From 4d7692b850fd97251273c42f63e5b158f10b3ede Mon Sep 17 00:00:00 2001 From: 180838a673f39011c57d6df0dfcfb140 <180838a673f39011c57d6df0dfcfb140@app-learninglab.inria.fr> Date: Thu, 26 Mar 2020 14:36:38 +0000 Subject: [PATCH] Premier fichier Rmarkdown --- testmarkdown.Rmd | 30 ++++++++++++++++++++++++++++++ 1 file changed, 30 insertions(+) create mode 100644 testmarkdown.Rmd diff --git a/testmarkdown.Rmd b/testmarkdown.Rmd new file mode 100644 index 0000000..09a928a --- /dev/null +++ b/testmarkdown.Rmd @@ -0,0 +1,30 @@ +--- +title: "test" +author: "helene" +date: "26 mars 2020" +output: html_document +--- + +```{r setup, include=FALSE} +knitr::opts_chunk$set(echo = TRUE) +``` + +## R Markdown + +This is an R Markdown document. Markdown is a simple formatting syntax for authoring HTML, PDF, and MS Word documents. For more details on using R Markdown see . + +When you click the **Knit** button a document will be generated that includes both content as well as the output of any embedded R code chunks within the document. You can embed an R code chunk like this: + +```{r cars} +summary(cars) +``` + +## Including Plots + +You can also embed plots, for example: + +```{r pressure, echo=FALSE} +plot(pressure) +``` + +Note that the `echo = FALSE` parameter was added to the code chunk to prevent printing of the R code that generated the plot. -- 2.18.1
