From 9a12a5050c5aef776be828ff3314e2ed9b3e9eeb Mon Sep 17 00:00:00 2001 From: 180838a673f39011c57d6df0dfcfb140 <180838a673f39011c57d6df0dfcfb140@app-learninglab.inria.fr> Date: Thu, 26 Mar 2020 14:37:48 +0000 Subject: [PATCH] =?UTF-8?q?R=C3=A9sultat=20html=20du=20fichier=20Rmarkdown?= MIME-Version: 1.0 Content-Type: text/plain; charset=UTF-8 Content-Transfer-Encoding: 8bit --- SortieTestRmarkdown.html | 451 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 451 insertions(+) create mode 100644 SortieTestRmarkdown.html diff --git a/SortieTestRmarkdown.html b/SortieTestRmarkdown.html new file mode 100644 index 0000000..f7f4522 --- /dev/null +++ b/SortieTestRmarkdown.html @@ -0,0 +1,451 @@ + + + + +
+ + + + + + + + + +This is an R Markdown document. Markdown is a simple formatting syntax for authoring HTML, PDF, and MS Word documents. For more details on using R Markdown see http://rmarkdown.rstudio.com.
+When you click the Knit button a document will be generated that includes both content as well as the output of any embedded R code chunks within the document. You can embed an R code chunk like this:
+summary(cars)
+## speed dist
+## Min. : 4.0 Min. : 2.00
+## 1st Qu.:12.0 1st Qu.: 26.00
+## Median :15.0 Median : 36.00
+## Mean :15.4 Mean : 42.98
+## 3rd Qu.:19.0 3rd Qu.: 56.00
+## Max. :25.0 Max. :120.00
+You can also embed plots, for example:
+Note that the echo = FALSE parameter was added to the code chunk to prevent printing of the R code that generated the plot.
