfr3qK}gM4cu8UbYxJ^UwTJ8%K=;YQtBn36=ige>hte z&Yq+7RJ-{xHR3`RJ1tRlxO+NnYcuZMtB+5x>G>`jm|7~_u+$rbdmjjZz0}kqoTIi1s zXcNz3zQiXAp5;B^=bNieD1Vxwg@pEe5d;j z&xZKAgTYWPaLao|{}=aTd+l<2YvbC>7tjyo{f(x~)!YLOf(^`sBl z{5Q0|Jb}Uyhm^1eo1?oysK>ygu9SQ=FlUwVtu0w9EN7-NW9GClz1&6So>6HMBaX$_ z>?S~yS5RtVUyfgA?A@M2b3|kbelxH@$>^vC;-&qtf6k&f>wf2DET1$a8F~6PHuiT% zNHImv!zM&}R;-8+h0#390V*5%+qjl3ip1*zN!=*~J)x*J8tT?NyeqzDb`JF`kb{ck z`^#?gesS3x0*_>gq(-LRK8uyWYvBkVLGAm&wNRq1?y#5UZ$#stZ(2J zia7WMuYjNKmo`<7WkkEe8L}loxJZzICiv->J)3e_7ws{!R#D2KiP))Y>O`rFB`!?F zD=E*m$j?k`*~F(dA)eU`vtfJi|H|V;g@?1qHf|+hduHPquOiFA;D=OC3dZxU>HV*G# zsnS%KW&-uw`d^6z+>=*e580EFfR2eG)cdx;1$~ke$Fj#HCHjtvN)@;^s4PTBkl~7O)jG^1o;X zKF-_suXv#wiPO-NJ4
LJ8C2+-udfqSWWbHy^BmzIcz)sK8<183L4wbH`{{oddy{ zKu`k-mfG5$x7S6(xfDX?IVD1(3p$i63*3*C4S8`vq7m874Q>k`J7~2caqX_3fXp9^ z`$gca(;=uEG`ef!ZU+b#FNVz@n#Q8(;$&+D37x*=bZ@}~AK;OPlOzAL?7_-J7{?t8 z`|nx+jFUO;)6(qU!|FQ~kOlCcMUZLGZy+EDJyow9-J<@nBe}|K;46zwU3yz*w37UEusXGJ67re-BM(Y9JFU zGY7|i6tFU&z0i#}23;GHtVRms0-O}YkkOGLsN@llxrm7=(pm2z+<8Hpx#5FzJ07cj zH%f}LqgC6%3!p$@&mkaUP=$nGiAag^t=NYjm|0#wOv!190!X9TTi-e(duwZ3Yh^Q2 zp2sgg#}r|TW~l^#$Pn9TLbPBIf^x~o|EJLx`s)2_0$~M_^Zij8y)l8$qq+~5o0pfD zo!+kxL8}=uhkw4)AmRcDlSVhaAJ;Q^Jq_$hU}nT4&1dq(b$y=q%U6-`dDN7Y>O3DW zI5xc;murmG7GV6GG8ykr7bgb?4;RjtmzU9i{5XPn7hA8Bv5oS@;Pn^Ro2^sa?7A@enoj0f;GJ2tj z+1zpg_BmrJ-in2xrcaqp^OCObCJHJphYs8_YaB9MfRNv7SH_2gUUp0ANY|(T3C43D zu&2%RcDcU?g1)4!EnQN0$Hk?@TO|5DOPgE!hsG4M5TSunsSirE1*ByR%)(O@svyrC zQ$az2v5AR^kx@FIw??^&Ycb<`LJnH=75}-_46quGETA51fmjGkgRIXCMR4s`^2ggD zKLNMP-@-zZp=cs_3|c~QRCbv(cI%@lU=B1QE*6tPfKZOx>v`jPv7A7e*oyd!Qg4J5 zBPGh|xC=5>iAYEVoS++>6oJ=Ox3vM;P6WrsRdOttrLm)&35|NCqL2_dR3Pdw7Du27 zoZuR1{H>MQig~qSm4F5{#z+A%=bJxVAR(m`Pq)lW71kIcqnt#F8u@qq6has{AR2=m zT(TMxMohHaNIzW2U6u29zqRjb{;MByb!cmG4GTM^(f>pt6mv?(cf$(W9SkY3!1o_E zzx)g~D9wyvncaLO7{8uA8d`P*P1B#J0slURovED~F|Jlq{+p_s{5N05w!j?W^xvE8 zlDI}$BbV5Jy#Yf_^)qB_YnQ5+K>e~AuVF*>Po!Mhha(m1NMPX5IvH1oaQwe%qJFW8 z)>#!-S1}*WUn_${-qt;m@>W~SyM!mQZSc#2c@-!s^9;O zVneYYuKpLKe}0Au?ggr#{)y3s_Ty?`tOgI(xLzH=4i0>8LvSou3LU6Z?qA@l)pg_> zqXP$vpP=b0HeuvkoS;Ap2Z5(ZAy{>)2)PpV;rKH5lWw7i6;{L%a0TMmGw0sMoTnQi zI;`#axvU!9{0b(6u$*tstXW+M`$dh`pvOxmIi5M!HsGr|SM)~1Mqmy21_f8HXgF)+ zoNX>7m&}C}BL{f<09HN6DfEIVU(FcgebhE?y`F^~q2LH{Ljr!_IWSD|C2T??;cHbJ zKuXUl7D}aX*k)RKs;e*4RJIu~Vp0Cls56_M$`MZ6l&undUVDnybr^ZTWhgK^Oc7d7 zaOmCBufE>ya4QB#sVGpPp+Wfm^vyQ3Kt#^iA58*2?Z5b#j?b`2;i?Skd z*eq@j#tD3$wl_aN9v9Rp49qU8_@$+`Ei&#*23PP7Ya-G0ld3&tMYy|V3^>0ejV?Ma z4h<@;MvV4t0qzALw zfhE(mwL$X)$ZOK+0Q-f%>J+k>S~W(n5FSGMv-r|QU)LAf3l__7;#BE14pOwTPrl_~e$|uW+NgPWBH#ZJR zo)%a&)@x1nbH(z}N3%sy<0fS#CCy>)WqYywJPU?r!tz>%e!GWdeCz3+QNhmH(|{}b zo$fk+AY(ycA;$Ob3Gwku=Pp%Z=H})VjY7i0QMjC7p^{1TzKrIqsjaWDcKYCoLYY4{ z<7#2|xo#=aCiZj|)<=IK{!k#q4>$WV?$-0{IgHfQ7S}udDJdzt0}+z4vbxO<1;a*v zLPN!6WImpDqZZ3G8~?e34L6dngBs?=8b<`y7VH;pY)~J+^MchoCzfi^tR`ot<{u@? zUCMa6RLF_ZwPBxP(8eijIJJT%NSGXW&$|EH*;I8xyginWq zm5RK6Ez{Q~#;lU4KEb9%*ylZ2Jhb2_iPGrM^|}_&Q=5xrFBb*M#o^z-+?rGyO@Yj@ zN)899v`re1mD0_~YwP|ln3}#MnSWXl(J@!Y4+F(Zwyi!BaQx3}$D7@MK58YzW#m_{ zQ+=5k2CsG_$H9j)G=eVe+>};^GhTU*%KO*)9lNbB`?47w5*URPhR2r8tqR$8=ynWz z_zoEI91_uE4gNA-C>0~-2SXw$KoJNASxhBhLW1k%7@GLBOe?rF+81(350NK6j+~AJ zMfdS0hzsnMb+xeZpT@^}_owfgs{AAZ?Oj;-#!EqZXsI4rHrVA-&x>n<5z^f+t^eQ;qFYNrJ2HT1x9{GKY z!cjkHBN-a@6U?PE@1PC71N?gS5<`CWl$c+yQOayFbgX5nYM9^U^G}7BcYQ6&RfLq3 z94YKPt51r>xL#4$cpp<0i|3%Sm#-ZLE^hT>8G^~j?yf6y45Eh}y5425nPwk9S9+-k zQ&1o1U|Ly| z-gI9GUz9BtRsy*WLGPvOW<#fOzrH-I#BX$RAEq_E6vj$4E|RD7LJI2NAaAk)?t|F1 zoo^qc*>NHN4Ix67Bt(J+3w z8^nb^HgOctXAN#L9;&fgu32s8@O-ecwY@AZru0kWx_Q9makJZKb3a`uuhl3=;<*y& zZFD(XsdO}B-8Pf_knKCu}C;}Gz}P$5fzqAr6?M(_9VjP zTgp@BV@P^$ed%a|R!^@~sS^|>p_r7E=V6MhC98(yWGuJky+O)9 zsobs?sce=4X&WA=}=@dMT&%RFh7Nebi|Tnkx&YkmX=`A$a&tbdOJT}PH*-{C$sno zaBy(Y(dUi~i)6DpzLqsB%TI?Idgt-}4Ble^$kq6t_u^Qk|1lzR;_|v^ro_V_H?-YD;n|t>%-!b{ z>^KU}Ix>y)^Om!b!-h|Ycq%KZ{|8pFOV|q{aLg1_DTnoT<6^y)2(GN6!sn!0jT^&0*&fIrLL}y4xjhS-T7*xr>7^!vnE%@52w^~j4d`p zqaM}O+jG+Pd%c|Bh0vtISBeQZ2^7|@VtvFN+CP<*p&FZ3n6fe|Gsj_P2O@qPPGrDi z0FMWX`gc@yz3Zn3yXbu{n${G1)sPUBE;rh{t$&J$i2VBH?|U*|mZS;qE)wnWV#vF2 z&LcZLVcm&NWgM$h{qZ*0&@Xc>os681omz(W{&qY0qZIX*hK5EST}eqvHh_$b%%v4C zT)7vC=jABxR}{YSw-`h|@S8o*pBMxeuRswE+-@1hW_?}3?s=|{Lu^eA;!F}Lz!1_OzXadu$k>;UIXybtnCbi3hgTa#i9as^K?QcQAnkF53 zt)^&6WQc1_j7gd%&|xBS_>^}~Dh|TS+FehmCrUS)RJSK9M8S(CrfJr1D}4phqSB1g3 zQW(E3jI|@Wp*qYjmW-N}#wLMl4!7gi?4B?)8u}g&%clN*eh(Mx@UANqSzZo30kCR1 z5#NfUlbLxYjCftY{G3KTr{iNFf20I@nA-|CN-ifldEa>;Z1Rv_{~Q8p_0{nmzOL0M zxIQ)QtnHF2<9&>qk4s_gGS$lQp8GF;2y?;Y(z3F}FDX(`5Q@F;^#=acYDNt^Q|SsC z!%cWvK3LPpdzZ?QDQ}BqVvG&OQ%V2JPGw}4itLI}2nmnTH!$#(^U9I-6mimRmB&xu zWZW$$)|&j7)$i9N!*kH(@DX*SlnU{LkJG6H-i~urhii!ct~59(4q#~9=ce>HoHnRe zn4#c{cAZZ5&oxU8_6L3=6cbM67Tn$4rJ<&-3fGYRlCqV&Ya#ZaSAF1i|BME{$&5j- z2|-92ccK06!2R*;FY+>i5|Gnm4N|5V+n!z~etg>ejET?J=bpA|-d4z~GE;ttw13G2 zRiAdCIRbp*bjAz^lbCJ8CFcYy+-HzAdc}3(ErqAlBRV%3FwUTzXeYBL;2Y#c>b7^! zN%+I&gfb2-Vnr`pN~aA(VAwsJEl2TxV2zd~AVV$BzHZ5~ z%MmlMWjb};I+6z>@c4ySm(&4(o6e}Lqy$raJ(`ghE18L%P;8Lphc{Ze2CNCEz|J!- znvYxwxMJHfGf70R5-U?Fr>3KWJgqb6|HJ=&EDPlIxH}4wx&kJmM~c=))jeo3+gov5 z&O&Oy?8A-T`BYrq+()XVr50&gY}wibH5Gx_G3ZN z{oYC+tW9~w2DCI?QUhjhLc1ga=HcdY2nwQni~^=WiWn6Zwk?`5%L}a#!zS5VeM+q% z10RUeffn5NW|!Tuy}wq?+v_%UHDg8M-KW6A1+!@;lT0p~xmFzZ_N7GCLl>#gsD39> z_um*6uk*GG=D+?Dhnj;7E%dL%pyR&(onF6o`O9?LWcXt?D?Tk;&4ltQAvdBGe!Rc7 z&iF$kWwKdfB&z<{#?iqUi*)Q~Tj4r=0cszb8k35*It_4qCBMOS4UoU5&1k8px^FDF ziHWZF^6XIrrFutq{#4kyg?>eM9F9^IT;!>Rl9G~H?g!Ykl`f#PGvP6?S=OAI+NS$B zI*|mp>wzRXspX`RkdaLhjLj#>BE<4;ZfGF*MR-3RfHRI^Sl{gDy1M2-Ev#I z?F9FiU4m*bl{^5GRki$T)wZ+!df-RsS56}?UfJ<-;tLMlqgFMylEioIOY-U(9N?ed z&8s}G(L$bD%Xy{tk7`0f0#`<)q;PI&Dcoq8zuQyCRIq}Onls_z#Sm~YttERFO`P)_ z5jP)p+nbW(%aUL34k8io;m+tKWqLoT(^ew-5r#~IlYBGz|JZt~sJObQT{FQYxVr>* zcXx;2?(Ri!E8HQt6Wrb1Ew}}@;K4mOoc;ahbdNq`G#7P4F?QA3Ysz}wcWy>A22Owk zm6daJ7^isgD*Z?rtqPCa9(|>kUZR})-Uo>yB68%)N0t*GA8@c3xRpX$^5qAo4pFGZ zv)$t1eJ9f^NWDN}qx{E}gL}3cGH^LCY)E+cHu&R>-EvYy<0PgtMCLJk)H~#vp3DzO zx57S%f2SQVFNVlG(15l9kOT1W0Dcv4m%(oJ)8~Shp*9X?fSW}QpOf8kYL$F*Nr@zO z+1~BS>eUD;v>aZuTDKXrC*|biBvT3;GjVXtyxbsci|;aGD3-0eR(sRj!H2cMl8tL~ z9AvM^2M~~u1~%oGdN3a7?^`!kQk3H>-haEPYlz1fFZCBf{JhbK5tHPK=WUzy_b!1_ z=yJ=$Io2NxyRfhz9fMo%eSf02z1jZVN=ys_Dp-4?x>PUV1m#$;4dm2H#KfnOcixoi zuENnmAo57Bz})+Kv(f$?{NG0Qe?FFs#%_PU;|eM$`+w2I{~;6Bk2Q1F`n~>d0Okz0 z@GBj1zs-1-5m=Tt-|LY-inimM;n>+%l1ZD_|NdDe$?bG0hX({P4|FIybXks+)YQ~$ zY;5G@5c9yw0l*Uk0@ZkE)#&qDO=ol3Eg6G#wxMa~GT~81?fHJiV7{Nv-~jO`8RjY# zj%CjsaHXE!2P=3zgdq$xeE$Pl05JMLWE2@0879Z2J0&em3uuUZAFr@OWedNxOM1Ea z3oVdDVZ%i#zA%f1G&?RorR8=A3ute`KdIAD2pKjYzb!yOE;@o{S#t%@!Bhz{`$tDs zjjQGj*wfQe%4r6W=(8Me$nthK`3o5vVksRIxqf?)O?)y;btq;3>Bgt+W zB5BNZXCM@h-BP5ZqT&Snbd>vXx1g-1rZ!iyMVoj3mE_E^UTt(nBa%R}Vx+CT^2#J)2NWeaIXTj}iScpokGF^RbKB-;AfWZ10hVM4 zP?ic+y(XK1Kh~8wlZ?L?@y~&i*$lyQV<9!#r{EIR2mqFWccNLkUoJWU)DcQ^2CQ%} z43e!0j_LJjZLg5kG+|T$kb%GGwzwROCnqOM6MI2Tv=X5qL{f*1uAUt+r!Lu?R@r&% z&)_9(mMjQw|wBaNY8`?8Xj-#~t7GZU?$@DH82of5B8YenQ3sXP}Yn z*#gy+fj6A1*Iw_Hk1S)A5@q?F1wPTIQ?=uULrU|#aBbXG-+23Rxo7PXY2Hj)GHcNF;uH%^Rxc81ss6B06zrdl%LvC=Aj_M)0$CxWfbsP<@ z_JWDta}{llC#6D(b$D9_mXugn3;ySXGUI6$E+)x^Pp5JaO~117LLgV7Py2IPww*?E zs)*6>AH#gwxp!@l>;JN z+y?PaitYwLo4qjm{pGF{_22Gxvh4s=XJ0P|N8Sd!X~6bteaUf6yBpmC0I#qS5t70& z3cgLZ*C_tU^5=0b_d>f?o6y~uhojCc;X?ge*=7+<7!4hIY&b{N+|bhlw%L1^|9#$E z?qsSGt(O^dSSQ@K$=ar69jynDlpl*FX(gL8iVZFmA}^QSIJ6zd_@_Xrx_d`^-(n*p z3*aou@}fI}(8pCObnz&Xcu^+C$2coRMTe>)i&Z{wgyq7y66t{Uo+3(mU34!&5_Qav zqhMC@;piEY^%ITM{VD~HRZL1boBf6)pqHf*Gt0W!3H3yK7$<+2Nt8ohGq&NkwdMb| zNr)NS{U7<+cZ9q8Hc5~+xoBm?Q2pXP%3ImJc~T9!;03sMyZr0#8?QZYm`9c${!!yd zMvgPwEep6*n*5Sx{~?r+4IRY&+^KoU&6#Q3vxbI^_>6wUhKRu9Z(Nk2Pzbef=m_} z9QpbCRV0e^_ra?RKFx-El{o_f68rzS8QHm1Z_yv&B5LP1^|(U~^NSwi&dN;tMEA@p zo?d|6gfwA9ZoUD9`>^BXCw+}h_dQb<4;XJM4mn2{0npnn7zZG`f0Aq`5m5itZGHlv zpM~y1&c)E!i+j3Ol`%n10fC(anc|geFW&6ftVF?)?aM8$UReA5hqAMiJ>*h_M83I5=8UBT@ z0}sj=s%;6X<8FuGch5tyF`_&DeCyI_&=w%(Z8Q< z!F1G_?n}5;Ws3jZQSda4`L1x$gXeyrbC3g49RNz7bB?B}9c5(sq5t<=K3lC-;!sr1V6y-yPtCdAa?NI)Nw5sXyfueY z@0+`}Hg0O0&*#sZud?MpYv-w9SHZcaO(9U^Ct-H$_M z)N84V?aZUGz1V2CTdMjj3&5M!=lfGwwxMo|##KY#>tUdLX)|D}lqGzX=4yv6Ts3KF z6J0O~6|=49xoGwk(_W?)nl=4etC;~vQKB{mHYu!38(MTWI*u!7p0s3SZ5mnXbQ!B> zFtA{v+trJwvmzCy|EE(Bqe}slMRO~w&MkZv;{dUKSC7A&ogQ9Zyj!pvn338%080Gb z#DhmK1te;rt@MR)&|$WH@QrRE5;e03A7^r9Ss5HW{LXxTe}A4@tG^|{;>E+h*jQ5I z$Br|OpBhddUAQw=H_N+Z_LQ~>q-USl*?=1Ac!gaoVFv+F|e{xaAD7br|bnK zBTu=?hvso!%i7-~%DoZYz{;|U@juvF{D+OVi;YBLymj(5EJz!GJOfr4^Z>M?57Enz;koJmrDK-ZX5&w9$MCV1+<7^qQGrEtU|sT5ycnj2OPWKf0Pq!{ z83K-$?wx}4^z@93Q}>#NhFd`8My}Yu{BhgtgIT}nYv|jhRjYki7ew*q+qK`w*p9{b zo&L2sZ^?KN#GC-e?($mC9fuDc0D6|;XdLl6F2{|wySqC8Hf1W503>e(&hq3>fAD`j zGSKUf#NaLL6JM2Q^B-c6HzebJd?N8O$@p1h9lQ#9)u*)o0e6Frpl7Y{sYI44Nd-C4 zTCy>?20C}V*+)q4mUUn(*oyLh1dD_Zizqh*MHldM;=j_bT6c%uw0CL~9JY8eC=}0B zFvH<5TTDq(-NU2ubm%Si>))BRJ`%rIS1h6bt;F4+=b-Fh|MK|ntK^HaA*YUPioQUV z@=AK(H(#N@#G0cN*rYN9ZQ8mo+Y8I;2=KU8-D4wM6;1sRIP9{#9z^tkGaE`-XB5@d z&Ev&j@?!mg#fWXC6n`F-U&Zvc4Eh~~&G70rFZtx3UszxX1=9}OxxCOW{EOeFla86-;ur1+RPns6ApTx|$B;wD?`~W^bLhU5D#~nTWhzAMz3(k$$sUKp&^oZk-i?3cfU|UxuBdQ)GT%1PC0!%+=hxO&s5^zeHpWp~xC%B#;@XTfi}s?K%ioIr zKy}&wy(rk5mTIGTf8+XXon4B(%0s&~fS*_)s*>txgz=MNqMQU9JWa9;gBW$_fNLww z0ebB^2YS9vf+^IgchDmJA*0nBeW04NnF`HgxIEkZh(APeY%VyUTsG!T{_lm)g`6VS zFSTa8ICaN-O+-@?*F1fg5R)lW{d83DjxZ)?h?t2nD1nP?78$ zha@XGH2ScCW{qy+Gp7u$Zry2!buu7;`c)YX&AmpMJ*7}ZLq=V=igGdp_8>Sbcke-} z-~77-w~uVfK*bixQL*Y0#-lclAml#evv?t+QZ`Ygn(s%J$ewh}xM&0#C~qjWx7iI3 znoj|wb&lKAGq;XCtpYq%NmFiKky~NQs3To-CZL;*d%Vm|#sXB^-w7o!$RWd0T!c0O zYBXr;q@Ulz!II=b>k&u1K$HH=O!gUp3JuIn62Q_Y+5fIZ@|p9-!nXLgeN!Ulf=SDc zhR<7nF~1Ib+n<*^xR7E6JHAvSP=$z{$LtmN&+e*VKxJ)bULyIT-ug-7$P;f#BI|WZ3%ijUNHU>_%XSA?V*x#1>CJ4tF!zufux9FFIIhTZ2lvgQNzq@dra#(!d za4og*Bna3W(KKV#&=TXC@?y%5e=@fV!<8}-6UfjMDtFZgTwIRWtTN)3&dV_$Fh`$* zgcq%|wqw*!0y!4(IpnxqMpo7VcL*$4$XN&VLfg?LR5pjptRjV4nuO`r>6x8Ety#UI z@@?oZPCqZRd*h$2@*Ob~u}mb!9dESef8-%6XbiZ+<9HZ1EVca-t`X+Yk91OZ(Vj(4 zo}kd3-;xd&7DU{XfVA{Q{@-OWKy!*{dW&RwFZyj0_=i-Kw9b9lJuv@)gTUR*sNBnR z^W+IN(*wf~*}iDmsi6LzQ$72{mrtiX&|(EWLIL-VPzV^iAUZ00u|b(AE*;s**fTi4 zAUj&RA%fKU-~s^D@}^bXM%glON#$4EFB!Si^cTcOVvzg#NIZ^6Ke`Szb}3;qYiWh+ zP2inr6OaV5>{6OG9K_Ld2_+D=^W)bxKr+f%%Pl{xnRJ zu-I2BK+oS!&smqOk=0&V(=-k>@t&kbX=Nz)0o0?62dc7E) z=c~DlR%d{M#KHp?#35)%LwU>c+l46nXI{z)Oq3rUKjjqqlb3$|X$92JKOpBtU%b&M zpwic1t0rngM57K04XjQ!;VbEr*Vg96fU--@Q$rIq+z~bWEaW1fO{4Iu+Z(%q5naOt z9uAf!c~y?D3>lA0i>9je8&ClP@l)0D5hv~>51w}szJj?`nE&oJ+p;rA-==%y5C6x=aFu0Wf_`uc;;bJWvb}Gt%O4FU`(lS??G~7f+?eg%;<5X z;gqmM1hbrS{|>ZYBTu`Tx5M{F2@#=W_!eco=u5^`L2t=&yoRE{M-vQ=!3$D_Vj3}} zu6B>Q0RM6Si>e#eSf3@*H>s^<)l|Q@FQq-+WLfhT7*L%7ku-e2wx>d$QCdz8V&R!uPT{{G|gTCQ5nC2ZB@ zgaraQI!+y|ep&rz0SEIM-FDIH)1kIksG4bxSm5Sz#oA@I@+@fI?h= zjj#UN%Ez}M-u~%jFe18DfV0FuRWWJtTRywiUxov|?-sGe4NH@P$9r}Bf7vvL9gzv( zjhHiXbq{r4JY`MJs}qfJ{?o?9#RQzVDj*Uds1Hc_J3H&;m?Do4ArT+ukIgM@%PX3} z>WjL~ZrF@f_e=QQ)h6uXi7vLMe+=x*7BS$uFwvcuokLaQ4YbAWe=#XQ`2YP$6#pp{ z9<)uPOrye*bjm~6lw*!LF6!2Aoo`&OO_b14B-i)PyOMJa;7EWuL&<6J*x?F&-f~^> zYo3@T5;iP@7IX>Kzsbo3GMEEZ+VoX0pGc`XLVc7C990-JIzomvEr!p2w)cM`+E=3wW|>GriJ-_O2AjC7t3;JbKBsM+v810F=fx=GbmU}BBb z@9|_>z~A=Wp>_RSK9zyj=O4JLw)Qfd#2=TKI8Fy^CvNozQuB%vDEUC!cwjUKh+QGS0A3dCAzv9YdP6tqE=P-X z57eEl((6^9`lf%6?Q(FlZ8M|5p`xRBxb}=+XZ$rPHYBeq!w4Lx|5R2Knc%Mp>(-(I z%LauH3&w9FYfNcck&UOGWs9!%Uz$1mtOg&Q*B{^S(1uZGh7>FV3PxT=`6JslLTWj} zjJY^-LyCqrb}gDip@1pLXw>6-zSaz!J^_``6A;4n^$8!A0Ew)tyBqxebW~MU^#G93 z!XH8dh%m=s!vBaISz1k5y$B$W?!Fe_rw#LD>w%(j);>8t@&!8_)hAZ)on9VQrqd`; zgshx|L#8QAPVRkiKDZR_zkBi9e}`Lk(<7Zz$r3Te z_d9S6{5M%_>xlS3A8%czh}0wYJCpE5IR!1|934!*vL#TLboYLLQ#x1X%2!elHMTOB z_?$7if+hzzKYHjg7L`D^0WJ>AZKbeWum|2TeQvYuYBeZ+(#@A>_OK@7V`GsqF)S0-Jw7f2-L^RWhuy^&EC~J91f#o%pvOO2-mBDdj#dE|c9;W7MHa?{;gLI?C(=npI|7kXN*gCnW*A=2J@q8l`1Vmr0{j>32A?*g!8Dg+MUnt8y(V3c z4Weg88_fqydjTerc?8}?1S-b{M1tjy^iNFZmxabXrW1CLpD)jNQL3y4C>=duZq z1i!I6k;#l+_kVmj*ipXvM=wxBq$?6&K*!ANp;MHXmlx(_&^eNBn@E8K6I@%%Y{(9n z&%^$|ZpVMXPHX}(o zJ{n7q_VZ_t%Yj_d7$ycrQha=!!+Hyf&?Bj^F!<@_KuAbPdl&dqxE-a&26DKde8Qmr zOv}KF`0`y!3x4NyV$VoTEm18GQCJ7h0pX;rr}r{1&uq}`&B?%U287VA^5RdxYH+`(#jM{Z zf;t4qlSD*BQ-i+P*w|tP0xtW2#Iw1=QU1#=H65L?nWS5A zmQzolFJI0yty;+|@EPn6##WJ2wmm-U3!9C^Wbl4J#84Kv-U%lW8+$)B`UpDxnBv|R z@O@;#1liisfum9=WM^mV%|?3wGg8;ozQ?v7H-OB_)k+5@G%7WRM@I+0g)4|@!Xn`h zCHabd2HX>y@60KRW93Bys$IWU+d5G`<_0hks5yj*sQChm$fuxuzEo}bry-~-YCKNP(-^$Htk zcj)ZQ{-?go!NI}H!zK9jdKB8;?3=&kjV7s+b5b}|)x+89V3Iyw?8vr1_$8KJp)EI< z<(fU0DUOgA9S!X>x4Zu#MpxIOZRiB-Qea@Sr9s$L`m&eM}R{Tya(h@O!^RlXdGs)jP#xaPEO9(Ns7_4)ke|n z(gt-ct?yI%Ce;hao{8dMxM&XiDWmtBwC_jL_h+lOPT&^;;oD9+&SawBhy}fyWEVzr<>BlFvdf)+0m^*_K(_p!dD_6OM+XPp|JLlB5&Zzl z2{^?V|FEJGo^N(O9Hbc?TKzjYIcd=OZF@fuinx<`bTo!XK)?^^VzVm6su}U|pS1kw zdsl`bhXW^tAO8fGD&;_g24Ub(kQ9`L<>+?AV^AygmBWW`ST>5{Hkb}00A?1qkC5ix z-j4{huP!bwq~On=1@=*wT2DDQpF-*a=tRBuea=k97YG)YpvN1$9}cR zMr{yqt-)5i!mid>j$PV#4Ko5(+s`g2j+^3D3px6egWCUD_xf73Kbb~ z#g-q;a|OUzSw+RS+>fW+SOV^_u&^5a_C#T5IM7CcWHceNw1mVE5U=739KyHoI075Y zY0O5`-Pznu#M?LUBkY2Le!D}F#tDDyv-#Xk>P!Y7y`UMj>+)J!uy3A52%H`tADbFj z>g5rFNV_2Q{J#PN5+S7j`{lpn1pc2CMGQMV6un^#bSLhen>)^!SXlo>ZtDL2zQ>kV zDPp55;Q2{ROavBWckVxd;2W3y%BR!$`T4OVYNyqPVs>z*U9<1$zpkz>V5hdKraQJ` z0EdZd4gjV;zCCQKVIG{HzdiJR2-49Z+}Q!nJGzt;U`OTWgY&^}KwfzOf8h8|0SY@T zd=M!%qi&H3O;mLB#KgpZBQMK_K8oZCxL?9rxBXv$<>Sga&krZ|K1k6D5!-39S$GD5 z{AORaShd}DvEnEf+*48lBlM{=XnX$j{sS1jQKVXUyxubr1`;qBa2FyI@jI&I zfp%5^#v#b4r4%h2Iy(4RSwVn$9{-=4o)aJGmAvS`=_}@*$K7EZqoKWsfe=qjQYlmg zkO3iJjp2s)as_xooCU*^l9H-5E7Q_&iZIa8`zS#J9Nu@e@=zlqZy|rqF1!E0Ou-`Oo}nRhrZZ>&n~xs(C=}&bgrqhgAOFB zv9YnwxzM7!V8G`$pqR3TI;{b+fqQV=gnan!)bnHs_${th+BsMBKiMGHF!OL<;Yxl( z?Qgz`7Jj?K;K2zWtan)FnilV`=|k;Tf;ziG2kuyG4=|JR`uZx80wgV-3CKSAmFZ%@ zP}pY+GTP|zdpT$8vYf(KYKf8BE0#~YA}ufz69C5oMxp?N|E!1o6#)c6pBO1Ai#d%# zv@e0r3%d+iF@#k5vSwHNwny@TE9@_TOH;1?+}iubNKRg`qeZ2Z4Hviq6e>~~sEI+@ zl|0elo~Oesz^5mw^!~iu%LJ5-!^sR26BA&Ooo+mGeJ0DCbjl`Vq<{aL&HKN`@_^_9X7fIOpn&}L zi~oNn4*$=SZaMz1(ZXi!bw}Vyw|8S1p}Qpx>j-A`NZ3sfl9u<4@X z7@U^C+dGoTHn7cmZ8D~@*3(y$q2fO&e!wfSJ@(6r{^6Fd(73tf@B&Mt$0Y1$Q!McM zf}`0zlg66f6HSMxuYOt_GkZ60A%hiL(>Kt67F%fXn{1x!czLdCRFI695V$ARE(rJW zD8;lZm^x(}OTaabT)M8GP?t`a^D(5btDf3+s&1+v$6jp2|J3{5s~8Il$BvxajyZO; zjRNx=dP}Q|eG4I*x}h3Wm*;-otNxVta*gz5&_13-^s!0!HMppbl{(cs;xBZo>LdI}r7&lVXzj-fD48L4Df55A>MvEJr~!LhEv7ntwvn29Li5&8oS z^^-Ae%ykS6sa6q(3=Lf8tta57Xce^xOpv)HMx{rzO(5=(lt^|vQM+S!>rijNIjmtX z+k4>BLyOMTygb=2hyl#Oyj48W@eukUk;}u~Ni&$a{RCDoWVl3WKC@J)I}*{F42pgg zvPZilOzZQS#G<}GI=ltHBJ$S`c=0iaaR;r8an%UQVr}pTF^i64yA{9)60|-JnGn@m zMA(gYFT)`6j8o#k#XY7lV;Icxk2?3l1V80L>3iZ8KacuNT()89!1Rhm-TQ;O^Tp;q zdH1IA&IMU=ypYUBne&nCVS!D9%&$R+9`mm#yyPJr-QI5kXylvz$O_x{C!op>TMx#^ zS$-7p?@Fl>{`<`{ss>=>gW|}7x(sBy!$BL4L!A#y=%WaZsa zNdnS3KM&yb8z{mbRpEW$<;A17wrgc>DwTxJ;Z;2s#pjEH`wzg{=(`uE7;r#@FSvg2 z%>7`Pa2l7bY@o-f_=nN#<#c))hU3aUE}qo zL(5GK?>)qD*QB)&qu=CFji2G(y&eh@`dS_fvp{}>Dg1QHBokjFJ@Bs3WsV8cs-f6_srI`` z1)B7jt2v97BFJ-2x0Kg&6S&|n*0VdT8bL{S?kgP4nTlZ4S@*o68I)84|>~p-})zy}lK4Q~1 z)+?-Kow{vOiq`nlbH(i(a!#u9BGe_Ju`J+F@gOJ^AU+Qm|3W514P${x_R{=@M_9SU zm*2ef+=SKK(p=s1+?0D%lJ?=ugxM_rvZS|-Ku^JYbmsTZ>EoY}PcA(v3cGW*a1Xew~% z2Ti|Xeh#!4`0LT4G1^?2B3Q$?)c_ou0uKI$Q5MELGYiay|%`H#=uofFDXVT{(V#`2nC{0Fa%#KeGZekA1rvgiSDBp9x5L_)c<2Xk!V{hN8>Ve2 zn>wdtiwfm!YWcu^4?>p=@g6)>wszG~Ir*Qnk>Y3K> ztC!u+xbkkSe7X!>;=;rG$6pry2pZaT9t=y-lA)3`&n>9ssv$4}3qm^BWGGj0SBR;V z&-*uJ0*%W5vKO~ZO#18n?7%60jXzJc$~10_KWJxsuX=A0h!c@!B@fB>p3t9{x8cOD z)=2x|OkeZH{@q4~4w?3|1+wpmwIM8h(Ph3OCKf$`YYZS2i%=1hRvDrnsvKe&_=&3& zLu&Yy5RUblPZYxm^(%Z>JgO7A6B?W8muuu}Cf1+nB3;t2!Rc}eUxmP=mZ&7?BxocU z(GkN#=%%#wG1^KzXwyRorj$!9QO=Z_7>+}wL%OC!J4#j5T&M)_C<95es0iel+I@|# zs33V2S{|xL|JiiWp5R1SEF@b3*YUWP==v9nI?Fo6bh4(%E{TV+SPB)0ikRoUlnO0K z!?#}Xu5bau3X(PUsyVQK!rRo2|JR|fwnpE58Rtb$RG9s>VhopiL+Ueml zl=0Upi<`(oiNlr@4#Go1%J*b4#Btd(ko`cB2@zW=F|8p)9}ynR)S)gpf=z@W7M1pH z2~`Fmx6wpkd-pM!ck&BKO0t9rc3Msa5j}x-w9SM+v{gnz*H(#7Q{3j{qAbWB#&3wR zu$foy>oRp)v0QTXeovLU6>X{aH&06JpIY#rdXMX_7$FDVRxhnVN;00FGS(WN4i0V_ z4vN~bsVJ=IsCea%B!0mb9Dv z2ni&=!{?Uvg!vHv9)ge{SkcPZj6mGDew?KB&y{;~Njp6NJY>E(^4P>ncchq$NqIY= zyxk%`+J1kx+qq+~BP`*U@`|((l;xE+F|D;(bzwIY>y{5I@!ao2#mo~l3wM6o~>knD*2`SVrb7E)n=0zws_KlY+yZy%G{%~Ap z3Cm0Vk6C&KSU}ho^muor7`;6T(UQO8n$E@L;OBet8iAFoM5kc7Hs15*H?x{)hi>RQ zs|E2pCg^X+g=#(e0%W6jU_foFf?SuA8^nj2d3OFDX#bTDH4o+B7r97?sK zy~{to>v`&$&zuxwIqX`BI-t;9){76f6mxL9F>zD@lhotzy|82E4_)XluQcBJJ=3e0e|IbWv8J|?sd2k%j47L>?Qa<`3bYJY zhQHw3^D$9W2|8v&TsnwmH!lS)BT0yj7mmHZ9fKoZOBxlWMP1%kywji^ndFOT)4YW#W=NbQ~VX78Z%$`N@5~ofkcVaY5nb`RdF&iz=j^#$MXfePK4Vzl?eJ#% z6M|LDezak8l3RIyhObOQ7hu=C7d;K3z)jhF3k?32a241-_SZ(Cq0eSatuoFEey!)xgEn5n~eE@47pIi~y`x?CU*aBS0m(OJeB zC14s@#zdd)>5nAj77egW0q6SQ&uuQ0ti>FDd;|bqqAopFfcZK$u=C=t!KUv%h z7pU1=^+lcJ@_8#6dW#CmzkA@QKtgq0R|oSPOAzN&qDA4H4f7lsXHR@*nf7seN%%9n zhiFZs8`)!aA``cQSC)$u-M4UMsObXcGs}*#q7+9DaKzW39_KX?N;13n1m6(lYXuFa z^EhX(7?a}W{cW)2idAg5;c4KDGbM>)otsW1oAAxWs|m+GZ>yb`1RkV~{vq|1a3}2J zvyy8vy3xzE!k|Bo;-;a?iG$;>m?twr6R+mi7fwuUQLkC66d!^9oabM|UjHV+Zl#yJ z11W29wd>an4Y}57&v|~%=^e9+{!entC6aM*h5q?RQqiCne3Ha_kwzjc;QfzZ`o&cuUt0ox_A0HI<<9u(d+*}n zLn$YBR|I3%pMWhXOlqEhvx~@DB4d=r4s>6R zX9CFBOhTH}fZ{8Wr=3hknC3`6o`xZQc}QJ&is51@bNh?vLul*A+*7@YpEX*zgN=!D z5WOjPN}`1}6jIXhkRB4&V5i#%AxDB1BbDo+>3{wx)l+&0oebVWGHpm31nI2Azn~-I z1$D3fsO)cZ23$Hh7Z%dScY18rtTc zIY@Q{3u&&;F4ghDQoM$`d6T>I+7vHR6kNf0h|+GE(@yVGF0+3s1w-8Ny{TCmFER&3pg}{`)BzRaM?8qSFt-6DA0v$l%CFJG_fep6Ud2`aj`Ll zqH`DIpIy49l&^Z?*7PAwy{98M=!n_aFP9iZn+P}uW0CN6*8bD)4#pV3hMWE}GcqK& zltwjkA$|WMe&rbc1}6U*7&M2}LDe`ti)zfD0}ZlQ<^0 z)6H?WilX3>EdLJUq=Ji?f!UDg##E;=)bI>;4& zj5iY_6457xCswcG*o8*0I82ZN@tv~!f?`rpd9`5u_t6SvF4&5TAa1w4TsmL!!%NC2 zam!SJd(bVin~~nTS8;$p5$SPkTB;G-_ogr5Y1Q?Da!n<_>44-tkJV7Ut#fZL}povLgw3 z<1!l=nV5}y{a`%A`+Y*x;MaJ5@>%01U2ja}l5<%BEVXhNUM5BVzqQCOtPYa>XVCaH zS(8K~Okbxxqg@l~J`0FgXlFl>FnAEuZQP+x=oGDAKB!BsfU8XdSo=XSnO(+{{V8Tl z?zYe+naAEww*&1=@nAE>T+x=i2mj?Pdq~{2^g;Rk7E3m<>85Tbp}5-*Awl(BHo>4bXv) zg5Bwz%$Q!)2A&h`Wt?VEK=IHpesL1HwcO%d!^Gq}xg{IOd!k#jtb75UD}gx5Ebo%a zsH+5H@8Aft?q^y_y4;oeJ$qsfoI%AyDrb{yVf;}=F+-VHA<^$DxHm`U5&i0`JBo!* zD7-$?KW?+fy9X49X>}t;^3JUnm4D2Q@^mVmvM>89gI7o=oOnJ3J2=e(?)ECGJmTCn zj_)T0%Di%!2)eVl^XM7Au^_9!5|-&Uc5bwGXK|{Jx?<$8=3pJZJ|Mb3sbDqz1aL!J6xZo zCD?j{QDprAtk)oUo<;`>2X)-vb+IQow>aS2Y?#SPzc~SHWe09`Tmo7S4Ry#T-C#O9 zCN*Ysc4wjQwa5FWZ|*9l|CFy5!cD2ZZM+niJ99Izs+d}~_cu{3plHgRNa`$y?!t#{ zKDF}*ojJVgRyvS7QdBrx&b0;Mg>2@HFrS5qb`j{h9^iTD%11!8-#`DJVTNOHNh1Vf zr{vID+jj+G*EgmcjNV39jqsTnJrzbnHoGmueC-Ul(goyfKPkHaGchJ5AR;t4{c3nYcLj8mWm(%;*zx{P+D!%d5v z6$LFA?i69p9w!BxLnvRnL{AqCFeNGf;jA;k(*|m1p56A`F?;Cl*bxZ3?kXId4NrFu z>-F(uQSpU;%2_5zGtoNxfi=!$1ExpT<^Gw}5?Uw4ww(ELa-!d2XQpm>o5w+nVK6pI zyAjXQIBw?juH!-*fpUZpBh;sR`B;Snr=3KlC$Ji}Xx7%DhQ5;Fx#}v**B6RdNnikB z8j+U2@|3?}jXw*m z$i6Aq?lDE?;@A$M$1K3!@LdP7dya&K*Xm8QA%_ig&F{`t~En6|2K&)UgPr^%VhwoZi^*x{p0E zYf=xeQn*>hB;V&m*FNc&uP}DRrc;M2e~=1B@E6QS5NZ*!{Z$Sbb>rjM7KQa5qCDeR z$}sHIvq27FQ7M+R7Frpog1$s9tbX=GJYzTv zVxtOkml*D-gs?m1W)ug;$26@0d>}e+nLs-HuX|(o5&YSH-8blp{bi=>^02Y(6f2jyTeb^9+qRA0 zwf|8lV)_wNsq@=#^Y5?cX~Nw3RaD_&PD>AYdBlTm*O&IJcFI~U=L~;F&hBav`}_jT z>FpJ+zEvY3+(T)BwO8t|Pm|kg6kL2eV2&6pZ1lATVy0r!(=IpsvA6Gbx7NJ$@B93;p$9(vLxq+vkH-NnxI8_l{`uFks&%dHx|XVa z%~;ov2YC5~=`Ed^u;)^Ajkun2lq*4q>;$E-K=|A3iSQG%r6z&xQ&KN>#XZhb`h$0r zF6pZO&MeL*te_BRU-x>0IVS9#E+6%)Z>01}cy1Qb5yh_@iP|duRq2?r-(@RL(_cCs zVzU4J{nO|p0}fyRc~iuo%;O~+^afza`S zMi6$H_Ihxt1PY1FiW%* zpQV5Eeb@GrskExSSaJ68vhEI(Ds(=j=zUv>Uo5<}Qp2B-SpQ$HE$TQNJ7pxwfJ*CC zX>>)-9kzJ`(eO$<{^5_Z4x_>V9y>VtE<5y&a-)1Ap-1$-7%cWETwkB;7w(AFJt5QLpm#cqU?WuWmDi^{=CL{%XrNFx&h2h zJ;#4M-%YBIis&nij!YR%Lm6C^8^XNj4H>0Xn>!|$j+QEcv2j+~-hZ*wskt_-Scr)4 zfhEuQi`w=tZPrP&m>@xmkGXr}KLt@Ye@)w9f;l$C!!K6zVKha*?~QZ^S9Z5vDv5Dq z2Eho5Ugoz_Z5>^5v@Qr65YEKz{)&yZQg(gE!Wk6roCg0We+;mz5T|`5i*k6Whi%?Q z+n(_`Y&P^He)qpJ3VJOyH?SAC<^L_F;SM53_nSJaJn@A(q9GLbxLUnL`8)=?Zp3Ek z1t;!)Qzk=&E!4>tL<%kOm6vs}(_1yk^A|c7NF_MCyLLV1yQ00f8T-_AM~&ZEN8n~F z4W&q>b`#4CsdmHgN_4DhmxbO{B|OWn#~IV;LJy>#Rceh zqT51oUAfpCnnsQ%!-c7@kBbgw&CsUczWh~#Bta&M{JM;ftKfCjAJHG1kV}DwYv5m@ zv7*a_9{rAL?n=w7QflZ4sJXCI5j9%$xi{FHfUX z9UhE%LT;4(!{@qqwZ9k*i_B+N*%T~pux4Up;%4!H2P1Y5>X=IQbm2x$C-?t598hls zJn|pf9=#A#apA+TJT9tg z6|4SkEq_O)`W+Q2HF2e(d*3hq4s4z`(OGO!Yzj6{Xz38$d!gZytCU_E@flzvD;u^? z-dH;6QPTsec2pOLH6^+_)Lr4nJn5DoyFIK*o>l3x)VYJ*!lf^g*x!pyNNPLj$LlU}nr>CZ3)MfeqbSVoPF3OR|?- z-NdN+Ns1W;K_MMr@95W4XjIC|!;Hn%truj!PF4lY?`H0f6W%VPq*H@86vV?+vXirn zmAFb(ccG<0cSok%lm|QA#EUydC%@p#3drWN)hUiE!#be^kFSB%&4V!%lxhpC3$j44Tj?1?kbF! zk5ES(PmEre5Sd4U)%^$F5Y<~1vE2S)v6wP~Z+N&-`Z#r9p=n}-X-g&wQI5BkGv=pU z0X&;~j_@O-N+%>tP;79kpM>ZA8{UQOBdo=*v6gtlMwyGE$JqiCU4)w$>8OU<%bt~c zMPK4z%gT3md*ipfkE2+x&u#ZQC8AW81dv zj`PRK>%kk`yY9HA=d7wa*xPAdGdo%1=;gP;SLe6m8QpXp?tci@oZ0e}rYm!W0y^uV zV&No*m)}G%!wt=C%4{UKkq(|O-nOW-4G4JtPCvhs^mpkcRQQo*)Cf= z$K&?fe9r6pb$;?}-}^B6O5r{GF8F=={gFSpj{=}kq4E>P!@~XevH9mIa+{A#)KpE) z6b*eMfr^V-4XtfhV@C?+Mn3O(p5~Vpe?Q&b!%W5)qsgcPLEE3KZ)y>FY#^cYRO#@# zVeu|kJHinO5d!%G79xJ{VZz(-&f&Hvz~(LqD6CN_n_Oy(CFePArfQ!gPpefjQ4+K%_Uy2MNuNv9W#7uK zoyMp(S|%&TcBqPRw}33sMQ=c+N1RHxys*S4RB|`*2ob7TD8EXdR=X-~T8f)WZy3Zi z?s8yG>tLLyPN7y#!;br5@Ow@gZMorGR|g1IuS%g^I8Jn+F1?gG%8cQ1Q6@? zibYd#YbXtCl&wqGOwL9M_^|)TH0aLMN(QBu%JKxTis0mrdp~?;acU;kCfbJ&$kyD7j4e?wpxx*gk!wt%nl8guvc}%%$EEsy$=p2fYL?1QKLLL= z-tyjddPJ)dODC{)qx%6Yj4txeaQzYzRYj)n4=j<}kNhJ64rh#pJeVU$laQVo(m-TXHW-vUwgVIsOqTErIetZY@;vf9(lnIGNQ@yU(u6f>ekll) z{-KALnCX|4njuaTK0#aPhG-Zv4*+dn9HJq7O^SXGf-6Wnur+6I`h+02-e#a3cK6@C z@o8@Y4ln`o^_os0)#Zex8&vjrZtnNL$5)Bgp871+W|U&{-|~RqUdt@!x14htBt_r) z$9_FfJ}^PdYxJEg<0mPiLKyZSt|-O`gmy~*09Bc|hB2o;75QS^pzgtCKxI%q@P4-cdwvJ$nfBX16Kgf6C_HcxgPfKts$xogJyl;pdCXH`^A4A zs0*(5W@W-;3{*@yj5@f1s3UH=Sp{%LHFNf5zZ9087Whrd_>VNRr?S-Ga}hd32RJUP zez3Fb$~1i?(r4B`5m!vQ06945mWws6zVTliAl<>!8=Ent#?-o&hxy1b0@9Z3e?&Q! zSmx|1TUydLtp6(oO9r-tXnA;}tYNq>OMtAYHTOFqJ>JgL3mDMfTZL@!Hn#U=7dP}+r!3eusCCx2H zXhtPCw}Sj3`ImLG>_Zy*gGZRbUMefZ@x^< zg@Ad@-e(aA7^;TCYBnUV{lQzu;ak_4(i@dH)>vtjZN03oS~q-!E3&HReD3J1+Ny=J zWEeK2;?ZR+_^;0UjE{XCiQ)FY$T|FMG{x+?>%0Zybez!el94K7&?z zxz~Nik&)wHCdpw%YNjh|;= z{dkqIbCI#8GN5V2@XG}12Ra6N#vqSq=w-qZlpyV2#<+=59$F4g^L3HcLNWxs<4<^? z_+LmWYv?*L7cvhj_c?TQXRc73xv(l&Z^4E$FznSU54aPgNmdMLk-0eq*RgYn@KL>V zbLLX?LS5ig)brZMk+3I9F3wjKIj+G8;*s6<(yVr$0H51DJFv}jHzyB7(f3uHbexx* z;Db<&=m9R!y3gf~^Qz+**yA{xwnidEXl*_99Gd@K8ayWT7}OpMHymH7{%6dYxm+|{ zjUIILeCsmZ8Itln?HS7?(bjFHehn+EHfOp6Jtt~BmhF(3CeGHd8#@PLdcqmg`fkqV z1A^>$226BLz2J3o?eV?nKYi^a5@2bzHpXkOQIsuPkXg`NAX`Kl{472y8RgcuSsY|N z@xX>159R^t_65weY*js}yFNn(iWi_;6e;&lO2Y5wN>^8(*qb(KayuoEMtR{iPV49sQ zmwj4rn3;;Fo_~YQlcJ_&DX5gXkP#@saTQgrtrLDYZK^PiA>mbmvQD(@TF{2rZJ|fW&o7z&ZrhB$a>wO|lu)z=r={c2^Jx zK2SXBq+)aXBVsRX*ys0@X)(0)$}UVnUpmej4JR#O2%m-xOaB5lW6*J z@bqM9q^d1_h;Sghqrnr-j5>|Vcz-QrINzSOvN4z|1$5Z( zGmC#Z!;erhf*?{);hdzN$lEmQesJ)2xASplh!XS@msqI+tAuPqRsZ^08*T%&y zRv=X%GHJ`YSeKah9>I$VHr$1#v7N}?X58)!MGd%2tHkMVXFO-KbxmS7!$Q7vhZITF z*Rt3CJgrM&BJ2pJL6khQw2Fgp0L1mPfD8<`g-blOjy(j9uZ45lgC^#jO(rHI86>zp zj`#BkvM}1W*A)2}0C~>}i7Kwo0MWHlJzr7zaPswlaNwA9-f9 z<-fDjySNfS+ph8LzI&o%kz<3US2mWYifx9xfP-E7wiu3D3pg}N`Kihs0N8vci+EO2 zB^=`|X}HL1qlH_B=1pw>Me%MTLkXUH#O(>8w5vSdLDlXn`3U_4c`cTj2haEqYZn=( zWh44^K%#E%>9?e?N=DN>Rvh%p2bXPT&&I!`p^nKm? zKs$mi!FEvXjJUC>#Cu6|9#EP8F@@*EKHuV^!#E9PCQjAIL|tgU{Bz3pz@mc5mA7Jc z4qZhtjGqdzA|+?V6cyXrrFWZKU&3|Xhi%BZzGL8BRFZ`mcT+b>D+hr?EyoT`rg~nwPvdLMGtAi8 zfY}HvP9gqC8v)R;62z%A;bY4OMl)+WHNnNb(Saa=7)^39r5O zC>E4+f3D~JhLv*=IPR4GA;RxIgUU$TobeU)s(w(@n7QFMBLH1OYJ8AWGM?<9YKP4+ zI$q4k!xMpv-I#DCrby@1Ye(Bn_i?+!S(8{XI0jY2FePaxC837^(|8p4WY;AYL?S#r zzCKxW3$Rz0)K%eUMyan8^XIP<+cn{pC=7=KV*r2MxJS+V9T5AoR&7G)!4A5sjNRiL<=si!6Kow&50cnDGw z*rJ@)7(hpWW0V9xtIT31>EI#aLRd;txBhB}2WuRL+DZDtE@~JFH5n5F@={CZ~26~563Od9>AA)7xFzMUx7J$oH%-&Z}#x&gcdgxmJI14|o$f^M2r;8Zei26OKDjMu4%g zMI}FV%GJY#$1+grp`^RZkY914muDsU`Gpaq0JS~a4*cys{Tgv4z!+RZqr)NqrdEN|n`cZGXo6WKPehd{=Iqcvmrr@dROg27SDjF7$+7 z0HRHj)J#k}F~mXy1VTc_1)NcdD0af%=1&B7(#Lj@DBjy%urR34zng=>a*kTBQgpXp zPi-1=h>F49t&|Z@6g@HNMdi9)(6mq$qDR|Cez#ZalD_u1yjlahV=} zU)c;Ww(l=9h3_Ex-~DiBmXcvrfOjRP7{%%E?08~``-mpL&?9FTkEWrfLu-1s;Ks9{ zpD669|NGUS_2;Y;=n~}_K|kR1Xrt`ty(Q9?>kaYX6(k_klsN|7^MQR8TXpI~JyzR)AmGf=%g2NG``6pjz0*h8^H|t+yxdPUqbt3R_{Otj$R}Ruq9W8qkH}); zcFti_>~b^+iYwF8rts)lFva!DLnFC8g7#CI=Lsm@Le{z;9Th=&Ei88+Ib#jxe4caM zbnZk4Ns(&z7ZNJYrXI$H01Hw^1-LsIs`?|txmPU4*(;Vbx9w#uzQ9?@p{we{^U)e9 zJx_v!Jr&pRE!+5{xnE0^{zalc{dI6llx(`A)u$N)m3dV0Ej<1qV#WyZ&6H6zLhsP_ zhggm_qm!tBTL!i9V|*u1txf3htU0CWKuDKj%Q6SRMxUQq)c-g%8d4x71kVcxI_m4B_ z_?ty5O&A6IbtL2sd~=QJtZ1r;KGzRtq5ytV)|Tfi?p}AY0K?HtVni$f`oYf2GP`m| zy~Z}exXsh1l?x^tK;Vk1g_T4(wDCt`5NG#I{E98Om)40bomw}TSJiy-Raek*=c}@% z7ud2^I^5R@X9_I0Pl>^2UCyp@VzMY$Qvb=QVD{=3AX+HfnvYT3de$9$Y$vYbVXSFP zsitd3&&aTFdWnQ{FQ&q2&&c-A<)OhxYjB{ZDLC>PaYsA?ykdtpZ7!L(VDhMYQU=@d zyW!bCh!O0hl78U-eX!(w)~~Bv(NEQ)Go4%5eE8GZ%$JM~_mh=)vQ$7{S@x9CX4a9V z8RP-8i`@fCK{9d2tK)ZfOV5Z$#-UroJWOSpa@DL!?z#p7B*K{jB;_FgilR{LLcd8h zvnKO!?1(HqSD1~Kc}?j3tjDhY;m$s01l4={$(R2`N#eNG1~^$9oNs2;6pJ}rmWAgA zfm#{qX3RIF_r(W7^3#hHz`@MI{Xd0Hxmw=ZYL*>BC}?rZy0%%H$>-RroiQ~n%Qjfu z2Ko)U>gvctkUC%xqNt6?16h!b-Bj>0FnYvS#L3EWVsTze&SOwu#B=C^>!XHU?HMc_Mjf zl(|a0y$XelXtZs}GfMw%V{r5dib#L;PjT&pEQXirC!z-n7A9uPFN?QL-v3C0GoIeI z3(N0n=hV7Dgd*SX4h?5Tg9W00qS$HjTq>*p4Ly2yFZbnXKgHtd4La;X7UQ>>Xal=Mks@N|Xm9y=32mW1 z$>8O>7bFn|gWB&D8n_01iXqHmF3FvtiV11e&@0+uFCA*RK|VEenu`Q3p}NYXA=Of4 ziV3yQEAr@Hl_sV7NhQM`cPcKSUQofhG-+kui*KxjqA7VL(y0+CY^Pz`ujRmiUY8<} zG)b|M>1oc^8PLL{Nh6WeJo=3j@@=Gkn{*3Ekj0>esgo(b9>+uUXSLd`;F=h`Xp&~F z4a<_Ma_iVhWQ5I`WNyh!QC*W>lVPGEAtRw8p&+64lBFTXBg_3OT*;dJt9h+S+mVt+ zP7lcqVVcmPNZ66Jpz+X69eNS-x*P|1c6`;dj2bcN!VA zx$Nh+o!-pP)EN`*5ma{EpU$`X)ZQU#OqPz&KP5+Hqg3 zPyGG5EQ_XMqP-`U5If0%Od@e}@B@&Jh3Jkq_Mp&yeyZ z3px(NeG<c34~YlOJuo4@$qxqWax)Xfs>6{vc=DZ+%(XAoIO z9;5Si?BTC*&!DGu$ud=h`n}hlD7Xm=nQ^QgzZm=Y@;(G#1ZJTSDhgey4{d%{u z^ObHcUvAyzUOopOR+^0?&U{KUT4MYfm$WLt#$7Am8N8u~)Qtrsx}33yx~v zeMkCW2f^$r9?c~+GE$vh6D%(6WM3O7yYaVz%vqlS^zj7Q25&&+m{64GjEpdA&^knM zv+d8acB^e?e$%0bQf$@#>S8$3P&2!r? z`7Zx$fY%Q0!1h$7GMu7c&6VTHE>ZT3bnT$Sj~A4YP0CmT-0F*j8`0faSu#a=B##?0 zM(}g<=exH(o_QglF=;p6NwNERoHrWT+kClqw8(xVX;pukrly@ zzJIy?jZaknLi;JlS*}OjR2^>Ny87cMCT_tGUOOp!Zakv~o(&_9G3yX$FhA;Y|K=tv zno2_)gu~+E_HPqoKIIsWy!Rw0P}}it*+iv5!{}UTQS0BFGA& z>vB*Y$E1i2^|1YdVy^M0rW!j$EaZPy@$}9Q5jt{eZc5F;NCTT2Aj$e}+$P2Aq*y~u zHrqys+8h^$4zXkucx(u^w>=qG8#+nVcxX2P`oL7Oa4G$p z!_0^HOnJ9zui9O|EMPtYn{kmNIT9tEjvq)E1uAFlECfR31e3QoK2aF&VOG10To)lQ zv#r;GT{#TFjBZb%S`Da;Gp8fvo&{MsiajSF=1ITq@3V*ZtUofpMCxODb=>pkZYL#vJ|y-@PADz))NUpxkPU^hYLz>Y)ru-??JZ$B8Em1UoX zQYSt}-0z)xUB0sS?8u=}9FxI`R1}-JwuRq+QGYApF}v^m?iXvC!++d_dEvE*%Ct2G zATXnhH=pP1^clsN%R{kE&qwvOU=Ayd8Zjo4f{!&X89?I*2mi}*4m4UC7{Jwa8$$c_!_fc4!bhJpU*Z6?<*}%Nb&*4!5dUNp3xy_$l zeeunCU|aG=of!ycif1#{JW+wyh%g=ALNW1?1KMVv7KO?<5iJoOxQFD%Q4x^ zf({imKZW^W&zrSDQlH7{*Vo8bUg1|U8P!fAtNuie z2V`zyEyMDQf?KeSzTkxjRn2*yvMn|(@qfef&!y|Qlq!Y!>+NyXK!#mlB6#jo>k7^rX{g-TgczSuU(Sr$-MX9h zQ;1b(c_y6wWp*P7y-RuZ6@O&pP9i*H{W_Y9V@yRJEZ@Lq6pMx8@8I+W`R zsTTwrE$`3c>&VH5Wk{M&B8x|J1esO{k~RQr(nvV5n^W zjnbG&oOguyxCmaD@y3I(D4d@Y9VUurKMCkaWU3oPs?s!{G~0`HAt%2)Of*9t)9omfJ)Blm|?k^ zu{c=B_i~7Xl-d2lh4$Uc$bH&s~kB95#gTqcKb&q8sVxda3o003s4d& z8yRqGhQ2u$-4=jfWNhvYHDSE&o%&>Xk#+)|b$klM!YYUB7~dx-q(5#{jpe`;b6EDp zz-T87rNiR7>GqDy>`X4t?Bem1g z;b@LVxR8i38P%>Pxgh4UH+|2>;$UUBH1(05_896aDm}TaH?E1>i9SnTYw&KVZa2DC zaFgB%9@gTsy^7DDT*k-`Nt5#ox^2&@LEbLo-2VLGWY@$W^%Vs8+Oj>%$ovmO-Z||z z@;JQyJ{;BoMzAs~$S@=OZ*}h+4U{ayDKR=(6V=nPE|(Q@fBsN!0WGFcLVll{OyPmm z_qb7H!g{o<79(tTDJ0v~Vf?D+bk$hRqK<<`wP%+VIeyl8y5-OT)|snVLG2GIT!zAi zzq^)~VFMafv}!OSjD0PZ@(`?h{u6GN4BAvXMc_>VFn>Nl(B$bYF3+tV)prIN?a!M= zms+H@TfwWz;!se&+B5ui3riS|g0q{ycIW7dR#a2$-G(MyaJ$~=$kr=>%c=_Flj@{4{Uk9@Y*?~^=pmGyMEr_@zd)-ztG%$fxLTi2lj*~4c$@xu zNNLf(qz+=Zy@H?Go`P}-gT-{&`5|cxkte5sStFs4I&5djhgBxkS#QuYz--F3pmkcl4eg%u$VFpc|xyp%L5)#KY8jd*u7miA}A#aHlXqaoUfCk$Gp$_gD|OJ-|Ee+*Hv zHH=Sz{~&mJ&l+*eQqkV5qB1%}ijBi}fL{2^exPkxfuqRURJcbmQQE1#cq{hzDX(e} zK>J9xq>6U~J$J@|BNeu$QLUqmnAk1E!ZSO;SKgHsu8`V!Yy537HiL~?O{MFu9=%9@y zh9#AlXDLF+5J`9{AgI4)O*r%9RXTv05y&Ayr03{h>$_!kLWJ^p8Nz43J5;d%>gY9AA9SB?C`Zojul~xEH45)&hN==>^$f5(^ibfx4SVl^Uq8T_H_^KUEDI;VWc@^ znz0(a$*;i+H)DFWI>z$FTjq$@fmM^k0NV?G9m@6tc*iqTLQU!gI7&TbXlCcBL@aw1 zGY)xy)9F&!MhZz_fUv7}|GEf(IXi!IagT7JZ?W;qQ#$4R?p~eN-BZRvB+N3wh0_~q z0&h}JOvf;^AJT!^uXN8Wx*m}Er| zTymXNna&RgEd+XeUw5Y9N3OPfk0J_wH9wuOYvJCOQ6~t>pUu}VeRn}Xm|(^)G#!G= z-$>pS1U>vh2uW&WA?1);av^hdHL1xg3i~r;Gn~73OFo%YXa_%i|LgH5e_q6IR|Gw; z?_|3)xqC&mS<|ixRd=}z8j5|{Mo4%un?8Eq_p(942?TZrs~lhfTmE5m8=8r=|8HB30%3jBseSl?Ye}7zgsd!-x3vQ^q%Qh zbp5L~Y$0V#j+_GS1d^78ORAhhCz>XQolQ((Yf9j4kjcALwh15ZJN_{hl84uB$jaq# z;-KLjpTmu3`ImNX1b`iy?o&Da`t~w#ijht6{yIOIzncM8GJo_0ND2Sxo>+FlUuBTsBnEvE4FZrba2rw$>4&zkmmY{m0n!$ zOww#QGwP`0@c_Fq@sP;n9lXb4uk*G-+5BN|(i($Z7-RdOKBJPgcs(V*)uh1-oL`|< z5S5Lh4Wur|4^QBybThTEgrqw@E{cBmO^;wWCWqqNZXjq9@V<4P)9)t2l9CZSl8wXv zD2yJ>gB`Byg7#nlC6DTM;aP$Q0 z5(@*f=iWdVvpGraq zEm%5ODr#Iphiv`mLWS%d+ERzC&wlDFaSd<~v6it(40a5VwNW9QQ;BI2J{@OaW?^k? z`#jrw=XvftI=S)5#zFdCGXFaN_-r|=_TGLt)pA>%`1YRG)SEXj6s+?VP5X$~>Kzof z6g9Is`tCBT3L2YAIi)jr8T6ic?y^S1YW!5pn(2wU1bZH!;pfLXdAOZ$ZpfHD-T(Mf zh5+H0bhA!B0RxpvPTM3!Gm+nr#uAOWt0QSyUMUgUR8KBTp4?OfdN0=+{NMB7ZVm21 z2}eD;qP$UH6)T5-8&}s5j@&n<&6oM?(h7*ICZK;Rb%RzgPgEJB z*iaar(x%YGQfPDQo={|8|}a?K7YfxkZIV`V0=J6gV3T=l{=E z_uT3n3-bgM$xB zi6Fnm5sCMpf+X4q2dfxH1cfFh7FU;T_VsDc_VtbN^cFNyvk4T7i;(H4_0KIV=u7pF z_4TRtvvB>PX5(Q|>gQ@8C*$C1fB?qERbXb6X5<+v)#vKRscC5H7gm{=m{#Sc7*-~k zWLp=PRH$d^$CY7Z859|4ZU{;8TyPcc){N-$|&PRdI#k3n;X zVcduYS)nK;B{8Ro2>gUj1L`)WylzH4Px3EztHe*I{^kkwHg?K>%}TcXo{+x2zi;1m zJ$jA8`ffHF`%ljYw-X;L`qhtcMuuNsfPX8yozvAZZ+Z}XsB4!f3Iqhb&tm-l!lbyF zlkXbX{vlhqS^sBWBh(Ap3ti*+%WmRo4$Mq@i+YB1p(K(Wlm=Fmm;@9dNH`DzjD#fB z&S(8GfU`Sshwm40VYme~o`?am@=}E~vRy&I8(%S(;OzIcgXn?QN4WWanT^kR_j%7< zmgF&!uw?(tWSX|Q_L@91%}uS(!1DuOdTj^o8UHh1Kz6%Z;y^BjTZFX7jvQ{JXrN>^ z((3#6Th0EBbx_)6WP$AA)N1=~lBMHN?~&QMjmMNWv7XOAnDk^ilh3n%^9y<~6`G$v zgmNaE&-3eQ{jtrgNbhAx!7)&jZ3D5kwb{(JexVdYfS=j9qjy)F z%X3yh@SW=ICjacL$NnH~+7_QvN&m9md9rM}Zu-^J7J7#3h0g!^Mfp-vfi;gY)4XMB zY+_B+_fh~>2(#ry$%yfi}iP>c& z*gMfX(mN9c8G#>-Tg;)?-q%5*ksVb;T;vcPM~b++(e=BqSk zjLAhID-5$ws83>(+>D`(A;jsmv$MXk$+7$h9oJ7LD@!YrS{t_m7~ad-)!*p2LeyMF z+k3+xk>1^3diE`)x;TqW#dpVI$>=2Q37&e^5t^3f;U$Hzo808jwVN6&N5Ar4@lN7S zki7AF{Br#C*V+izEe{DsT6>v4Lz9^z?q%WILz9QMv33LQ&g3+iQkAgTNM4Rrm{#Fi zM5{~^2V~|$!l!Qmcz!w*i~~fSlXY{h1>27Po|6pb@_+lOD+{b3BFm1U=EMVwZP2Fh(s!_?CbNc0h4@I=yga`BO* z#Yf5Cm&+J-F;reYEh32rVw^eh9PWf&w~Tl)l47hNScdq33PrQ9g_@)aP1ZQ@X~ZQs zk5@=6H!oSHXV0I?N|tI zElWK;`wkgko(>XSS1Zhzw#gI=VJ^qElnOUmVx{T454v?A&F+xIgKj4PhqbrWez*;Z zUwh^&0=22{Q5%0er}QTBD1)^&lF4vABD0;b5nJaWx6#qj8BqQmJ8#fM+SyxY8{YKJ zmo~Y(?N|G-w(JWQCXkvcl^O~clz^RvFLv>*OQr-w%E^U^Ggh-VidKYf-B*j+y_nYU zR}qupxwJ?7_fB44_qO=Ie<^5c{>`4rckK1hBJMWHo8p)fqNJ?8Q2jRX|QUNfTD=h*_SYz((0T8n}f(B5QFS_v9~sMz)W%S z9!~{81I)M*ll?%)BG??8?R%Rqc20EnE}G~b&@H^wZDV@(IdJwO4C47`9lK4}F<^37 zY1l}_x=dkBfsD#JQ7Lkal)JM| z_jnpSL%sTRa?v2c^CVQwOh+{C;@~8srsD#62!;CUGU7UyOzHCxyehtOq&^FOpO`6I zp%cSf5ruKJeX3b@Zqoj|ulRP-`TPCH1>Hji&=TlW1g% zpr~!PNfEMzxGr)oKlalB?MYX;Wf1QioodOcMd=yaI|E!%p)T4%M73K;6LI;nL@XeZ zVf_}~8#H$A2&X5aCD^?%M!uC|FrBG&c%Pe~+$Mjg+x3!zHMXM$Wt!azleXWiV~x8x*7025+Kl++Wkn#*$sTjB0CJ(LC;gYxzh zRb{Q<&gZ4Zc(L=Fy5HL0`p|@oMX=Zswv2tP+==ZD_i=9Xs7rfB3vo(CZ~$()EEc!i zoA2QCPp)g<5~Rn+IQXi&FVs`R5TldfRN3@&9mE8kh;pBuR017SPWyk}fS6}VWr@k6 z2NIpC$$9b*-a{%eRr^{FT6DHYb=Ma$@7Z~HIQ&p|`D2_qQLsmS<1N$^QhXO$MQNxk}6Nkklu_jY=LJbmqb^~io zAtZ+7NDbGcaK2{OcwmZ}f5sw`Bq+X2en0d|gurtoh3m?f(>#elug}s2kPbpBIVrfo zpUi=xmCkCBELUrpbhQSnOAnG%Xi$e&Uv&kCt;F3|v7eP|t@r%#IRvud0PXzKZ$l3c zLq_)onhJLE39f+MgSwRh*f{?;m{`c|7Rha^g;+WElXQo=F9bC~*M)ma3CAr`F^>Qy z7SxS%S)Lk=JMPq^v)(;LnUVo&UHSBnln&(m(lm(;>TuRM#l9?cQ*?W%*op<)n(9>}kHjnT-YC zHE5E}SaWjmzAM;c(kc>vM6tc5cvv~S@m}Tl&^vFnlVXg@vNA(DqK37|+<XKOu`sth6~@uRGsG!Ch`oJcG>Sc>o{ueC;f9|SO675I*6wn< z4EOA9-+pRvLd6Y{730aX-A*Ths^TFqEu1E{jimgR(L4HghZM5TI+`n^_jDRv=KiRcmk?jz+jCvK=-PO zMJ2@YFNpCfODZ#(i{azUUzK`mTb@RePFThkA9yCg4Z5YoqgK#S5V7$KLuQuMU2&mp$8!vmu@FB@FF&$P9` zpl@eXx`m{fI4AfjltwC?`k6*N@{e)n@knc$1k9R8n=OrYL~c?t$~VkEgy&pwQr99k zWd5_t*5m@Z^yPeEhvqnp+7WCKp~72GA2cfJ&y~T@vvaY-ScC`S`qJY;2)^MlW&Ig6 zzXN{GH%DtDE4I@5oC_uyHFJyjW-$@~43y*7(t1g7KVbY#p;vjg%I|R-?{h@5+(nsk z`Z`3+Hc={Sk@Ft88l|~{~_MMO59fJC5(@FKsubunmOUle0{9GM{#-yRm3pkpzyFfePa$GOUK3X?yYwLt!7Aw zyJO==6eeOMLdJ{Fj|2%ElVPXX6BH*)t(o%OZ`D81W$Xc9blFL+0QH)q?tB9WpN#Yvm&27eg zBN8Fgb=^vTfLnR|aa>%%={r=!G@Ge9x4+kK|JvMhOg)lQMTX<D}eYBb#R0*srI zbbB((SS2us>f_qRO!*H!lRnzqIIpk#=w&A(t2Bb)+NR(1XglXNpvueh#JjLsK5Aeybe zcI*UeEtM(enfcELkZEC2p?y~9LI_u$Udx+?6y;-i@Ke2!=~sT3RMaY!;`6`zBiG2z z8%-A(7+sLeE1O1XCYC=1e8k^W;ME=f5Ryb=Fd zX>A8mL0tObtPNhQF*Ia@i=OoRDQgbr#J7X&_W8~s5@F==xYd+aKwpdK`9+dxHKWlR zhs4p(D~6ym3)!$J>_#z|D^(MsR0;<}p)CFjF#=V)MiJ?^A_5A4>gbx^N7UBm(%~|5 zfG*>W?|o3_vLOEfs$B=wPJ z+(0y1Fg5v+=Vi_YMoTp~@jDmU{mNM>y1{L`@$`xWFBtNkfNy?e+`8)T@Hg6Rrv=Th zs9aOe#(LF{B@F9|dfFv}~+5&qkuw{54zip%4ZebW5hmi$BIP zINjKvvl?SMG*7*frg3{3^Si%n;_y7Zoi)D!wtz+SG+^QTLk0J_rxEN~)e0;csv_{i zBPIIyzF6app%?X&{Uo%Fm=LRZ59}*ayMWGcJ8lvP>x*)yKtkmt=Pi9-6i9Zs5_x{Cc+X!^hE zP*UD3bx{#>i)-_k8Qz)7b^7#4a{b)2s_JlkpH9riO~JCHl6n!Xn`jQ8OSV!|rkJSX zj}baB`*x_2!_kIP>hcM4yXsS^q_~9wYXA0H`Q1v(YtY*&_1~xuIH}vzH~&-9mrv>x zu8YH>()ba>w!Hk&H!~WQH9m)zo~feLnlu9uWm?PF<3|_tK_eO~&tu}w&OJtEmoHrP zeN9v~hHL?g(e@8-8+UWbhPMO<(f6aGSsO?|Cs|g~F+3BW$o8}6FOw*r+i9NtzSpEp zzU%pDplx*-57{J;s^SB)jx}=^&QGfEMi$h)ndpfz_gX+uZsxp%-&G}|Cg6O0)`9vq z=JeQ=Z;0X%DE9(N^ur$Us}5IPtNh(%O&O*zwzX05Y|WLmClxd0X!Itre2c?1_HPz& zoQE_E>shi|Yv}WRy{rKbvCWuoL+;s(y;kKLO`gc{CX$2<>ueoaC^K)&R}-lB_+O3V zEJqQ#(QhBD0}Pv4I1L7;KN{u=o`#TEChdvx8A_4?T#(Z$&PU~qU%~+;P22dF&T)TM za8GaNO#-58Vbp`8GX}rH_ss||mya}oj%=4mvlIFOx)*uYllhq4P)6?gxwWA?Jbqz! z{kFl2=$NT~E_1(4i}YbSO~&@4s36nrq)hp99`YJA(vwZZkhYs0k3`EGWuUW ztyh+q46+Gx4r2zrU)oNJyY7L&VK`f2XdXsqV0QOL(*5lqizUeWTElHZ*%O(`BPwacmyKPWw7R=xM(^d}g)9cCr@HP%RFmW+aNpx}%d6rS7 zs8|NYI;g z@~(;yZeTZAsJ|eFf~+iRE%xwN*WV*nV}dq(82Ce{K|rK;!hNiSC7)qsIOj`yKgxE^ z(lg$mP5r7@g}Cq?!P^Fy6X4MMP8mp8@0^{w>ub``H6*(}ORq?-9}U!GwU!oCkm17N z5NFO|vr-FS%p}*G#0{zX{0s^C{HzMW!>g)tr$Jnti}O%!?Qb_s5z;F@?iNSW%Cy>^ zHGWt-o$J5zZ_Yd=Kn8F?W(h@&Rt);)tB9CRX@Gf z`-DN^1#ykrV_9Zs?RnhJ;0yfYT?bb{r(G(=0}|qu#-%7FNbKj5m&rQ_9zu{%PREVv z+gL~@GL7nKY{8#*WdJK?+V@%hCQeVy8zxnjowxoDLf;|saSO|JuxA~+xi+QZ^HhoPXiNx8eBWzR-Z&M~M;NOiUrv~>M#P4w&fZ*H0w z!W{Dp@GEtxS!86h2hH$F&>+?R^(%K-=t!ecvm~;v+Bhof4oH%3p>!@ztPA?`!^F*- zc@oTRGsvRNFt)ceH3hClS~%@DKc7P`e!{5~LFq4HKK9|T@4qXC_ zU4OnToAKU|v%)xu&c#1EwiaSv*yn$d4bJ#~GrwW6#&#lG4-S;Gdq8SbNR`d=4TyTN zgTnnT5Wsq&2C(DbxDk?qZ=C{I+zR-N&JKF@gQJg&1;Z_kIa|D4{SqG8WSLds#`HcD zQy64JsP&_%XpzCTwF2uiF}$P)g6sx!7AWWXahFA+x%zyCE>W&E%#?up1vEZIDfpPk znSVt!oh|l{v0+@gCG5y*E_J9c(t4V!^Coepp2{Y1;F>{WYxTD4ngadJ462ljg;e`> zq1jEyrlfTCn{LHVk|>@}_33ZOke#18gT`v+{YNvk$!k4Z*44FW99T40RKH8mq3+?& zaiDy&kc&?9ALV0ZETh?A@3edPN?MM|v?J!9JlUporhlp z%DLKdbVCr$%Ht`%ImQ0C&bHi(d*ro=yG++g0urdip^uM|F)ffS*vZE9M=Wv?Rh8pV&zI-lwI;TtBJ6^OvNHrj^mxLAFpT(>qcKBYow!+K*5A_)iX^W--n%^12kONE!)FU73z>{S2d%=j5M6 z>i%<#EXU49{V#s$eWfvbR5@#NVGH({DrJujiE3^HyMEe*acqgdCuRVFWWFoJ!@t0L z#6sn38?>FMcuPFb+6!-bJ^4{N+LPao3OMtc#%;M{{H%HJltU7`Qh-yqpNSU3xKRto zaAtBmhG1dSqNkH51x$v7Y5XDmZzn7$)VTa&2rZRP@J)`0l&@1Bn+8JG!hOmU1XwwRV3!Z!M z0BA8!F)uM&g_5Rp^mO!NoeaHPpj1Ip%IXhh3|+GF#*x#^mDsd*_>q5sMS)P?w9X%o zP0`0;X-m{b&skV%iD&B~HYmQeV+d99_l_!$WYV7mR1oFiN)p;wq4rXFsPeq*7o{y@ zw-5{gi{?V&aKV9b5*IhSFb`(-;ZGyE6PuR2B*A2h%H?`|f0Nj{!UbFvf#PSV?i#um zku30|ym)W&A|+~WZLh}t%=X3Ys(!j=MV}6o-&kfC_5BWLl3(!yPLfEW@nmcRO=L02 zho!E-O0pI=nPjt?smVb(?L6dfWUMHB3ia4GfcQ^3$A5WrVj*TCwl}hZw9ug`kQ`cdQeT|h2;>c?P_Fexp@0AQNxC(msn>8GYRU0LbLhVWNH@{&q*pqQx>VdY zVVfrKkS%GNOfGz12$3~a9#6qOP&Y>PELD-fMjXATtJ2P?Vl$(4H@#3QCZ{@=Rj0gM zPpRkUW;vwN1k6PPXvsrXr7!a56UK=NihidRs)N}IGzCNy=@l%hz|KR_#7pNl$5qr?6zHNa`5)2C^f zyHmR23rmq!q|v4k*WXY@IB>C8@Z`~zsLA`{yzuos2l%MNtb}iun3Fgt|NYBh9`cWG zsU7nlvKU)*Sxs*%mcrRkI`ch^(} zMdwUgPhGJ&3zB)An)l$Y8zgz6a+t$d^MQF*tW}^P#2Q22b8d{p;1iml*jQ z>pFB357^a}UyST6+vx@Ctp{sF$EJ#aybev!eeB)vG?&x<;UO4C}w^j?YGuXWm z7UaTVVHqmH-km0kLF|2 zH9duAGTvxp9mv+7yB{#4U;QgEyyAW40Ps$jPzi=%g`F3{cQAUfsVE=!>`3u3jAv?# zb}z^0CkJdj1`AC&v;^YV>mPBsh-k`=4bQ)JS0kw^9T~go66AEgw_umEgW7El5n|L5 zlFuKLqB{8>GKfS6b|$NkASZx^=6v@I`mV_VQ>|BdVPY*kh3!pzVPk)JP#obC1_TT! z@_<$Nj#KUa0uBCh=D^)ZwZbzS`CM4-{S-7nM)F#hP`>OE;*L==RIk)<$@tmUMwuwE zWO{ny*ycqj15ZGTKZTPzi;?~2LC9t1Mr?6eh&$y;+6_r46AU7Y((lLl>2SWo#Y)qR zK{UH#2g-5i9dRBs5B@T66qiTjPsY7&HhCbNg;xaxXxR6f(=q;7Mpopyry|X zY%MT(vTIkGqy{Hf1~bcAP^>ygmG9xM-&;l#Jo{T}r;a>D0+QqnMVYc{I#< zeRejq@#gL%1}MS2sR|84n02JaVA5=pb^eQk?CA9TM~ZkNPD`;$o4cf8$65zx+#J+(06%nfs^c@pLcGEtn!`b(NH_B&V zNw&9^2mtRE)(e*WK;fLN87mfj%QY0I4l=>D>{XawV|!NP_vWLif?sKR#NWIoL%DXr zJ7!3SxR;A38`B~+bw)RDMSj=^4IFW)`seSnE`i0oA~df4#4)+^ar+p%1sUN9Gx`dP z6du%EyjVlS>dtDGL$E)zeq>%>}HjVOuSr9cMh3U5wF;h6qHKr$x<#8p8$u zS#OYcQH1eI*umXDF!R_xW{>G)SLSxcSVGe8$C_G(B3gY3`EvST ztjF}hA>fyd`jO|NToEbrY`H&f9)@h^+>{rIt1X4BajkGccqN<1uyK{Kc%VZjF%F*( zW4Nq6zG|9_4oxhMmtnJO$Yxel-pi(Q!mD<^z}Ky{aQ@5PpLkuz_S+T|6dM`_$u$ZN zX|^Q_6jU7)J0c;3>c5P0{4bxv%FN9ApL|M{hNq&=QdhSKvA(gamFhz{d6$N~@o=>9 zsoB;#J9#5$LL5k)lmP^kG2Rdd#Dx?*&}Mm=tF1nF?0Pw zhqF5&o}?1v)9J3*#c^h5G+{{NOMW9%>8YVK=Z_LZ2I*dStXo~=7vuNKl#rN@hpvpp zpd2IYv)|UKm>r%|MsFvvm}^I=l%4{RG6r>AFAInfl5-sPe(y{DJi(>)og#D|E_a8+ z9JWTQ<`BRTT;C#FUv++hRbFLYyRxFH_m5gydNR4V?@7#A$pMJ{+QN>O;xjueziMUU zbknK+j;uB_%G4TfU1suY2`aqdO}i7a2Ir^e4mB^#Yv?Ab zk4uWGz-4n+8JQkbb~5Rcy*F;*o3V78S(&UA8ZtwvpN^xj3*V6u{WegK znH&MpG%#P(-OPDU#|L@8T5=-G6B(mo)g)ojuSQV5X?f2xD$yXul0_{}u00^4WXiQzIfpB;D(`4KYYxezucp|7`x zNG%~T8YpAFzX{oPKMaag8Q-)(5 z!^cP3R-BeoSVCdHlGaRBjwG831eV?iG2);9w6X++Wdwrhz3% zWpBq#{Fz2!ylipdp0M4_{M8Z{Yk#H9hqAf0Z%b~HYsq3=5v#s(;6Jyl{R$YSuY0&% zt?l!5`qdW<lYW{&xgIya|#8}9`_L?7C!EIpVBB4@2FMnTsySX#3{dW zA)sX70!IdJauD9_#vdplZs0vq zC7n-PA@Q}X&|Fm zrFD>vX1_2#5I&yFZBF4_Gdb08JVQKC=6M@yPAc&G4!fS^W9qZHy@4?9H^AX>hUo7x zhAVOpR2eRlwkt=++#;0j^AAx;-ccNx1A>Eh>4I3mhzSHc!=>Fh5iU#&YGm)UGyL(W$Y?V5U@MT9z1%Nq zLu0K)SSE9;=&x+545%t#bl_rpR_3BvfXeZ?I8Jq#Ku~rXgNyL|vY%BIRA|VBP0yP# zvo-D7c@O;ae{|X3Os&`C3m2hfA!BK%fK#d2;XSFxDJ}TanI6 zHA`sfE3PmfpXUHGRW+(AUD?#n)gLCXVT+q9oFh{>Ee!m*Rb^I4#1GUrwixb+2SH8( z44+-111g_AMz!XvI zagNb7gt9p@AuyrU604_G)G#IyChXwC)eg0pfpibHd0}ZuE^Iy9oSsu0`6AJzh0OB4 za1z1Uoh=z&0HLAygZ~d+g1giyIceQG6)d#q23e#BHG$}gcinGe^X`49D^fXA)zqY0 zTT_2)ibvFhHvtIzDwKdR&z+w+C40APZf|YQhC01)(Lhy|S%dakJ{aWY^xQnBaSs!A zatr}6oIwvY*@sZJCd16Skh42##vi4nO-i@VtFQ~Gn&B1BV8SCwI-)aTq9drhk!3hU zk3X^pX@b!t{myuN@C!^>^*cy*sMze3$-*>iZYT}|pUuqQ@C};YP(oLMrN{f&p0zL5 znC-;DK#5N*!DX8KL#t}S?}8g94xHbE|x6K&Et?#I{+|A>nb*tF>jHYaREDE%c1xm1T7Ck z`Gm1`UmQv0AG1ypUr-GVfe`kRe;3X!b0ofBL;1D2&?Hg^eG}J8b84?_0Hw**D=)R; zsT>8P?=EaIEcS5-UTc4c2kqrwlpugjS5Fjgi6%T?3`OkmCBomxX65IE62SFk^{{zA z2N1Tq2yHQ7A;n$t>;L95(WI^a7F5Rh*yR`+OAEylh5B=COFj5T>H8_}g^~56rf8(` z#TF3b(vH3qKMN<|Ae>m09qx&v65x;A6_l)eI`n!ZFtPd3=tLA0dzZ4XABd#J$g?;;-sp_$3rv(b7N-t$c!+4 z$rD(Rl|YqK#d*aYU0=WUgWr@*jx&09|78-fAzclT+MZmBlaVZb+b z8zs?f6ETM%B1V4FA1g-7ivp@Z0y@8FZHeG!+-K~34Bp}hEJHchmG9Za*S(v!qF@|y zVEPg_214RJaT-(rJ6NDd&)zNsv(ssLc?R#4M<7G+6Q--$#~BrL_whB3jT}C;rYshl zp;72NTX{Jx#=)(TGkqxu-f4iXEubd|kpib^8qDEN*51S3Z_s6u6`6^Em=lorOqxv# zPo4OE14-9ZWtDf=21F%No@9cNj>g1C;S?cp8zQ6YjOBD6s2hKC5{St4zUVIMoGrNj z9;Q9Lq}6D8Kk$C_@)tTY>t0i2^QM1HR$FLf$6m{W&dr@Yk0mUc<-o4k2vAD<$X?Uw zj)qF1#p4yAcCJWs^vV+l;yy99h#5+jx?ntt7}!Mm!@N()wMWoP?5=m6O?MI+jnb)f z6I8L!^*RI{9Erz&jGA&Cd+@}#C&5q zjFkVxIl6RwCD1$Wn@W<~=TDHKTA%|x1#cOf+4%Yt`%UDKBh!;gu1)X7JxRc@miyN< z>fuHP+CKM4A@6L4LR2ok$cG*I?)a2~k{9ulaf;Usmmi9G9l0Si1u#6eg~}+?1yyDe z@q>)U%P8y^9Fk3Wj`nj33ldnWWnF&ZS>{oI*gRb8SQ}22o+-IuM>S%SrXM#K0o|hJ zmHnc|yGBTbjdK{paB)TM8oR=Ggfc+?y2i-3bg;%iF=&<+F>|+;q@52KpI=w5u$`7d zKzPiRpY$=uA6(jqGs+~6=??=eXd1twx`{ReZtgzrJe-`Vk}rjH_-xgY;<0n+WwlSF zrGpC9;KS?GW*E+Pr|d3VcoPyPbuN(b?v~9ETNBh(d<8!N*g9sX|JP@5C-%`$v?P*( zf`cY9!ouUKdODagDi~R*xY#nv6LYdMN?1BMyAZQ;uqBeb-~(LT-2Z7uCbZU^*0{d; z=G64AttQtyko<^KQ7OBnkmj?dVpx%9aeVoeKpc*jJ|Cz0ZEEQXR7i@PVnv#=gWYrt z0_Oh01$=|vIftpAtlw8Yh`9eQ{5m|8laMUIao2P3i3wf`CCEcm#3qq2oV4;S2>$&B z64=S^w-#?5G{f1&f%u0wM3LW+^h4vAI1r)XY?lcgp%OB64)dWzJ?Cm{Ujzz35E0$S zE0P+h5Yn24c1$xoLge+x=36~RuK=CZ#`m*7;`=GXqU?6^g zk{jf(y(RUdRiZom(hR6#F+hc_V}$6{h0_fdGaVu&4B`c1 z0W&CFis48Nn?0=yx&+f4axE%`4sM2u$u+-=Af09^)eDy@qP5ozGs}fP2AKr<13(>o zp~URfzd>OL;Q*mfMS+0N2l=+0z2#T%!B;U3-c0NV)rd^h4!Z3W2%^0LTG$H8^^c-b zttaEli^g**2*XSFVEKpFo~XsgR=c`N)=a+MO8^zeFQR-4C6|u7ghx+|`k%9k6(qTR z3n#Br`)&PKN0u*ajXL6fKAi8d03nXV5i*z9j>4=74!J_mpxJw6(q}jvA8MvGTl4nf zFDOo-YqInWzDaie$@9wZ66& z{PA)ty-#V&vOPmRldhLNuIgPqJ=qgg^Y$=Wem#0jFCK-va?T3ESt!G?2yd?#K6&-%q9Bfs4}CVXiqQ-$ zS>E?lJ7z47)4D_E1YQ&p>!l?is2Utdwsy`gb}Mjw3K;ZlaH!;$q%sR5MbI*H4A12i zB!ku|NPkAcXle|WLHfbQw5gw)#7Da*4M{bV{Mn)~6MYj__M;q@!8$}cn?3X7>)%?* z?@!T({Shm#L6uI2$nlGr#Mj(e64VU+m`YrWzRL;qx6ItJCD83}B>5>V-lkqbdAlU` zu#D>1Vx2qYqZH*5uDn>iDsu;S1*S24%s2KQowx4=_5{f97{_+MIB8vtf+k;eJRw z-NbcDi)HVkf9McTro=g~*IITdHCwy2^;O`S`%SIIBp**c>tof4$;1{q?&19wYcA^W zMU?jsz$!%R-ZRVwRW6@e)+5@f@s!5Hl*XaQNLMNvUsshF<(XkZ3V*n|ThA_i1$O<5JY0&G-Xc2>frGzl)dHjk^9e zPJg>-_6$@LQ?{V?Feu9gv&H($j$O=CMq<-x>#KhKW{bpb(a$!ahnSv>ErIxVk*r}Z zDnRIBe(`Su_JU?w+m5+MMq7g!H(Z^O`$C0X4UorPF_xU{R@`VEG#*2IroA$~s@b`3 zwaE*y3d74kep$l52d2Q%R6i5+L?cFT-Y^^$g+DMco+UZ%_g1#|_oVH)~tZn!3 z9V;?^&rQLzZTv}WoljY-KsL8$oYGrI68M?NBzcsikB@j8x;!f4&PkKN?bQAv(xB_u zxD?NQWbeX~m3JBj!OtLB45CEJM37HF1cb-UITtROxMa$y$YFO?-w$|ylU`NW`)*Uq zryy(VIHm+6oTp>J))JeSz=1K2Uvu9aXOKMKIyK?PMczJ}#oJF_hklBhwdGd|nvR$Oj+48>f zaxA5ZEF_$HN+9Vi#j)<;KcstRBzdGGW_Aq|PVFc2Z-TiGb=ySp10!=c68B=>lF0cc82pu}{C=(M|D1Mna4h5B_~F(H zE7B?ZkXWOOYfI>XY8Zz}z1L-r=kmv^VtaSb$GV+5-RX-1=AjP4L~pP2g^7!iiIQf` zK{wi&lopxL?8WhUHp zmew16YkJFCa>$#j>>^)R^WuoKW-s5rMmOkYlng6SgQ#Y+hpP+Up?L?g`>X9HMGuCw z?GbF)WUUQ0pMDrB>oop5iKErD>~rM-$cmf)r!#5^Vr{zFIdt3>D7CV+e||0K^hk+< z{bpxt#Mda}o|W7F_=>+Ya1M|0FHpBzZ@Kyh;=66U6_^@zuqdhQc#8qtD$~%3PYAq7 z1|!jurfrjj;Cy>{c9pQP^*9vP2XcgOBV48i9 zNq~6o68~oiD#pnk|AnR^ZRa%xeV13hWXe$x7luD^*<*T;`JBATG*75uXh0Fmlx5*Xg9F>URpx!{Vas04bsGV)8;QAuj>e z3N~i+t%#tG#z&hHp!H$uX*rBxv8>gSxrz$nJ*3|npAmS`=IQ?4b)}E!Cs;G2uc~OE zqlEDS@VJoB8Q|PeRv2NLMdJ9f>tSm+@ z<{EdFhmyJrZtb^d1!&-EmFN=dZV>|QgnYo`05HAsTW1pRv;5Sm@KzhagSld|6Ab$( zxl|*(KwWD2SVR6uY3s0m4&?Fv_dzkRnToD;@3PN%eC;*5TQ9%4Tx7-M0Hn-cDxMwG#*F3zC7ajOqW% zb_Co1S^f_}z|6$-`<)(?L7jtxgWZ_L#LUQ$*_efkliSpcgNeh8jftIugVUIc)mVV< z|2v_}sAB15`fp2SMhzWiVpd`n-TxK)oXr2J_30;N7{CqCLw2r`^2@col!~OA>|CuE znl81;F-cHa!!c4}!sB&+P-TVF*Fr_2fMY7Y9?E8Savx2NFiKsx2}M{UnLDB{IS_Ex zg{-xPLVE;JEi-+mnPH)A?qn^V4sO|L{r>Gy3Z$WUIa#5d$y^#x|GJ`f->OS`vgMRd zr@_d9V74!3=Vd&LC8%lWzUTvcOt;hHU0X}Ff0La+zC!uK6a|jmCmdxYh-8Q>>43eL z+Dl&S05$9YR#F=_$7OHD{{mpjUfFL_%pEm6<)55QdXL;^-RN18}9ywm-aMOgOP^+nAV>%w%HQ)`U-N+qP{^GO=yjm|((x-gEB#>YTdYuCA`9 zyVmNxdi8Ii@%sRBdJ__rLQzbDfrXI+o?`Fn{1KjoH5Qc;;N%b#gm-juFxIz*|G84B zq3yWZg5h;pJ!M5CGya1a1P&RKDoDOAzv5-)f~N3XvvRFS%1~P*l~hpiw0Q}|C>8rT zbEuBWUd*SbxAV|jWa129e3Sgr#X?|ccfkc%X!~7mI zG_-7eqgk^747g=srZ;50dq1;X==DntpGS#HAtcv}_v__5;0ac*IzW|UY0dbAcJDwG z%klYS+g$4j8u|s0Ixssm>7fdL3(&iT%1?mStvk@~LJ@(!4Ce+c>IS0naykYlUD9{@ z7HM^gTW(HWHk;g@Y`PQ^V7ljycP=Fn*9=l*>zvbpMDb`7sND!D6JZo_Ic#1Y!2$KI z>e>7qbTRfZnhl1-xB#770Gv3QJH!~OQ9-(O<8mhN_cY1xN%x5#F)HR>x(j@Kzx|5V z{wAw%5eAl|XNGvppO-kKj}FpHqphW3=ycgp>%yMF)B38@;e0lK=qAeD)_?h#LNz1c zBBt>N5D#wFBZ>XRJ*TS}i`uJ??tCjS>@tysE-|8XvY{|NLMomzr*k$xn_xjt8sX5r zXPHF4+G5kpl64!n#UnJ}mf?RHC;=rz5!~|C?#&-~ujSuEHs4hd>kW3doo`}#`!*n* zB`6OEV}(YRBGkH4jX8waLICzoXdiDnzMxJG6ili~1&9p~`M+viSk@p^xvKaoG{EzB zY!*5o`pBI?@t}2c4 zLopJ0bZgK_{>9RyL4D#ir|d<8Z10y;pnr>03??Hxi$tVZC{gd*HEnYk99lnvNwD=Q zpmJ$rgB0AiHs$luY(DB^vRs$M-VcDa79U-u67=l77h zwbD$2i&A2qL2}_L9?Uys3W9gCQL@PZ%qy8>vZ*0(*wuzpBieY}$@4auqdaNh{)vb09MG-L!n8DNh zAm4Ey?qmbU=D#gvvB`2#*3|f9s1Zq?fGT(cc6CSkrB5A%bYISLx`-IH`wg7H7$YAx zFhvwDO-G`{Jgg0>r(-$^$DAu8&Q+_K7)Np|I$?K>=d3xw@$W%<8_TaqV0_W5P*>iPDk9ZazokWy?^NmpCpj@s_CAJ#!ilz- zGc-U8CY#t09c7c-Au%ppPnyQozD!mW4k_2Vha#otY_3Xf2A>Mqp6xdQJAF@0q@kt| z&&ug6WbgtKegmi3gR~({Ud8NvIAyAD1aZfJ9sB$&D%xkM6YpgbejLXcB&!a^i!dgEcQ>>q~ zY{CnB%!|V{lbtoA=RZj(18|83#^rtl#(}#2MB+^s8n+$vL|Qnt{-Q5?xZn;e`9zvt zN7JGuM_~rc%rnl%%{B2*$L^YsNsvb4@T;pX8EU2BXy-AFUsEpb^wTSwspw!3Ym|q8 zh38?D;I@g3=aARQwVJ3d(WJu`=Y3x<90CFrfyUK3SOIbS+GWF4;A+hwy$o-XpZuc9 zK6YvRj|9Vg`-mp_q>8gv_LTLdNy5-_vcjuj=NGagv^x=qX_T9{0kCD7M{6TauQ;}C z`wn@)kcYeUTsmkJ09?^$N1Crce`l)lIP2%gCsh4xT|R`uAbm--wPkYRY&x4Jx#b?y zD50pFiE*yoR6c?W#O)F&c2CY8puggeZa7Z%B=tH7D*j=G;w#P3q?9n6{^G_sHyvRa zD$x~WH?HK!@Y?CL1<5MLt;ydd8>4>&)fXw=QBNb`V1BC-{e|?1llZ}XAG*&RT6&T5#N^xhtFk=ymLD=FhUX#uvaP82Lv-n;z@KoA_iV@DXr3_lpM2QJ;h zqq;knsZ0B5Ek5OdDOo%e?o;o1UM;GFc*LIx$OptQu8^}gKjOmN!@U+;94)(+ETmGh z5l)+(rcPpns0m*5?P>4YDLnDOqst2-)8uJ6D)f9ZJw)s19kQ+NjNd(lONOa;Y8&nC zgAGlpgYE6*05bNc$$eMI>?@j5PfA=Aw_K*kM#HAqqa zRuAWEO^p|=TQ_rI$WZ%v z^PfysA))yK*OC1f>c~!Bv}G=lKKsistFmqs)D)FmK=*ZdTl(My@)BYyrtnZ;j4nzk z*70!HK8DSjB3BY{iW29Ice?=8pr3bgsgVPlq3UWf-kEc@M+jxHr-VzJk7|Pymkhti zchn2K$~qi?_LMsl14MG%{-|`$qg)`m)4}Cp(*8A>LEI|iw^^@-t+I-8M-@%E<;wfy zSom!T7({69Dq}NPbMJ%OfhzU)EtK$hig7bPK3YaWDW~lSi|k$4Z*|j=k;bACU6Q4) z?ar(p_G+=Uy+z-XKIgS`z|Evl+dsFg#9{f$&1P#fL9()?*{Hg#AL5oN-rm6{7FK>{ z;Xxbdnu@yNEaReU78$ZCzYrI{3C1c{g$kSBc>n(T>+<T=}FF` z0KqRCj4J^cMV)C*fR&Eb;N9Hl_=D|Xk$ zJ8yA<^|h;{kb1S{I9)BFdETNHXlr|_eJM!MIs?0N{gPKgw|v9SSk^G=Ru9!4l&qLD zL?p%!>oWqW+nVqgK2N&eTrs+On11PW9XNdL^LiamjDKuO{Zslixqr1e0I6bAsKbqo zHE0X$Nx!y{PQBM~7_ZQ}Q8B8q<0r?KPRF1b7cTa*Oc?Fo$Thae*KxDIBD&i!nYaDa|O}8IPt!ASI3s@5}r_RfzmCy+> zq@cy}QYj9kykR9%Oh(Q~9eO}RUl$~qUZ-=0vFThah53x()COl! z^PsT3-2q~0*DCcefX~4ahs`fOs;hd9Lxaxo_DT@I86=k4q{|0AO;g+w5wCSs$3Yfw zrV7(2OeH}$B=>hdhqd+U{NjwbIDUvRR#lyHWK2wW{o4XLRz>A)+4?|OPl4t!B(!DH z%Z~9%is)FKmBhU;%$(Q6!fKFmc_NgK3lvaNxQ%ci>&r*Vb#LBV%2Mi-MYt8yI7@r}ZN{uk1B0m)piKL-qFajNG8Fw^aDO`A)Qb z7}c?VP+9DoRt#Py?RKMe1m9lOoV0ww7D12H1Y>!uR(JysUgC}V|BTQ2pD$Yj3wRcu zSX6R=i;eX^O>kaSK02KlrSn16E@W<9w1blf%)MeRaYeIytqdN=?mHK>M=ct|^XaMZ z*kBdOv5JOuf)>hU_R2gBol{Nj3 z%4?0lGrobw?Gv_0opg4otOm@Jv6>v-`6~FN2n+E&>3o=u(86XYnnd=jwtEA?W^eeS ztgo;kq^CydF0R>=;&gzz$q%Ra5QEbrc5FL*tC;u*RkiC8gmlw+4n2gGp3Ghw&Xc41 zZ#$Z!tbTq*{nB_Z>jHj#h^TJvL(XM2+W^15gog=8go_^xQ)tMSkSjyMdMc3Ph!$6| zf+d+zWH1=(tLqM%4k0&Rj4PA3kpKh6^2rlg%%0Ymg{x}yECKKmY*T_qb#>@``?B|U z$FeKstd=GBoE7p_&DGu$?pQzi7WI=GT0NH@%djK=CdyF;Ts1oy>1K)|zp?8wOh78Y*y|FnZnRqf~l}KHHp5BjfguUITERTy$!9_HFC~BW4 z7$}5OU2J-;Ue|i!r%)JJKlCE%6oHe6+}3<^W=*e*AF}F#{?_WFk)8mm9$7f6=38Vj z$#0{&6z{CpvPH5bXCEm9l);r)`>ToNKg`s6DLnqoMEyD{4x0Sf#ZEUaQ|7<;WTCx+ zuvudILy?4_6P)_0_u7UW6cbzN0}u(o*SLK}4~&aw!5Zw7s(oWDzxl}FZ0Ol^4;~qU zHww9j3KA74*c20yS+oLE^*@Xn#~;AQj2V8YjCNx0`x>H9k%Lh3WD^lI^UIGS+L7!> zK$4yziE1N7IR<}Q=p@ovB$8QO4cTt4O#-Cr;h@{fCr;q4?(_964=5kF#JwbuNrIwq zh(cC84;)z1>?)cu!{6VhlngX$@!HlBS|7_-+O#aS^FT=F9)E%AMqyBHSKuk1C{V8* z+QEAy$$NHe27BPBKIAS)r2DO0ZlSd#(-3^;i@C*kk0(>Y@KVd`*ZsEd!lA{PB_|N? zdkHJDnu_e$o1+KAohG2HdeFR0CXFuNl;KqEyS)j_XCx<_?=rP`QYlKpcDs<~P42>9 zxZS$PRqE6fMCE{OaypfJ5ljh;ll$Ma<@KTpUK|HC_kq&8cbz4h$KZN#Y4Bw$RoeWk zwjAQaV)#=Hk@oONsOhm~6he^;qx_;xv01hF`q05`| zxR4NjANw^Tltjt;pLJ*Jl`$FN6(P|&M?R?pRAK7l=V##F0lRI0%4&4J@(VZAxf?{X zzc4fOL0$9L%DGGpgKiXh-g|3OZj2UX_IzsS`3vu*457h7m3vKE{&Qafn&z6_$qfcclf1e z*=F&|PY3{NDr0CFQ@aKo+7z5S0WE&sY>?;fv~UauRrN-j!mNq@&}S!Bq9=J9Wa}vj zw-%oE_`8DsDVdqe_7zh!SCvProv7AHN}DHvi|S{R@<3Es2K`N2SMl>IQv;B1AbE+JqS-=`L{hws8M7U_O(>oe{6o)2Q%Nm z95h3$I)a&hLXhq^R8Vu_(mk<@hqbqDL)eT==hh?_vYA5c(l4P1J|?oT=%J zy~YCDuS09!22dl&zP|X-@IeiT_8eJR77i}RblAr~BCYxV6i&9(G;;7LtCm=33#88H z4S@X)n0W_$4a#W^HrRn+4A1J&cbeFvMvkx>pCBEylZI`cJq^99Chm&WM-_%nFc_+mbWdIJn%`1n9EN@!LN zVrJs+@wI$p_0vS(KY?-m%h_>o|JMOzqq=(ZDkqBfWi^ThdaSS10m=6tzFtR(q~a^2 zmA-;!jNp~>t0G3j)3M`k&o^;m>Q$->v`eDs<9|)KGyK_H1bL>wc3^l(K6m%16J=zp zOxz$k5?_&_d@*fw2H#;D!dLhjJEU%HqYa5kNKRr8kf<5d7#Z1jKWR@fH-0YR_%Z(N zAefq6DOX1_M*-a600m?bhdNx7`a_8@$d^bwRxc7NP#+O*!7lXZ=YkWtrJXN_#!pzW z*iXqQ3^)XXsWq_~xoH|*zD+j*_m$7ke(%DwVb6kX9&YqRLw3X99Uw2n*pK#Cf0 z0anFSY4daP2r##0JcH&>1;$<>Tqf&5gIy}@1>WRM#;2|8Iw-Bt(rIC+U?QNZ>!#M9 zbtb+WI$a0GrBrb;)zPxA^rv?^w@=Q66$Fp{z~AR)7qzpACH|O$C{L6inY?BZQAnr@ zYk#%^VJQORXarrg3D2@7YliOkTr{PTX0#iq^KA5GcL6$=!!m-C2MEPRYdxo&AVf7I zf1L1hUxJ;Jlmq27{){}NK;K`1&>-m~N}NSW+qHhdr`@98oernuf4+r4VUr7ruPD46 z0)Yio-n0|#6b{5X@E@Hh8!6RWalf{%Ahv~|3++&SEqs59}|6|8^njj zXEkcqTN1`mqhx}gD)I+QoA7x{$Wm8hE)!}zk)A_}*%yub5%~zHfxg!apY|u$Ql^c; z@}_;fyLM3`l`wPnYjDy)!4cF}_k?i(trvt&Qi)N){rEjl}Sk$^kB zz+1D$M!oJ#s?RKXO%`9eX&#F;))=x5kX(}cg(R_%n!SWLTAhL{bJrtc@;GMW*)r*+ zV1p%CNymGc*;|+Lp2@y8J2xc_+m!KBgGARp(1ovvCT{v&F4??FNiJEFzAgK9rQjrt(ik=T;BM9^9$N3`5gUPGa^ZmxF=Vbi%_on8hAC~SYQ8K+ zxh2UzEW?zG1nY>7Z%V&F00-B}MJ=XFYZTqL<;i}M5Kp;kR}#4pxK;r!86duIj_ud4 zRG4qBVow9~xEjmnMl__X4Fb$NIJ*mikF<|fD0e1~?R@6+@FP7395BUz17J_vg!ow1l~sDwFPf|VdGwg zes@>QAPQ{R?2^wD2~y7MM3;4vFd9OUC8ZLsi@wAZNK=@@ITAe#uK+O#ZX=4#smT^z)W+AKI;h_$Tx*VWHlP}&ZFHV8wbL`L=5DcWHlUE;GLMKU;$RKsfaSHR z&i4bMs6D!P5)3qOHkMda3V?@&?LQOfMomrI)gg?3VhT8Vu5SpRDiRL+bB#QK(YDj9 z*paLidV`p{81;AA@58+7Zx30mv7)g}G%_xXxZl}KCtf`rug@NEvPd5NP5pXw*)?rU zyXj4Yw1e0pUSP$4HmOZwKZxQ_9Nb_;n}p9}G0|NBO}}Y}8Er7TC*EpPNU}NJ1v^jq zlUyOl$v*Kc;BFF-^1k!Ky-R) z6b6U^0;RS(+G9NW8s)`hi2)^tHm2X{;QX_OE^m2hl837V<27h7>bxp6Xz~S0bu&w( zNAijp_~qjhZnLoH!9JXZp+*VpH%AuZ&Zwm4#a4n&5a^LJAjO~kX0~dD9ku|+7c<_M3W6Z!Qs?7u#E`RucRRm7-5L9< zu2yeQ@Sr!)zs6P=U2knDr%~CLt`a3A1EmMWdsT8}v+lSK9gR0**}u z_;M###m04n28R%gdDJIkFe>jBMXQIhr5J4bQW&-+<1rHP*~zuat-nW2Fo}AjQ{m&Y zOg*JeZg~Cv$0PBqGT(pz@8@Vp)8%Y82)idG_xVZjQOTo!K%^FkARMYBaTmz zAw(qow0JV3@-kyTw0!u~X~4WSP%&1}2vG49yme*8P99l~Ac9?XdWQZy?4%>0#mGc! ztX;;5;_Zp+U^YL?RHGfR?}Sa=1~x`nMwIw|KIb1L1+%534kNZt8%szi1TK(ILsWW* zPPD18fS13ML_pc1JmDkwCR){I;MXA$a#(M}ahlwp!I6L6fHn33m?V=TX08Kdo|Afd zPf9UWUN!lkqbrPXzl(CWJx3N{6v-~Vqb~$4mW0-^Ji?#H{C%CuyL@!OQY;zKz}UWE zvlCDY8hzSe$xI9AcUa4v2d>|*mIY7|Rpd*CZN@VpT3|6qA!4HCmTZN&62vw*-^kW4 znx9DGrO$LISza@KIJZTff|t=14$&<sM^~MtW1Q5!+J!DGuj=M z_U2-h$A(h0RtNnw4S9r=WFx|>aI>C0Qb_(HDJ7JEop+3d{4Lyb0oaS;DuOt+G5-ts zZ7^G%z2qAu3&n{Eh~}@b?iFNEf5ao$)k6v75*ApC-0H1MNY>iNz2Gp)-v%0@s$HU~ zTnF2}d;c*xmL-dL6;bkBtsulHHB1Unxpr(dGy~=k0sU+vBXI-wJQ5k+=8hGzEcd() z-7}WvU$GTNd-dYcF@Rr+DlXf0mwsZ*s^Jq??PSXDPtw+AMsGPZ z)tzf!&8-<{I@Jg4M!!JZA_HGPg^{KP!P8GUIgLNq2@N)t-y zMO-P-DBs}*EB-?JasFZHMKOt;VDtBem>>Yxl`rP<*MXG}uuhRS!$iU&GHTP(HJfM@ z!ISJCKxJ{`zLTs8v#3!uV4r%@UAzI$*tqwqZnxR7m8j0yVpYc~bXyy6^DJH_E(;i* z%&d?_L3;p9W=SExw42bzYbP=46TpZEh&Sbs{H*38obzWiD|ubOxD-wVYw5D1!&CH9 z>+(_ip+|RQhaVJ4_%h*wKILyT#>0ZA9q}2?aU4Fiw+sPucw>-Ny|89&;*$OOlzW_g zA}E-Eeqd*nUH0@jci5NOw?Uyq2}r%NfWfEbmr?^jr98vNbbsow7as5ga?dJ*19cjg z7oAPaJfrDelMKumL*V=vLHi#2`{H8c9kF87aZiQEs>u&QI=Q;oCF%HMdHasotLA1? zvGw7<7C$q}YASoEYbP`kph8S?4|Q2IsGZ5KFE#OzSZpE>6G%6*n5Q9I%d)E7%GTs0 zn>_(PjQbA?_#%Wl`Ho#KZ50T;j0`xLw99~VRAmFQe2Dpm{=BcH15Y`<6wvo;#^RZU z&5{{1?T|D4vW^5&j`iTq3=GjK@Adv6Dc*iIoS$3Pz~TCr^2>wNUDs@Q@oHAiV{jeA z6lxcO`7Ri!_v#{=hZ`R@m5^`7C5(gLTBCpr)EP-;#`D|kgwJa5cSSgkX+&aAkiQ8Y zGzOiz(k+bI>3&w^N|QUKwCxhpmuYuE^7WmRRutcei9ZHh63Md^cs1vm^{aQU@bN3Q z@nlt<7}TxcRAhSOy4R(QBX!7f;F3`KV@N6pNsM_4z5da(>#X(Ep*ipElEuK=dTRkv z?%6j8+`Q~h_7Rar{fo)mHNNloM9v*F%091Q>9?#6|70ykVy61lwN*`}`yG}HQHa-t zpcksYB{9d)JB{e$}DXr9I2tRB%5gFdn={vGJYpCRl|@7FV#fDu zNKbYHORXgws_W~qPOFzzeFtDJN?BL%G$>4lBj@ap$JZwOMuNTF zpGZm)#kbZZ`)FG{hG_O&wBTtn%sbR{TGWhEGSMgI$ZcE_XcL~lMe$W=3~+$1l;8{6 z#vOacv3v5Hj51hey?OFv-iAqC#q(-Oe%f9`j42#fM-g!-R;3CV zZk~4Kblvfv(B+)n>Dx1cj!-tIgZ7-(-aPq+O6f9bPiLS@rQ1*kdlx4``=Is2VnyZK#uG9=8UaXYiOJ}!0SHF`!-)R`~N); zVq>o_;ai6VB(B#$`EygU<#%M_6=CR!s}=c9=eW_w)x?2zqbBD`jPA<>cA zX1YHpefVvdE35`Tabn93i-Kggbqxwkaf^2cDG59ra8hin0&CA(udH`A8>rEG1vR7_ zPRFqz8qA+)66EkTS4H6pZ%&z3)szWv05q;j`%PGYcZFojrl(uTC>5D?Jo~a(p*P$M zEtmg1FXylJg7&O*{S=9p!q`oTbTdb1u2-}g7A!nt5(6-(Q}(hJ*4cc-x_EO_R!RCj zmy62OwkSe+AcB1)Pr0LJi++fek#m^8%pknepQnl|bqeJt*a}quNw0FH_G(XJw&e@> zsxxs*Pz+LwaISDr6-mvTW>5fiPX9#Y2yLqEj)}pbGg@fx9%DmygE{Nfp<9txb4b0L zl|%%Zigebo>$Z@D=B<7re}5_}+A}+*Z%pzq?Ql;C@Kg!KwkF`=_Y@sMaEJp}m!7pDpIKC#e1{o3yI~<}8pF*qtp#&)5?5Gs z3R3NN0Jk1l%r_wGA@|>kB@_UtLX9)VPf>Egw<=WRrcdjq0&&@gUpQ0N zAE3F9QGP?kiMe2OPaQ$2)iT7f4yznEs~?oc0t?E@9bK)hn|pMB8lq?+!Mv3ARxLar zM29ga`XIHG238qbOuL{}M_Rd3Ad3 zi0?JCYF#3Xf9sx3N}KOQL=@8eZgKRy=xZhJ^tWJoq4V9io=|F5dPDV5&ahq zDG=w9n0IMNqIGX=r>fCZMmjfu?7gllT!fkRDS|bek}4g~p(P?XwhK za$5(6lbKdi?lyh;VY+r&X6E*N5+83c^8z7*>3U&qw~%YpOsoNrEkv-6SCTyt>it;{ zZ*VY&$fvOQ^z5|i`S?3wAIh&EFGBn>3&<(jESQmD4}BJ(Nc3IrJuMlsK!@LJ(!lPl zl(gAwVZKL$mR#wH+zUVBn*H#7J~4+P_E8>Lgy%Sg95 zv<<+iTj7WeC8{$md#iu{@)Vsmto68ogLGWCG(92yXQO$&mqa6)* zCjMKsWAzxUH$sZEcr@xR_nMTthJa?a2!v7iS+-l+_sLUUdNhYmt}<>Q4KKfj0V0N`d=Tj;iX zqDm**;zzhxkQB{qWdaMNGbc!5cDNjJ7^wqko*-cZ#t_YH`^W+neb=k%(- zq1vsuznNR=J`4!7KO%ACn+Y_$3wYy7E}On)vt-Wj(Z#&!&E&4;w#-)cGhxp)6FteVePk5Li5u<- zJW0*(;lu?IeEe%9BdzGnqe@QBKkTT35-eqgl87`m9{tIPiStv$a^j_i7`dFk9esv>cBTV$@~4 z=r?AzynPqE&*yQu=b-9ZH}kh(=0n|Ck%o2=KYO4W46sJTs43S67#zm1aJWLxZQO#Y z#MsWtqVB!@30#Pl;9UNv=m!)0@8`e!{^^Kk5yS-AzPR*ZYJaJEwf~j%t?iG&(tOS7 z#9LL@$u^tFp6bV|Hf|IbjYd@6 zt%p5R^@HP0^}$t`r1REFkKs?%JS+2AMqlv+u^L^Qd#VD~cddSi&il=Z;IB4&I2`}P zJG1Blga@n^&POzCy&Xp;vX>VUu3|^_Kc7MJ{ZFasL*hI8r|SLR@~_rM_4R+tzX<+m z`S)FDy)f>uSr=pWR0U~kzPz30ZR%jJg16(kSZkjQ)I(($CDdAmZz5+$P8oNdFZJ&{ zaOIjVVs;Z9M|Br!ZT3!A-ILdMIy6(uSNmzhwKqMkUtQ&~%+F5rRULdPaJ+6`r4&_A zAt5T&ik}hW(NRdzZa?%%X?|y9JF{47^gs$pk9Mc*s|wN9M56ylwUVIQNnOsfAZD}E zG+iPyJ&+It+HbQUE&xp})q&}%Cvvu%_^&KguV2{CWd31a+BH*sfSPfe1Y2s=@{4yD zB9CVk{0!jAxg731{K#)~9ya}0?GJh14_>PhW8pp;mzpn({eL=OKbGxdV(0rD>G;U> z-bC&n9IhVGl$)-B`Pz5VCJRl^8jqCuAA-FIzWQt%b_vrygCA?XyxG{rb3YKDX)*Tx zw?6+-D%!tG{J9_@ppdfeHtDPHamk;p2=k%Ok6D%5=(4;&tT_s!wm0EFW{y4Zr@dO& z(CIH;@La{_>Ue%$pme|FVJ) z){%xz)1I{au|tO#m8(eEwH9zY=- z5mB9DKtmf9yNuzbe>C5$${6pd`>OLvrGlS#;^fiqQlt57SjHheGgh z6*DBIp=9gSoDW@MQ}hQ;Gk%pD6=J&+lkp!5>C~pWEzqH$82uhc+DI3_3EP~Ih9%Qg z?LCJuX6iy@-*g#fuY5Il8L~d8cID>o@)*S&}>2NpiLF$lXGhuC;2u z#veAS|9EDznj1QdU3U%f6503H=7JWS+FsiF+rLEaVO7Nsxuk!yy;k`vrq-#Sfjsg_ zfV{o=Ji_y*bH>)Oxg#Rc#e z=!q(>@%n>g3};CqV072FlusmL@~B#cp~k!2`Qr3f^ZNOG=ODhM$1BJEQEIYk1S8&4bk`exHm7@Z$|)o6@5$M-nbJdG8ye*(>~v{5yO5-fJ`bIhabb zU&@f?AEvbj^TFjd>jdUT>n0)WzT~hoXa(!?hhkUu6vlM?GiTQZNkNX$H}>lRl_A>* zfk$Dn^lSw~A`gkH`7%lOhDvWDD0lCxuwylsR_amSE^7y-=du#W(*jXPOc2alY@1%B z$3xhO;C)GKcO6h*p(%c`HhJ=H9R@6X<~20Eg;DZYc2=*=GoGLT!7${%v7qQtk&=== zy&vHXVZ_^sp@XwC|7$bI6JIG-0lELvpDLoDV}Mo9x~20T)Q|EN@2u_5PtYLIsQRkx(fauj zGXzq~&la^Fl3xljjMf#&i#mSwNb?j@$P%QYIzH}x&$t~2E&+!LxKN3FRuE{K`3M{& zJOToJhX#RYAV5+$|7vLwyD1=}i11RidCn1JZ=UCaKqbZ?VO*N{HmOh-DMo7$Xoi60 zPMzO%&caz*S~{)!_iYC|M0gMlZqUWZcu*~U`ayg&0bf!cV{G_z%S7nS%}rZd8#_?` zQ3EY4YJOhpOG{?;%Tvrws#P2nU0rXdy6;bc3z%4(2H+s*36q;*4BUk-np&qnDSLxw(1UJFbp42ndb&+Fu~7X;!QD;{6To$F}qM~B0)8ios5zh=HaNUo_4%k<< zos>0NF1iRh9?uk}bJ z4*b169OeCL?|EF9oaOy=JTNezT&`lh*_8=B@+Q5yGEJ1J@3z!0SXEVu5~B0Og5{fn&a8x+0bagr;@xpKNUKMR?q95 z-|RL<1cR6K8Vw;|>DB8B9FZ(=eCT8IJ`al>dZ+gDTod$k5>91rOP+mT!a>{3ji*ut z9|>mi*0$psy3+D!Op5&GAl-H*R8`k2QAPNJDCg3ObM<7tyt?bjLSqila@$YLOirA( zXbeUs%Hnk{n>Jgk(TDhep!@XPT*6P+$E)p7tW?c8l54oTyF1Ew^YJu})OYiU6p*mi zzY)3@)a!6v^vRm)JG3yZ7Gv@s|DxL`R@y|`SKZzXU66E$7-gKySqd2?P0ryU@eSIszKhde=|w+Hazx&xohsskf=^Oz8VO>CHHn1lE9(Z^>e?34`yYX4 zUq`SG4bU>DflOsF(^1qU6E$^7X(=G>XwE;$#mPxINi;E%q)Y2@Y`51t9%VT?w3eId z&GHxsA1JcUY1JcLuYXikVUE2{KD+7tTLwpC*U9EeyDAJnn~{mBx~xpb(R_Y>o-@62 zHTY<)I7mEeWB%sA9$>3(wbtmqD9W`IRzSp4o3X-fqqD?S(bdgqe{hIOrf`wk*T zkaC>2(DCC5H{JE|+nNBsWy;gG+kzc=n?bzSrn-=hkWa7nC^?M$`=CtSH_g6(cMjWt@CCmykyr^s#W0>#o z9(on2438!@13_Y%eV$$5K-I=!Yfk2$KFZY} z$SUe)45I!;(~&t~!XqJiR$UI`7z-dG?bhKa*>f;rW3g{0DixWQkt0SAHVzq1Bxax( zR#I$}y@m0{5uD{Rw)Dq=*D3FdqmUo; z2dd*lwCT-$00bC__tPL^<9_%w4plV_`rI#$Z5Ur5J~Uu@^k)h~C1^;++J${<*ZM<3 z>>yljT=wabv$yf_!xj4;LeO^!ND7IIURq0^=(X9gOhUqAi{HQ~ViVY0RfiWGT{ zdj<9Ko-4f^Rojp)q+~FDU))?+&?K>3IXOkb+Y9EJM z4*nt0&+x%hO^8?_BJ)Y5+D}Xi`qm$T4K@Ph#-BzaIs5%?u+q)KSvh|i7H1OKn}_oJYrqZfDoo4=ZFf5Q1OE;=t%ec4Q2Ts((n8UgqF zN6;h-@~re!E}X{;t61LY(eM37$sbeyfb!|;ujos=Ap3@Y=7W%oS?0|?-f(HPRmh89 z2}6v))0Pun9Wj?>c?i5ehPEqGb=y=B5`cdweFG8g&msS|DpCW+$r3BlE0_;z{1hyS zP*#>}sPgq#RT5eyHWyfk%IH)igW$R`m3UZio&SfZv}2cW0M7fw>$bRb`FG607wl69trPYlsjwgD{t)JV z^VF42xRkwwK)gx$RE=Osb+rQUJZ{!M*WCN#zSTTVzf8XMjSOpI6&j@_>9`L0(T{MP zl3p}vf_?KA`PpzaJzI^rKq@*q1H@Wo+%`w^hw(TDpM~f9v>CUFabO^c(fY!Hi{~CB zu@pl*K06Nv-7viK&3^qjvXu*e>#Un@VIU^AnlI=H&>0nO9zg!~rrLVETkpGhZYypJ zGSc|y#7r<(Xce&~xI^G_xRtP&CiyV&0M}ci-G1=>aOWxog2y4a4+wxKk+@E>YjT|B zuV%LRQT>AxcM3<_Knj#7!8*jvX2g$0l?;t-ca+!&O`2k|(6rMR_{Z3bkd-%?duxEZ zgiEIErhKjsJI-sdsjyKAeR_Caz2|(I#{0*2po(0yjIpovzgiX7=OXIj!h8(pD>G4% zVx7dc7kmCy>k|GS>j2Muxkx==ySSQd*C1U&L-?TT3jp5-zH%;PU3a@oMQ(i9K*&yc ze&ekS2k_G0dE0>8`47wiLXy1?fA|~oVtJi`O8eieV1se{^$Zp~Zbq8*d_DsI;2Je$ z{!E~rVO)@K(-ZW;H~L!zih%cA2t2eD|Ase6qgb+n)R-*BpnIgYcv&T|w*OP{)00tr&d8 zQ6JbOId-|@kJrO}@-4(X|M1d_dh_;a?_2D?IDC*%kA(k_rNnIlj-O{yKZcKCC62OWnpQ?odfyh- zw1!|5g^ioURwKpo?N-z?Y*L75Th%g5sU;j$4cCB zDbFs~NCPxB-}Uf(h|8lgiXyTzI~*MIo9OqnF^&OFol}w9-{<>5S9T#mKq{6HigHha zAs(Bhb0ZMJocmxy=9B2qO6B3{~yB7c5-Ltfwd7=}+@!goNC2|3?^tJ#9xrOvWnrzO_Fk%-Dx)Wj2uc8q>ed zex3XO$oj_UN`r0Nq+?qh+crA3ZKq?~*&W-qZQHhO+xE*j_x*Txyq|lIsxiL8nrki= z%9{c|ETOAzRH5z# zoRw}W^-;EYd$HO{cK#9QzxyFj1^PazPZ{JNN93164R`0mr?Z4VBX>6$dS?!HzwK%! z%M7Y17ITDtE`T6{B~+`Chi*9i-A5LBeOjt=iD34Ri3K`Tdyutyl$d@IZR1*%ZYuLl zkVZ@Xry77`$KAnG>7OLMFpcGVJv|BeR!?smf8y6GSgwDSZB)p&Y-P^7j3?_D@0Q!N zcy*Z1g!L&=e2Vk%mki1OOL*)rXLyjezU;+1rJAjMi+?BJKzQ33*>GGe(Ix=e7AJtG z2=_KDeJMmXvzcu1)Qvi~jxCh14(A4)@mP_4xc^FRkJ+c-u*{bHL!*#QVTP9xtP9G| zjs^@NI=r(e5#W4YcCmp;b%oKFfEK_)Mj4NMYiD8X(i?2Bfy!GYA^HADpKfq0(Dq@tST;gRDeZD!3^dB&@_xsU8g&pFL zikat?`Ir9#KBzPryyHCi>W}BqTI@I${jQZjiU9C{;o5_$)FWz9GhOb3uSs4|I9MQ@ z_w-Nopbh&}iGCz5n>$eAW*O#L&J*+>NXa3kCTx~wJVTxMVLh%4bxuJVlwvbLqS6Eu zf+MbEm_7`H>gzjznxS2I;TiJ(TvP8$qRqKf_iRpoYPQvM9s?)HA9Qr94>re3F>(gH zy&PVz%Qb-h&vwXA$n!GMXA}NCBoo`j;^PASSzO01*;Odm>kk#`Ur+mXfgQd8Rs5-n!Q>WYoh^s_{pI{V+jZ`F(X3S-__HAK88IUCUHDD8cJEc%8i< z0AhvLs(C=Dr-OjcAj6|&@CJ(|jxL_}ufAobQ2~Esvf>N#8(f>P$P{>1Fu=!D>nrhM z`xyv}O~r4QQQ^-FBrI?L!=(5uHTaf5O-*R}MK1QNn@vt$ulJ=OFyh5#S?2x3#HA1@ z2Xq-<3=1ugk5^Yz0LR-??frJU;q%=CfRJnU*i2m8?MO-rm+>0!*;!UBuP(}*+)tE> zm~6zpVJ1XOn&}PE+fN>5+RmJEhN@_p^Iw9m@9cRLrYE?kMH~j*oKN=k#ecI3BOd576N-@r(JVU$m9XO?8ah98tYsFN1*kyc2_w5X&!!zM%lubWi4e= zZxJ`E*x;gdA^6V5SiMOz902tPOhckH+hjdHnHPb(x}6Rc!DWlwTtfcS1P|~jCi?4> z>LMEYw&-sS_?}RDZm$2aM5}%mCK`!R|Hu$O7nqQkv=Z!A^BEfbwYB##^K@i9Y%-k6 zE)Hr>2vh)zvY4uxhN^0cIqv<5%W;@Y)RZGCP$TR=eY0C8?-GwPnZ{E9%(W%N`qgI- zW2^k@W@wOt2^bdyB?tj#5+Tf3gJV$n_gCw&Tz1R#ni)O4A}wCE*b;#;P(VQf^EPIF zvHg9sQPwxNWc?7|U{Qxng^yJia;AR*Fk(cIQ5Ami_nOF>EAM@WcZ2sK+3( z;Bsuf{Ug7C+NsAe-=$aMHR|yOFs_QoACF9~DtC}F{IW8v62K5a72opbo05qymBN+P zBIji3l=pu3{|quf6dZz6m`mS8De5nImUCOOdHi9_9g34107W=S?1G;y`C&@evMgSn z8C_2ifPMRE?BGpo_;zww1#N}0RD}vv#}&)}EbP~CTq>!Bhvi)W`%f9!4$O6ZyAJ(g zqb{4W3ZwR)R{6nNObNoD4Pp?c)??vSUBj`4U&?s6e3@&%l*$ew{yCg!3I!d_5=8== zp9Q880|FvysZKAGD2G6ff33^DKC!&8Wj~Z1{tc61^)9inh?Okv(TAo4iFxH38!!yq z66`qDSK8^H?^PZvGx zPK||&!azxnbom^XQuPP4pHajUd=N@M6!Q|0b<p*IsycZ>iP6}kYN3E)a$hv1=8rq;fWy%;z6c|AA*EKdrkoyu69#?ZE0m%3jMUTr-TYM9bxbqk_5tsaWP zKUqpKwNZXV!VcIBO36eufmEA(0XJl!Iq+<~@4;mV_p6SzqquikY=1f$H;qSl9Np~j zRWnKUz|s&!l+?fPXJ!m~XWZ#VF-ms7Se^_0_6dBpHA43N&4X!tFdty)!Wuzzf7&2) zqQZpsH`|laiv@4?-$mN?cw-5H`nd2)K`HsnBd)LeU`=Kx&YtgSR} zuX=Vt2t7}1_a8{LO~)e6AB<8!qjra_g?fu;b&`hIoXz19&X+0HuY3HUDS+k2H|H=3 z2;FKq2=>YinIGo%js>9eUEhgmetL!T&7p_Lu($O8_%pf(XTFMFZe)rHH0hE!)}o+f zE<_ukMQO>MG$)Z7JMPI99BWf0Ib*+k@{}p#)%Qj6XKjvM-68p5wPZbXId_U4{Z#tt zQcJd-`W$m87hY!u2sb)n*9OE+CkEQZE_@@&y!ssLsBM!Sh_`zcY`$Jax$DEW>pD<3OJ zK)64(%wQW8hk#RI>Elg0bL7F;gc&`gdqHc<93zN|&GB!qWa?Xm-|P@+Q`5Q8yv@TR z%kxv2jSpAz?b^4ENjBv_x@z?AlpDH}#@!DFI7PyXO?}gOhsctE%OoG0*4;efH*T^; z&IFc!4w%f(kS}LKIq`CijGypdG?@=g@yW0^5a2%s0ZwT5V8py}Q5sP5*!4IBujf*I z?X2KGANhwr(Dg`q?w!)Uh%zMrqI5h=T{>i1D}2O7Q-38g$wq-e2?*Z4@OS2Qdi!Dl zdcN^l{8G_c#m?OaD}VdwXM#^qkd=zY@4>X)lF7+=C7bDuE0kj&U-gaK+~;g^HBiC^ z3@LDO0j6cdY-a0}<#Un#x}5gDN*Om?0DXypV5C9{?7FW99uQNR@!TlVMFQ}@ zt_7w|pS*=;Z#tlu@ta#jAXs@?kRQVz_@97&&yc8GAN-puN#1<%o*+i#Rm}nr zKz6?I9XQ1*0!qOWgL#!EQK#QTkIO?2N2iuzrQ}7!RFFi0`$2ZWQq4iK0}%GoWp%{5ZWr_Hf^ew z$D4j#HlIbp3**ucQR+H(z!B!NI!@Jw#@BmHB)ztFLvw5`X`LZ<^=!Kk2OJIC3?^s1 zaZA;<7SfK~$`$q?Fr+*TKh()FPx!L7l<*|cz$dL)bbSG zWQNk@m^@es=}6sgt~+B|#O~l+^g!MOGy{IS{?Ke`=a(*vyU6)O4T^jBD3Lo(tFeY-JERqT(FSnDCNj?5ThfyfVplCH6zu1|$aR`mQA0Z)(+;es0ovuA!d| zTHfd)k$XD7ivF>xdqDF3h)}(Y_w#5~!s=fOc1<4C?AXZ)I9gMLQn4RZOAk~Tdimkn1!gyVAi2u9Rbt$up_ zoj0jKKuN6lUCJ}-A@cr9$jT3kDqHY|PZ}R#0DgTYxA&bdad2A<(2wQWTV8Nxyxlu7 ztP+sBdN~@a{jJI)o4nco;N1`KUk2d-9k`KY?YwR}{WczpI23A~@S@Y~IWgu2#YOQjb_6#si_-FIMgz=2c>3NMJNzsmxJB>)VkIU|pTduT8aX^RyTj5qzJXGmXwXpx>cs#dO%FH$0*$2f7Zf&nltN}^aQ)Re12(B{IbJvYRLS`uB^bqjg-(iI-7x%-3p|=hVWn}%3Tcc zzd$ZH(OPUFy`fqK-O z%}Dc|p*eYVE1@ELxm|aizt7{v1uyBw&Ne}MV_gwYDd(!Y_`w3w) zu_me0L$qPz9r$iLN``_)mGvP zs^cO+3*2*cc6<_7FsH*L74xt(4l6LX&WzZ;q2LI*t!&XWYfjau>eOX3KZ}w!hGoq$ ztMCugqzFZ?wJ&Oc76!4MbZ>sgnDnj==pmuw^0a=PEFVT}n?2L*Pk~Eek$;!;THinM z6+@VOz+w0(7>h8m5X?!v_}1B4odqk$#r1Rhtg&+=)7viv9yj9(>XoF`eV69;_UQ0y z`;0AVy?W<-8wnZqvl;lUJGNA;d^c2PQSW#SN6%F!O>H_&i?P+&J?RCdtBfUkK;x*3 z25(YqjD;!3+1jjV6hYrZQGO?dfW)77pr`X1z}sNpfY}Oqv6^~=oK-}nS?M>|AwaA zzg49!?-IHBMYi=ETC&bj;270cM!Yt6YwNdW+{irBC8%%kpKp zW?2&n(P$X?moI;vA)xi0t6GJ*lilj}E;{4}0b0r9!`Po`E?dtl+&fCY7;@!!7^T7q z_WYtpa>&8f{<8b{vrF)WMZ?M}``d}M`Y}a+q_~VGDKNK;F5HvtOhWthRrg10P zz5ck17q>oz(ebDPZLDMuTmkI~BWq|jWfkh$@k=qjp_J^lxuT-6a zYpnZ-8$jXXmD>+d8izPVSQ?vo+@7&ELS3T5<%WO2`P2HWg}c5>;InG=rT+ack_fon3_OsC`06+p3%lZV;`t&i(n#OP)GcYN1V!`^9? zX%mlQsC#g&M3ST|FZS&P;E&peb~5pMd=ul?7+w8W5RM@o$LBCXm?(TTY#7`LcRL@h zsRXM90gmAFz);8j5QU4S%RlTxxvD6{p}1se!KzG91Z!3GD;HW6i7>TKeb5pR$&EIA zD?nTKp1TiIs(3=JU4ReD|ri)XP{n82u*D#d1dfe#i#wCJFJJlmW=7ab;M@I zULvW2OH5`F4ZErABgL(zbVm(3kk5?a-nv*QM1A)B-p9zviMWW4laP?Njz8^Kk(0|$ zGHGKy-=7Ngv78pr+9#|BLIrmL!I1lyFM!-bbJX0mPXg~dcdEikb_e%7tB4`-JS>-Y z8{t%ffp~BT04=>Tf5nLpJzau_Z92lxQBo5^MI+Ll)jfi^Efl>j+1#dYx=$X-BTS2e zC;U4%u#X{@*rKkw4%)}Sb^cn1lVQd~NvSWOpvbbB%#>ca)!MV2CX>(Ss0f5>6kuJX zwh?v}{>62*{~)&u)1u(kdgiqm`L;!^N3y_3KMB7=l8tm(rU50zugcwMtDA1=ICE^P z#Pj^fjvM8;`%rifM=K-7*Rmc#!N0%DJb8Em{JQziRqu_CFs=2@qf@Uke6iDxv;zue zE_t9bBnzX{dQgwiSI3M9H!(J)6Tr!7DG~9`%`7#aQdQRd?Xe@YZi<}c^)mcxA*kd^RP&_O~0l*)X15ckei(^0RT~M0(P@p zWnl}i@iKai?G5ghk2-$e5YOesL}9x!fLzwhcbGW~#`+uH1Fg$pgduusRxkVGk+=uJ zCf>^vL21p+bu?lJN1g|o7@eaFKrQf>M%!ldbW~2Tfx?4Jy=ORinE(!|4i5*!j+n+xX zxgJbze74@|v`7*<+#1W$=m2-!cJX?)P)hrk6cm3rd0qmE+jO0G_FyHw(eDRrxP?KK z!swWZyn@J{EFE_>5AxxeIG&Ix9G2!SA!xk|ID8G5L>KDfQD-s}0%WRZ$i4Xn5Z&KpBe%VUNgjb;#Pr|ch|36AvD{m zqWI|_2JxXwBTJRFyr3y=qnD@Io_gLFDvhrl;pbRuhz-`+&Jc2D&yVfi>;-B4_rMqY zHckpjD&(YYCw16i0hQEo`pQqypzxw1eGo@%`PGb-pi|;iao0kPQ$>Yz@jjj?1R8SY zB2))7zZ%x;<~I^8Op-+GFNJ(XEC}ne@>}hYpvAhO-8tH3tCK-5;`KNP7~fGMPdba8 zRw^e=$eNL9Fz*#>FsU3TCgwW1owjPAT+Wiy92_t^i+#wa03k39%#GZYtJ1c%-lqyV zU3~RH#2mqmR~bF4*j`jhXH9^q62&KL3V8ZW%34xa6PzI6mW>;mZ3yyo`aW`0Yd+7jKRz?#9 zk7+8WINw{c+|x2cY7>JXxsV8tj33{3?Lj{~#FmOd3?{urNh1k7?+xZu;3NIINUxs^ z-hp*?JUqo{`SIs>Pz16*-c_^7r+^*`0ZMpwV73;p@oa2qSDcQTP^(xTyyhaKRlKD< zSpr=FeT-*(OOZ%rclouO1+PA|M!qVSjA@3K!Do%T4f z|FQ~a_L_Z;Fm3K8%s1+B+#e(L3M%btO6o51=cUP-Lr``K_L}0yNM4vU=zSdyeB+KP;&^xO;xDGSQy~?RdUYnX}{G8V>651Z;Umwrzh=OVJI1`~P;$>)6 zMWRkUU{L?S)?~tIJBiF|0m*CO7nv(6!%5$@tH zJ+jvhd#Y;65J97?LL{chlTL-9Ejs`Qqou)aH+wmq?vINh0(UEn#K-4BX@{`Du*8Hk zPu|U5&RzCZeEJ#0XQ5z~h}S8t=d+pudJIQn{6IxStrW>fZ3OmL^-j4Q({C}geb3W` zpjfd~C=)}y*Pkl?nfFA(d2UX6c3!{z$v|up3LxY{;O-6GO}O7BTyUa5mg3%xa^nr- zUp7zARoI5h=I?A`>PPNR=?sV@y0os~qUXT`<{r14F1 zViK(;su#KuyzQvkDIEb#j1UV6p4d>P6W$_XUU0E*It25KU9Gu@{)uzc3<@@BNYsnN z)QM2xBtlyxG-IP1Rhw+EUt`a3)^9!??B)1t&ezBAZ8aZq|TDI~3sv+o!7<|H4; zAvlPHWI?ZVy$U8?g;10uUnmoheLCbe{KFkEG>>2jIASbYofTs> zVuW0tNWwG9Mk-D}TvK29#hWu%&AqY-Gd1_D3J<^v_$&VeH76Wlc8?Oj0rJspI5@k+=MYJVCn4n2vqnnNK}%|vUMCTs{kg$J%8o&2NB?)2sDfx%gWa(rQ8&+WFCnS+t1vNPT_#O^jbBlA?i>3Mw ztBta}u2*<#%mYqbFhrjrIdp^AXj$$E!z@WeI$}wYV=iG2FiUMdNGUn9vX>fnZpd&p zc*>-qs{f50+0Wj}hP2=js2k_cC_A^m|GD;CM}mt)ia;klE_0$1H|#G5{!#(+X@q_p zzrB5ziX7)xRzzWnDcXt=lbKR#t+Fi}y5?`%#}j%h?07W|b$KH*yjnf3B&#HaKJqIz zYlSFYiC>yCfU^c1=7c^w+q$n>(}tu8Rf!e~o6Rg-ts86Z(Do5&qt3>`HX@1yei;LS z&fS@s7TGnLo8@lno&~ElaBF)_fe_G0Y%01{pte3-^+`XI@vk!7iXw9V_k3HeFN+DQ zeNeB&%(pGJuJ*)CJBzN+Usd6MW=yl^Ibj0!G>&V-0ZBKm5m*+^Vs7tXSjumm=p0l6 zmJ%$B-=Ja=t^)dL+MS#k_T=Yvl4)h0F!%O>_qaH)Y*U$8BX&xLY%jfD8S@y=S1n|f z0nkQWseRVte>IVI2oZi!F*NMgFgvNQ|1P%}-=h6&fZXOER*bIqyZ3|fH~UV8KT+`n z$~0JQ1(>=Xr6#h#e+e%uUUayha4S?1mYCpZ18km*%)W2BPS9fMY)=9&` z%R>xGlF@&c9`bs*l3JY^y|dTFM7AB@3w4eVQ2fNz=p71=5JtVyT7lhZ-#v#6t&lSo zHQUjYxr&I@frH-D=h2++TN$Q1>0Z;v8^0QWW5aA1ox!<+CkA);W~l9&yyuXG?0Ilr z0r=?er+qoSj1lK7T^0q|~NXGrjl~%I(HZ5lz0zwe-3*IaH5shwsepr;47+UlMGG1E!&Rwvj ztsoY@_i~tYrR-$34W96>|C{BW-m1e=Y}MtO)sBct{%3?Qqf z!t|UxHJm5);Q$A2N@HxSpey0kCn7~^R2nJ>(&CC1K^tL8c>juEIJy~Ei}dg)ys0GY zJTrGdQCThClnqn5NKgk)_9=K*SVc|9RZ50D1E{=-q&{tLsas6%Vzs4b6A)Zn|H7y3 z`T%&+5PRl4-XgU94TVs)si)WQ1Q0Q01$8VIcd+(b?0FQd0nWCH4vxB2`%H-?iTOBl@Q zzqfwUIL!1O7jSw?jp9;Vwm53vvLVIv_bmKy!hGKM3}krCgKD~$b))oswRtA2grYEy zcWg;rZFvPzr?}^JU$~4F4q$osFrKqwxot#%H>-bj5;HyyZqmZ)a33v5Lpo@pJet~V zi+Dw>l2Za{+edn+BrUF`33X+Cf}gte^tPvp^Ef}!X!+>^E<*EcxN;dyFg`B-Ic>bc z8fN%tbmWFWiZr}E%BM}fb@mV~fI9je8ku-8?i74te{}n?Wd_<62e7CY$h_jY=KBIX zWiyj=H_^p9Sblj~DQ7hegP!*f*Q~oowdr7QH+qjvad`|Y4{6= z;zO9@!wTw;4AAaOdi6t2itT9*NM z+W%$`ByO&9vkY2)Zc)VEcKxEh2zzc>5=|J@%TsT*1y^`Z-fIs;s9*y{=;!oInL(jZ4dP|}&?W8X7Vn&8#F z<-Nc^MWPo+0ip$C?61l9)^$!uf2&#&GlRT8<4m0O!c8(a^R*qr%3!@CSIjoHhwGKw zQAXDZA~;t}KKUwpneVujWY@2Wp2?j*W2dvJ1s&|GN_nN{tJ(KOdF-7j$&u(t zU&&U7^+#qmM|+X-HhD>{Gyd3BNIFuV@^-c}yLjiq07spJx}=-wf_MFHPWtX^(EQR6 z35h8QAPM=n#}Z~Lq4-h1_>KG3J`fTdrY5baLUhKm192JQHb%v4px6Z}2m2C+D5t*w z@lXA6aoIy+)<}Bhom$Q-IAlYm1dB#RtSn^E+#DLoGD*s53qNAiGh+PBXsulpccer{ z)>w!*z;=I_hm(-0x%Xv{1~_UPNhLmM7VAHdq6j??7JZ!6dJR?J^{J{H>w~uqVI5== zfjpm1U&T0`)UIi`S>qOm{eNE*1T}>-@9MAhUya9 zI0FJiJWMkqrxh-_CkQLU+Aps~&76t>#q#R|PU&Hsy<5wcV#T;7Z7mxKuS>&GxeZ!_ z>Jz**BRaY@y)CL*JVB)v?mj#PpGM>C!l5^xNe!hf5td|g9Ez$E#--Z^Z3bFh6(Ed# zKutqq+nlm^0>7q>MbuDmJY#BY>g_HaPAEJxWu?Z_ga-~Pspff>hf5pn<{3#+E?t7$ zeu@t@efNkmaGYX#IOH=BbrOLj#gk-}1T~c9VTs!ij!vdlX}JWYbZpM;hC>Fms)?~# z-Ml~@`B@P~_lQ1K6-{&E@{tyA>+r`AfOh5>de9treovspbe64zL znDGQ?^p|S6%Th=G;#19yLVrDz^p7= z!s$m*S=W-;zByf6^fpnJ32u{!Ie39M0X4gk?b}T>ozevz%kcNgJeeShk0^@n5CYD3 zd9+c-;*|xOM79%!$6@y{-|W-DP77Q3suf$>P&7WvVPaJFzliv6h)K4pi~qm>2OG;z z>+%0QG!mb*LJMGF`d{r~E7gBO5Nc~(Nb%a0b4lmc*NtqUmX(^rWtpm#i_n8*kS)H@ zicO$>zr|PlM$%#qqyz~FF9Ku`|Dwq&+m&isU;61(IBT}A$~LFEv}LZGe@_E!EVPO< zPrs*mzT<;=ppLWdJGb9Ew;hNG$Ye=C0l$FTEluU^_;>nnwS@fh+Dy3w? z4l&f)u8B98L9gD65p706n-|9aSQ9meaDVo1;j2PjlZQarZcla}Z;y71Z3b?Kg1uaJ zneztN{URg?@N?)T?RD;5MxfWd8}YK*>kWj#cr7Y(m`k+3{k{5AlU@-cay(*F2^je} zurSsRv%>p|p_G$UAsts@2{&Fpa7ZQ7rBkAaKVaI<+0nuNwLE@Qjj%zeMK2dyEJix& z$D9|Rz*q-l9Kj<(3y?1omq{l5d=Wv9PeU$Wpioj;2sf51Gge?~l*G#)NIzI*bU^E_ z5ig1>CZ}Gs_|Pa)9^aeGS7f?k*i z;>K4goBv%gtjYe4#$^4;a@wlW3{5sJh5qBc?lpi%LY z3llch>vF45=2QqF7^Ins{2cx$Qs?BZt?XeHr+vwpYQ(M^s351A(QgJhTbhMWx%SeT*KSr9dq zLK@>pKbHh$YanxAGXOyVX&y4ICAcM7A2KOLc0+7}=m^m<6e0v{Kxm+UfXR^a7P2<# zhV&z(7!qLk=az-nmYCO`8Gs}Xy6f1CxE^vj08bPEN$P^!9?EyKm(K4+s}D8~dWljb zH{li9o6jXGX!6y4Y*Z54+QGBJl?Md(19-FIo3J~1p)w}jUpjCeh zoF*T^wibqIX&p)D(%!LgAfFo~+KvbiY~{sKpMpUm!mMFaR$jNnzM!1}b^dwIt_}JK zrnaeKrVayHK#4-m%YhjMT`3MEIzD!yT==l1nekH1yq&-UMB` z_6q}tz0>N!O1kdk(k^ZD^ee5%B4i|Bprpj+@J3#4dPZJQu3-VYGg@#Kv=@_0?A$S; z?c*iRN+{N+x-&(9l}IbNzPhTqB<^;~6)FZHO-PIqRYAe~r>L_3(_2U=%onq?c|8Z$ zv73?XL{#ZULa9T3Kl1f~2~swJuM&1j3oe6wv{X+$1c5LPmSxH~D>Iqw{ zvJxu}Yh)UOSbC*{lnbp>-ANs0m8Nb@e&}l=>@n_8s1f_IfQN>QaoTW^)VTxx#}dS! z=*hJ;SQfO1CCxxFVP(F#-w~DaaLzO=>E*PSg=|5dO@JOVvGbXuoU)*u-2>2D!rM7o>H@Pyc;bIRt9Kc0(3S$C3J zWrCV@hKkLkjeq{d>ABh+qyqH z3~&kLA$$zZ4Bo3IIcA8IODIkze>!$K73E=3QmXK8*nAR6L%QO-3&HL@AGJLJmWZ*op8(_?_EOX zx*M6w!ah$Rja1mrcJE+`_tOr95d)ohDe?#v(%%bc-r_E1#AnuJz?=`9W(+a$v_*;C zavUaLVJ*LvmtV&dUpN^79P^8d5n$RpI+}blS@!Kg8}R)3 zJFv4IS|+C|Kk&r)?H2PD{)YItb3d4j_-R}&HX1bQ5Lfba%51zetctvpdVhEgdH-uMUku?f&C7?=D)CF9l`<9@0f2)s_6`J>f$C(?E)a6}rYhC__p%1pKKFfEPpBUF zHFm`H(ljF?{cAOwTQ87A&z0das^+@Nz3YE3Tbf4~&a~;aDTg z0kdK16UsZ6+-=E-%H8hY$A;;$hv>9K=lv{l119Y&hBHDZ!)HvN;45p1gInFi8Fax1nr!0o98OD-wc_QJR`khoqNjwxw5ne>+J z6`GDda0~VF2Bi&a!L!2Pn}9&wobFw!0PTX2_aMRdy!U=)KVmcA<;Y^bocnS%Ds~I@ zy`-b@*q2dSvrD}$A*sS-1D5v(x^?0S!q|I9%X}mLYdOWETcHl)!{~D z$|F3bPh$d+I2FI3@^Av(#S~+Y2-vqcM=z>_x|$aQZU-nO0J+B)_pWH*y~Fk9 zAVkedZ+QIP@MqCx*NRGf)Jhd#Jhlds-%EySp;To8_vco%VC$RH^N0Du%BX~RmSstV zD6R=gPNlKS9CVaFbzBG3=D)FD?9@;^dOo9*A2IyC)vJv~C-4+bxTNmSIR)LOmK98X z%~&)s%`huuPz4mEQWsbaW_UBct5|OJvBQn|M=9Qb1?PzK z7Ee9rAE#5K>?G#x^q@=sMc=TP@ftYrcOzX#mQ&EE;UA1HX1M?y1?`ah*@*C~m*qj> zET!^cnz{g4c0Sw2(x)CIU!aq*eUCFR_s@=bvPYvs19Th$QGA{sWe2Dc2e1@lY79a| zZnG{M_WXK-Je$8YTY)hG67SXQ-6-4-{`M4?ilYx^%r=n=V7?v{T}F#9^$$%I7?I)| z?tSgdGFVi2J-GA_BT1`^StEENN${5ZIC_&(ntxrNsf*e_NmH+fNmz|6k z7H|Ui3Zle~yo7U0r43i0;i6skbiqRGS5PM%GGxeU3e$YV7EDkF6KyB32zhH1W`2Om z^vX%hq?3dPVBw59-Zk8rst3LeDfgYOZH6mEXj1V>oXJVuc(7;J-fQ?JotS$l$ z&6@tgzTpn9rA0A`B#w2!dPCPBfa{7Z4FAc;C?sY`FcqEu9EjNgz-U!2O=jKM@$!IH~Sf+4Ra7 zt%j46q6-6NLv?X2z@NIDX~c|A@f0p-2RX7%!<}W>m}?^s$p8 zZ}VLvb5AF(vHzZvnf=Fng1XER^yGDSr%-@$Uatw2mtudz1 zX3xFi?~;+jYa21xJCS%k(Tnz7|9cXPSuY`+s@uPcHic5qjZsu;D*mOlp>v_e88 zkKSr(&h!zx6_r%hB&|0JZwtO7!=K7wF*5_PZrRJbrX1HxMr-G>AEGpu>9MLAIqM33DjbGpjGEyu z72)5(<8J?s>9#)C%Q+;`pW&VH-Ajpm3PFeeL34zc!vccOj@-X{?Ak#Uaxkk<;R>7! z8pW2cz`dxK4zIKtQw7uj120E5Ct`dLjW^v&FJAx9?O=nRX(e6A=j4n@(95LqA1Z(! zijYy!vTuEd*5o* zBgKjzxa@_ho=>G~R_K+NNXD8D)Q;L4vIT}0Pg7GMms8MBud!`_vbQ@;{dVvcPhlq6 z5{2@)=D=E;*J#j|?o$-6Nn(kw>DU$kqUSfmB8sJ6GWkro&qw~5)+X}_KmZr*3d+tK z28T^&2c)8oL{rihti`j$^+r3`t1&<;@;L#W{CB+1#y#9rEnC-j^PW1u_9c2*jyGVL&{Mm2ON1WtWFbl%?Jur8eM5{GKyN}*ok25JU z&i97-iA1YuADK=+iIA^%e!Gvi)1f4^{7$7S<~Xx3HNOw&AmcRU3-bcgc|WnwfaBHM zI*VDB?;!s_Y@K6wpj)_QPh7F>RBYR}ZQB*=jcwaz#dgKEZ5tKd>i%?ljQ$mSJaezL zCVFy+_TV&1OCM<$pO%UrS(Nqf|2jtc?%5c|s@-q(KZJNQH7qQL9z+}lY04%h#_d`f z(uUu*1LGvEx7`(Vb3SDjd?aM4+Rj?t<$LU;0sE{rx1!dBKCoLFyddP_u9PyaP=Dj+ z7XYORr`rGeAYn+Ggzn9mbFgsB`24K4;94Y+-Ey=}sa2hsT@*9*s__sc3uf)_{i(%3 z`ph4n&SyoRQ-@RH!=sQdT!k68Lwub)Rf0eVua}yQJAX9xM=`zmp1d(Uy7CoaUTlK2 zE;$qg=;nyeHz#s+)qyGAEH-5y7{~D*j(@vAX!YG}L|idAljPiHW65iE;+uG;$jZ7Y ze@)xklyl)Sj}hI4N*aZ}8fU~;p)g#f0YqnkEihpVEKPn*p=r!xDz99zcigf?y@2;{ zp5>=WTb99K#8I$xc^JY^DY1{1tbcl?t1MFq_KN<>$DBREI6iF4Kb5&*Os0L45Cn;nJzkKJjyDjG&MJkrew8GY&90O zt&}CUV}h?HiM!kCAqIbmnqpmE+iDKAJ^e}HiuyiPoDt}Zk5%CmH$)1dG$38C@JQEE zN!`fY2vSGemXe-s{^;WQ>>)@A!-SeeEik6Kg(o}F1cP|kGmjYYAbafKlD!3sChD@1 zkRq@O)CCp7s{r8z21j7T<0E5AV8y1IP3>rTT&wBv*k_7;YT2U%WtDZ*#rhdDnVBnU z{XyrEu1`PE;@@y!l2STPC{STtS5sGieZr+@%P5%0wYp!gY2l0^0s_lz5}+gy*T@uC zh{lLZ4To;)RMa0Zq-zV9?N#}a{~rp={(mWKQt~Pj!12GAm~%8NTvRk#dIltWz=eNA>erG7 zRmU@v#)E@W-71%pBY~A-;i^PO(ZWt7RvT;8TB~np3?W5C6+#jsjY>}O1dq21KeqK3i{+Y}Gj~dzs95e}A?e+He z+wkw|$CRy{Gerp=R>@r(Si9P|T?moi=xCY@5s*@P<&X4wdofphMNt9-G$*LsMe06j4j5&x<`r%yM{`p(gdNAt+jvs!15^ zae%_V6uNMTa_mauEet=kdaZJmatca_b~xQ|ZCp=;QcglO!iJjEZG&QNtb6I03Y(FG zpS}u(j45@2c5)TMh7>aN0x5L}t5(?6ei54V7%O;;GzseW!W&9~GO4_Jsgzjd*{{Ls zj|G7}I(-TnH03SevGe{+PhcahT#dx)?ch7Q|C`|-gMIBSL>~SzSea1#buSTUIHkpG zf?iMV%z`X)X-I}zkuBT8EG%>STlSjt7{wj=1sV1qY=w#l3lEFfL5>QS2p{@C(6v5L zQ>OYKw4M7SzE5V1TAvY4+=8SNVfR{m^+()L03I-&iW>E*_~dGhB8 ze&>68r$J7y&sSdC$<5qUjWNM4ens2;NkVH!-CYd2j9IDdRMNO!1@uSzsYo&RV5JB( z0gSWt%x@rrds~-p)5BK6b~n^Wh@vfb?Gv zG-1-!`iZN*ReG;+oy+4If+(b3?5RRrSFTHmoV6`PUcZo<5%$ZS5esb} zkrAi%n}owmCb#$V&qHgr)t2qtE{y?h3nXm4CHcIK5kgnD`5YIp+nIj<1o~S(DK;lv z%r4Y`9y|+-nnBH{d}qdAc*%3fQ6gywFp`dmn=(+ASs#C{(38;AC;!_L$}0-$lgMCq z!!AR~Jfr_mX!p(*nlbw3+*ued#0Y*I&F zmQ?PI)Xjdi!t3I4&e3(Vb&^k5bo8EUYSMPnJp$&7Q17Vff|xELWsYl1Ckh>idK>v| z`?<$lIb?89>)6qq+>Jt!hpD?;x)pQEKYqr*Q03^BsyyAoY7_bs;xUpWJiH7V4xr`pqz^Qs!|q43$PxOEbFG~)hmDgD-jle{~KlYB#O zt*PJrLA1B(I7t!yh)?_c?AJ>hB^*~?xMq2kfFUk;z=2vTBHYo}0?Ye8KeY*BEPpg>R^4p-dk0a|9Y0RfT0u>k(&P=DcT4p_;8ep2?6+xsTFi$>&QDbXRTGx3h4pu%GNO zJ+T?4<{MZ6F~+OF^cE{_+63by74fj;SNa9C3Gb6k%Yas5@1lJ#Szmq8sy-^h?~~>K z6v{?jIQf5oxp)O$YnRQOxvDj#LFUv5`mrXqn2$Z+5`;_duRfk~$ohliP$q`Zt(ivR0ycw!w6{xI&1|kM8hC6e6s5hfn^k!3y7esl7=9V8~YJuWd zmYz2+$6l3xj2m@oG9p1uK;nl{05dd?KCw)817ZZ^~rc_s75nd5)U;qK&@ z(r9$SA&2|@!2p7`mrw4 zanFeB^J!^0M^tr=PwK@3swaWWtF~=Fr(c8h`fl1?CnnTbwY2c1A7AOzn#u;nf6B)V zdNQgcHA2vDZb(wNpg+ByG&C8SHu~?KHo(XZRk6#{CBsHvpR8&}<6YiX*4a{u{Z$Nf z%V%LjNMXP4r`!wIfB6SwM{%b=KNKh^{GOddN;|22U{6)o?oM8-rJmzK3CNqNkYK42 zu)V+q`7*MkD_2fwr&4g$3S&5}D7^2US7y5&{>z@ER$|buRx@uI+4#r%-lshB~z}WG*%2Z*T{k)L0!bx2-I09IZX zkRQ+=2)*5rhkhfx&j*m(;cfCDVWY37hZY*wSiCg;J?lSnYUrNe%|`BWXLb;-4s)z9 z>j1}_P^x;Xs&#_wlUT<3{0jcve(EKVeR50RIYbqm! zb(TEpg%wJVSKbt_%Jzea6W|bIBzvd1F&IQ6zoO3UD{ikGEC#Sa|AJzNyXYVe7R!E~AC6!03vL%g$fCMJ=tXHQLZBIP-2gw;u#=G1p7#)B1RvvnS6pQj2! zc0pbW3d5kL4e;*HtMt}czm`IaHT8JivwiK3-tMszb=#xHx`u}C6*FGk8x-=s$*4UE zs2be#aI;Pecmi(wk`(d$aZCa*sx87(kss+@c90QD_EV5kHQ>SChjId0eibDKf_?Y) z!zJbYdSS;az5LE+f8I4_;K8sd+4lLkbz-Sla>w$c&(zuMmBtNJ+9-G_3`DPzTer4C z(YMR%W?>SEwb43dl8Mv))Ln@vD0y&FhW)4IK+VwiSPWP#4=c3J_spvJR%g1$L$p@J zDk9tvT~6@Cw_Cplgau^CYzuT9gzl1dEi?0aTrUy-38)*JdCvAzkEh?yx#GT+MWapK z&TG<1OVXo-aPBna+^kuZnA1D>L=PBN){QNz(m`6280w!bWO)#QrT>LlAc;BSVDf9n zjwvK+p9&C6(1^_;{`W^<3-Xm#kBXF>C-7j8B%IunoMMW*wTBE3JK&m;PtC<6bB250F zGfeveHy>u4Hele)e2q|hSpaxk;`{N(!BOB!Fv=q}I1%pii~pY_wI$;$ zFr|K)LKK>VpMe=Qjj1A1YK>o}5#k&n_6aNj~fnwo+k>|3- z*e_yJ|Gyy)bWiYD@NdVS%IwNo#zlho@g_h!h~QN`s*V>%o4T&GD2#eqNx%^lm89wq zJ*eN4MZn!U>KnDRPBmpJ22BQLd2zOF_p~uXq2s(PBHP`<%PC^-VTPJI1lkATS=D{x z(`xwG{!q%$30zy{sd6Q9JvY)fVxhQ(`k$67fQNva;7viFXvN^%eJ@G7YN=vUB#yZ%H}&W-FFH`^d+6Sz zE+1?BQl}_^DGtqnN;YNaPDLY1xdHH>R3zjJLbZJEOEW0QSk#MP8$j*!Y^ycF-qsLijOwYLasL|lIzJYMIuEt~CnnH|qj736SQy`rXh z>e%e7dpshD9GFh!l=X~Gah54=NU|}T3e@-b4yp>z8SRoJW5j)~-tyN{X(E7L5#&wA z*<94MV@$>teGkIx$43qb`v<_(ckqGqt)qUR@$ zQv!W3)`5YDZIzq}(4wA1o)mm74*-TQdm8$_%zf@-P@Z@j?Su~`DA~$UYJ-|Oe9=c{ zba@k?_BRR-fS0bi@0yI;-OC93I)|MZ*2*;ySVS+_7!^S>*-~_17e>ULQp_M29_}Ru( z8Sb|k;r`kmg|iz_DhQ$kvq~ih@l(tCKN!`G_|iEnB6v|XedpwQxOmcVFDzxx%(zh$ z$Vlo1FWef%O8@G;qQFQr0L~O0{J95?MAD_h6AoN!{uBo%{$~>lEvy%A@xzNvx@N`5%Fd^Jobi<@6=Ws;XXrwZv3!d0t?OM#&n3B#Y8r(`u9&SX?%i)A_G6LLOqs zG4s{B=WiN>M(~lyy(Un*uOJ^+Veij|YpzmTe4KU@ISiblxRk!V*u(oOa#eTWR&P(AL(rZqy@SufA-C0DYjE|M?077n#CS&s zJ&8-=EsqCH;F)B8M*?y6GwgORDdvvshY3Fl?~UWq zZOnS{4{2${9BYyfaG%YT_AvvvgAnheF$mN)&g8Uv-*BDuobcVOr7%K5MvIapWL>p1 z>~y%cG{?jMb#XUY4=3v#ZIGT^e{J&UFbs_TM4;TM@hQz>qC@)fL>#x@5K<3nV2da6 z$LePY3|rP2L@(*5Elk)zl1CSa4qQLMz!@+)e0{VozY!ojxVyW;W;YpreT4ivnZKBq znl?(BJdtZ~=H5NSMcF;$9~(Q_C9U#ge;~JehA-d%wkW0^pE3?F_m2-KQqW_9w(n@NmHYn18TMr%n=*o zoJ_OHnWOnl`mmU3Spu1i#hHuJ=c1WdLa`^JO=PihJtGpB4l>fPxlG1o4fT!m&A`R` zWsOP!=7n_ZNm+9Ymb8qKuKr1jZBq)(rGXYIAs#>1wlOrVDIXbFjvQdeiE3 zxo9?%L0j`}qZURTY#no4lM!1BH%6Wey-EAw-1Vk3?V~=;GbR-4MRRBxuBuj zxT3k4*UcWm4oZeYOqOH+npGdI*4FR0g&ep=d)qdQ6({EPg*_PbJho5DyZL-n-&qWQ z-#It?1p2gom@GV%j*wU9DE^Hcqaj8ek+t<%dRzKAfMV2oOV)yYaN;3PLj5PJA^O)f z(5{38!_R~rEA~gJHgfWZeK7YZwML4QDfIRC3HGpB|Le0|wjVBLn4~D#`o#Jck@j!X z38#)d&z9f#>&+Z!^tMdWjohI3Kl>M96Mg3ke~wxHUF_}djEr#u<7joGRQ2f#O*jjE z7U76(L^g#Z1#vVQ+EWvTHDxWqOf9Vc01Upb`bW5bqM2fAk2gihEoGSdJdvMQC^@Sb z@CH|z%^tl+%i8ST<~Py(4Qz1Hu=P=96?FxWls4#5ZYF@8a28b9GKE>S%BC+kEG zj7mNgv(tt*M~auj(%l^zbUFE5SFuW-vTu(egCa3P<`6 zxi`Y(dZ5TtQ43&qP*K{A zWxF0E8FYqGi0Nh8`z+e*e}4R-Fxj_uRzmXR$&T$(DSrH>0trdHAfuy=4nWIIkF6h| zL+ALUmC_Dl!dp2vvU8gW=XlsNVvp&zskeatUp8PY*#$}hi_)O%2%V4|FJ=hAf`AO+ zY34`DM;m^)-zajP=_oMH6o-TQ+|$#B$!DsFk&{+=&#*CjtPwrQ=4m9agrMq}G3z2o zWU^AaQnejMzQAkwaQj~zCjjE3ntJ9J+)k`$4MU+C6 zOgP+%`86BK@lv9~&nk7-1P6-1&Tdvb$6DH3pjrRQul&A6MMRYQ5L81;RbQB|s++Dq ze&fxU^GQC9%#>N)2)1A=rZ6kEG=6LzQ*dO=6b2XG{tB%t1XR9%3{b|8jR6^va%7NS z8L@C>e(FDng#zv7)64wW2(}$nIx3b}zl;f&kClU#2}GiAAnmGtT5(rWn6+c*=w5xB zR+Qhve`b)0TNr`jYe2a1QosZl>O`jeYDUhrwZTp9W*@LW%V7e8NB>aX59MLp2Zyuz zd(c;tb}5&KW+z^f03ZA9A-rX(5b+b(BjrQ7&4+=IaVn0lyK30>xuFcGe8!AHvP9~p z4|RuTiy}dJPN3S*7!b_N3z1kgx>h0LoTz0sxm%sy@2<=ujF8Qi)#3+8(ByL|>>Lx? zphUvy45{_&!Dzz7Ox#rKW_Q!+vy0(PyQ;TG9}`K^!7!(j0Kaeag$}y`4)TBc+pda* zeX=dZ2$|^XY$}W7X~yO8x`Ig>Bi1jVIdMVAp#T?-dCtEy*4^4bGjeu)e?D`_s$vJx!BJs5cr#)kcI7V*O%SqYn#4J zcQ9QOTP)xHl4Iph-n6{u$tj<>|AK;LrcF(o0ld5XUAyP`|J_Ko4hrS^eO1&}w2USE z$Dgf1w{=H5aU#&!=5%pvxBP$(WvCXg(_USjZCie54T#Wuf(4QAVScoskL*qu@Of6o zFfm)-so@-WYg;29I4J<>8v72mI>NP`yAzOt%G#Pdz@Z&-UXzs(Ais@M zx?f1+ls01WODMV0?uS8e3n@3TS+FTczi9W{JD6c`U`3672pX!g9$7* zFl~*ku>OFZAP5z}P*_od<6DJAii1pO8jDwNjTsSnWux$}PmIH42Gd^lwOiKqsB7i^ zyI@yV0;FQzDbrcqaHNLsyuhzEm-kd&i z*!r_t`f%)*7eY7@{-6OBmbRwjwx7Sd)J>*FvKQ98iW z#;09|6YFU#rb9U$)gaQ$&CSe2ur+Yi&rS$YuCKIu5DW^@_(Qc#7^*)+&0DwJ#v1Sm zH{XxtUnB;oEa7P3_dIH!4D~6i51OJwQbnrCa6TyP5^Nv=5i|Rp@q7|$4)QP{TTq5; zUPee>iC#5*IT%Cyhf{oFY4lITF%VB(V^v;s0T*jOP(L}{!yzYZE7mJ%8Wp}b%{>BjeCQ&?1$yFw% zl#vYKQ^W>Eur=INm7KdI!bMMeMEGOAaE)U38KjwZ4m^`TH`B_|@`K8UA& z%d)+ER#(5Zi(-~fRlnpE0X!fMH+;lAd)eMxy>I?>CNn#@we=By3QL-<_7>2ZnurGP zJ3eR|EFibxRikA^OBf!y;!Q}o{YO5dvFwP}h?;wsGxhth${H6@41Eaj|Lmu8fDRrp zMAO{ftup@wHT2(9-s~=0W>dg*Z#dTKr0C^zzv=YGSxV<0KU2Bx1JlogycLBl_L&XslD|A@brIPJ;G2Z^DZ< zor+Z6MMJJFCb*rHJ)J1P5rYXm{2^a}?4SSBYV{o;rY81|xY>zxeTv}2297!(V zkgp{2JA^&B6%|RcA(#{R$5;EGE!@>gVxuuC@0zroWrLnv8o_0Oc(!+;VnOkSgs;bN z$}k%FhPgj|em4lasWsw|7Q34>Ur&N_2ppgjKavP?@%6qPgy2Gp(Mtm&iB>43D@x=vV)oGbGWYZctgKsR^dW@sBs`4g1b<0p{4-li*f?m4|feujwA8KzO!d^2la@#YLUpg7FPMgh`8sW!F z#9)O}=wwP?o(mQ#1nfo!JNS24Q#GTg=Ij!%!}?tYX9HHAs6NBQdl7{u3?9|$Ew|E? z57jf(5lg3l5bO~&W4D|pVCIYTa@i0prYlR`CI`-*l>HC+DA zF}lA>K@}Zu&En6CmrMyT|0al`r+lSvj53IE2jVyYZ548%>+6FuRuK2g)^xhAP^#WW zf$WA=rerVj9m`qegW`(C+np$M1+yA$@`w`I#N(-}YA?_g-8SW;3 zkaz8Y#U4Ob2xGU`^cg|t1lDHm;AiTMud~-gZh&N#ZiiV3SD8@A@Daw1*wX|v_NEIT zw%(!7zT@=xz1fj-nQ)pL=ZM}VHy|PSlQJXgDg{|JUXv@m?*7ZCB$1kTd!yagy8vuT zxm!aA#B5Jza(mR$HGr98mp{7Huwi+s_!w;0*6RD=mS0@^b`z_Q@4WegZfw=kid9 z3GL9GT1H{=8grZs%+p7G_7_R-#0*pa{K`U9`)2W7v;6_SFrcVK;liC0X;Xrg`0>hj z&#Grp*Q(t+e>La1SNpiWG{JGL#|FsEUf)M(J8J}ibg$nikv51EN}`bvv9l4AGEuwK zVLL{xY=1rb{FJ^+sXRa`Qv}-8D6Q%Ybkvqz++jH5*>2(^V8_aDN(-Q=V?R{ckwy`l zTe1xKrWU6R&SE#GsIniGejnYGjDpQp-J#D za(KOK=*bkpowimv>|PJIcGx>TQ$}Nzt~Z-!pL@?W8yuZ2YgStU7XYEbNZKO#htb_` zK96d88EG)&)jGk6jHlyNNO&Dr*QmOhAXGz^AIZVk=o-r?7Q~KFG>{R?oSf&aOHn;I z#;n|rvD5v$ZI?ekA>dFME9kw*85=mO{cynXR#@^{d->)ZuGwR~qcaeTt(+sGUHBIA zC`+iWV-v>d!u_0o2QdD|%`+kN`EN?tdAt94Jab;WKRsAaqLJoCZ)9nuyDp1W4}NLY z+OcT(#=61$Ld}o%r+JjKmYn5;8!_bN!gKqtE@V`tUG;jzw)Tr<#q%|TVxC@-C-NG&l{?b+PFi|tIGf$v?ca#(6 zcQj)Qk%MVSIGwP?$9K1P=XTfHbuiQ8@_n1{q*<8=P^()})@ z$XK$dF#u2Gqh?34idg^ZTxA{6WX))Q?d#Wbqc>+_m(eK>^J)B?K}v~wK?j1*r^qm3 zL%-n<7YmMDYn8R%ckz@(U#oNc&A1ZQ20m$;#i)t3pyWy!k(Z$TxYdTu{u2mR*xddHL-6#jkOnC2LQ?H4ZFtr;mU3=N6G>a05~*H) zo6QTzVl%6R8Lbb0av(iqs#9{^YLHz1g@SvK`$mj>Kl_M;yl7%tR*!ai$ep{MFx-}9 zj=kNP5#n2X|AJygrgb)buw72iSla~Nu4;7L`8%xG@&*XPH11;6xrE&kh_B~YiX$z{JYWtOUqxV+6}AGhyGYMH$u z>^)uhbDLcnzaA{&*km>FJYAB@Ksh6~WndGT>RU>H{VBBXi|b5_9qw&tP+7uY!(8F> zdL5BdTM;5TWD!I|PivjggO;$OUblvUd!G~g12I9()7*|S`Q6l>GWbB(*Jk2n08{ZY zXRi!K0nq^)DLqrjH=|ls&av7#Sn>SzzOSSf#^a#%mSVj2b*9h|%KbEc#K(xi7NEHW z;#G5XcRBK@ES_Y>c`4P<-CWxB6`+z&iBTz+-qjWFW@xU*oxX8nZ; z+R9O#g!}fsOk&yGee^#=GESKWa z0l0tWMWUdkr8otH50TcVuKz@Z>e+hIH4`BTqX!Yz73%0xbY}!$Cs6b~f}0+uR9z5M zM6y(Jp=UKW21SoXGr%!~37`5$&rhCTtkO8to;!Rr&)Exl8;3ooon^7DtB~a}_B}vp z-lNb9V_4wi8isMd1k9?606_z`Z|4SZ7ZtQi=XzVHy&%S1{e{RGQp1U2p-`GV*F(N| zbA-ZnC!cJwXJjUDzCn=xXq7!?NXx06II4uU%o6!iTb8X)I7VAm-tEq`1)WnIcQRJ$ zZiyWW^?oG^^|4W4*YyozRmjlTp{F@*@qg){uf6z33h1$MIX2d&01lLvrx=W%oStTT zZ(kla9>MX6%b{S}z6EE{{UoT5$mYYoqHBMWi`DO>;{b=U%gRTH0X@lPGzTLMHL{v+ zvr>sbB2^-Vcb-~b5qu54QkgNjd33zQRM5TB>m^0vaFf+@+wx$PSav!Op?92eZyqzb zuS(7U*-8JR*?~P0fNHVCWt}arn#M|H$*HL*n42>pLC5b>$&1HvEoH5F@r7~7izu=D zHpD98H?B`RN69WsLM?J_Lg#{IEqN#@q{m9>5zYC6Vq#)X&d-Tr)fX<^doJu({Q=Ki z%5_S`re3{02#vLerFqO=t%U!l-?9+WjpOk6L2*B;-CvOiJ=zl>ldEWMWQ}MF61&Y68Qb zVqPnogEdgXp~-nsz-2&`oJags6{Q8C6F9(?TacyWI?8JF2uFl3+B)g1wyxH%mPg!L zuXDC02)$8}Hpx#mfAwTIT)%Ygyu5$b1}BbDMu;{TdP^(MU&GHhtaq(hGTM*p)JE#t zELyx8d}{k-qU0rnM+J$hQ-@9fu0lzR4U=I$77hX zOph{Z%j-B0fFThqyWBHMUis7GM?Hat|x3KxMp+qI>E3M8pt6 zyFfrzVx3%h8ebQ7jK@x<2Dg+@%t`Cv&a=|<8X?1K_%flUk$}3 z-u9~^2;FR=o-7N%)-hARaXEF^H^}}PFy_=HFDrn?vXu)6h{;U zI;FCu(NMwIO}Zgll#(P73l%+XOw@hd#Krj{%Eb6^ER@>54zXjkJA-iOG0sC26G-sk zKhWOxmqvf1fl2>6B@I8xpojHiZb~Mis!aasNkdeQU-Ao>M6S=p`yw*x_Tiaepo0$Nwc5HjrXQ=6lnbExNF-PW!{p_m`nR4=mp2>e*1~1AEQp0-ot0b zKtWoviS_-wo^nCx{c`=JAx_*HFB%_?1CG|M-4i$!W;QZ@54*FfVIPRQ8~ReyYPkrj zOE(*JD1`{zg5u${qX~qZe7(}J67sQpe0tJj(5dYf<=>qT73>TWdvNvok;zF0@(%nI z3S5qp8Is$FinL+K{XN|M_~y*++P-OAJ`djJiRrD{=M}G5lq5O|lF1FthH$SgAHpjM ziRV{(h*D~}_FtPy5vP}cBx zKJeU4&j`q0L$&6;hV`u!}yyXThPF zl1b)hgQ?9VYw{RgV$(OJ{2zqco_T_l$RcQT4)8UG24Ndf?l+~lhtbS}BxHumn(%7c zv1hkgKY2p=?pR`@tt}pJ@j(5d!`uP-F9;>K%m@yinv)rxtPW5dek!bx-!tGYvW6`Y zR+c@W`~$GrYiu%E7zErII*2)}MJ{g5euK<5J^t|K-UJ4g45WUXqpjTSS>Uq2)H+is zd%G?*+t(8ipkLAjb~Wxz*zlsiDsJCV971j}cm*$-+MSA{ywC54V_Q^nmqh^XDRcH; zbI!01j*YIfATy6}7ZR20l3B)`-@GX4XAmR>CqCgn`G4cmDP{-NoWo_c$2XT;($V-o zLUOvqiu|RN=J%!BEuRsJno5yppD|hKrbUde&Y^scYx^M@ZNA;Z=eO5Mwec9wZa|T| zbz>4a)ZuSMV9w_El$JMbn3oRx#=U`>9CgsAV8L2TXMH^9S1ay4uD;cPsMNqTOsE2P#H9$1;5xQ^En{rt%H~ zvB)|)+nk1^c`qk5K5aDvJ;YV5hMeKq`1M&WMwb@G2@da7t*Li_ZEA@^L_|X2)`u=) zI(J_oNXq>Cc zvGn~8g8Q)_=uJ&UPnBt&Q$6`MzTnKAqjKVTwdb?*0%y7W*VlJPfbiBE5YQ*cJ?XeP z>8N|}2$O)vm%al$x<)v}>~%Z*{zj`+X+$xL&P?UD^HPx0anawF2{;{4T|*PR93sU+ z@2?h2p3npuf7>j^`;lFDzVtJc^eZT%IlQd)CHV#ORxpf!=hnrKycR1`r;i*sC`_eJ zXRvucZw?j8TB$qF*Jg)vHChM={37?9jtfr_@8YL17Lx^ZDBHek;K;~iegQbl4*-d7o{KwgxzMq|r_ zDIh2qRx|-B6se=Vl2H`nl!UGE*m8}_e^{fi~0!P?g(6#7-60Y%)xY6ymsu}#2^8&lz3bgrW57OMGX>9aq9!-h<*br0{4JYH-c|9j;Au+2 z45<$9y`ivyNDgG{Qa(;$T+2^AjocaD8>j$Y)6!nYO;?+%@Ut(m{YZ0B@WwQ*aXgf! z*&m{Qp;!bYPCrpoXK?>k%gmurY`YB;@c0I(cGe)TXc2@aAOdPi5&nbAa3_%Cje9(q zQ#lct8_2!j8?&&_hQ5%%dkNYVRo9qom`c)*tMPe%4Pn{wo6JvS0j=v&o;(cbP}Ex` z{9A`E+^k#&f}V3iRc>6_cihC)HtJ0ivdr9wj`ukE6&3hEH8m!?I;Vzf-qW?7H|GZI zO&ZwOa|W=$E)Ux#P|M)dly%C#r!zKB6{0m-n)k~6X0i`Tht|<8u5-#h=RWwA?i{rm z&$jQa?_4A1E3`Qf1L}ym_Bg!NqcIJZ33FPpVacW)=7Da80PA6ywcN^sLpYr9N(yGP zHLJd*2Gg?$PcHS=spW6!x}4bK6n{AY1=bH$z23>>t><&%jybHTzy)e1Y==^aem zqU=IH+~RbBASR$=+7$Sw@*FOO%^IOa$TJgDN>0*|{}%r>5y;6iPSU5EN^(){9%4DU z23fWQHtpEi!yKk0Bo(0>Gg6DxQczz)UW6~ZXND7(E(PJ5*`pXN5MKllPE|Frt(OZN6_|nG|L#6;LPv0e&8sm zANbZhqiqR<81UscV8a!LG5%C*%FV|c7K3y;nO*x&0v4P0@O{psG0WBxp)T2bDEbGh zR_MM5uTHoH@2);q)bL%>org1!4C1mk4-;5GaLH!wPLW9_x&Y;g9w-rx95sBe2$P8v zJgX$6Anf`UJGsj0Bxa3iLTr&PEtXY8hD{wqtN>>GKZTvsUnSrch9}PCCfoMZ&O1%E zCfhY>vfDM;wr$&*?44_8+mq|eRHXyZAJs_udTEy$@M zpcSUaxZ^$Jwq{cZ2KuEWzn1K7l2atBk(!)SzmcO%dbM@BrzHzPi@95a9<)t-Ac)e= zeX=nxQY?d@+LZ2l+Ozm20^3sn3k(D0o;zX0xI6Knj$n%#fjxE{+pj;hF)sT0F#E(v zB@Kyy26(QQI9&sPgois>m@x`3BmzMP`Ob|ITE&=Kys1NVid9pczDUfX1GC_szh`>f zAqf8Zc6)80AJ?suz9OnLAi7i!Z>lY#BAkLGtX3@pT4U2(<+8+abFmY#U|@g@BBHhx zv!yAdcGJ1jN9Dt*AKzPxrZAMCZ;*ncCm-t7Mrzw^YI%G&GO$r&1}NgvttWF*D^-vb zo?;WV0#9E%o@TA1Tf!vIMSRSw0m{XQ;t3|Xgac&1zr0$zf62ZDF-0#^w2Tv`I$rrr zE`B0nThXL>Jc|_TGJbO#%Z;OR91cJsOfCN88bvXOX9{k zXIw5>MgtHyA;?=&_IfHSv&vlT`?#YJUo@b5x3uc^O(vy`#7%ecnPhaz=}!avR*dc! z^`Glc=w^Jfq-P01o4S5aHqZvy2xa*4Tjm{)EftG2^8GPGtiH^bu>o+O8b&qu{Ruv; zR#eJwmaV2e-89)6P?C6V1H%osw7qqF2eV*4*Yxu8!CsBNhGDm~KR-Wy z!itiRO`j!Vn_Ymb_NF1-L#(p#6hbT64s8(!NFm)~DOh1!)AF3-)R>S0L^xV=3rf}3 zv^9&Qd#4dy>ivt!uVbI@es@5$*MbfZtEd;_5p#(*bvmGry&f?C+~wnXdbC{TtH*b1 zQ(=0yZx5M*XyEcWzj=hr5|Bgtic>yjh~*kOpco)KDwXtvSqBBEN#kl2p~%6d%0<^B zYPc=g=GHuO4a#NlTv|1MN>0VHfS8$)P(-?TWJ3ynH?|7tt=$pRFFDYCK}bUnN$vQR z=4Maxkd&*tJ4x0EK1ISt;BUb?5dL~3gXG=jb<>3aiba`SW!4H#?p-6Au@1k*-75PY zRWJ5g+jA@3y4Tb}E$8XL?$qJe@4>D3g%S@WzFsKxU-)j-k$S{$5C*1^UQrPR3$+Se zIZVydiR_9}=t&WN7H=D_wX;HdSSijA;0YNVZvonqw21zW`j?r68WJr((t&MvI&*GU zISG?Akl>M(ZE1MlKu$UrapFHy-MBe(g9x)8WzB?Kg6Z(IxM*(r6a2+px7S;ZWhJoy zOx7KHgyBU#9A=K%rsK!sKvoC0u51fCl!wUp?DCA?9~%)PBOgcv#8SjsUEXu2dhbtU zIupnuqbETta2hof4fEio>b;iS@^(S7`lfpybQ91jihJ2^(4UutUeXnd!wqP4Yr_z^JZMn8u7p#x zk9ViKzjs-fWT_%fZ4S`rTo)!?XO%W2x3g~74p|ZJcXzNOqMB>Fn8Xzndbjf`0>_Pm zurO3As0KU49ly?;81K;L4%x05yxeMSH~F|+_CgUbzHt8|Hg*hBD7$KVR#g_)wb`LL z8DM>gNIhYt*fl z!4zw_YmeZ5qEavc;ai(?0SleJKZw zj(_)=^$QP!Zc#-sQ@4&f6d=by&DVY*{81wyhVAo#NOEZH6k$yI>PDRi%BXU24waqA zq8U~|f!O9sv$*5gP?N^=adU6s_fdPxMwKnK4o7BVG>3@{QTbQ%xOlu*@AG{BDw}dO zj+*+qXrgy?*}oX#Ce(_J^wUH?!N{ja!%_*>VnGCd4mJ5Ec_YEHbVhmIcR*i5n*tz( zQb&F2;-3GDd#{DVR_UMt)T#{7V7^=U>>gmyHnzL*r(Z-dW)o!Clf~o->RoLhPuF)2 zz+#lADo2vXNR>T_mo}JXR6A}5uD~OFOQdd6$2pU@@j++{Itcf}Ca|H$P{KKiP<<#) zy_Gsv!n|^xnBu9sU|)j?LE|IBF|$3R=Rs|HIj?5uc>yd-`{adzpn+%9ay{5p-8-Uv zIeBr1d=O>j2{LpnxmutD+_H7vh@uA? zh~!-^2@yjnQ1L>~E$W9ITY8|Td6}}`lhajfk&fx5YyKAN>`cWA0mdRbTE1^RT9G&L zA5I9m`)xU5=tL=qldnrGodWSkgel1@=5_bSu~RcfCtrzf6|;&6SC&@QRnz0iLwCb@ zuQ5|^o;%PSU-K}+T7Hex4MRJZSRs+b(ThoAGz#2R^Hv%7=C|S)BgmjSGdesv%&3^%vlG&@sY^x zpbaEQ-!0Tdb#%BniymGUOq1W2w3CcEoG`q-Tf|i8ECS%dhedEaj<}d2nTW zdFeW(Iv4BtLeuFNfXiVtmp`~pi+$tI>hhEDZ}EuvVMF$CyY0a}W)N6Q^9zf1u~v5Lm!*VM6| zi7H$Z#yV!PgKTww^3AZPRi(pac-5>gJ=fJc?%mzP$C#|hP0|L9 z%1U3hVp|A~WGs{gkp|m$Fy4SfjPne4KVv~N8K~!;hr=X*{C~Ep(1UDTz@FNk`GNWV zUYk>fcT^HH6fiTq@GPJ^$!EA5;r5Ni%CYJP?YK_76rW~wTM)_%dS^0*WnhF(I#)+l zbVSPJfoe&5(0n}vES;@=!dH+Hf+I^1n98hI<|P9j4Km-hC_4aYKxuT6qU zs~*#GQeBl$R$^DBf$+Mms)wIM==tik=JD%W%`u`dT>2ID61(F2vj33B$a@lzIB;}` z#0zcKODOGcMAnmpZ5ezn;>j6j_64YXjuUr_XB~G9YrrPt&pQ67w*5w*RA_*+bhoZS zjs;kl#gh8DpXW6{7MVAAX9BX1pNe+UhqD4(r2cT+Zat3%!1TyYXkzn zZxcToe_tY?A=oJl3#%6m+h3_ga*ZgWhqJmtQIbRZRh1U0+DxMwRI-HB*Z?pXgieD& zE~jq2?^AN@Az@0IGEw6`6}0c#T3hnn;h9;OG6v@q7+-zSij*i%@=x8^h==$*_=bPh zk<}yxqxW&=OY}{Td+85SUW2{>p&A-Ilf5NY=PcRV<&2W!{{G2`3Sn7|cS^i-VaNCV z)&BEMfkITP>uAN_XY6H$mCBLh1l_yt4NSNvvm>5gnTe?^0ry8ZS*n|#RjnHVkrdX< zc{QW5sajPKx&a_N{(D2XpF%>CM$U5t6|kGP8M;F%o*|1;g+NPAqzn=&IHvoJayR)= zXZs_R7tGNL4F=ffv%+a?T=gj2{SvUzEm=+gI+ozSXDrOnfVmXz3l6()Z4LCaLal2Ls z|47f8LV15Ha_sO4pajiI&@8d*G;FTz98(RX6Kdy46sw;i<%KHPE%KEUGXBkhY`i09 zX9DZB%DR;W}pXeH|ewiz|j4INDYoG#?{IH9#DtRV+lBk35 zh*Dkmhi$yh*h|S>c)?EgAdOLo3JuJBTJVk-Q16kD_$l;*#tvztUg(*^3W=`pc!>$P z`QXJ(zO-jaUEdP=HQ`iX>P1pt!X+ShQf^8146$B;nZ49)XDKi}lM48xmYbj!#mv;W z+<}_EJ;hZU0E!UITE^mL#6kK4llT+5Vf^emyTY0xu|ADcMuoPWLf*GO@OM;gK(-ru zS;*rQ*HU(}qqL6#t+R+vLC40@Hc;Nw3f+cId!^)9bowr6egC!8U?%TECRqlF3RxK~ zs%@l@At_-+njnOqMq=#M3*XYo&Fx({IP3nY{{fo`Z(!~ zZc8e|?nUE~c}(Cz~XcrJ#Lgb=F33iw3@$6*YaY zUpJsd*`C!QQ5aszIY=CTaHU)qrSC#@pFY8eR^Z9}0?M4V(Vd{3poK(rsh`?XNOjFg zD4|owP5E%Cr|oeaijr(vr-hjl;b^{78%(Hc2J)(MDa;J~i<2;Se(mmUMxuhw5~Wp4 zr;aV$CoG=imd28~Hv4t-kH~K-M%uZY9VsZ!e)fq7;?fNXHvUPw&7fU*-`uw(t+GN- z*>L3aEcZI4I;)b*R5GPymy4e*b-}faTekJ$PdaXmwr%}@UJ=QP&79?Gt4{>i8=|88 zpFvEU|1j55A>;-v1_=B^RZ3sFcZX1JI9>&XIJF8zdRQiU3*xU-o%}Y8c{B&VTWd+4 z5=#cmp)K5{Egz)f^It7jzT5%Yn6kq$qlm@KbPxK!Igw%X2r!Q-rV6WbiQ2nYW=DQ<+=;d7qIm8}?4^`y&mH7ggirAvMg4sCkc zCqUmwg4n;Y0sgzv&idh{q^d#CLr$fO?Lb}FbsYy;w4E)-@;6Rb-<;gF_xg zfdHt;xrN>7p~7Za1IfrjzY7bK2)fhJVb6#EsA6hf6w%Qu$tpKlaxJOWQ#?DDdw^eG zeRDgU@^+ef%esB*zI=E)xMH&h*+&lVPD1Kgn3$OC>?RJD>4MZNlxCmrZwKzQ)e5Ea z?uov*C=Nq7+%M9)Q*}=EldspIHo%vwp!<7cjauA)iP9s@kS5q;LH_4Yk8@Him`Mv%A1F6UZa}{G z^I!AqveyBjhyb6U94Ag;iH*^R1B#Rj(-&3t%H@@>;|M87{*if2M!v{M;$v&GGjNE@ zGLGIi#)H4j6RA{j$FHUks+292Sz=Z#eG}RHj9f;B4^vdwCYz`wjSuVvf`#$ttb(@} zsU~B~B!Z^I%A^vq3td1mw#8$j({CE5E;L}nc_(+ikY8o_cadSr1XclIdw2!vAw89| ziN$Ol?)d2e(p~BNWne}Qf%VtmG_1yGa{0uSy>00{DeOtS#&DwO6j?Ji@b16Urbd=~ z&KDq9s)!+yfq5|U@V@k>UFgP5j}aN(cIr{@?Xhh0(F#-4Y5^otV{!E%9~3b1K@g&= z=$R?%St-i+f!oKH&GrRp2pccR>Ko=^4E^$t2~tcWs8l>J7%xmpHUymDAQQq`Je%-g z4*g~1N+Pd65r^cg1xp;={z4~JIC5B6h$LT3-W>IS0Bm_&T5FZvBxZa8AL8`@0XYup zTcNkXKaLtzX=2k#oh^-|w z87UF->Jw-$T&N~^rs#`73O zFMog~D<5ci{@zOVjZ8|yGl|d?{ZWIz;&7j6ASBF*h>mKm#8K{!E7NF5L+ zwD4D(1t$7;+$IM=9)5EOZKAv`tuXv2k8X8H6-RpZhQbXZvY(0lErNxt& z&UT&kIqk5zmI z@PQtr`qb?@oOa4y%53{3?NQvSlu@1kV93eF)KE&GO_u=z?@ zN1u+i?v78cjxa5qNNAJ!9M9kuloYA>d;Rlu&pU8WXl`Mg~`4l#jQ z6H}nHX_7Us#b{@{?ljNc;wv%ul0LD*e)V+HQzuw&DYc#^ zcAt0tN7abcdG(U_nG~Hm={MOn^s-9(j1`EP2Ji2>UYzG&=9mG;ms#8bDKGz}0Pk5G zK+@$D=qtrk`8+?qCVWKvfI16mn8hZnEBw^^^{OM4Fx8EyG2mr8IBqZ#3M=iV^jWeA zM*fhmhiAzJA$nl8-@G_K($GY+x0VxXIIn$<=irAR~!#Au7 zMww833ll4j5|M&myyI&)qY4&owRj!6>>KGXCB7fYJ-EIxzu$>L8h3c3vjX32QNtAD zL{m-sEbn>>2YwYDgVV;}szlkKH8??U|Mn6YLL;)EXRA&vR;T*W-}j4eFJ%+R+Jxgs zx&@dC7Jqk2^Cpg^-C{Pm%dIDUQhxmTl&oeQ|7U*jx)kbe_PIM z=BrI<8(W*AK&k670XeOIVnLj$zzNOQyi{`dXYURI0;q%Y8$PvQk-CoNR$N=%W(`ei zuf1&1&Fd&0IC4tt>$@oehpj>THcfx|yE7V6c${_edEu_aME{9PThE%zYz>y&h>u*> zfwL=U1CPUHv|O?&F#Pno*wtZNohV=3H9?Kc)z`hb@_`__jCzVs2vb0ULw`jXz(ap?H<#T!I?B6<+Nvcpare?)Cc z$^y^n*?u%kG)%G#1v!5n8yl!4n}-poqL)Y;kne-DR=v_=Lw!T}pyf9-hq?!lddY1d z**0*>lIFP|XtVIGej&bwZ|G0AAjdS!yUE5GU9F#E(fWE!8zCbl**b zZ}vz@zj*=e&CM!gUEcqOW zq(7qe@#R1cJ48}_rn}n}c5)N^(7jSektAe-PFLAydL7(!& zVl2QEoq?3VGnUmT_mExk1u7sr8jS(O`Ujgq7{pw=L93JtSg9~1!UD5I!tr&JHGcZ{ zZ$51@g_?J~+V3MEgQojy58i*=yXcF_fwdvr;bZnE zlK3b8D@{Kaa<-tWUjJwEY8Jp>QJhCM#@_f|gq0l7O#u`0F*M=UJCd&$;wlsfPzq0y zSP%218lD`h4u;OpjWdyoWS~Ux$s_xIBlRXYhm_=6_O@wn_+fU2=ts)iiKF++-LXA0 zN-<a8`)#Y!VQ!`;=tQ2spR#6@w3WMGa9puZfn(3=tn>^ zc06yCgX}jxY+g}c8n5DaKh4Ed zK6TVBO=dks%}wHl<133e3CvwpRUx4_L)8aMmqKI)WT$0%dk@a>R4qO0bSv3&e9PkH z)(6gB3J7%(6KfMePEJO(5uHD#C&Qe4nj&<6$oB<{swTo^;V$}mI^w5*!dBV=UCIOx z`GJGSWaF0w>{BYiZoKT3DeEz`MWe^><8&8MXLEE>@%G}nY@N5#?UN6^=O`bH9TSh_ zz2xo%kV0x=szNa1mTbu6@1q2!li_3Z*JpJ7$ZeYTb4jztURCB>;Pj*g--!9^J^P1| zZlXiXzIkd!zMm12ca|E+I}69aEsiz$ZdYbW1dBESQtObtF7D=lk+O*+cBDp;Jl_=> z5o1%+$3>`FxfxkN(k+>QA^UDfw$6(uE^Q1Zhkz}=lMvPx$fUu+!P5W2Iuu{&b-}=n z(t0J!5UwK@P*a|mFAp<~kZKM!Z93`4TA{j3gXRp(>U!nkGUNsURI`2MlagDR?FxUo zjsV+w$lI1Ea;jN=R?R0?%BZmJ`YN9zmm9S2G1Psxt0m(;qjBS+)Hvz;`LC-`YctmR zRr~!{E7|fTmD{}eUbJ`Zh8naw(y+43pX(oYV@w_jaZ3<{Zs#AZrWRr&RQ z9Z|Ha2AG8gn}2G_h=Xzyicjx0ZV7Hy3xyDC~hFgcz>TIrB;jQ z%7l*7yiZqW80rYYo37%K>%MqN=BHO^)TVyF4GIw55`8K5F2BEa>y7dfW;jn52S4lb zgpcc3k60~ozm~IEB(R66E}O-0|3tOax^0|-O*%%A!HI+c?Hy7Pf}su(%6AZcU!<6P zU4Jc7(!-P&ErEo8))UAyuSO^INz}QfO#iv}BH~lD>}(VhGY0IX`DFu)&!97e4heU+ zFORcGAQX3>24)d9XxXTnxq{^ z6yY4jvyLgWBmbaw1t|E$;i@K}Q$?+vZfjn=svNf8%zTMFC(fv&oiK=^;i*r~*7KD? z0J!E*b6eAFRxDw?vMfbt8s4-oXKg9w7)rR_k>9rr@;$MvylZT%1rJ{PlWazp(q{WG z4IxeY9#AH?Mqu9>SG}?@%fsK$3!?yiJI?fI`8z4N20U$F{H#N-X=l9WU`1M0Nv@`O4MnXhbR@iMFo~ zf5Aq^say6kP9Mo|>7>-N=vAG6p-JtHIhQuP<=jd zNdI`pUg;-V(0>3%XZGSLyyeu4jN$J~Jwv(hhVtYH(-I5RBN_x*<4f_bFKMRTlL_>F zN8NeHqPAh?%eLNEt|;EekZ$n-i&EM7)zCGt7?UN^iB|%?BQcK#ue?GBw6EAgyD6_A zX3#LD@32?rbYCReQ|R!k{d*kkYjz26*ChM)cZzqv&@JmLmch*ll$@-=F}MEc*)x%tm?b64NvaXWc!+FfVkHe5GI8GI8bV_!( z{@Ts=IW4rfSMXNmXISl(zGcx4S}&|CSEou(K#Mx68`q!78`XBeB{1^*~DtGi{KJv))k&i zL$YxrSSFKt08?adC|*OnK6VC9mlPEg6dM2u#)tjLw9<*JQ03gHzj!A#0GV*DDp^ls zNc>>zHyx{C5g5ylOPazZi3JeuZRzT61t{gp*%4%MLqSs9nL}*~_dTo7jnw)RB7ffF z$na?4BQ9#&A1rYnFv@WVQo@o~lq*5eKN#HsXV^7!&v?Oxq^h>SsYB5*)%ifResTtB zc2rKX!tiBsN?9v3rkBN2^Y35ccs5u;@5aPMT^D!le24}H#H2l5`Vk-@`aI#oyyJIg zbeWotY)8HTCDmYY`(sPkJj^M$?e79=k`oorffYnpZd8-5V`p4m95c9#ShSh`(bsoU zNGCbf^%a02$^mH5d!*O<`_9eVMhu7WmC)Fyc1jqmZw~9sNGspngB&tM&Z;M?GydGK zjaL*z?4~_pm#F=NP^^REJT-W-wZ+^ow!lUx4u-p4P{xtJ$?JDRHaC0pS!_E_CX|5Xww7**-MUQn z{l!kPp7MFpA7&C@Elc9pTn-e$qmjt1lE4=X3@HK(ptmS4J z1bQe{lFDq0v1LZxidI_<^&m#oN?O``3F!EfFtEI6(#Pi`bAa0tma@NGTnERo94fyY ziIO@9bTvfPsY6+FfbFP5`|N->TzMMd?gMFmip;JhnJS>IO4&W4KRu`OTzyuMoL+wa zh|uD{#}=@7=$5?PhGyAjuioKHcGx6A7l=^R(d^UndY62L8wFA=rVw*L5hHPPuyG+$ KQ;RD~ApQq+q@=X~ -- 2.18.1
