diff --git a/testmarkdown.Rmd b/testmarkdown.Rmd new file mode 100644 index 0000000000000000000000000000000000000000..09a928a956100a2ab3edfe9e85dd4d4e19e8d934 --- /dev/null +++ b/testmarkdown.Rmd @@ -0,0 +1,30 @@ +--- +title: "test" +author: "helene" +date: "26 mars 2020" +output: html_document +--- + +```{r setup, include=FALSE} +knitr::opts_chunk$set(echo = TRUE) +``` + +## R Markdown + +This is an R Markdown document. Markdown is a simple formatting syntax for authoring HTML, PDF, and MS Word documents. For more details on using R Markdown see . + +When you click the **Knit** button a document will be generated that includes both content as well as the output of any embedded R code chunks within the document. You can embed an R code chunk like this: + +```{r cars} +summary(cars) +``` + +## Including Plots + +You can also embed plots, for example: + +```{r pressure, echo=FALSE} +plot(pressure) +``` + +Note that the `echo = FALSE` parameter was added to the code chunk to prevent printing of the R code that generated the plot.
