diff --git a/module2/exo5/exo5_en.Rmd b/module2/exo5/exo5_en.Rmd deleted file mode 100644 index 819ba9f263ee410da787d67710fe27e860ab929c..0000000000000000000000000000000000000000 --- a/module2/exo5/exo5_en.Rmd +++ /dev/null @@ -1,133 +0,0 @@ ---- -title: "Analysis of the risk of failure of the O-rings on the Challenger shuttle" -author: "Gkiouzepi Eleni" -date: "24/7/2021" -output: html_document ---- - -On January 27, 1986, the day before the takeoff of the shuttle _Challenger_, had -a three-hour teleconference was held between -Morton Thiokol (the manufacturer of one of the engines) and NASA. The -discussion focused on the consequences of the -temperature at take-off of 31°F (just below -0°C) for the success of the flight and in particular on the performance of the -O-rings used in the engines. Indeed, no test -had been performed at this temperature. - -The following study takes up some of the analyses carried out that -night with the objective of assessing the potential influence of -the temperature and pressure to which the O-rings are subjected -on their probability of malfunction. Our starting point is -the results of the experiments carried out by NASA engineers -during the six years preceding the launch of the shuttle -Challenger. - -# Loading the data -We start by loading this data: - -```{r} -data = read.csv("shuttle.csv",header=T) -data -``` - -The data set shows us the date of each test, the number of O-rings -(there are 6 on the main launcher), the -temperature (in Fahrenheit) and pressure (in psi), and finally the -number of identified malfunctions. - -# Graphical inspection -~~Flights without incidents do not provide any information -on the influence of temperature or pressure on malfunction. -We thus focus on the experiments in which at least one O-ring was defective.~~ **Wrong assumption** - -```{r} -# mal = data[data$Malfunction>0,] -``` - -We have a high temperature variability but -the pressure is almost always 200, which should -simplify the analysis. - -How does the frequency of failure vary with temperature? -```{r} -plot(data=data, Malfunction/Count ~ Temperature, ylim=c(0,1)) -``` - -At first glance, the dependence does not look very important, but let's try to -estimate the impact of temperature $t$ on the probability of O-ring malfunction. - -# Estimation of the temperature influence - -Suppose that each of the six O-rings is damaged with the same -probability and independently of the others and that this probability -depends only on the temperature. If $p(t)$ is this probability, the -number $D$ of malfunctioning O-rings during a flight at -temperature $t$ follows a binomial law with parameters $n=6$ and -$p=p(t)$. To link $p(t)$ to $t$, we will therefore perform a -logistic regression. - -```{r} -logistic_reg = glm(data=data, Malfunction/Count ~ Temperature, weights=Count, - family=binomial(link='logit')) -summary(logistic_reg) - -# mal_logistic_reg = glm(data=mal, Malfunction/Count ~ Temperature, weights=Count, -# family=binomial(link='logit')) -# summary(mal_logistic_reg) -``` - -The most likely estimator of the temperature parameter is ~~0.001416~~ __-0.11560__ -and the standard error of this estimator is 0.047, in other words -**WRONG** ~~we -cannot distinguish any particular impact~~ -_it is inverse-dependent on temperature, if temperature decreases by 1 degree, the probability of O-ring malfunction increases by 0.1156,_ and we must take our -estimates with caution. - - -# Estimation of the probability of O-ring malfunction -The expected temperature on the take-off day is 31°F. Let's try to -estimate the probability of O-ring malfunction at -this temperature from the model we just built: - -```{r} -# shuttle=shuttle[shuttle$r!=0,] -tempv = seq(from=30, to=90, by = .5) -# rmv_mal <- predict(mal_logistic_reg,list(Temperature=tempv),type="response") -# plot(tempv,rmv_mal,type="l",ylim=c(0,1)) -# points(data=mal, Malfunction/Count ~ Temperature) - - -rmv <- predict(logistic_reg,list(Temperature=tempv),se.fit=T,type="response") -plot(tempv,rmv$fit,type="l",ylim=c(0,1)) -lines(tempv,rmv$fit+rmv$se.fit,col="red") -lines(tempv,rmv$fit-rmv$se.fit,col="red") -points(data=data, Malfunction/Count ~ Temperature) -``` - -~~As expected from the initial data~~, the -temperature has **VERY** ~~no~~ significant impact on the probability of failure of the -O-rings. It will be ~~about 0.2~~ **in average over 0.8 to as high as more than 1.0 (certain)**,~~as in the tests -where we had a failure of at least one joint~~ **so we are expecting a failure of at least 4 joints**. Let's ~~get back to the initial dataset to~~ estimate the probability of failure: - -```{r} -# data_full = read.csv("shuttle.csv",header=T) -# sum(data_full$Malfunction)/sum(data_full$Count) - -estim = predict(logistic_reg,list(Temperature=31),se.fit=T,type="response") -estim -``` - -This probability is thus about $p=`r round(estim$fit, digits = 5)`\pm`r round(estim$se.fit, digits = 5)`$. Knowing that there is -a primary and a secondary O-ring on each of the three parts of the -launcher, the probability of failure of both joints of a launcher -is $p^2 \approx `r round((estim$fit+estim$se.fit)^2, digits = 2)`\pm`r round(2*estim$se.fit*estim$fit, digits = 2)`$. The probability of failure of any one of the -launchers is $1-(1-p^2)^3 \approx `r (1-(1-round((estim$fit+estim$se.fit)^2, digits = 0))^3)*100`\%$. ~~That would really be -bad luck.... Everything is under control, so the takeoff can happen -tomorrow as planned~~.**ABORT! ABORT! ABORT THE MISSION!** - -*Unfortunately, none of the above analysis was carried out properly and* the next day, the Challenger shuttle exploded and took away -with her the seven crew members. The public was shocked and in -the subsequent investigation, the reliability of the -O-rings was questioned. Beyond the internal communication problems -of NASA, which have a lot to do with this fiasco, the previous analysis -includes (at least) a small problem.
