Replace challenger_Python_org.org
parent b486f2d3
* Chalenger - Emacs - Python - Windows 7 64 bits
# -*- coding: utf-8 -*-
# -*- mode: org -*-
** Risk Analysis of the Space Shuttle: Pre-Challenger Prediction of Failure
#+TITLE: Challenger - Python - Emacs - Windows 7 64 bits
In this document we reperform some of the analysis provided in
/Risk Analysis of the Space Shuttle: Pre-Challenger Prediction of
Failure/ by /Siddhartha R. Dalal, Edward B. Fowlkes, Bruce Hoadley/
published in /Journal of the American Statistical Association/, Vol. 84,
No. 408 (Dec., 1989), pp. 945-957 and available at
http://www.jstor.org/stable/2290069.
On the fourth page of this article, they indicate that the maximum
likelihood estimates of the logistic regression using only temperature
are: *$\hat{\alpha}$ = 5.085* and *$\hat{\beta}$ = -0.1156* and their
asymptotic standard errors are *$s_{\hat{\alpha}}$ = 3.052* and
*$s_{\hat{\beta}}$ = 0.047*. The Goodness of fit indicated for this model was
*$G^2$ = 18.086* with *21* degrees of freedom. Our goal is to reproduce
the computation behind these values and the Figure 4 of this article,
possibly in a nicer looking way.
*** Technical information on the computer on which the analysis is run
We will be using the Python 3 language using the pandas, statsmodels,
and numpy library.
and numpy library.
def print_imported_modules():
import sys
for name, val in sorted(sys.modules.items()):
......@@ -45,21 +48,21 @@ import seaborn as sns
print_sys_info()
*** Loading and inspecting data
Let's start by reading data.
data = pd.read_csv("https://app-learninglab.inria.fr/gitlab/moocrr-session1/moocrr-reproducibility-study/raw/master/data/shuttle.csv")
print(data)
We know from our previous experience on this data set that filtering
data is a really bad idea. We will therefore process it as such.
#+begin_src python :results file :session :var matplot_lib_filename=(org-babel-temp-file "figure" ".png") :exports both
%matplotlib inline
pd.set_option('mode.chained_assignment',None) # this removes a useless warning from pandas
......@@ -70,15 +73,15 @@ plt.tight_layout()
*** Logistic regression
Let's assume O-rings independently fail with the same probability
which solely depends on temperature. A logistic regression should
allow us to estimate the influence of temperature.
......@@ -88,46 +91,52 @@ logmodel=sm.GLM(data['Frequency'], data[['Intercept','Temperature']],
family=sm.families.Binomial(sm.families.links.logit)).fit()
print(logmodel.summary())
The maximum likelyhood estimator of the intercept and of Temperature
are thus *$\hat{\alpha}$ = 5.0850* and *$\hat{\beta}$ = -0.1156*. This *corresponds*
to the values from the article of Dalal /et al./ The standard errors are
/$s_{\hat{\alpha}}$ = 7.477/ and /$s_{\hat{\beta}}$ = 0.115/, which is *different* from
the *3.052* and *0.04702* reported by Dallal /et al./ The deviance is
/3.01444/ with *21* degrees of freedom. I cannot find any value similar
to the Goodness of fit (*$G^2$ = 18.086*) reported by Dalal /et al./ There
seems to be something wrong. Oh I know, I haven't indicated that my
observations are actually the result of 6 observations for each rocket
launch. Let's indicate these weights (since the weights are always the
same throughout all experiments, it does not change the estimates of
the fit but it does influence the variance estimates).
family=sm.families.Binomial(sm.families.links.logit),
var_weights=data['Count']).fit()
Good, now I have recovered the asymptotic standard errors
*$s_{\hat{\alpha}}$ = 3.052* and *$s_{\hat{\beta}}$ = 0.047*. The Goodness of fit
(Deviance) indicated for this model is *$G^2$ = 18.086* with *21* degrees
of freedom (Df Residuals).
*I have therefore managed to fully replicate the results of the Dalal
/et al./ article*.
/et al./ article*.
*** Predicting failure probability
The temperature when launching the shuttle was 31°F. Let's try to
estimate the failure probability for such temperature using our model:
%matplotlib inline
'Intercept': 1})
print(data_pred.head())
%matplotlib inline
......@@ -135,27 +144,26 @@ plt.grid(True)
La fonction =logmodel.predict(data_pred)= ne fonctionne pas correctement (Frequency = 1 pour toutes les
températures).
La fonction =logmodel.predict(data_pred)= ne fonctionne pas avec les
dernières versions de pandas (Frequency = 1 pour toutes les températures).
On peut alors utiliser le code suivant pour calculer les prédictions
et tracer la courbe :
# Inspiring from http://blog.yhat.com/posts/logistic-regression-and-python.html
%matplotlib inline
def logit_inv(x):
return(np.exp(x)/(np.exp(x)+1))
data_pred['Prob']=logit_inv(data_pred['Temperature'] * logmodel.params['Temperature'] + logmodel.params['Intercept'])
%matplotlib inline
data_pred.plot(x="Temperature",y="Prob",kind="line",ylim=[0,1])
......@@ -164,16 +172,16 @@ plt.savefig(matplot_lib_filename)
This figure is very similar to the Figure 4 of Dalal /et al./ *I have
managed to replicate the Figure 4 of the Dalal /et al./ article.*
*** Computing and plotting uncertainty
Following the documentation of
[Seaborn](https://seaborn.pydata.org/generated/seaborn.regplot.html),
I use regplot.
I use regplot.
sns.set(color_codes=True)
plt.xlim(30,90)
plt.ylim(0,1)
......@@ -182,12 +190,12 @@ plt.show()
**I think I have managed to correctly compute and plot the uncertainty
of my prediction.** Although the shaded area seems very similar to
[the one obtained by with
R](https://app-learninglab.inria.fr/gitlab/moocrr-session1/moocrr-reproducibility-study/raw/5c9dbef11b4d7638b7ddf2ea71026e7bf00fcfb0/challenger.pdf),
I can spot a few differences (e.g., the blue point for temperature
63 is outside)... Could this be a numerical error ? Or a difference
in the statistical method ? It is not clear which one is "right".
