diff --git a/src/R/challenger_R_org_Windows_64bits.org b/src/R/challenger_R_org_Windows_64bits.org new file mode 100644 index 0000000000000000000000000000000000000000..9984ed76d7ee619a59738baf046e85a8cd18e3d6 --- /dev/null +++ b/src/R/challenger_R_org_Windows_64bits.org @@ -0,0 +1,409 @@ +# -*- coding: utf-8 -*- +# -*- mode: org -*- + +#+TITLE: Challenger - R - Emacs - Windows 7 64 bits + +#+LATEX_HEADER: \usepackage{parskip} + +* Risk Analysis of the Space Shuttle: Pre-Challenger Prediction of Failure + +In this document we reperform some of the analysis provided in +/Risk Analysis of the Space Shuttle: Pre-Challenger Prediction of +Failure/ by /Siddhartha R. Dalal, Edward B. Fowlkes, Bruce Hoadley/ +published in /Journal of the American Statistical Association/, Vol. 84, +No. 408 (Dec., 1989), pp. 945-957 and available at +http://www.jstor.org/stable/2290069. + +On the fourth page of this article, they indicate that the maximum +likelihood estimates of the logistic regression using only temperature +are: *$\hat{\alpha}$ = 5.085* and *$\hat{\beta}$ = -0.1156* and their +asymptotic standard errors are *$s_{\hat{\alpha}}$ = 3.052* and +*$s_{\hat{\beta}}$ = 0.047*. The Goodness of fit indicated for this model was +*$G^2$ = 18.086* with *21* degrees of freedom. Our goal is to reproduce +the computation behind these values and the Figure 4 of this article, +possibly in a nicer looking way. + +* Technical information on the computer on which the analysis is run + +We will be using the R language using the ~ggplot2~ library. + +#+begin_src R :results output :session *R* :exports both +library(ggplot2) +sessionInfo() +#+end_src + +#+RESULTS: +#+begin_example +R version 3.5.1 (2018-07-02) +Platform: i386-w64-mingw32/i386 (32-bit) +Running under: Windows 7 x64 (build 7601) Service Pack 1 + +Matrix products: default + +locale: +[1] LC_COLLATE=French_France.1252 LC_CTYPE=French_France.1252 +[3] LC_MONETARY=French_France.1252 LC_NUMERIC=C +[5] LC_TIME=French_France.1252 + +attached base packages: +[1] stats graphics grDevices utils datasets methods base + +other attached packages: +[1] ggplot2_3.1.0 + +loaded via a namespace (and not attached): + [1] Rcpp_1.0.0 withr_2.1.2 crayon_1.3.4 dplyr_0.7.8 + [5] assertthat_0.2.0 grid_3.5.1 plyr_1.8.4 R6_2.3.0 + [9] gtable_0.2.0 magrittr_1.5 scales_1.0.0 pillar_1.3.0 +[13] rlang_0.3.0.1 lazyeval_0.2.1 bindrcpp_0.2.2 glue_1.3.0 +[17] purrr_0.2.5 munsell_0.5.0 compiler_3.5.1 pkgconfig_2.0.2 +[21] colorspace_1.3-2 tidyselect_0.2.5 bindr_0.1.1 tibble_1.4.2 +#+end_example + +Here are the available libraries +#+begin_src R :results output :session *R* :exports both +devtools::session_info() +#+end_src + +#+RESULTS: +#+begin_example +- Session info --------------------------------------------------------------- + setting value + version R version 3.5.1 (2018-07-02) + os Windows 7 x64 SP 1 + system i386, mingw32 + ui RTerm + language (EN) + collate French_France.1252 + ctype French_France.1252 + tz Europe/Paris + date 2018-12-10 + +- Packages ------------------------------------------------------------------- + package * version date lib source + assertthat 0.2.0 2017-04-11 [1] CRAN (R 3.5.1) + backports 1.1.2 2017-12-13 [1] CRAN (R 3.5.0) + base64enc 0.1-3 2015-07-28 [1] CRAN (R 3.5.0) + bindr 0.1.1 2018-03-13 [1] CRAN (R 3.5.1) + bindrcpp 0.2.2 2018-03-29 [1] CRAN (R 3.5.1) + callr 3.0.0 2018-08-24 [1] CRAN (R 3.5.1) + cli 1.0.1 2018-09-25 [1] CRAN (R 3.5.1) + colorspace 1.3-2 2016-12-14 [1] CRAN (R 3.5.1) + crayon 1.3.4 2017-09-16 [1] CRAN (R 3.5.1) + desc 1.2.0 2018-05-01 [1] CRAN (R 3.5.1) + devtools 2.0.1 2018-10-26 [1] CRAN (R 3.5.1) + digest 0.6.18 2018-10-10 [1] CRAN (R 3.5.1) + dplyr 0.7.8 2018-11-10 [1] CRAN (R 3.5.1) + fs 1.2.6 2018-08-23 [1] CRAN (R 3.5.1) + ggplot2 * 3.1.0 2018-10-25 [1] CRAN (R 3.5.1) + glue 1.3.0 2018-07-17 [1] CRAN (R 3.5.1) + gtable 0.2.0 2016-02-26 [1] CRAN (R 3.5.1) + lazyeval 0.2.1 2017-10-29 [1] CRAN (R 3.5.1) + magrittr 1.5 2014-11-22 [1] CRAN (R 3.5.1) + memoise 1.1.0 2017-04-21 [1] CRAN (R 3.5.1) + munsell 0.5.0 2018-06-12 [1] CRAN (R 3.5.1) + pillar 1.3.0 2018-07-14 [1] CRAN (R 3.5.1) + pkgbuild 1.0.2 2018-10-16 [1] CRAN (R 3.5.1) + pkgconfig 2.0.2 2018-08-16 [1] CRAN (R 3.5.1) + pkgload 1.0.2 2018-10-29 [1] CRAN (R 3.5.1) + plyr 1.8.4 2016-06-08 [1] CRAN (R 3.5.1) + prettyunits 1.0.2 2015-07-13 [1] CRAN (R 3.5.1) + processx 3.2.0 2018-08-16 [1] CRAN (R 3.5.1) + ps 1.2.1 2018-11-06 [1] CRAN (R 3.5.1) + purrr 0.2.5 2018-05-29 [1] CRAN (R 3.5.1) + R6 2.3.0 2018-10-04 [1] CRAN (R 3.5.1) + Rcpp 1.0.0 2018-11-07 [1] CRAN (R 3.5.1) + remotes 2.0.2 2018-10-30 [1] CRAN (R 3.5.1) + rlang 0.3.0.1 2018-10-25 [1] CRAN (R 3.5.1) + rprojroot 1.3-2 2018-01-03 [1] CRAN (R 3.5.1) + scales 1.0.0 2018-08-09 [1] CRAN (R 3.5.1) + sessioninfo 1.1.1 2018-11-05 [1] CRAN (R 3.5.1) + testthat 2.0.1 2018-10-13 [1] CRAN (R 3.5.1) + tibble 1.4.2 2018-01-22 [1] CRAN (R 3.5.1) + tidyselect 0.2.5 2018-10-11 [1] CRAN (R 3.5.1) + usethis 1.4.0 2018-08-14 [1] CRAN (R 3.5.1) + withr 2.1.2 2018-03-15 [1] CRAN (R 3.5.1) + +[1] c:/Program Files/R/R-3.5.1/library +#+end_example + +* Loading and inspecting data +Let's start by reading data: +#+begin_src R :results output :session *R* :exports both +data = read.csv("https://app-learninglab.inria.fr/gitlab/moocrr-session1/moocrr-reproducibility-study/raw/master/data/shuttle.csv") +data +#+end_src + +#+RESULTS: +#+begin_example + Date Count Temperature Pressure Malfunction +1 4/12/81 6 66 50 0 +2 11/12/81 6 70 50 1 +3 3/22/82 6 69 50 0 +4 11/11/82 6 68 50 0 +5 4/04/83 6 67 50 0 +6 6/18/82 6 72 50 0 +7 8/30/83 6 73 100 0 +8 11/28/83 6 70 100 0 +9 2/03/84 6 57 200 1 +10 4/06/84 6 63 200 1 +11 8/30/84 6 70 200 1 +12 10/05/84 6 78 200 0 +13 11/08/84 6 67 200 0 +14 1/24/85 6 53 200 2 +15 4/12/85 6 67 200 0 +16 4/29/85 6 75 200 0 +17 6/17/85 6 70 200 0 +18 7/2903/85 6 81 200 0 +19 8/27/85 6 76 200 0 +20 10/03/85 6 79 200 0 +21 10/30/85 6 75 200 2 +22 11/26/85 6 76 200 0 +23 1/12/86 6 58 200 1 +#+end_example + +We know from our previous experience on this data set that filtering +data is a really bad idea. We will therefore process it as such. + +Let's visually inspect how temperature affects malfunction: +#+begin_src R :results output graphics :file (org-babel-temp-file "figure" ".png") :exports both :width 600 :height 400 :session *R* +plot(data=data, Malfunction/Count ~ Temperature, ylim = c(0,1)) +#+end_src + +#+RESULTS: +[[file:c:/Users/dondon/AppData/Local/Temp/babel-mb830V/figuremlknwM.png]] + +* Logistic regression + +Let's assume O-rings independently fail with the same probability +which solely depends on temperature. A logistic regression should +allow us to estimate the influence of temperature. +#+begin_src R :results output :session *R* :exports both +logistic_reg = glm(data=data, Malfunction/Count ~ Temperature, weights=Count, + family=binomial(link='logit')) +summary(logistic_reg) +#+end_src + +#+RESULTS: +#+begin_example + +Call: +glm(formula = Malfunction/Count ~ Temperature, family = binomial(link = "logit"), + data = data, weights = Count) + +Deviance Residuals: + Min 1Q Median 3Q Max +-0.95227 -0.78299 -0.54117 -0.04379 2.65152 + +Coefficients: + Estimate Std. Error z value Pr(>|z|) +(Intercept) 5.08498 3.05247 1.666 0.0957 . +Temperature -0.11560 0.04702 -2.458 0.0140 * +--- +Signif. codes: 0 '***' 0.001 '**' 0.01 '*' 0.05 '.' 0.1 ' ' 1 + +(Dispersion parameter for binomial family taken to be 1) + + Null deviance: 24.230 on 22 degrees of freedom +Residual deviance: 18.086 on 21 degrees of freedom +AIC: 35.647 + +Number of Fisher Scoring iterations: 5 +#+end_example + + + +The maximum likelyhood estimatator of the intercept and of Temperature +are thus *$\hat{\alpha}$ = 5.0850* and *$\hat{\beta}$ = -0.1156* and their standard +errors are *$s_{\hat{\alpha}}$ = 3.052* and *$s_{\hat{\beta}}$ = 0.04702*. The Residual +deviance corresponds to the Goodness of fit *$G^2$ = 18.086* with *21* +degrees of freedom. *I have therefore managed to replicate the results +of the Dalal /et al./ article*. + +* Predicting failure probability + +The temperature when launching the shuttle was 31°F. Let's try to +estimate the failure probability for such temperature using our model: +#+begin_src R :results output graphics :file (org-babel-temp-file "figure" ".png") :exports both :width 600 :height 400 :session *R* +# shuttle=shuttle[shuttle$r!=0,] +tempv = seq(from=30, to=90, by = .5) +rmv <- predict(logistic_reg,list(Temperature=tempv),type="response") +plot(tempv,rmv,type="l",ylim=c(0,1)) +points(data=data, Malfunction/Count ~ Temperature) +#+end_src + +#+RESULTS: +[[file:c:/Users/dondon/AppData/Local/Temp/babel-mb830V/figurePDN133.png]] + +This figure is very similar to the Figure 4 of Dalal /et al./ *I have +managed to replicate the Figure 4 of the Dalal /et al./ article.* + +* Confidence on the prediction + +Let's try to plot confidence intervals with ~ggplot2~. +#+begin_src R :results output graphics :file (org-babel-temp-file "figure" ".png") :exports both :width 600 :height 400 :session *R* +ggplot(data, aes(y=Malfunction/Count, x=Temperature)) + + geom_point(alpha=.2, size = 2, color="blue") + + geom_smooth(method = "glm", method.args = list(family = "binomial"), + fullrange=T) + + xlim(30,90) + ylim(0,1) + theme_bw() +#+end_src + +#+RESULTS: +[[file:c:/Users/dondon/AppData/Local/Temp/babel-mb830V/figureUmDY5S.png]] + +I don't get any warning from ~ggplot2~ indicating /"non-integer +#successes in a binomial glm!"/ but this confidence region seems +huge... It seems strange to me that the uncertainty grows so large for +higher temperatures. And compared to my previous call to ~glm~, I +haven't indicated the weight which accounts for the fact that each +ration Malfunction/Count corresponds to ~Count~ observations (if someone +knows how to do this...). There must be something wrong. + +So let's provide the "raw" data to ~ggplot2~. +#+begin_src R :results output :session *R* :exports both +data_flat = data.frame() +for(i in 1:nrow(data)) { + temperature = data[i,"Temperature"]; + malfunction = data[i,"Malfunction"]; + d = data.frame(Temperature=temperature,Malfunction=rep(0,times = data[i,"Count"])) + if(malfunction>0) { + d[1:malfunction, "Malfunction"]=1; + } + data_flat=rbind(data_flat,d) +} +dim(data_flat) +#+end_src + +#+RESULTS: +: [1] 138 2 + +#+begin_src R :results output :session *R* :exports both +str(data_flat) +#+end_src + +#+RESULTS: +: 'data.frame': 138 obs. of 2 variables: +: $ Temperature: int 66 66 66 66 66 66 70 70 70 70 ... +: $ Malfunction: num 0 0 0 0 0 0 1 0 0 0 ... + +Let's check whether I obtain the same regression or not: +#+begin_src R :results output :session *R* :exports both +logistic_reg_flat = glm(data=data_flat, Malfunction ~ Temperature, + family=binomial(link='logit')) +summary(logistic_reg) +#+end_src + +#+RESULTS: +#+begin_example + +Call: +glm(formula = Malfunction/Count ~ Temperature, family = binomial(link = "logit"), + data = data, weights = Count) + +Deviance Residuals: + Min 1Q Median 3Q Max +-0.95227 -0.78299 -0.54117 -0.04379 2.65152 + +Coefficients: + Estimate Std. Error z value Pr(>|z|) +(Intercept) 5.08498 3.05247 1.666 0.0957 . +Temperature -0.11560 0.04702 -2.458 0.0140 * +--- +Signif. codes: 0 '***' 0.001 '**' 0.01 '*' 0.05 '.' 0.1 ' ' 1 + +(Dispersion parameter for binomial family taken to be 1) + + Null deviance: 24.230 on 22 degrees of freedom +Residual deviance: 18.086 on 21 degrees of freedom +AIC: 35.647 + +Number of Fisher Scoring iterations: 5 +#+end_example + +Perfect. The estimates and the standard errors for him are the same +although the Residual deviance is difference since the distance is now +measured with respect to each =0/1= measurement and not to +rations. Let's use plot the regression for /data_flat/ along with the +ratios (/data/). +#+begin_src R :results output graphics :file (org-babel-temp-file "figure" ".png") :exports both :width 600 :height 400 :session *R* +ggplot(data=data_flat, aes(y=Malfunction, x=Temperature)) + + geom_smooth(method = "glm", method.args = list(family = "binomial"), + fullrange=T) + + geom_point(data=data, aes(y=Malfunction/Count, x=Temperature), + alpha=.2, size = 2, color="blue") + + geom_point(alpha=.5, size=.5) + xlim(30,90) + ylim(0,1) + theme_bw() +#+end_src + +#+RESULTS: +[[file:c:/Users/dondon/AppData/Local/Temp/babel-mb830V/figureEStjqI.png]] + +This confidence interval seems much more reasonable (in accordance +with the data) than the previous one. Let's check whether it +corresponds to the prediction obtained when calling directly +predict. Obtaining the prediction can be done directly or through the +link function. + +Here is the "direct" (response) version I used in my very first plot: +#+begin_src R :results output :session *R* :exports both +pred = predict(logistic_reg_flat, list(Temperature=30), type="response", se.fit = T) +pred +#+end_src + +#+RESULTS: +#+begin_example +$fit + 1 +0.834373 + +$se.fit + 1 +0.2293304 + +$residual.scale +[1] 1 +#+end_example + +The estimated Failure probability for 30° is thus 0.834. However the +/se.fit/ value seems pretty hard to use as I can obviously not simply +add \pm2 /se.fit/ to /fit/ to compute a confidence interval. + +Here is the "link" version: +#+begin_src R :results output :session *R* :exports both +pred_link = predict(logistic_reg_flat, list(Temperature=30), type="link", se.fit = T) +pred_link +#+end_src + +#+RESULTS: +: Erreur : objet 'pred.link' introuvable + +#+begin_src R :results output :session *R* :exports both +logistic_reg$family$linkinv(pred_link$fit) +#+end_src + +#+RESULTS: +: Fehler: Objekt 'logistic_reg' nicht gefunden + +I recover 0.834 for the Estimated Failure probability at 30°. But now, going through the /linkinv/ function, we can use /se.fit/: +#+begin_src R :results output :session *R* :exports both +critval = 1.96 +logistic_reg$family$linkinv(c(pred_link$fit-critval*pred_link$se.fit, pred_link$fit+critval*pred_link$se.fit)) +#+end_src + +#+RESULTS: +: +: Fehler: Objekt 'logistic_reg' nicht gefunden + +The 95% confidence interval for our estimation is thus [0.163,0.992]. This +is what ~ggplot2~ just plotted me. This seems coherent. + +*I am now rather confident that I have managed to correctly compute and +plot uncertainty of my prediction.* Let's be honnest, it took me a +wile. My first attempts were plainly wrong (I didn't know how to do +this so I trusted ~ggplot2~, which I was misusing) and did not use the +correct statistical method. I also feel confident now becuase this has +been somehow validated by other colleagues but it will be interesting +that you collect other kind of plot values that you obtained, that +differ and that you would probably have kept if you didn't have a +reference to compare to. Please, provide us with as many versions as +you can.
