moocrr-reproducibility-study
moocrr-session3
953a4e09
953a4e09
Julien MARTY
commit2
4c59e958
2 additions
2 deletions
+2
-2
toy_document_fr.html
module2/exo1/toy_document_fr.html
+2
-2
953a4e09
@@ -12,7 +12,7 @@
@@ -12,7 +12,7 @@
<meta
name=
"author"
content=
"Teonas"
<meta
name=
"author"
content=
"Teonas"
<title>
À propos du calcul de
p
i
</title>
<title>
P
i
</title>
<script>
/*! jQuery v1.11.3 | (c) 2005, 2015 jQuery Foundation, Inc. | jquery.org/license */
<script>
function
a
b
"object"
typeof
module
"object"
typeof
module
exports
module
exports
a
document
b
a
function
a
if
a
document
throw
new
Error
"jQuery requires a window with a document"
return
b
a
b
a
"undefined"
typeof
window
window
this
function
a
b
var
c
d
c
slice
e
c
concat
f
c
push
g
c
indexOf
h
i
h
toString
j
h
hasOwnProperty
k
l
"1.11.3"
m
function
a
b
return
new
m
fn
init
a
b
n
[\s\u
FEFF
\x
A0
[\s\u
FEFF
\x
A0
+$/g
o
/^-ms-/
p
([\d
a-z
/gi
q
function
a
b
return
b
toUpperCase
m
fn
m
prototype
jquery
l
constructor
m
selector
length
toArray
function
return
d
call
this
get
function
a
return
null
a
a
this
a
this
length
this
a
d
call
this
pushStack
function
a
var
b
m
merge
this
constructor
a
return
b
prevObject
this
b
context
this
context
b
each
function
a
b
return
m
each
this
a
b
map
function
a
return
this
pushStack
m
map
this
function
b
c
return
a
call
b
c
b
slice
function
return
this
pushStack
d
apply
this
arguments
first
function
return
this
eq
last
function
return
this
eq
eq
function
a
var
b
this
length
c
a
a
b
return
this
pushStack
c
b
c
this
c
function
return
this
prevObject
this
constructor
null
push
f
sort
c
sort
splice
c
splice
m
extend
m
fn
extend
function
var
a
b
c
d
e
f
g
arguments
h
i
arguments
length
j
for
"boolean"
typeof
g
j
g
g
arguments
h
h
"object"
typeof
g
m
isFunction
g
g
h
i
g
this
h
i
h
h
if
null
e
arguments
h
for
d
in
e
a
g
d
c
e
d
g
c
j
c
m
isPlainObject
c
b
m
isArray
c
b
b
f
a
m
isArray
a
a
f
a
m
isPlainObject
a
a
g
d
m
extend
j
f
c
void
c
g
d
c
return
g
m
extend
expando
"jQuery"
l
Math
random
replace
\D
/g
isReady
error
function
a
throw
new
Error
a
noop
function
isFunction
function
a
return
"function"
m
type
a
isArray
Array
isArray
function
a
return
"array"
m
type
a
isWindow
function
a
return
null
a
a
a
window
isNumeric
function
a
return
m
isArray
a
a
parseFloat
a
isEmptyObject
function
a
var
b
for
b
in
a
return
return
isPlainObject
function
a
var
b
if
a
"object"
m
type
a
a
nodeType
m
isWindow
a
return
try
if
a
constructor
j
call
a
"constructor"
j
call
a
constructor
prototype
"isPrototypeOf"
return
catch
c
return
if
k
ownLast
for
b
in
a
return
j
call
a
b
for
b
in
a
return
void
b
j
call
a
b
type
function
a
return
null
a
a
"object"
typeof
a
"function"
typeof
a
h
i
call
a
"object"
typeof
a
globalEval
function
b
b
m
trim
b
a
execScript
function
b
a
eval
call
a
b
b
camelCase
function
a
return
a
replace
o
"ms-"
replace
p
q
nodeName
function
a
b
return
a
nodeName
a
nodeName
toLowerCase
b
toLowerCase
each
function
a
b
c
var
d
e
f
a
length
g
r
a
if
c
if
g
for
f
e
e
if
d
b
apply
a
e
c
d
break
else
for
e
in
a
if
d
b
apply
a
e
c
d
break
else
if
g
for
f
e
e
if
d
b
call
a
e
e
a
e
d
break
else
for
e
in
a
if
d
b
call
a
e
e
a
e
d
break
return
a
trim
function
a
return
null
a
a
replace
n
makeArray
function
a
b
var
c
b
return
null
a
r
Object
a
m
merge
c
"string"
typeof
a
a
a
f
call
c
a
c
inArray
function
a
b
c
var
d
if
b
if
g
return
g
call
b
a
c
for
d
b
length
c
c
c
Math
max
d
c
c
d
c
c
if
c
in
b
b
c
a
return
c
return
merge
function
a
b
var
c
b
length
d
e
a
length
while
c
d
a
e
b
d
if
c
c
while
void
b
d
a
e
b
d
return
a
length
e
a
grep
function
a
b
c
for
var
d
e
f
g
a
length
h
c
g
f
f
d
b
a
f
f
d
h
e
push
a
f
return
e
map
function
a
b
c
var
d
f
g
a
length
h
r
a
i
if
h
for
g
f
f
d
b
a
f
f
c
null
d
i
push
d
else
for
f
in
a
d
b
a
f
f
c
null
d
i
push
d
return
e
apply
i
guid
proxy
function
a
b
var
c
e
f
return
"string"
typeof
b
f
a
b
b
a
a
f
m
isFunction
a
c
d
call
arguments
2
e
function
return
a
apply
b
this
c
concat
d
call
arguments
e
guid
a
guid
a
guid
m
guid
e
void
now
function
return
new
Date
support
k
m
each
"Boolean Number String Function Array Date RegExp Object Error"
split
function
a
b
h
"[object "
b
b
toLowerCase
function
r
a
var
b
"length"
in
a
a
length
c
m
type
a
return
"function"
c
m
isWindow
a
a
nodeType
b
"array"
c
b
"number"
typeof
b
b
b
in
a
var
s
function
a
var
b
c
d
e
f
g
h
i
j
k
l
m
n
o
p
q
r
s
t
u
"sizzle"
new
Date
v
a
document
w
x
y
ha
z
ha
A
ha
B
function
a
b
return
a
b
l
C
31
D
hasOwnProperty
E
F
E
pop
G
E
push
H
E
push
I
E
slice
J
function
a
b
for
var
c
d
a
length
d
c
c
if
a
c
b
return
c
return
K
"checked|selected|async|autofocus|autoplay|controls|defer|disabled|hidden|ismap|loop|multiple|open|readonly|required|scoped"
L
x20
t
r
\n
f]"
w-]|[^
x00-
xa0])+"
N
replace
"w"
"w#"
O
L
L
L
N
L
P
O
Q
new
RegExp
L
"g"
R
new
RegExp
L
L
"g"
S
new
RegExp
L
L
T
new
RegExp
L
L
L
U
new
RegExp
L
L
"g"
V
new
RegExp
P
W
new
RegExp
N
X
ID
new
RegExp
CLASS
new
RegExp
TAG
new
RegExp
replace
"w"
"w*"
ATTR
new
RegExp
O
PSEUDO
new
RegExp
P
CHILD
new
RegExp
"^:(only|first|last|nth|nth-last)-(child|of-type)(?:
L
"*(even|odd|(([+-]|)(
d*)n|)"
L
L
d+)|))"
L
"i"
bool
new
RegExp
K
"i"
needsContext
new
RegExp
L
"*[>+~]|:(even|odd|eq|gt|lt|nth|first|last)(?:
L
d)?
d*)"
L
"i"
Y
input|select|textarea|button
$/i
Z
/^h
\d
$/i
\{\s
native
\w
_
([\w
(\w
\.([\w
aa
ba
/g
ca
new
RegExp
da-f]{1,6}"
L
L
"ig"
da
function
a
b
c
var
d
"0x"
b
65536
return
d
d
c
b
d
String
fromCharCode
d
65536
String
fromCharCode
d
10
55296
1023
d
56320
ea
function
m
try
H
apply
E
I
call
v
childNodes
v
childNodes
E
v
childNodes
length
nodeType
catch
fa
H
apply
E
length
function
a
b
G
apply
a
I
call
b
function
a
b
var
c
a
length
d
while
a
c
b
d
a
length
c
function
ga
a
b
d
e
var
f
h
j
k
l
o
r
s
w
x
if
b
b
ownerDocument
b
v
n
m
b
b
b
n
d
d
k
b
nodeType
"string"
typeof
a
a
k
9
k
11
k
return
d
if
e
p
if
11
k
f
_
exec
a
if
j
f
if
9
k
if
h
b
getElementById
j
h
h
parentNode
return
d
if
h
id
j
return
d
push
h
d
else
if
b
ownerDocument
h
b
ownerDocument
getElementById
j
t
b
h
h
id
j
return
d
push
h
d
else
if
f
2
return
H
apply
d
b
getElementsByTagName
a
d
if
j
f
3
c
getElementsByClassName
return
H
apply
d
b
j
d
if
c
qsa
q
q
test
a
if
s
r
u
w
b
x
k
a
k
"object"
b
nodeName
toLowerCase
o
g
a
r
b
getAttribute
"id"
s
r
replace
ba
b
setAttribute
"id"
s
s
"[id='"
s
l
o
length
while
l
o
l
s
ra
o
l
w
aa
test
a
pa
b
parentNode
b
x
o
join
if
x
try
return
H
apply
d
w
querySelectorAll
x
d
catch
y
finally
r
b
removeAttribute
"id"
return
i
a
replace
R
"$1"
b
d
e
function
ha
var
a
function
b
c
e
return
a
push
c
d
cacheLength
delete
b
a
shift
b
c
e
return
b
function
ia
a
return
a
u
a
function
ja
a
var
b
n
createElement
"div"
try
return
a
b
catch
c
return
finally
b
parentNode
b
parentNode
removeChild
b
b
null
function
ka
a
b
var
c
a
split
e
a
length
while
e
d
attrHandle
c
e
b
function
la
a
b
var
c
b
a
d
c
a
nodeType
b
nodeType
b
sourceIndex
C
a
sourceIndex
C
if
d
return
d
if
c
while
c
c
nextSibling
if
c
b
return
return
a
function
ma
a
return
function
b
var
c
b
nodeName
toLowerCase
return
"input"
c
b
type
a
function
na
a
return
function
b
var
c
b
nodeName
toLowerCase
return
"input"
c
"button"
c
b
type
a
function
oa
a
return
ia
function
b
return
b
b
ia
function
c
d
var
e
f
a
c
length
b
g
f
length
while
g
c
e
f
g
c
e
d
e
c
e
function
pa
a
return
a
"undefined"
typeof
a
a
c
ga
support
f
ga
isXML
function
a
var
b
a
a
ownerDocument
a
documentElement
return
b
"HTML"
b
nodeName
m
ga
setDocument
function
a
var
b
e
g
a
a
ownerDocument
a
v
return
g
n
9
g
nodeType
g
documentElement
n
g
o
g
documentElement
e
g
defaultView
e
e
e
top
e
addEventListener
e
addEventListener
"unload"
ea
e
attachEvent
e
attachEvent
"onunload"
ea
p
f
g
c
attributes
ja
function
a
return
a
className
"i"
a
getAttribute
"className"
c
ja
function
a
return
a
appendChild
g
createComment
a
length
c
test
g
c
getById
ja
function
a
return
o
appendChild
a
id
u
g
getElementsByName
g
getElementsByName
u
length
c
getById
d
find
ID
function
a
b
if
"undefined"
typeof
b
getElementById
p
var
c
b
getElementById
a
return
c
c
parentNode
c
d
filter
ID
function
a
var
b
a
replace
ca
da
return
function
a
return
a
getAttribute
"id"
b
delete
d
find
ID
d
filter
ID
function
a
var
b
a
replace
ca
da
return
function
a
var
c
"undefined"
typeof
a
getAttributeNode
a
getAttributeNode
"id"
return
c
c
value
b
d
find
TAG
c
function
a
b
return
"undefined"
typeof
b
b
a
c
qsa
b
querySelectorAll
a
void
function
a
b
var
c
d
e
f
b
a
if
a
while
c
f
e
c
nodeType
d
push
c
return
d
return
f
d
find
CLASS
c
function
a
b
return
p
b
a
void
r
q
c
qsa
test
g
querySelectorAll
ja
function
a
o
appendChild
a
innerHTML
"<a id='"
u
"'></a><select id='"
u
f]' msallowcapture=''><option selected=''></option></select>"
a
querySelectorAll
"[msallowcapture^='']"
length
q
push
L
a
querySelectorAll
"[selected]"
length
q
push
L
"*(?:value|"
K
a
querySelectorAll
"[id~="
u
length
q
push
a
querySelectorAll
":checked"
length
q
push
":checked"
a
querySelectorAll
"a#"
u
length
q
push
ja
function
a
var
b
g
createElement
"input"
b
setAttribute
"type"
"hidden"
a
appendChild
b
setAttribute
"name"
"D"
a
querySelectorAll
"[name=d]"
length
q
push
"name"
L
a
querySelectorAll
":enabled"
length
q
push
":enabled"
":disabled"
a
querySelectorAll
"*,:x"
q
push
c
matchesSelector
test
s
o
matches
o
webkitMatchesSelector
o
mozMatchesSelector
o
oMatchesSelector
o
msMatchesSelector
ja
function
a
c
disconnectedMatch
s
call
a
"div"
s
call
a
"[s!='']:x"
r
push
P
q
q
length
new
RegExp
q
join
r
r
length
new
RegExp
r
join
b
test
o
compareDocumentPosition
t
b
test
o
contains
function
a
b
var
c
9
a
nodeType
a
documentElement
a
d
b
b
parentNode
return
a
d
d
d
nodeType
c
contains
c
contains
d
a
16
a
d
function
a
b
if
b
while
b
b
parentNode
if
b
a
return
return
B
b
function
a
b
if
a
b
return
l
var
d
a
b
return
d
d
d
a
ownerDocument
a
b
ownerDocument
b
a
b
d
c
sortDetached
b
a
d
a
g
a
ownerDocument
v
t
v
a
b
g
b
ownerDocument
v
t
v
b
k
J
k
a
J
k
b
d
function
a
b
if
a
b
return
l
var
c
d
e
a
parentNode
f
b
parentNode
h
a
i
b
if
e
f
return
a
g
b
g
e
f
k
J
k
a
J
k
b
if
e
f
return
la
a
b
c
a
while
c
c
parentNode
h
unshift
c
c
b
while
c
c
parentNode
i
unshift
c
while
h
d
i
d
d
return
d
la
h
d
i
d
h
d
v
i
d
v
g
n
ga
matches
function
a
b
return
ga
a
null
null
b
ga
matchesSelector
function
a
b
if
a
ownerDocument
a
n
m
a
b
b
replace
U
"='$1']"
c
matchesSelector
p
r
r
test
b
q
q
test
b
try
var
d
s
call
a
b
if
d
c
disconnectedMatch
a
document
11
a
document
nodeType
return
d
catch
e
return
ga
b
n
null
a
length
ga
contains
function
a
b
return
a
ownerDocument
a
n
m
a
t
a
b
ga
attr
function
a
b
a
ownerDocument
a
n
m
a
var
e
d
attrHandle
b
toLowerCase
f
e
D
call
d
attrHandle
b
toLowerCase
e
a
b
p
void
return
void
f
f
c
attributes
p
a
getAttribute
b
f
a
getAttributeNode
b
f
specified
f
value
null
ga
error
function
a
throw
new
Error
"Syntax error, unrecognized expression: "
a
ga
uniqueSort
function
a
var
b
d
e
f
if
l
c
detectDuplicates
k
c
sortStable
a
slice
a
sort
B
l
while
b
a
f
b
a
f
e
d
push
f
while
e
a
splice
d
e
return
k
null
a
e
ga
getText
function
a
var
b
c
d
f
a
nodeType
if
f
if
f
9
f
11
f
if
"string"
typeof
a
textContent
return
a
textContent
for
a
a
firstChild
a
a
a
nextSibling
c
e
a
else
if
3
f
4
f
return
a
nodeValue
else
while
b
a
d
c
e
b
return
c
d
ga
selectors
cacheLength
50
createPseudo
ia
match
X
attrHandle
find
relative
dir
"parentNode"
first
dir
"parentNode"
dir
"previousSibling"
first
dir
"previousSibling"
preFilter
ATTR
function
a
return
a
a
replace
ca
da
a
3
a
3
a
4
a
5
replace
ca
da
a
2
a
3
a
3
a
slice
CHILD
function
a
return
a
a
toLowerCase
"nth"
a
slice
a
3
ga
error
a
a
4
a
4
a
5
a
6
2
"even"
a
3
"odd"
a
3
a
5
a
7
a
8
"odd"
a
3
a
3
ga
error
a
a
PSEUDO
function
a
var
b
c
a
6
a
2
return
X
CHILD
test
a
null
a
3
a
2
a
4
a
5
c
V
test
c
b
g
c
b
c
indexOf
c
length
b
c
length
a
a
slice
b
a
2
c
slice
b
a
slice
filter
TAG
function
a
var
b
a
replace
ca
da
toLowerCase
return
a
function
return
function
a
return
a
nodeName
a
nodeName
toLowerCase
b
CLASS
function
a
var
b
y
a
return
b
b
new
RegExp
L
a
L
y
a
function
a
return
b
test
"string"
typeof
a
className
a
className
"undefined"
typeof
a
getAttribute
a
getAttribute
"class"
ATTR
function
a
b
c
return
function
d
var
e
ga
attr
d
a
return
null
e
b
b
e
b
e
c
b
e
c
b
c
e
indexOf
c
b
c
e
indexOf
c
b
c
e
slice
c
length
c
b
e
replace
Q
indexOf
c
b
e
c
e
slice
c
length
c
CHILD
function
a
b
c
d
e
var
f
"nth"
a
slice
g
"last"
a
slice
4
h
"of-type"
b
return
d
e
function
a
return
a
parentNode
function
b
c
i
var
j
k
l
m
n
o
p
f
g
"nextSibling"
"previousSibling"
q
b
parentNode
r
h
b
nodeName
toLowerCase
s
i
h
if
q
if
f
while
p
l
b
while
l
l
p
if
h
l
nodeName
toLowerCase
r
l
nodeType
return
o
p
"only"
a
o
"nextSibling"
return
if
o
g
q
firstChild
q
lastChild
g
s
k
q
u
q
u
j
k
a
n
j
w
j
m
j
w
j
2
l
n
q
childNodes
n
while
l
n
l
l
p
m
n
o
pop
if
l
nodeType
m
l
b
k
a
w
n
m
break
else
if
s
j
b
u
b
u
a
j
w
m
j
else
while
l
n
l
l
p
m
n
o
pop
if
h
l
nodeName
toLowerCase
r
l
nodeType
m
s
l
u
l
u
a
w
m
l
b
break
return
m
e
m
d
m
d
m
d
PSEUDO
function
a
b
var
c
e
d
pseudos
a
d
setFilters
a
toLowerCase
ga
error
"unsupported pseudo: "
a
return
e
u
e
b
e
length
c
a
a
b
d
setFilters
hasOwnProperty
a
toLowerCase
ia
function
a
c
var
d
f
e
a
b
g
f
length
while
g
d
J
a
f
g
a
d
c
d
f
g
function
a
return
e
a
c
e
pseudos
not
ia
function
a
var
b
c
d
h
a
replace
R
"$1"
return
d
u
ia
function
a
b
c
e
var
f
g
d
a
null
e
h
a
length
while
h
f
g
h
a
h
b
h
f
function
a
e
f
return
b
a
d
b
null
f
c
b
null
c
pop
has
ia
function
a
return
function
b
return
ga
a
b
length
contains
ia
function
a
return
a
a
replace
ca
da
function
b
return
b
textContent
b
innerText
e
b
indexOf
a
lang
ia
function
a
return
W
test
a
ga
error
"unsupported lang: "
a
a
a
replace
ca
da
toLowerCase
function
b
var
c
do
if
c
p
b
lang
b
getAttribute
"xml:lang"
b
getAttribute
"lang"
return
c
c
toLowerCase
c
a
c
indexOf
a
while
b
b
parentNode
b
nodeType
return
target
function
b
var
c
a
location
a
location
hash
return
c
c
slice
b
id
root
function
a
return
a
o
focus
function
a
return
a
n
activeElement
n
hasFocus
n
hasFocus
a
type
a
href
a
tabIndex
enabled
function
a
return
a
disabled
disabled
function
a
return
a
disabled
checked
function
a
var
b
a
nodeName
toLowerCase
return
"input"
b
a
checked
"option"
b
a
selected
selected
function
a
return
a
parentNode
a
parentNode
selectedIndex
a
selected
empty
function
a
for
a
a
firstChild
a
a
a
nextSibling
if
a
nodeType
6
return
return
function
a
return
d
pseudos
empty
a
header
function
a
return
Z
test
a
nodeName
input
function
a
return
Y
test
a
nodeName
button
function
a
var
b
a
nodeName
toLowerCase
return
"input"
b
"button"
a
type
"button"
b
text
function
a
var
b
return
"input"
a
nodeName
toLowerCase
"text"
a
type
null
b
a
getAttribute
"type"
"text"
b
toLowerCase
first
oa
function
return
last
oa
function
a
b
return
b
eq
oa
function
a
b
c
return
c
c
b
c
even
oa
function
a
b
for
var
c
b
c
c
2
a
push
c
return
a
odd
oa
function
a
b
for
var
c
b
c
c
2
a
push
c
return
a
lt
oa
function
a
b
c
for
var
d
c
c
b
c
d
a
push
d
return
a
gt
oa
function
a
b
c
for
var
d
c
c
b
c
d
b
a
push
d
return
a
d
pseudos
nth
d
pseudos
eq
for
b
in
radio
checkbox
file
password
d
pseudos
b
ma
b
for
b
in
submit
reset
d
pseudos
b
na
b
function
qa
qa
prototype
d
filters
d
pseudos
d
setFilters
new
qa
g
ga
tokenize
function
a
b
var
c
e
f
g
h
i
j
k
z
a
if
k
return
b
k
slice
h
a
i
j
d
preFilter
while
h
c
e
S
exec
h
e
h
h
slice
e
length
h
i
push
f
c
e
T
exec
h
c
e
shift
f
push
value
c
type
e
replace
R
h
h
slice
c
length
for
g
in
d
filter
e
X
g
exec
h
j
g
e
j
g
e
c
e
shift
f
push
value
c
type
g
matches
e
h
h
slice
c
length
if
c
break
return
b
h
length
h
ga
error
a
z
a
i
slice
function
ra
a
for
var
b
c
a
length
d
c
b
b
d
a
b
value
return
d
function
sa
a
b
c
var
d
b
dir
e
c
"parentNode"
d
f
x
return
b
first
function
b
c
f
while
b
b
d
if
b
nodeType
e
return
a
b
c
f
function
b
c
g
var
h
i
j
w
f
if
g
while
b
b
d
if
b
nodeType
e
a
b
c
g
return
else
while
b
b
d
if
b
nodeType
e
if
i
b
u
b
u
h
i
d
h
w
h
f
return
j
2
h
2
if
i
d
j
j
2
a
b
c
g
return
function
ta
a
return
a
length
function
b
c
d
var
e
a
length
while
e
if
a
e
b
c
d
return
return
a
function
ua
a
b
c
for
var
d
e
b
length
e
d
d
ga
a
b
d
c
return
c
function
va
a
b
c
d
e
for
var
f
g
h
i
a
length
j
null
b
i
h
h
f
a
h
c
c
f
d
e
g
push
f
j
b
push
h
return
g
function
wa
a
b
c
d
e
f
return
d
d
u
d
wa
d
e
e
u
e
wa
e
f
ia
function
f
g
h
i
var
j
k
l
m
n
o
g
length
p
f
ua
b
h
nodeType
h
h
q
a
f
b
p
va
p
m
a
h
i
r
c
e
f
a
o
d
g
q
if
c
c
q
r
h
i
d
j
va
r
n
d
j
h
i
k
j
length
while
k
l
j
k
r
n
k
q
n
k
l
if
f
if
e
a
if
e
j
k
r
length
while
k
l
r
k
j
push
q
k
l
e
null
r
j
i
k
r
length
while
k
l
r
k
j
e
J
f
l
m
k
f
j
g
j
l
else
r
va
r
g
r
splice
o
r
length
r
e
e
null
g
r
i
H
apply
g
r
function
xa
a
for
var
b
c
e
f
a
length
g
d
relative
a
type
h
g
d
relative
i
g
k
sa
function
a
return
a
b
h
l
sa
function
a
return
J
b
a
h
m
function
a
c
d
var
e
g
d
c
j
b
c
nodeType
k
a
c
d
l
a
c
d
return
b
null
e
f
i
i
if
c
d
relative
a
i
type
m
sa
ta
m
c
else
if
c
d
filter
a
i
type
apply
null
a
i
matches
c
u
for
e
i
f
e
e
if
d
relative
a
e
type
break
return
wa
i
ta
m
i
ra
a
slice
i
concat
value
a
i
2
type
replace
R
"$1"
c
e
i
xa
a
slice
i
e
f
e
xa
a
a
slice
e
f
e
ra
a
m
push
c
return
ta
m
function
ya
a
b
var
c
b
length
e
a
length
f
function
f
g
h
i
k
var
l
m
o
p
q
"0"
r
f
s
t
j
u
f
e
d
find
TAG
k
v
w
null
t
Math
random
x
u
length
for
k
j
g
n
g
q
x
null
l
u
q
q
if
e
l
m
while
o
a
m
if
o
l
g
h
i
push
l
break
k
w
v
c
l
o
l
p
f
r
push
l
if
p
q
c
q
p
m
while
o
b
m
o
r
s
g
h
if
f
if
p
while
q
r
q
s
q
s
q
F
call
i
s
va
s
H
apply
i
s
k
f
s
length
p
b
length
ga
uniqueSort
i
return
k
w
v
j
t
r
return
c
ia
f
f
return
h
ga
compile
function
a
b
var
c
d
e
f
A
a
if
f
b
b
g
a
c
b
length
while
c
f
xa
b
c
f
u
d
push
f
e
push
f
f
A
a
ya
e
d
f
selector
a
return
f
i
ga
select
function
a
b
e
f
var
i
j
k
l
m
n
"function"
typeof
a
a
o
f
g
a
n
selector
a
if
e
e
o
length
if
j
o
o
slice
j
length
2
"ID"
k
j
type
c
getById
9
b
nodeType
p
d
relative
j
type
if
b
d
find
ID
k
matches
replace
ca
da
b
b
return
e
n
b
b
parentNode
a
a
slice
j
shift
value
length
i
X
needsContext
test
a
j
length
while
i
if
k
j
i
d
relative
l
k
type
break
if
m
d
find
l
f
m
k
matches
replace
ca
da
aa
test
j
type
pa
b
parentNode
b
if
j
splice
i
a
f
length
ra
j
a
return
H
apply
e
f
e
break
return
n
h
a
o
f
b
p
e
aa
test
a
pa
b
parentNode
b
e
c
sortStable
u
split
sort
B
join
u
c
detectDuplicates
l
m
c
sortDetached
ja
function
a
return
a
n
createElement
"div"
ja
function
a
return
a
innerHTML
"<a href='#'></a>"
a
firstChild
getAttribute
"href"
ka
"type|href|height|width"
function
a
b
c
return
c
void
a
getAttribute
b
"type"
b
toLowerCase
2
c
attributes
ja
function
a
return
a
innerHTML
"<input/>"
a
firstChild
setAttribute
"value"
a
firstChild
getAttribute
"value"
ka
"value"
function
a
b
c
return
c
"input"
a
nodeName
toLowerCase
void
a
defaultValue
ja
function
a
return
null
a
getAttribute
"disabled"
ka
K
function
a
b
c
var
d
return
c
void
a
b
b
toLowerCase
d
a
getAttributeNode
b
d
specified
d
value
null
ga
a
m
find
s
m
expr
s
selectors
m
expr
m
expr
pseudos
m
unique
s
uniqueSort
m
text
s
getText
m
isXMLDoc
s
isXML
m
contains
s
contains
var
t
m
expr
match
needsContext
u
(\w
)\s
\/\1
v
function
w
a
b
c
if
m
isFunction
b
return
m
grep
a
function
a
d
return
b
call
a
d
a
c
if
b
nodeType
return
m
grep
a
function
a
return
a
b
c
if
"string"
typeof
b
if
v
test
b
return
m
filter
b
a
c
b
m
filter
b
a
return
m
grep
a
function
a
return
m
inArray
a
b
c
m
filter
function
a
b
c
var
d
b
return
c
a
":not("
a
b
length
d
nodeType
m
find
matchesSelector
d
a
d
m
find
matches
a
m
grep
b
function
a
return
a
nodeType
m
fn
extend
find
function
a
var
b
c
d
this
e
d
length
if
"string"
typeof
a
return
this
pushStack
m
a
filter
function
for
b
e
b
b
if
m
contains
d
b
this
return
for
b
e
b
b
m
find
a
d
b
c
return
c
this
pushStack
e
m
unique
c
c
c
selector
this
selector
this
selector
a
a
c
filter
function
a
return
this
pushStack
w
this
a
not
function
a
return
this
pushStack
w
this
a
is
function
a
return
w
this
"string"
typeof
a
t
test
a
m
a
a
length
var
x
y
a
document
z
(?:\s
[\w\W]
([\w
A
m
fn
init
function
a
b
var
c
d
if
a
return
this
if
"string"
typeof
a
if
c
a
charAt
a
charAt
a
length
a
length
3
null
a
null
z
exec
a
c
c
b
return
b
b
jquery
b
x
find
a
this
constructor
b
find
a
if
c
if
b
b
instanceof
m
b
b
m
merge
this
m
parseHTML
c
b
b
nodeType
b
ownerDocument
b
y
u
test
c
m
isPlainObject
b
for
c
in
b
m
isFunction
this
c
this
c
b
c
this
attr
c
b
c
return
this
if
d
y
getElementById
c
2
d
d
parentNode
if
d
id
c
2
return
x
find
a
this
length
this
d
return
this
context
y
this
selector
a
this
return
a
nodeType
this
context
this
a
this
length
this
m
isFunction
a
"undefined"
typeof
x
ready
x
ready
a
a
m
void
a
selector
this
selector
a
selector
this
context
a
context
m
makeArray
a
this
A
prototype
m
fn
x
m
y
var
B
parents|prev
Until|All
C
children
contents
next
prev
m
extend
dir
function
a
b
c
var
d
e
a
b
while
e
9
e
nodeType
void
c
e
nodeType
m
e
is
c
e
nodeType
d
push
e
e
e
b
return
d
sibling
function
a
b
for
var
c
a
a
a
nextSibling
a
nodeType
a
b
c
push
a
return
c
m
fn
extend
has
function
a
var
b
c
m
a
this
d
c
length
return
this
filter
function
for
b
d
b
b
if
m
contains
this
c
b
return
closest
function
a
b
for
var
c
d
e
this
length
f
g
t
test
a
"string"
typeof
a
m
a
b
this
context
e
d
d
for
c
this
d
c
c
b
c
c
parentNode
if
c
nodeType
11
g
g
index
c
c
nodeType
m
find
matchesSelector
c
a
f
push
c
break
return
this
pushStack
f
length
m
unique
f
f
index
function
a
return
a
"string"
typeof
a
m
inArray
this
m
a
m
inArray
a
jquery
a
a
this
this
this
parentNode
this
first
prevAll
length
add
function
a
b
return
this
pushStack
m
unique
m
merge
this
get
m
a
b
addBack
function
a
return
this
add
null
a
this
prevObject
this
prevObject
filter
a
function
D
a
b
do
a
a
b
while
a
a
nodeType
return
a
m
each
function
a
var
b
a
parentNode
return
b
11
b
nodeType
b
null
parents
function
a
return
m
dir
a
"parentNode"
parentsUntil
function
a
b
c
return
m
dir
a
"parentNode"
c
next
function
a
return
D
a
"nextSibling"
prev
function
a
return
D
a
"previousSibling"
nextAll
function
a
return
m
dir
a
"nextSibling"
prevAll
function
a
return
m
dir
a
"previousSibling"
nextUntil
function
a
b
c
return
m
dir
a
"nextSibling"
c
prevUntil
function
a
b
c
return
m
dir
a
"previousSibling"
c
siblings
function
a
return
m
sibling
a
parentNode
firstChild
a
children
function
a
return
m
sibling
a
firstChild
contents
function
a
return
m
nodeName
a
"iframe"
a
contentDocument
a
contentWindow
document
m
merge
a
childNodes
function
a
b
m
fn
a
function
c
d
var
e
m
map
this
b
c
return
"Until"
a
slice
5
d
c
d
"string"
typeof
d
e
m
filter
d
e
this
length
C
a
e
m
unique
e
B
test
a
e
e
reverse
this
pushStack
e
var
E
\S
+/g
F
function
G
a
var
b
F
a
return
m
each
a
match
E
function
a
c
b
c
b
m
Callbacks
function
a
a
"string"
typeof
a
F
a
G
a
m
extend
a
var
b
c
d
e
f
g
h
i
a
once
j
function
l
for
c
a
memory
l
d
f
g
g
e
h
length
b
h
e
f
f
if
h
f
apply
l
l
a
stopOnFalse
c
break
b
h
i
i
length
j
i
shift
c
h
k
disable
k
add
function
if
h
var
d
h
length
function
f
b
m
each
b
function
b
c
var
d
m
type
c
"function"
d
a
unique
k
has
c
h
push
c
c
c
length
"string"
d
f
c
arguments
b
e
h
length
c
g
d
j
c
return
this
remove
function
return
h
m
each
arguments
function
a
c
var
d
while
d
m
inArray
c
h
d
h
splice
d
b
e
d
e
f
d
f
this
has
function
a
return
a
m
inArray
a
h
h
h
length
empty
function
return
h
e
this
disable
function
return
h
i
c
void
this
disabled
function
return
h
lock
function
return
i
void
c
k
disable
this
locked
function
return
i
fireWith
function
a
c
return
h
d
i
c
c
c
a
c
slice
c
slice
c
b
i
push
c
j
c
this
fire
function
return
k
fireWith
this
arguments
this
fired
function
return
d
return
k
m
extend
Deferred
function
a
var
b
"resolve"
"done"
m
Callbacks
"once memory"
"resolved"
"reject"
"fail"
m
Callbacks
"once memory"
"rejected"
"notify"
"progress"
m
Callbacks
"memory"
c
"pending"
d
state
function
return
c
always
function
return
e
done
arguments
fail
arguments
this
then
function
var
a
arguments
return
m
Deferred
function
c
m
each
b
function
b
f
var
g
m
isFunction
a
b
a
b
e
f
function
var
a
g
g
apply
this
arguments
a
m
isFunction
a
promise
a
promise
done
c
resolve
fail
c
reject
progress
c
notify
c
f
"With"
this
d
c
promise
this
g
a
arguments
a
null
promise
promise
function
a
return
null
a
m
extend
a
d
d
e
return
d
pipe
d
then
m
each
b
function
a
f
var
g
f
2
h
f
3
d
f
g
add
h
g
add
function
c
h
b
a
2
disable
b
2
2
lock
e
f
function
return
e
f
"With"
this
e
d
this
arguments
this
e
f
"With"
g
fireWith
d
promise
e
a
a
call
e
e
e
when
function
a
var
b
c
d
call
arguments
e
c
length
f
e
a
m
isFunction
a
promise
e
g
f
a
m
Deferred
h
function
a
b
c
return
function
e
b
a
this
c
a
arguments
length
d
call
arguments
e
c
i
g
notifyWith
b
c
f
g
resolveWith
b
c
i
j
k
if
e
for
i
new
Array
e
j
new
Array
e
k
new
Array
e
e
b
b
c
b
m
isFunction
c
b
promise
c
b
promise
done
h
b
k
c
fail
g
reject
progress
h
b
j
i
f
return
f
g
resolveWith
k
c
g
promise
var
H
m
fn
ready
function
a
return
m
ready
promise
done
a
this
m
extend
isReady
readyWait
holdReady
function
a
a
m
readyWait
m
ready
ready
function
a
if
a
m
readyWait
m
isReady
if
y
body
return
setTimeout
m
ready
m
isReady
a
m
readyWait
H
resolveWith
y
m
m
fn
triggerHandler
m
y
triggerHandler
"ready"
m
y
off
"ready"
function
I
y
addEventListener
y
removeEventListener
"DOMContentLoaded"
J
a
removeEventListener
"load"
J
y
detachEvent
"onreadystatechange"
J
a
detachEvent
"onload"
J
function
J
y
addEventListener
"load"
event
type
"complete"
y
readyState
I
m
ready
m
ready
promise
function
b
if
H
if
H
m
Deferred
"complete"
y
readyState
setTimeout
m
ready
else
if
y
addEventListener
y
addEventListener
"DOMContentLoaded"
J
a
addEventListener
"load"
J
else
y
attachEvent
J
a
attachEvent
"onload"
J
var
c
try
c
null
a
frameElement
y
documentElement
catch
d
c
c
doScroll
function
e
if
m
isReady
try
c
doScroll
"left"
catch
a
return
setTimeout
e
50
I
m
ready
return
H
promise
b
var
K
"undefined"
L
for
L
in
m
k
break
k
ownLast
"0"
L
k
inlineBlockNeedsLayout
m
function
var
a
b
c
d
c
y
"body"
c
c
style
b
y
createElement
"div"
d
y
createElement
"div"
d
style
cssText
"position:absolute;border:0;width:0;height:0;top:0;left:-9999px"
c
appendChild
d
appendChild
b
typeof
b
style
zoom
K
b
style
cssText
"display:inline;margin:0;border:0;padding:1px;width:1px;zoom:1"
k
a
3
b
offsetWidth
a
c
style
zoom
c
removeChild
d
function
var
a
y
createElement
"div"
if
null
k
deleteExpando
k
deleteExpando
try
delete
a
test
catch
b
k
deleteExpando
a
null
m
acceptData
function
a
var
b
m
noData
a
nodeName
toLowerCase
c
a
nodeType
return
c
9
c
b
b
a
getAttribute
"classid"
b
var
(?:\{[\w\W]
\[[\w\W]
N
A-Z
/g
function
O
a
b
c
if
void
c
a
nodeType
var
d
"data-"
b
replace
N
"-$1"
toLowerCase
if
c
a
getAttribute
d
"string"
typeof
c
try
c
"true"
c
"false"
c
"null"
c
null
c
c
c
test
c
m
parseJSON
c
c
catch
e
m
a
b
c
else
c
void
return
c
function
P
a
var
b
for
b
in
a
if
"data"
b
m
isEmptyObject
a
b
"toJSON"
b
return
function
a
b
"object"
typeof
module
"object"
typeof
module
exports
module
exports
a
document
b
a
function
a
if
a
document
throw
new
Error
return
b
a
b
a
"undefined"
typeof
window
window
this
function
a
b
var
c
d
c
slice
e
c
concat
f
c
push
g
c
indexOf
h
i
h
toString
j
h
hasOwnProperty
k
l
"1.11.3"
m
function
a
b
return
new
m
fn
init
a
b
n
[\s\u
FEFF
\x
A0
[\s\u
FEFF
\x
A0
+$/g
o
/^-ms-/
p
([\d
a-z
/gi
q
function
a
b
return
b
toUpperCase
m
fn
m
prototype
jquery
l
constructor
m
selector
length
toArray
function
return
d
call
this
get
function
a
return
null
a
a
this
a
this
length
this
a
d
call
this
pushStack
function
a
var
b
m
merge
this
constructor
a
return
b
prevObject
this
b
context
this
context
b
each
function
a
b
return
m
each
this
a
b
map
function
a
return
this
pushStack
m
map
this
function
b
c
return
a
call
b
c
b
slice
function
return
this
pushStack
d
apply
this
arguments
first
function
return
this
eq
last
function
return
this
eq
eq
function
a
var
b
this
length
c
a
a
b
return
this
pushStack
c
b
c
this
c
function
return
this
prevObject
this
constructor
null
push
f
sort
c
sort
splice
c
splice
m
extend
m
fn
extend
function
var
a
b
c
d
e
f
g
arguments
h
i
arguments
length
j
for
"boolean"
typeof
g
j
g
g
arguments
h
h
"object"
typeof
g
m
isFunction
g
g
h
i
g
this
h
i
h
h
if
null
e
arguments
h
for
d
in
e
a
g
d
c
e
d
g
c
j
c
m
isPlainObject
c
b
m
isArray
c
b
b
f
a
m
isArray
a
a
f
a
m
isPlainObject
a
a
g
d
m
extend
j
f
c
void
c
g
d
c
return
g
m
extend
expando
"jQuery"
l
Math
random
replace
\D
/g
isReady
error
function
a
throw
new
Error
a
noop
function
isFunction
function
a
return
"function"
m
type
a
isArray
Array
isArray
function
a
return
"array"
m
type
a
isWindow
function
a
return
null
a
a
a
window
isNumeric
function
a
return
m
isArray
a
a
parseFloat
a
isEmptyObject
function
a
var
b
for
b
in
a
return
return
isPlainObject
function
a
var
b
if
a
"object"
m
type
a
a
nodeType
m
isWindow
a
return
try
if
a
constructor
j
call
a
"constructor"
j
call
a
constructor
prototype
"isPrototypeOf"
return
catch
c
return
if
k
ownLast
for
b
in
a
return
j
call
a
b
for
b
in
a
return
void
b
j
call
a
b
type
function
a
return
null
a
a
"object"
typeof
a
"function"
typeof
a
h
i
call
a
"object"
typeof
a
globalEval
function
b
b
m
trim
b
a
execScript
function
b
a
eval
call
a
b
b
camelCase
function
a
return
a
replace
o
"ms-"
replace
p
q
nodeName
function
a
b
return
a
nodeName
a
nodeName
toLowerCase
b
toLowerCase
each
function
a
b
c
var
d
e
f
a
length
g
r
a
if
c
if
g
for
f
e
e
if
d
b
apply
a
e
c
d
break
else
for
e
in
a
if
d
b
apply
a
e
c
d
break
else
if
g
for
f
e
e
if
d
b
call
a
e
e
a
e
d
break
else
for
e
in
a
if
d
b
call
a
e
e
a
e
d
break
return
a
trim
function
a
return
null
a
a
replace
n
makeArray
function
a
b
var
c
b
return
null
a
r
Object
a
m
merge
c
"string"
typeof
a
a
a
f
call
c
a
c
inArray
function
a
b
c
var
d
if
b
if
g
return
g
call
b
a
c
for
d
b
length
c
c
c
Math
max
d
c
c
d
c
c
if
c
in
b
b
c
a
return
c
return
merge
function
a
b
var
c
b
length
d
e
a
length
while
c
d
a
e
b
d
if
c
c
while
void
b
d
a
e
b
d
return
a
length
e
a
grep
function
a
b
c
for
var
d
e
f
g
a
length
h
c
g
f
f
d
b
a
f
f
d
h
e
push
a
f
return
e
map
function
a
b
c
var
d
f
g
a
length
h
r
a
i
if
h
for
g
f
f
d
b
a
f
f
c
null
d
i
push
d
else
for
f
in
a
d
b
a
f
f
c
null
d
i
push
d
return
e
apply
i
guid
proxy
function
a
b
var
c
e
f
return
"string"
typeof
b
f
a
b
b
a
a
f
m
isFunction
a
c
d
call
arguments
2
e
function
return
a
apply
b
this
c
concat
d
call
arguments
e
guid
a
guid
a
guid
m
guid
e
void
now
function
return
new
Date
support
k
m
each
split
function
a
b
h
"[object "
b
b
toLowerCase
function
r
a
var
b
"length"
in
a
a
length
c
m
type
a
return
"function"
c
m
isWindow
a
a
nodeType
b
"array"
c
b
"number"
typeof
b
b
b
in
a
var
s
function
a
var
b
c
d
e
f
g
h
i
j
k
l
m
n
o
p
q
r
s
t
u
"sizzle"
new
Date
v
a
document
w
x
y
ha
z
ha
A
ha
B
function
a
b
return
a
b
l
C
31
D
hasOwnProperty
E
F
E
pop
G
E
push
H
E
push
I
E
slice
J
function
a
b
for
var
c
d
a
length
d
c
c
if
a
c
b
return
c
return
K
L
x20
t
r
\n
f]"
w-]|[^
x00-
xa0])+"
N
replace
"w"
"w#"
O
L
L
L
N
L
P
O
Q
new
RegExp
L
"g"
R
new
RegExp
L
L
"g"
S
new
RegExp
L
L
T
new
RegExp
L
L
L
U
new
RegExp
L
L
"g"
V
new
RegExp
P
W
new
RegExp
N
X
ID
new
RegExp
CLASS
new
RegExp
TAG
new
RegExp
replace
"w"
"w*"
ATTR
new
RegExp
O
PSEUDO
new
RegExp
P
CHILD
new
RegExp
L
d*)n|)"
L
L
d+)|))"
L
"i"
bool
new
RegExp
K
"i"
needsContext
new
RegExp
L
L
d)?
d*)"
L
"i"
Y
$/i
Z
/^h
\d
$/i
\{\s
native
\w
_
([\w
(\w
\.([\w
aa
ba
/g
ca
new
RegExp
da-f]{1,6}"
L
L
"ig"
da
function
a
b
c
var
d
"0x"
b
65536
return
d
d
c
b
d
String
fromCharCode
d
65536
String
fromCharCode
d
10
55296
1023
d
56320
ea
function
m
try
H
apply
E
I
call
v
childNodes
v
childNodes
E
v
childNodes
length
nodeType
catch
fa
H
apply
E
length
function
a
b
G
apply
a
I
call
b
function
a
b
var
c
a
length
d
while
a
c
b
d
a
length
c
function
ga
a
b
d
e
var
f
h
j
k
l
o
r
s
w
x
if
b
b
ownerDocument
b
v
n
m
b
b
b
n
d
d
k
b
nodeType
"string"
typeof
a
a
k
9
k
11
k
return
d
if
e
p
if
11
k
f
_
exec
a
if
j
f
if
9
k
if
h
b
getElementById
j
h
h
parentNode
return
d
if
h
id
j
return
d
push
h
d
else
if
b
ownerDocument
h
b
ownerDocument
getElementById
j
t
b
h
h
id
j
return
d
push
h
d
else
if
f
2
return
H
apply
d
b
a
d
if
j
f
3
c
return
H
apply
d
b
j
d
if
c
qsa
q
q
test
a
if
s
r
u
w
b
x
k
a
k
"object"
b
nodeName
toLowerCase
o
g
a
r
b
getAttribute
"id"
s
r
replace
ba
b
setAttribute
"id"
s
s
"[id='"
s
l
o
length
while
l
o
l
s
ra
o
l
w
aa
test
a
pa
b
parentNode
b
x
o
join
if
x
try
return
H
apply
d
w
querySelectorAll
x
d
catch
y
finally
r
b
removeAttribute
"id"
return
i
a
replace
R
"$1"
b
d
e
function
ha
var
a
function
b
c
e
return
a
push
c
d
cacheLength
delete
b
a
shift
b
c
e
return
b
function
ia
a
return
a
u
a
function
ja
a
var
b
n
createElement
"div"
try
return
a
b
catch
c
return
finally
b
parentNode
b
parentNode
removeChild
b
b
null
function
ka
a
b
var
c
a
split
e
a
length
while
e
d
attrHandle
c
e
b
function
la
a
b
var
c
b
a
d
c
a
nodeType
b
nodeType
b
sourceIndex
C
a
sourceIndex
C
if
d
return
d
if
c
while
c
c
nextSibling
if
c
b
return
return
a
function
ma
a
return
function
b
var
c
b
nodeName
toLowerCase
return
"input"
c
b
type
a
function
na
a
return
function
b
var
c
b
nodeName
toLowerCase
return
"input"
c
"button"
c
b
type
a
function
oa
a
return
ia
function
b
return
b
b
ia
function
c
d
var
e
f
a
c
length
b
g
f
length
while
g
c
e
f
g
c
e
d
e
c
e
function
pa
a
return
a
"undefined"
typeof
a
a
c
ga
support
f
ga
isXML
function
a
var
b
a
a
ownerDocument
a
documentElement
return
b
"HTML"
b
nodeName
m
ga
setDocument
function
a
var
b
e
g
a
a
ownerDocument
a
v
return
g
n
9
g
nodeType
g
documentElement
n
g
o
g
documentElement
e
g
defaultView
e
e
e
top
e
addEventListener
e
addEventListener
"unload"
ea
e
attachEvent
e
attachEvent
"onunload"
ea
p
f
g
c
attributes
ja
function
a
return
a
className
"i"
a
getAttribute
"className"
c
ja
function
a
return
a
appendChild
g
createComment
a
length
c
test
g
c
getById
ja
function
a
return
o
appendChild
a
id
u
g
getElementsByName
g
getElementsByName
u
length
c
getById
d
find
ID
function
a
b
if
"undefined"
typeof
b
getElementById
p
var
c
b
getElementById
a
return
c
c
parentNode
c
d
filter
ID
function
a
var
b
a
replace
ca
da
return
function
a
return
a
getAttribute
"id"
b
delete
d
find
ID
d
filter
ID
function
a
var
b
a
replace
ca
da
return
function
a
var
c
"undefined"
typeof
a
getAttributeNode
a
getAttributeNode
"id"
return
c
c
value
b
d
find
TAG
c
function
a
b
return
"undefined"
typeof
b
b
a
c
qsa
b
querySelectorAll
a
void
function
a
b
var
c
d
e
f
b
a
if
a
while
c
f
e
c
nodeType
d
push
c
return
d
return
f
d
find
CLASS
c
function
a
b
return
p
b
a
void
r
q
c
qsa
test
g
querySelectorAll
ja
function
a
o
appendChild
a
innerHTML
"<a id='"
u
u
a
querySelectorAll
length
q
push
L
a
querySelectorAll
"[selected]"
length
q
push
L
"*(?:value|"
K
a
querySelectorAll
"[id~="
u
length
q
push
a
querySelectorAll
":checked"
length
q
push
":checked"
a
querySelectorAll
"a#"
u
length
q
push
ja
function
a
var
b
g
createElement
"input"
b
setAttribute
"type"
"hidden"
a
appendChild
b
setAttribute
"name"
"D"
a
querySelectorAll
"[name=d]"
length
q
push
"name"
L
a
querySelectorAll
":enabled"
length
q
push
":enabled"
":disabled"
a
querySelectorAll
"*,:x"
q
push
c
matchesSelector
test
s
o
matches
o
o
mozMatchesSelector
o
oMatchesSelector
o
msMatchesSelector
ja
function
a
c
disconnectedMatch
s
call
a
"div"
s
call
a
"[s!='']:x"
r
push
P
q
q
length
new
RegExp
q
join
r
r
length
new
RegExp
r
join
b
test
o
t
b
test
o
contains
function
a
b
var
c
9
a
nodeType
a
documentElement
a
d
b
b
parentNode
return
a
d
d
d
nodeType
c
contains
c
contains
d
a
16
a
d
function
a
b
if
b
while
b
b
parentNode
if
b
a
return
return
B
b
function
a
b
if
a
b
return
l
var
d
a
b
return
d
d
d
a
ownerDocument
a
b
ownerDocument
b
a
b
d
c
sortDetached
b
a
d
a
g
a
ownerDocument
v
t
v
a
b
g
b
ownerDocument
v
t
v
b
k
J
k
a
J
k
b
d
function
a
b
if
a
b
return
l
var
c
d
e
a
parentNode
f
b
parentNode
h
a
i
b
if
e
f
return
a
g
b
g
e
f
k
J
k
a
J
k
b
if
e
f
return
la
a
b
c
a
while
c
c
parentNode
h
unshift
c
c
b
while
c
c
parentNode
i
unshift
c
while
h
d
i
d
d
return
d
la
h
d
i
d
h
d
v
i
d
v
g
n
ga
matches
function
a
b
return
ga
a
null
null
b
ga
matchesSelector
function
a
b
if
a
ownerDocument
a
n
m
a
b
b
replace
U
"='$1']"
c
matchesSelector
p
r
r
test
b
q
q
test
b
try
var
d
s
call
a
b
if
d
c
disconnectedMatch
a
document
11
a
document
nodeType
return
d
catch
e
return
ga
b
n
null
a
length
ga
contains
function
a
b
return
a
ownerDocument
a
n
m
a
t
a
b
ga
attr
function
a
b
a
ownerDocument
a
n
m
a
var
e
d
attrHandle
b
toLowerCase
f
e
D
call
d
attrHandle
b
toLowerCase
e
a
b
p
void
return
void
f
f
c
attributes
p
a
getAttribute
b
f
a
getAttributeNode
b
f
specified
f
value
null
ga
error
function
a
throw
new
Error
a
ga
uniqueSort
function
a
var
b
d
e
f
if
l
c
detectDuplicates
k
c
sortStable
a
slice
a
sort
B
l
while
b
a
f
b
a
f
e
d
push
f
while
e
a
splice
d
e
return
k
null
a
e
ga
getText
function
a
var
b
c
d
f
a
nodeType
if
f
if
f
9
f
11
f
if
"string"
typeof
a
textContent
return
a
textContent
for
a
a
firstChild
a
a
a
nextSibling
c
e
a
else
if
3
f
4
f
return
a
nodeValue
else
while
b
a
d
c
e
b
return
c
d
ga
selectors
cacheLength
50
createPseudo
ia
match
X
attrHandle
find
relative
dir
"parentNode"
first
dir
"parentNode"
dir
"previousSibling"
first
dir
"previousSibling"
preFilter
ATTR
function
a
return
a
a
replace
ca
da
a
3
a
3
a
4
a
5
replace
ca
da
a
2
a
3
a
3
a
slice
CHILD
function
a
return
a
a
toLowerCase
"nth"
a
slice
a
3
ga
error
a
a
4
a
4
a
5
a
6
2
"even"
a
3
"odd"
a
3
a
5
a
7
a
8
"odd"
a
3
a
3
ga
error
a
a
PSEUDO
function
a
var
b
c
a
6
a
2
return
X
CHILD
test
a
null
a
3
a
2
a
4
a
5
c
V
test
c
b
g
c
b
c
indexOf
c
length
b
c
length
a
a
slice
b
a
2
c
slice
b
a
slice
filter
TAG
function
a
var
b
a
replace
ca
da
toLowerCase
return
a
function
return
function
a
return
a
nodeName
a
nodeName
toLowerCase
b
CLASS
function
a
var
b
y
a
return
b
b
new
RegExp
L
a
L
y
a
function
a
return
b
test
"string"
typeof
a
className
a
className
"undefined"
typeof
a
getAttribute
a
getAttribute
"class"
ATTR
function
a
b
c
return
function
d
var
e
ga
attr
d
a
return
null
e
b
b
e
b
e
c
b
e
c
b
c
e
indexOf
c
b
c
e
indexOf
c
b
c
e
slice
c
length
c
b
e
replace
Q
indexOf
c
b
e
c
e
slice
c
length
c
CHILD
function
a
b
c
d
e
var
f
"nth"
a
slice
g
"last"
a
slice
4
h
"of-type"
b
return
d
e
function
a
return
a
parentNode
function
b
c
i
var
j
k
l
m
n
o
p
f
g
"nextSibling"
"previousSibling"
q
b
parentNode
r
h
b
nodeName
toLowerCase
s
i
h
if
q
if
f
while
p
l
b
while
l
l
p
if
h
l
nodeName
toLowerCase
r
l
nodeType
return
o
p
"only"
a
o
"nextSibling"
return
if
o
g
q
firstChild
q
lastChild
g
s
k
q
u
q
u
j
k
a
n
j
w
j
m
j
w
j
2
l
n
q
childNodes
n
while
l
n
l
l
p
m
n
o
pop
if
l
nodeType
m
l
b
k
a
w
n
m
break
else
if
s
j
b
u
b
u
a
j
w
m
j
else
while
l
n
l
l
p
m
n
o
pop
if
h
l
nodeName
toLowerCase
r
l
nodeType
m
s
l
u
l
u
a
w
m
l
b
break
return
m
e
m
d
m
d
m
d
PSEUDO
function
a
b
var
c
e
d
pseudos
a
d
setFilters
a
toLowerCase
ga
error
a
return
e
u
e
b
e
length
c
a
a
b
d
setFilters
hasOwnProperty
a
toLowerCase
ia
function
a
c
var
d
f
e
a
b
g
f
length
while
g
d
J
a
f
g
a
d
c
d
f
g
function
a
return
e
a
c
e
pseudos
not
ia
function
a
var
b
c
d
h
a
replace
R
"$1"
return
d
u
ia
function
a
b
c
e
var
f
g
d
a
null
e
h
a
length
while
h
f
g
h
a
h
b
h
f
function
a
e
f
return
b
a
d
b
null
f
c
b
null
c
pop
has
ia
function
a
return
function
b
return
ga
a
b
length
contains
ia
function
a
return
a
a
replace
ca
da
function
b
return
b
textContent
b
innerText
e
b
indexOf
a
lang
ia
function
a
return
W
test
a
ga
error
a
a
a
replace
ca
da
toLowerCase
function
b
var
c
do
if
c
p
b
lang
b
getAttribute
"xml:lang"
b
getAttribute
"lang"
return
c
c
toLowerCase
c
a
c
indexOf
a
while
b
b
parentNode
b
nodeType
return
target
function
b
var
c
a
location
a
location
hash
return
c
c
slice
b
id
root
function
a
return
a
o
focus
function
a
return
a
n
activeElement
n
hasFocus
n
hasFocus
a
type
a
href
a
tabIndex
enabled
function
a
return
a
disabled
disabled
function
a
return
a
disabled
checked
function
a
var
b
a
nodeName
toLowerCase
return
"input"
b
a
checked
"option"
b
a
selected
selected
function
a
return
a
parentNode
a
parentNode
selectedIndex
a
selected
empty
function
a
for
a
a
firstChild
a
a
a
nextSibling
if
a
nodeType
6
return
return
function
a
return
d
pseudos
empty
a
header
function
a
return
Z
test
a
nodeName
input
function
a
return
Y
test
a
nodeName
button
function
a
var
b
a
nodeName
toLowerCase
return
"input"
b
"button"
a
type
"button"
b
text
function
a
var
b
return
"input"
a
nodeName
toLowerCase
"text"
a
type
null
b
a
getAttribute
"type"
"text"
b
toLowerCase
first
oa
function
return
last
oa
function
a
b
return
b
eq
oa
function
a
b
c
return
c
c
b
c
even
oa
function
a
b
for
var
c
b
c
c
2
a
push
c
return
a
odd
oa
function
a
b
for
var
c
b
c
c
2
a
push
c
return
a
lt
oa
function
a
b
c
for
var
d
c
c
b
c
d
a
push
d
return
a
gt
oa
function
a
b
c
for
var
d
c
c
b
c
d
b
a
push
d
return
a
d
pseudos
nth
d
pseudos
eq
for
b
in
radio
checkbox
file
password
d
pseudos
b
ma
b
for
b
in
submit
reset
d
pseudos
b
na
b
function
qa
qa
prototype
d
filters
d
pseudos
d
setFilters
new
qa
g
ga
tokenize
function
a
b
var
c
e
f
g
h
i
j
k
z
a
if
k
return
b
k
slice
h
a
i
j
d
preFilter
while
h
c
e
S
exec
h
e
h
h
slice
e
length
h
i
push
f
c
e
T
exec
h
c
e
shift
f
push
value
c
type
e
replace
R
h
h
slice
c
length
for
g
in
d
filter
e
X
g
exec
h
j
g
e
j
g
e
c
e
shift
f
push
value
c
type
g
matches
e
h
h
slice
c
length
if
c
break
return
b
h
length
h
ga
error
a
z
a
i
slice
function
ra
a
for
var
b
c
a
length
d
c
b
b
d
a
b
value
return
d
function
sa
a
b
c
var
d
b
dir
e
c
"parentNode"
d
f
x
return
b
first
function
b
c
f
while
b
b
d
if
b
nodeType
e
return
a
b
c
f
function
b
c
g
var
h
i
j
w
f
if
g
while
b
b
d
if
b
nodeType
e
a
b
c
g
return
else
while
b
b
d
if
b
nodeType
e
if
i
b
u
b
u
h
i
d
h
w
h
f
return
j
2
h
2
if
i
d
j
j
2
a
b
c
g
return
function
ta
a
return
a
length
function
b
c
d
var
e
a
length
while
e
if
a
e
b
c
d
return
return
a
function
ua
a
b
c
for
var
d
e
b
length
e
d
d
ga
a
b
d
c
return
c
function
va
a
b
c
d
e
for
var
f
g
h
i
a
length
j
null
b
i
h
h
f
a
h
c
c
f
d
e
g
push
f
j
b
push
h
return
g
function
wa
a
b
c
d
e
f
return
d
d
u
d
wa
d
e
e
u
e
wa
e
f
ia
function
f
g
h
i
var
j
k
l
m
n
o
g
length
p
f
ua
b
h
nodeType
h
h
q
a
f
b
p
va
p
m
a
h
i
r
c
e
f
a
o
d
g
q
if
c
c
q
r
h
i
d
j
va
r
n
d
j
h
i
k
j
length
while
k
l
j
k
r
n
k
q
n
k
l
if
f
if
e
a
if
e
j
k
r
length
while
k
l
r
k
j
push
q
k
l
e
null
r
j
i
k
r
length
while
k
l
r
k
j
e
J
f
l
m
k
f
j
g
j
l
else
r
va
r
g
r
splice
o
r
length
r
e
e
null
g
r
i
H
apply
g
r
function
xa
a
for
var
b
c
e
f
a
length
g
d
relative
a
type
h
g
d
relative
i
g
k
sa
function
a
return
a
b
h
l
sa
function
a
return
J
b
a
h
m
function
a
c
d
var
e
g
d
c
j
b
c
nodeType
k
a
c
d
l
a
c
d
return
b
null
e
f
i
i
if
c
d
relative
a
i
type
m
sa
ta
m
c
else
if
c
d
filter
a
i
type
apply
null
a
i
matches
c
u
for
e
i
f
e
e
if
d
relative
a
e
type
break
return
wa
i
ta
m
i
ra
a
slice
i
concat
value
a
i
2
type
replace
R
"$1"
c
e
i
xa
a
slice
i
e
f
e
xa
a
a
slice
e
f
e
ra
a
m
push
c
return
ta
m
function
ya
a
b
var
c
b
length
e
a
length
f
function
f
g
h
i
k
var
l
m
o
p
q
"0"
r
f
s
t
j
u
f
e
d
find
TAG
k
v
w
null
t
Math
random
x
u
length
for
k
j
g
n
g
q
x
null
l
u
q
q
if
e
l
m
while
o
a
m
if
o
l
g
h
i
push
l
break
k
w
v
c
l
o
l
p
f
r
push
l
if
p
q
c
q
p
m
while
o
b
m
o
r
s
g
h
if
f
if
p
while
q
r
q
s
q
s
q
F
call
i
s
va
s
H
apply
i
s
k
f
s
length
p
b
length
ga
uniqueSort
i
return
k
w
v
j
t
r
return
c
ia
f
f
return
h
ga
compile
function
a
b
var
c
d
e
f
A
a
if
f
b
b
g
a
c
b
length
while
c
f
xa
b
c
f
u
d
push
f
e
push
f
f
A
a
ya
e
d
f
selector
a
return
f
i
ga
select
function
a
b
e
f
var
i
j
k
l
m
n
"function"
typeof
a
a
o
f
g
a
n
selector
a
if
e
e
o
length
if
j
o
o
slice
j
length
2
"ID"
k
j
type
c
getById
9
b
nodeType
p
d
relative
j
type
if
b
d
find
ID
k
matches
replace
ca
da
b
b
return
e
n
b
b
parentNode
a
a
slice
j
shift
value
length
i
X
needsContext
test
a
j
length
while
i
if
k
j
i
d
relative
l
k
type
break
if
m
d
find
l
f
m
k
matches
replace
ca
da
aa
test
j
type
pa
b
parentNode
b
if
j
splice
i
a
f
length
ra
j
a
return
H
apply
e
f
e
break
return
n
h
a
o
f
b
p
e
aa
test
a
pa
b
parentNode
b
e
c
sortStable
u
split
sort
B
join
u
c
detectDuplicates
l
m
c
sortDetached
ja
function
a
return
a
n
createElement
"div"
ja
function
a
return
a
innerHTML
"<a href='#'></a>"
a
firstChild
getAttribute
"href"
ka
function
a
b
c
return
c
void
a
getAttribute
b
"type"
b
toLowerCase
2
c
attributes
ja
function
a
return
a
innerHTML
"<input/>"
a
firstChild
setAttribute
"value"
a
firstChild
getAttribute
"value"
ka
"value"
function
a
b
c
return
c
"input"
a
nodeName
toLowerCase
void
a
defaultValue
ja
function
a
return
null
a
getAttribute
"disabled"
ka
K
function
a
b
c
var
d
return
c
void
a
b
b
toLowerCase
d
a
getAttributeNode
b
d
specified
d
value
null
ga
a
m
find
s
m
expr
s
selectors
m
expr
m
expr
pseudos
m
unique
s
uniqueSort
m
text
s
getText
m
isXMLDoc
s
isXML
m
contains
s
contains
var
t
m
expr
match
needsContext
u
(\w
)\s
\/\1
v
function
w
a
b
c
if
m
isFunction
b
return
m
grep
a
function
a
d
return
b
call
a
d
a
c
if
b
nodeType
return
m
grep
a
function
a
return
a
b
c
if
"string"
typeof
b
if
v
test
b
return
m
filter
b
a
c
b
m
filter
b
a
return
m
grep
a
function
a
return
m
inArray
a
b
c
m
filter
function
a
b
c
var
d
b
return
c
a
":not("
a
b
length
d
nodeType
m
find
matchesSelector
d
a
d
m
find
matches
a
m
grep
b
function
a
return
a
nodeType
m
fn
extend
find
function
a
var
b
c
d
this
e
d
length
if
"string"
typeof
a
return
this
pushStack
m
a
filter
function
for
b
e
b
b
if
m
contains
d
b
this
return
for
b
e
b
b
m
find
a
d
b
c
return
c
this
pushStack
e
m
unique
c
c
c
selector
this
selector
this
selector
a
a
c
filter
function
a
return
this
pushStack
w
this
a
not
function
a
return
this
pushStack
w
this
a
is
function
a
return
w
this
"string"
typeof
a
t
test
a
m
a
a
length
var
x
y
a
document
z
(?:\s
[\w\W]
([\w
A
m
fn
init
function
a
b
var
c
d
if
a
return
this
if
"string"
typeof
a
if
c
a
charAt
a
charAt
a
length
a
length
3
null
a
null
z
exec
a
c
c
b
return
b
b
jquery
b
x
find
a
this
constructor
b
find
a
if
c
if
b
b
instanceof
m
b
b
m
merge
this
m
parseHTML
c
b
b
nodeType
b
ownerDocument
b
y
u
test
c
m
isPlainObject
b
for
c
in
b
m
isFunction
this
c
this
c
b
c
this
attr
c
b
c
return
this
if
d
y
getElementById
c
2
d
d
parentNode
if
d
id
c
2
return
x
find
a
this
length
this
d
return
this
context
y
this
selector
a
this
return
a
nodeType
this
context
this
a
this
length
this
m
isFunction
a
"undefined"
typeof
x
ready
x
ready
a
a
m
void
a
selector
this
selector
a
selector
this
context
a
context
m
makeArray
a
this
A
prototype
m
fn
x
m
y
var
B
parents|prev
Until|All
C
children
contents
next
prev
m
extend
dir
function
a
b
c
var
d
e
a
b
while
e
9
e
nodeType
void
c
e
nodeType
m
e
is
c
e
nodeType
d
push
e
e
e
b
return
d
sibling
function
a
b
for
var
c
a
a
a
nextSibling
a
nodeType
a
b
c
push
a
return
c
m
fn
extend
has
function
a
var
b
c
m
a
this
d
c
length
return
this
filter
function
for
b
d
b
b
if
m
contains
this
c
b
return
closest
function
a
b
for
var
c
d
e
this
length
f
g
t
test
a
"string"
typeof
a
m
a
b
this
context
e
d
d
for
c
this
d
c
c
b
c
c
parentNode
if
c
nodeType
11
g
g
index
c
c
nodeType
m
find
matchesSelector
c
a
f
push
c
break
return
this
pushStack
f
length
m
unique
f
f
index
function
a
return
a
"string"
typeof
a
m
inArray
this
m
a
m
inArray
a
jquery
a
a
this
this
this
parentNode
this
first
prevAll
length
add
function
a
b
return
this
pushStack
m
unique
m
merge
this
get
m
a
b
addBack
function
a
return
this
add
null
a
this
prevObject
this
prevObject
filter
a
function
D
a
b
do
a
a
b
while
a
a
nodeType
return
a
m
each
function
a
var
b
a
parentNode
return
b
11
b
nodeType
b
null
parents
function
a
return
m
dir
a
"parentNode"
parentsUntil
function
a
b
c
return
m
dir
a
"parentNode"
c
next
function
a
return
D
a
"nextSibling"
prev
function
a
return
D
a
"previousSibling"
nextAll
function
a
return
m
dir
a
"nextSibling"
prevAll
function
a
return
m
dir
a
"previousSibling"
nextUntil
function
a
b
c
return
m
dir
a
"nextSibling"
c
prevUntil
function
a
b
c
return
m
dir
a
"previousSibling"
c
siblings
function
a
return
m
sibling
a
parentNode
firstChild
a
children
function
a
return
m
sibling
a
firstChild
contents
function
a
return
m
nodeName
a
"iframe"
a
contentDocument
a
contentWindow
document
m
merge
a
childNodes
function
a
b
m
fn
a
function
c
d
var
e
m
map
this
b
c
return
"Until"
a
slice
5
d
c
d
"string"
typeof
d
e
m
filter
d
e
this
length
C
a
e
m
unique
e
B
test
a
e
e
reverse
this
pushStack
e
var
E
\S
+/g
F
function
G
a
var
b
F
a
return
m
each
a
match
E
function
a
c
b
c
b
m
Callbacks
function
a
a
"string"
typeof
a
F
a
G
a
m
extend
a
var
b
c
d
e
f
g
h
i
a
once
j
function
l
for
c
a
memory
l
d
f
g
g
e
h
length
b
h
e
f
f
if
h
f
apply
l
l
a
stopOnFalse
c
break
b
h
i
i
length
j
i
shift
c
h
k
disable
k
add
function
if
h
var
d
h
length
function
f
b
m
each
b
function
b
c
var
d
m
type
c
"function"
d
a
unique
k
has
c
h
push
c
c
c
length
"string"
d
f
c
arguments
b
e
h
length
c
g
d
j
c
return
this
remove
function
return
h
m
each
arguments
function
a
c
var
d
while
d
m
inArray
c
h
d
h
splice
d
b
e
d
e
f
d
f
this
has
function
a
return
a
m
inArray
a
h
h
h
length
empty
function
return
h
e
this
disable
function
return
h
i
c
void
this
disabled
function
return
h
lock
function
return
i
void
c
k
disable
this
locked
function
return
i
fireWith
function
a
c
return
h
d
i
c
c
c
a
c
slice
c
slice
c
b
i
push
c
j
c
this
fire
function
return
k
fireWith
this
arguments
this
fired
function
return
d
return
k
m
extend
Deferred
function
a
var
b
"resolve"
"done"
m
Callbacks
"once memory"
"resolved"
"reject"
"fail"
m
Callbacks
"once memory"
"rejected"
"notify"
"progress"
m
Callbacks
"memory"
c
"pending"
d
state
function
return
c
always
function
return
e
done
arguments
fail
arguments
this
then
function
var
a
arguments
return
m
Deferred
function
c
m
each
b
function
b
f
var
g
m
isFunction
a
b
a
b
e
f
function
var
a
g
g
apply
this
arguments
a
m
isFunction
a
promise
a
promise
done
c
resolve
fail
c
reject
progress
c
notify
c
f
"With"
this
d
c
promise
this
g
a
arguments
a
null
promise
promise
function
a
return
null
a
m
extend
a
d
d
e
return
d
pipe
d
then
m
each
b
function
a
f
var
g
f
2
h
f
3
d
f
g
add
h
g
add
function
c
h
b
a
2
disable
b
2
2
lock
e
f
function
return
e
f
"With"
this
e
d
this
arguments
this
e
f
"With"
g
fireWith
d
promise
e
a
a
call
e
e
e
when
function
a
var
b
c
d
call
arguments
e
c
length
f
e
a
m
isFunction
a
promise
e
g
f
a
m
Deferred
h
function
a
b
c
return
function
e
b
a
this
c
a
arguments
length
d
call
arguments
e
c
i
g
notifyWith
b
c
f
g
resolveWith
b
c
i
j
k
if
e
for
i
new
Array
e
j
new
Array
e
k
new
Array
e
e
b
b
c
b
m
isFunction
c
b
promise
c
b
promise
done
h
b
k
c
fail
g
reject
progress
h
b
j
i
f
return
f
g
resolveWith
k
c
g
promise
var
H
m
fn
ready
function
a
return
m
ready
promise
done
a
this
m
extend
isReady
readyWait
holdReady
function
a
a
m
readyWait
m
ready
ready
function
a
if
a
m
readyWait
m
isReady
if
y
body
return
setTimeout
m
ready
m
isReady
a
m
readyWait
H
resolveWith
y
m
m
fn
triggerHandler
m
y
triggerHandler
"ready"
m
y
off
"ready"
function
I
y
addEventListener
y
removeEventListener
"DOMContentLoaded"
J
a
removeEventListener
"load"
J
y
detachEvent
J
a
detachEvent
"onload"
J
function
J
y
addEventListener
"load"
event
type
"complete"
y
readyState
I
m
ready
m
ready
promise
function
b
if
H
if
H
m
Deferred
"complete"
y
readyState
setTimeout
m
ready
else
if
y
addEventListener
y
addEventListener
"DOMContentLoaded"
J
a
addEventListener
"load"
J
else
y
attachEvent
J
a
attachEvent
"onload"
J
var
c
try
c
null
a
frameElement
y
documentElement
catch
d
c
c
doScroll
function
e
if
m
isReady
try
c
doScroll
"left"
catch
a
return
setTimeout
e
50
I
m
ready
return
H
promise
b
var
K
"undefined"
L
for
L
in
m
k
break
k
ownLast
"0"
L
k
m
function
var
a
b
c
d
c
y
"body"
c
c
style
b
y
createElement
"div"
d
y
createElement
"div"
d
style
cssText
c
appendChild
d
appendChild
b
typeof
b
style
zoom
K
b
style
cssText
k
a
3
b
offsetWidth
a
c
style
zoom
c
removeChild
d
function
var
a
y
createElement
"div"
if
null
k
deleteExpando
k
deleteExpando
try
delete
a
test
catch
b
k
deleteExpando
a
null
m
acceptData
function
a
var
b
m
noData
a
nodeName
toLowerCase
c
a
nodeType
return
c
9
c
b
b
a
getAttribute
"classid"
b
var
(?:\{[\w\W]
\[[\w\W]
N
A-Z
/g
function
O
a
b
c
if
void
c
a
nodeType
var
d
"data-"
b
replace
N
"-$1"
toLowerCase
if
c
a
getAttribute
d
"string"
typeof
c
try
c
"true"
c
"false"
c
"null"
c
null
c
c
c
test
c
m
parseJSON
c
c
catch
e
m
a
b
c
else
c
void
return
c
function
P
a
var
b
for
b
in
a
if
"data"
b
m
isEmptyObject
a
b
"toJSON"
b
return
@@ -372,7 +372,7 @@ summary {
<h1
class=
"title toc-ignore"
p
i
</h1>
<h1
class=
"title toc-ignore"
P
i
</h1>
<h4
class=
"author"
Teonas
</h4>
<h4
class=
"author"
Teonas
</h4>
<h4
class=
"date"
13 janvier 2021
</h4>
<h4
class=
"date"
13 janvier 2021
</h4>
