diff --git a/src_Python3_challenger_Romina.ipynb b/src_Python3_challenger_Romina.ipynb new file mode 100644 index 0000000000000000000000000000000000000000..9b6a2864035710e102948737ca1c02c3697dfb66 --- /dev/null +++ b/src_Python3_challenger_Romina.ipynb @@ -0,0 +1,557 @@ +{ + "cells": [ + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "# Risk Analysis of the Space Shuttle: Pre-Challenger Prediction of Failure" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "In this document we reperform some of the analysis provided in \n", + "*Risk Analysis of the Space Shuttle: Pre-Challenger Prediction of Failure* by *Siddhartha R. Dalal, Edward B. Fowlkes, Bruce Hoadley* published in *Journal of the American Statistical Association*, Vol. 84, No. 408 (Dec., 1989), pp. 945-957 and available at http://www.jstor.org/stable/2290069. \n", + "\n", + "On the fourth page of this article, they indicate that the maximum likelihood estimates of the logistic regression using only temperature are: $\\hat{\\alpha}=5.085$ and $\\hat{\\beta}=-0.1156$ and their asymptotic standard errors are $s_{\\hat{\\alpha}}=3.052$ and $s_{\\hat{\\beta}}=0.047$. The Goodness of fit indicated for this model was $G^2=18.086$ with 21 degrees of freedom. Our goal is to reproduce the computation behind these values and the Figure 4 of this article, possibly in a nicer looking way." + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "## Technical information on the computer on which the analysis is run" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "We will be using the python3 language using the pandas, statsmodels, numpy, matplotlib and seaborn libraries." + ] + }, + { + "cell_type": "code", + "execution_count": 1, + "metadata": {}, + "outputs": [ + { + "name": "stdout", + "output_type": "stream", + "text": [ + "3.8.8 (default, Apr 13 2021, 12:59:45) \n", + "[Clang 10.0.0 ]\n", + "uname_result(system='Darwin', node='MBP-de-Romina', release='17.7.0', version='Darwin Kernel Version 17.7.0: Fri Oct 30 13:34:27 PDT 2020; root:xnu-4570.71.82.8~1/RELEASE_X86_64', machine='x86_64', processor='i386')\n", + "IPython 7.22.0\n", + "IPython.core.release 7.22.0\n", + "PIL 8.2.0\n", + "PIL.Image 8.2.0\n", + "PIL._version 8.2.0\n", + "_csv 1.0\n", + "_ctypes 1.1.0\n", + "_curses b'2.2'\n", + "decimal 1.70\n", + "appnope 0.1.2\n", + "argparse 1.1\n", + "backcall 0.2.0\n", + "bottleneck 1.3.2\n", + "cffi 1.14.5\n", + "colorama 0.4.4\n", + "csv 1.0\n", + "ctypes 1.1.0\n", + "ctypes.macholib 1.0\n", + "cycler 0.10.0\n", + "dateutil 2.8.1\n", + "decimal 1.70\n", + "decorator 5.0.6\n", + "distutils 3.8.8\n", + "ipykernel 5.3.4\n", + "ipykernel._version 5.3.4\n", + "ipython_genutils 0.2.0\n", + "ipython_genutils._version 0.2.0\n", + "ipywidgets 7.6.3\n", + "ipywidgets._version 7.6.3\n", + "jedi 0.17.2\n", + "joblib 1.0.1\n", + "joblib.externals.cloudpickle 1.6.0\n", + "joblib.externals.loky 2.9.0\n", + "json 2.0.9\n", + "jupyter_client 6.1.12\n", + "jupyter_client._version 6.1.12\n", + "jupyter_core 4.7.1\n", + "jupyter_core.version 4.7.1\n", + "kiwisolver 1.3.1\n", + "logging 0.5.1.2\n", + "matplotlib 3.3.4\n", + "mkl 2.3.0\n", + "numpy 1.20.1\n", + "numpy.core 1.20.1\n", + "numpy.core._multiarray_umath 3.1\n", + "numpy.lib 1.20.1\n", + "numpy.linalg._umath_linalg 0.1.5\n", + "pandas 1.2.4\n", + "pandas.compat.numpy.function 1.20.1\n", + "parso 0.7.0\n", + "patsy 0.5.1\n", + "patsy.version 0.5.1\n", + "pexpect 4.8.0\n", + "pickleshare 0.7.5\n", + "platform 1.0.8\n", + "prompt_toolkit 3.0.17\n", + "psutil 5.8.0\n", + "ptyprocess 0.7.0\n", + "pygments 2.8.1\n", + "pyparsing 2.4.7\n", + "pytz 2021.1\n", + "re 2.2.1\n", + "scipy 1.6.2\n", + "scipy._lib._uarray 0.5.1+49.g4c3f1d7.scipy\n", + "scipy._lib.decorator 4.0.5\n", + "scipy.integrate._dop b'$Revision: $'\n", + "scipy.integrate._ode $Id$\n", + "scipy.integrate._odepack 1.9 \n", + "scipy.integrate._quadpack 1.13 \n", + "scipy.integrate.lsoda b'$Revision: $'\n", + "scipy.integrate.vode b'$Revision: $'\n", + "scipy.interpolate._fitpack 1.7 \n", + "scipy.interpolate.dfitpack b'$Revision: $'\n", + "scipy.linalg._fblas b'$Revision: $'\n", + "scipy.linalg._flapack b'$Revision: $'\n", + "scipy.linalg._flinalg b'$Revision: $'\n", + "scipy.linalg._interpolative b'$Revision: $'\n", + "scipy.ndimage 2.0\n", + "scipy.optimize.__nnls b'$Revision: $'\n", + "scipy.optimize._cobyla b'$Revision: $'\n", + "scipy.optimize._lbfgsb b'$Revision: $'\n", + "scipy.optimize._minpack 1.10 \n", + "scipy.optimize._slsqp b'$Revision: $'\n", + "scipy.optimize.minpack2 b'$Revision: $'\n", + "scipy.signal.spline 0.2\n", + "scipy.sparse.linalg.eigen.arpack._arpack b'$Revision: $'\n", + "scipy.sparse.linalg.isolve._iterative b'$Revision: $'\n", + "scipy.special.specfun b'$Revision: $'\n", + "scipy.stats.mvn b'$Revision: $'\n", + "scipy.stats.statlib b'$Revision: $'\n", + "seaborn 0.11.1\n", + "seaborn.external.husl 2.1.0\n", + "six 1.15.0\n", + "statsmodels 0.12.2\n", + "statsmodels.__init__ 0.12.2\n", + "statsmodels.api 0.12.2\n", + "statsmodels.tools.web 0.12.2\n", + "traitlets 5.0.5\n", + "traitlets._version 5.0.5\n", + "urllib.request 3.8\n", + "wcwidth 0.2.5\n", + "zlib 1.0\n", + "zmq 20.0.0\n", + "zmq.sugar 20.0.0\n", + "zmq.sugar.version 20.0.0\n" + ] + } + ], + "source": [ + "def print_imported_modules():\n", + " import sys\n", + " for name, val in sorted(sys.modules.items()):\n", + " if(hasattr(val, '__version__')): \n", + " print(val.__name__, val.__version__)\n", + "# else:\n", + "# print(val.__name__, \"(unknown version)\")\n", + "def print_sys_info():\n", + " import sys\n", + " import platform\n", + " print(sys.version)\n", + " print(platform.uname())\n", + "\n", + "import numpy as np\n", + "import pandas as pd\n", + "import matplotlib.pyplot as plt\n", + "import statsmodels.api as sm\n", + "import seaborn as sns\n", + "\n", + "print_sys_info()\n", + "print_imported_modules()" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "## Loading and inspecting data\n", + "Let's start by reading data." + ] + }, + { + "cell_type": "code", + "execution_count": 2, + "metadata": {}, + "outputs": [ + { + "ename": "ParserError", + "evalue": "Error tokenizing data. C error: Expected 1 fields in line 30, saw 21\n", + "output_type": "error", + "traceback": [ + "\u001b[0;31m---------------------------------------------------------------------------\u001b[0m", + "\u001b[0;31mParserError\u001b[0m Traceback (most recent call last)", + "\u001b[0;32m\u001b[0m in \u001b[0;36m\u001b[0;34m\u001b[0m\n\u001b[0;32m----> 1\u001b[0;31m \u001b[0mdata\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mpd\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread_csv\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m\"https://app-learninglab.inria.fr/moocrr/gitlab/moocrr-session3/moocrr-reproducibility-study/blob/master/data/shuttle.csv\"\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 2\u001b[0m \u001b[0mdata\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m/opt/anaconda3/lib/python3.8/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36mread_csv\u001b[0;34m(filepath_or_buffer, sep, delimiter, header, names, index_col, usecols, squeeze, prefix, mangle_dupe_cols, dtype, engine, converters, true_values, false_values, skipinitialspace, skiprows, skipfooter, nrows, na_values, keep_default_na, na_filter, verbose, skip_blank_lines, parse_dates, infer_datetime_format, keep_date_col, date_parser, dayfirst, cache_dates, iterator, chunksize, compression, thousands, decimal, lineterminator, quotechar, quoting, doublequote, escapechar, comment, encoding, dialect, error_bad_lines, warn_bad_lines, delim_whitespace, low_memory, memory_map, float_precision, storage_options)\u001b[0m\n\u001b[1;32m 608\u001b[0m \u001b[0mkwds\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mupdate\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mkwds_defaults\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 609\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 610\u001b[0;31m \u001b[0;32mreturn\u001b[0m \u001b[0m_read\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mfilepath_or_buffer\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mkwds\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 611\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 612\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m/opt/anaconda3/lib/python3.8/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36m_read\u001b[0;34m(filepath_or_buffer, kwds)\u001b[0m\n\u001b[1;32m 466\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 467\u001b[0m \u001b[0;32mwith\u001b[0m \u001b[0mparser\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 468\u001b[0;31m \u001b[0;32mreturn\u001b[0m \u001b[0mparser\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mnrows\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 469\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 470\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m/opt/anaconda3/lib/python3.8/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36mread\u001b[0;34m(self, nrows)\u001b[0m\n\u001b[1;32m 1055\u001b[0m \u001b[0;32mdef\u001b[0m \u001b[0mread\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mnrows\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;32mNone\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1056\u001b[0m \u001b[0mnrows\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mvalidate_integer\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m\"nrows\"\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mnrows\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 1057\u001b[0;31m \u001b[0mindex\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mcolumns\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mcol_dict\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_engine\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mnrows\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 1058\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1059\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mindex\u001b[0m \u001b[0;32mis\u001b[0m \u001b[0;32mNone\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m/opt/anaconda3/lib/python3.8/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36mread\u001b[0;34m(self, nrows)\u001b[0m\n\u001b[1;32m 2059\u001b[0m \u001b[0;32mdef\u001b[0m \u001b[0mread\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mnrows\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;32mNone\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 2060\u001b[0m \u001b[0;32mtry\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 2061\u001b[0;31m \u001b[0mdata\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_reader\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mnrows\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 2062\u001b[0m \u001b[0;32mexcept\u001b[0m \u001b[0mStopIteration\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 2063\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_first_chunk\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32mpandas/_libs/parsers.pyx\u001b[0m in \u001b[0;36mpandas._libs.parsers.TextReader.read\u001b[0;34m()\u001b[0m\n", + "\u001b[0;32mpandas/_libs/parsers.pyx\u001b[0m in \u001b[0;36mpandas._libs.parsers.TextReader._read_low_memory\u001b[0;34m()\u001b[0m\n", + "\u001b[0;32mpandas/_libs/parsers.pyx\u001b[0m in \u001b[0;36mpandas._libs.parsers.TextReader._read_rows\u001b[0;34m()\u001b[0m\n", + "\u001b[0;32mpandas/_libs/parsers.pyx\u001b[0m in \u001b[0;36mpandas._libs.parsers.TextReader._tokenize_rows\u001b[0;34m()\u001b[0m\n", + "\u001b[0;32mpandas/_libs/parsers.pyx\u001b[0m in \u001b[0;36mpandas._libs.parsers.raise_parser_error\u001b[0;34m()\u001b[0m\n", + "\u001b[0;31mParserError\u001b[0m: Error tokenizing data. C error: Expected 1 fields in line 30, saw 21\n" + ] + } + ], + "source": [ + "data = pd.read_csv(\"https://app-learninglab.inria.fr/moocrr/gitlab/moocrr-session3/moocrr-reproducibility-study/blob/master/data/shuttle.csv\")\n", + "data" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "We know from our previous experience on this data set that filtering data is a really bad idea. We will therefore process it as such." + ] + }, + { + "cell_type": "code", + "execution_count": 3, + "metadata": {}, + "outputs": [ + { + "ename": "NameError", + "evalue": "name 'data' is not defined", + "output_type": "error", + "traceback": [ + "\u001b[0;31m---------------------------------------------------------------------------\u001b[0m", + "\u001b[0;31mNameError\u001b[0m Traceback (most recent call last)", + "\u001b[0;32m\u001b[0m in \u001b[0;36m\u001b[0;34m\u001b[0m\n\u001b[1;32m 3\u001b[0m \u001b[0;32mimport\u001b[0m \u001b[0mmatplotlib\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mpyplot\u001b[0m \u001b[0;32mas\u001b[0m \u001b[0mplt\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 4\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m----> 5\u001b[0;31m \u001b[0mdata\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0;34m\"Frequency\"\u001b[0m\u001b[0;34m]\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0mdata\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mMalfunction\u001b[0m\u001b[0;34m/\u001b[0m\u001b[0mdata\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mCount\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 6\u001b[0m \u001b[0mdata\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mplot\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mx\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;34m\"Temperature\"\u001b[0m\u001b[0;34m,\u001b[0m\u001b[0my\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;34m\"Frequency\"\u001b[0m\u001b[0;34m,\u001b[0m\u001b[0mkind\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;34m\"scatter\"\u001b[0m\u001b[0;34m,\u001b[0m\u001b[0mylim\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0;36m0\u001b[0m\u001b[0;34m,\u001b[0m\u001b[0;36m1\u001b[0m\u001b[0;34m]\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 7\u001b[0m \u001b[0mplt\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mgrid\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;32mTrue\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;31mNameError\u001b[0m: name 'data' is not defined" + ] + } + ], + "source": [ + "%matplotlib inline\n", + "pd.set_option('mode.chained_assignment',None) # this removes a useless warning from pandas\n", + "import matplotlib.pyplot as plt\n", + "\n", + "data[\"Frequency\"]=data.Malfunction/data.Count\n", + "data.plot(x=\"Temperature\",y=\"Frequency\",kind=\"scatter\",ylim=[0,1])\n", + "plt.grid(True)" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "## Logistic regression\n", + "\n", + "Let's assume O-rings independently fail with the same probability which solely depends on temperature. A logistic regression should allow us to estimate the influence of temperature." + ] + }, + { + "cell_type": "code", + "execution_count": 4, + "metadata": {}, + "outputs": [ + { + "data": { + "text/html": [ + "\n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "
Generalized Linear Model Regression Results
Dep. Variable: Frequency No. Observations: 23
Model: GLM Df Residuals: 21
Model Family: Binomial Df Model: 1
Link Function: logit Scale: 1.0000
Method: IRLS Log-Likelihood: -3.9210
Date: Wed, 24 Oct 2018 Deviance: 3.0144
Time: 11:05:55 Pearson chi2: 5.00
No. Iterations: 6 Covariance Type: nonrobust
coef std err z P>|z| [0.025 0.975]
Intercept 5.0850 7.477 0.680 0.496 -9.570 19.740
Temperature -0.1156 0.115 -1.004 0.316 -0.341 0.110
" + ], + "text/plain": [ + "\n", + "\"\"\"\n", + " Generalized Linear Model Regression Results \n", + "==============================================================================\n", + "Dep. Variable: Frequency No. Observations: 23\n", + "Model: GLM Df Residuals: 21\n", + "Model Family: Binomial Df Model: 1\n", + "Link Function: logit Scale: 1.0000\n", + "Method: IRLS Log-Likelihood: -3.9210\n", + "Date: Wed, 24 Oct 2018 Deviance: 3.0144\n", + "Time: 11:05:55 Pearson chi2: 5.00\n", + "No. Iterations: 6 Covariance Type: nonrobust\n", + "===============================================================================\n", + " coef std err z P>|z| [0.025 0.975]\n", + "-------------------------------------------------------------------------------\n", + "Intercept 5.0850 7.477 0.680 0.496 -9.570 19.740\n", + "Temperature -0.1156 0.115 -1.004 0.316 -0.341 0.110\n", + "===============================================================================\n", + "\"\"\"" + ] + }, + "execution_count": 4, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "import statsmodels.api as sm\n", + "\n", + "data[\"Success\"]=data.Count-data.Malfunction\n", + "data[\"Intercept\"]=1\n", + "\n", + "logmodel=sm.GLM(data['Frequency'], data[['Intercept','Temperature']], \n", + " family=sm.families.Binomial(sm.families.links.logit)).fit()\n", + "\n", + "logmodel.summary()" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "The maximum likelyhood estimator of the intercept and of Temperature are thus $\\hat{\\alpha}=5.0849$ and $\\hat{\\beta}=-0.1156$. This **corresponds** to the values from the article of Dalal *et al.* The standard errors are $s_{\\hat{\\alpha}} = 7.477$ and $s_{\\hat{\\beta}} = 0.115$, which is **different** from the $3.052$ and $0.04702$ reported by Dallal *et al.* The deviance is $3.01444$ with 21 degrees of freedom. I cannot find any value similar to the Goodness of fit ($G^2=18.086$) reported by Dalal *et al.* There seems to be something wrong. Oh I know, I haven't indicated that my observations are actually the result of 6 observations for each rocket launch. Let's indicate these weights (since the weights are always the same throughout all experiments, it does not change the estimates of the fit but it does influence the variance estimates)." + ] + }, + { + "cell_type": "code", + "execution_count": 5, + "metadata": {}, + "outputs": [ + { + "data": { + "text/html": [ + "\n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "\n", + " \n", + "\n", + "
Method: IRLS Log-Likelihood: -23.526
Date: Wed, 24 Oct 2018 Deviance: 18.086
Time: 11:05:55 Pearson chi2: 30.0
Intercept 5.0850 3.052 1.666 0.096 -0.898 11.068
Temperature -0.1156 0.047 -2.458 0.014 -0.208 -0.023
" + ], + "text/plain": [ + "\n", + "\"\"\"\n", + " Generalized Linear Model Regression Results \n", + "==============================================================================\n", + "Dep. Variable: Frequency No. Observations: 23\n", + "Model: GLM Df Residuals: 21\n", + "Model Family: Binomial Df Model: 1\n", + "Link Function: logit Scale: 1.0000\n", + "Method: IRLS Log-Likelihood: -23.526\n", + "Date: Wed, 24 Oct 2018 Deviance: 18.086\n", + "Time: 11:05:55 Pearson chi2: 30.0\n", + "No. Iterations: 6 Covariance Type: nonrobust\n", + "===============================================================================\n", + " coef std err z P>|z| [0.025 0.975]\n", + "-------------------------------------------------------------------------------\n", + "Intercept 5.0850 3.052 1.666 0.096 -0.898 11.068\n", + "Temperature -0.1156 0.047 -2.458 0.014 -0.208 -0.023\n", + "===============================================================================\n", + "\"\"\"" + ] + }, + "execution_count": 5, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "logmodel=sm.GLM(data['Frequency'], data[['Intercept','Temperature']], \n", + " family=sm.families.Binomial(sm.families.links.logit),\n", + " var_weights=data['Count']).fit()\n", + "\n", + "logmodel.summary()" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Good, now I have recovered the asymptotic standard errors $s_{\\hat{\\alpha}}=3.052$ and $s_{\\hat{\\beta}}=0.047$.\n", + "The Goodness of fit (Deviance) indicated for this model is $G^2=18.086$ with 21 degrees of freedom (Df Residuals).\n", + "\n", + "**I have therefore managed to fully replicate the results of the Dalal *et al.* article**." + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "## Predicting failure probability\n", + "The temperature when launching the shuttle was 31°F. Let's try to estimate the failure probability for such temperature using our model.:" + ] + }, + { + "cell_type": "code", + "execution_count": 6, + "metadata": {}, + "outputs": [ + { + "data": { + "image/png": "iVBORw0KGgoAAAANSUhEUgAAAXcAAAEKCAYAAADpfBXhAAAABHNCSVQICAgIfAhkiAAAAAlwSFlzAAALEgAACxIB0t1+/AAAADl0RVh0U29mdHdhcmUAbWF0cGxvdGxpYiB2ZXJzaW9uIDIuMi4yLCBodHRwOi8vbWF0cGxvdGxpYi5vcmcvhp/UCwAAIABJREFUeJzt3Xl8VOXZ//HPNUs2sgABwhI2NYDIngUQa8EqoFXcUEDEpSD2qUutlVb6WLVWuzz0+blXoYBrFakVROsjCIoLIgQEWWVHSNiXhITsyfX7YwYMMZAhmWSWXO/XK6/MOXOfc647J/nOyZkz9xFVxRhjTHhxBLoAY4wx/mfhbowxYcjC3RhjwpCFuzHGhCELd2OMCUMW7sYYE4ZqDHcRmSkiB0Rk3WmeFxF5RkS2isgaEenn/zKNMcacDV+O3F8Ghp/h+cuBFO/XROCFupdljDGmLmoMd1X9DDhyhiZXA6+qx1dAUxFp468CjTHGnD2XH9bRDthdaTrLO29v1YYiMhHP0T3R0dGp7du3r9UGKyoqcDjC4+0C60vwCZd+gPUlWNWlL5s3bz6kqi1rauePcJdq5lU7poGqTgOmAaSlpemKFStqtcHFixczePDgWi0bbKwvwSdc+gHWl2BVl76IyHe+tPPHy2AWUPkQPBnY44f1GmOMqSV/hPs84BbvVTMDgFxV/cEpGWOMMQ2nxtMyIvImMBhoISJZwCOAG0BVXwQ+AK4AtgIFwO31Vawxxhjf1BjuqjqmhucVuMtvFRljQkJpaSlZWVkUFRU1yPYSEhLYuHFjg2yrvvnSl6ioKJKTk3G73bXahj/eUDXGNEJZWVnExcXRqVMnRKq7rsK/8vLyiIuLq/ftNISa+qKqHD58mKysLDp37lyrbYTHdUXGmAZXVFREYmJigwR7YyMiJCYm1um/Igt3Y0ytWbDXn7r+bC3cjTEmDNk5d2NMyHI6nfTs2fPk9Ny5c+nUqVPgCgoiFu7GmJAVHR3N6tWrT/t8WVkZLlfjjDk7LWOMCSsvv/wyN9xwA1dddRVDhw4FYMqUKaSnp9OrVy8eeeSRk22feOIJunbtyqWXXsqYMWP429/+BsDgwYM5MTzKoUOHTv43UF5ezqRJk06ua+rUqcD3wwmMHDmSbt26MXbsWDxXiUNmZiYXXnghvXv3JiMjg7y8PIYNG3bKi9KgQYNYs2aNX38OjfMlzRjjV394bz0b9hzz6zq7t43nkasuOGObwsJC+vTpA0Dnzp2ZM2cOAEuXLmXNmjU0b96cBQsWsGXLFpYvX46qMmLECD777DOaNGnCrFmzWLVqFWVlZfTr14/U1NQzbm/GjBkkJCSQmZlJcXExgwYNOvkCsmrVKtavX0/btm0ZNGgQS5YsISMjg1GjRvHWW2+Rnp7OsWPHiI6O5pZbbuHll1/mqaeeYvPmzRQXF9OrVy8//NS+Z+FujAlZpzstc9lll9G8eXMAFixYwIIFC+jbty8A+fn5bNmyhby8PK699lpiYmIAGDFiRI3bW7BgAWvWrOHtt98GIDc3ly1bthAREUFGRgbJyckA9OnTh507d5KQkECbNm1IT08HID4+HoBrr72WQYMGMWXKFGbOnMltt91Wtx9ENSzcjTF1VtMRdkNr0qTJyceqyuTJk7nzzjtPafPUU0+d9nJDl8tFRUUFwCnXmqsqzz77LMOGDTul/eLFi4mMjDw57XQ6KSsrQ1Wr3UZMTAyXXXYZ7777LrNnz6a2I+SeiZ1zN8aEtWHDhjFz5kzy8/MByM7O5sCBA1x88cXMmTOHwsJC8vLyeO+9904u06lTJ1auXAlw8ij9xLpeeOEFSktLAdi8eTPHjx8/7ba7devGnj17yMzMBDyfTC0rKwNgwoQJ3HvvvaSnp5/8L8Of7MjdGBPWhg4dysaNGxk4cCAAsbGxvP766/Tr149Ro0bRp08fOnbsyI9+9KOTyzzwwAPceOONvPbaa1xyySUn50+YMIGdO3fSr18/VJWWLVsyd+7c0247IiKCt956i3vuuYfCwkKio6NZuHAhAKmpqcTHx3P77fU01qKqBuQrNTVVa+uTTz6p9bLBxvoSfMKlH6r125cNGzbU27qrc+zYsXpd/yOPPKJTpkyp122ccOzYMc3OztaUlBQtLy8/bbvqfsbACvUhY+20jDHGNLA33niD/v3788QTT9TbrQPttIwxxgCPPvpog23rpptu+sEbvP5mR+7GmFpTrfZ2ycYP6vqztXA3xtRKVFQUhw8ftoCvB+odzz0qKqrW67DTMsaYWklOTiYrK4uDBw82yPaKiorqFHbBxJe+nLgTU21ZuBtjasXtdtf6LkG1sXjx4pOfMg11DdEXOy1jjDFhyMLdGGPCkIW7McaEIQt3Y4wJQxbuxhgThizcjTEmDFm4G2NMGLJwN8aYMGThbowxYcjC3RhjwlDIhfuBY0V8mlVqgxUZY8wZhFy4v75sFy+tK2HCKys4mFcc6HKMMSYohVy43/eTFG7qFsHnWw8x/KnPWLhhf6BLMsaYoBNy4e5wCEM7ufnPPReRFB/FhFdX8Mi76ygqLQ90acYYEzRCLtxPSEmKY85dFzL+os68svQ7rnl+CVsP5Ae6LGOMCQohG+4AkS4nv7+yOy/dns6BvGJGPPcF767ODnRZxhgTcD6Fu4gMF5FNIrJVRB6s5vkOIvKJiKwSkTUicoX/Sz29IV1b8Z97L+KCtvH8ctZqfjdnLcVldprGGNN41RjuIuIEngcuB7oDY0Ske5VmDwGzVbUvMBr4u78LrUmbhGjevGMAP//xubyxbBc3vriU7JzChi7DGGOCgi9H7hnAVlXdrqolwCzg6iptFIj3Pk4A9vivRN+5nA4evLwbU8elsv3gca585nO+3HooEKUYY0xASU0fBhKRkcBwVZ3gnR4H9FfVuyu1aQMsAJoBTYBLVXVlNeuaCEwESEpKSp01a1atis7Pzyc2NvaMbfYdr+CZVUXsO66M6hrB0I4uRKRW26tPvvQlVIRLX8KlH2B9CVZ16cuQIUNWqmpajQ1V9YxfwA3A9ErT44Bnq7S5H/i19/FAYAPgONN6U1NTtbY++eQTn9rlFZXqHa9kasffvq/3v7Vai0rLar3N+uJrX0JBuPQlXPqhan0JVnXpC7BCa8htVfXptEwW0L7SdDI/PO0yHpjtfbFYCkQBLXxYd72KjXTx4s2p3HdpCv/+Ooux/1jGoXz7VKsxJvz5Eu6ZQIqIdBaRCDxvmM6r0mYX8BMAETkfT7gf9GehteVwCPdd2oXnb+rHuj25XP3cEjbtywt0WcYYU69qDHdVLQPuBuYDG/FcFbNeRB4TkRHeZr8G7hCRb4A3gdu8/z4EjZ/2asPsOwdSWl7ByBe+5PMtQfHaY4wx9cKn69xV9QNV7aKq56rqE955D6vqPO/jDao6SFV7q2ofVV1Qn0XXVq/kpsy9axDtmkVz+0uZvJW5K9AlGWNMvQjpT6jWRtum0fzr5wO58LwW/Pbfa3lq4WYbPtgYE3YaXbgDxEW5mXFrGiNTk3lq4RYmv7OWsvKKQJdljDF+4wp0AYHidjqYMrIXbROieObjrRzKL+a5m/oR5XYGujRjjKmzRnnkfoKIcP/Qrvzx6gtY9O0BbpmxnNzC0kCXZYwxddaow/2EcQM78czovqzafZRRU5faHZ6MMSHPwt3rqt5tmXFrOjsPH2fUVBt0zBgT2izcK7m4S0teG9+fg3nF3PjiUnYeOh7okowxplYs3KtI79ScNycOoLC0nBunLrW7OxljQpKFezV6tEtg1sQBVCiMnraUb/cdC3RJxhhzVizcT6NLUhyz7xyAy+Fg9LSvWL8nN9AlGWOMzyzcz+CclrG8decAYtxOxk5fxrpsC3hjTGiwcK9Bx8QmzJo40ALeGBNSLNx90CExhlkTB9IkwsnNM5axca+dgzfGBDcLdx91SIzhzYkDiHI5uXn6MrbstzHhjTHBy8L9LHRMbMIbd/TH6RDG/GMZ2w/aZZLGmOBk4X6WzmkZyxt39EdVGTt9GbuPFAS6JGOM+QEL91o4r1Ucr43vT0FJOWOnL2NfblGgSzLGmFNYuNdS97bxvPKzDI4cL+HmGcs4crwk0CUZY8xJFu510Kd9U6bfmsbuIwXcOnM5eUU2XLAxJjhYuNfRgHMSeeHmfmzce4wJr6ygqLQ80CUZY4yFuz9c0i2J/72xN8t3HuHuN1bZLfuMMQFn4e4nV/dpx6NXXcDCjfuZ/M5au+m2MSagGu09VOvDrRd24vDxEp5ZtIXE2EgevLxboEsyxjRSFu5+9qtLUzhyvJgXP91Gq7hIfnZR50CXZIxphCzc/UxE+MOIHhzKK+GP/9lAy7hIrurdNtBlGWMaGTvnXg+cDuGp0X1I79ic+2ev5suthwJdkjGmkbFwrydRbif/uCWNzi2acOdrK+1uTsaYBmXhXo8SYty8dHsGMZFObn8pk725hYEuyRjTSFi417N2TaN56bYM8orKuP2lTPsUqzGmQVi4N4DubeN54eZ+bD2Qzy/++TWl9iEnY0w9s3BvID9Kacmfru3J51sO8dCcdfYhJ2NMvbJLIRvQjent2X20gGc/3kqHxBjuGnJeoEsyxoQpC/cGdv9lXdh1pIAp8zfRMTGG2EAXZIwJS3ZapoGJCH+9vhdpHZtx/+xv2HrURpE0xvifT+EuIsNFZJOIbBWRB0/T5kYR2SAi60XkDf+WGV6i3E6m3ZJGm4Qonl5VZLfqM8b4XY3hLiJO4HngcqA7MEZEuldpkwJMBgap6gXAffVQa1hp3iSCmbelU14B41/J5JhdImmM8SNfjtwzgK2qul1VS4BZwNVV2twBPK+qRwFU9YB/ywxP57aM5e6+UWw/eNzGgTfG+JXUdEmeiIwEhqvqBO/0OKC/qt5dqc1cYDMwCHACj6rqh9WsayIwESApKSl11qxZtSo6Pz+f2NjweCsyPz+flUcjeWl9CZd2cHFz98hAl1Rr4bJfwqUfYH0JVnXpy5AhQ1aqalpN7Xy5WkaqmVf1FcEFpACDgWTgcxHpoao5pyykOg2YBpCWlqaDBw/2YfM/tHjxYmq7bLBZvHgxj1w5GOf7G5j+xQ4G9+vGzQM6BrqsWgmX/RIu/QDrS7BqiL74clomC2hfaToZ2FNNm3dVtVRVdwCb8IS98dHkK85nSNeWPDJvvY0iaYypM1/CPRNIEZHOIhIBjAbmVWkzFxgCICItgC7Adn8WGu6cDuGZMX05t2UTfv76SnYcOh7okowxIazGcFfVMuBuYD6wEZitqutF5DERGeFtNh84LCIbgE+ASap6uL6KDldxUW6m35KO0yGMfyWT3EK7gsYYUzs+Xeeuqh+oahdVPVdVn/DOe1hV53kfq6rer6rdVbWnqtbunVJDh8QYXrg5lV2HC7jnTbuCxhhTO/YJ1SA04JxE/nhNDz7bfJA//9+3gS7HGBOCbGyZIDUmowOb9uUx44sddGsdxw1p7WteyBhjvOzIPYg99NPzGXReIv89Zx0rvzsa6HKMMSHEwj2IuZwOnr+pH22aRnHnayvtNn3GGJ9ZuAe5pjERTL8ljaLScia+upKiUhtF0hhTMwv3EJCSFMdTo/qwbk8uv/33GruLkzGmRhbuIeLS7kk8MLQr767ew9TP7PNhxpgzs3APIb8YfC4/7dWGv374LYs32cCbxpjTs3APISLClJG96NY6nnveXMX2g/mBLskYE6Qs3ENMTISLaeNScTsd3PHqCrvJhzGmWhbuIah98xiev6kfOw8XcP9bq6mosDdYjTGnsnAPUQPPTeThK7uzcOMBnly4OdDlGGOCjA0/EMJuGdiR9XtyefbjrZzfJp4rerYJdEnGmCBhR+4hTET44zU96NuhKQ/86xu+3Xcs0CUZY4KEhXuIi3Q5efHmVGIjXdzx6gpyCkoCXZIxJghYuIeBpPgoXhyXyv7cYu5+w8aAN8ZYuIeNfh2a8fg1Pfhi6yH+YmPAG9Po2RuqYeTG9Pas25PL9C92cEG7eK7tmxzokowxAWJH7mHm91d2p3/n5jz477WsycoJdDnGmACxcA8zbqeDv4/tR4vYSO58bSUH84oDXZIxJgAs3MNQYmwkU8elcrSghF/8cyUlZfYGqzGNjYV7mOrRLoG/Xt+LzJ1HefS99YEuxxjTwOwN1TB2dZ92bNh7jKmfbueCtvGM7d8x0CUZYxqIHbmHud8M68aPu7TkkXfXs3zHkUCXY4xpIBbuYc7pEJ4Z05f2zWP4r9dXkp1jN9k2pjGwcG8EEqLd/OOWNErKKpj46goKS+wm28aEOwv3RuK8VrE8PaYPG/YeY9Lb39hNto0Jcxbujcgl3ZKYNKwr76/Zy98Xbwt0OcaYemTh3sj814/P5arebfnbgk0s2rg/0OUYY+qJhXsjIyL8z/W9uKBtPL+ctZot+/MCXZIxph5YuDdC0RFOpo1LI8rtZIKNAW9MWLJwb6TaNo1m6rhU9uYU8Yt/fk2pjQFvTFixcG/EUjs240/X9eTLbYf54/sbAl2OMcaPbPiBRm5kajKb9+cx7bPtpCTFMW6ADVFgTDiwI3fDb4d3Y0jXljw6bz1fbj0U6HKMMX7gU7iLyHAR2SQiW0XkwTO0GykiKiJp/ivR1LcTQxSc06IJ//XPr9lx6HigSzLG1FGN4S4iTuB54HKgOzBGRLpX0y4OuBdY5u8iTf2Li3Iz49Z0nA5h/MuZ5BaUBrokY0wd+HLkngFsVdXtqloCzAKurqbdH4H/AYr8WJ9pQB0SY3jx5lR2Hy3grjfsChpjQpnUNMaIiIwEhqvqBO/0OKC/qt5dqU1f4CFVvV5EFgMPqOqKatY1EZgIkJSUlDpr1qxaFZ2fn09sbGytlg02wdiXz7NKmbGuhMHtXdzaPQIR8Wm5YOxLbYRLP8D6Eqzq0pchQ4asVNUaT337crVMdX/ZJ18RRMQBPAncVtOKVHUaMA0gLS1NBw8e7MPmf2jx4sXUdtlgE4x9GQxEfPgtLyzexo96d2H8RZ19Wi4Y+1Ib4dIPsL4Eq4boiy+nZbKA9pWmk4E9labjgB7AYhHZCQwA5tmbqqFt0tCuDL+gNY//ZwMLN9gYNMaEGl/CPRNIEZHOIhIBjAbmnXhSVXNVtYWqdlLVTsBXwIjqTsuY0OFwCE+O6kOPtgncO2sV67JzA12SMeYs1BjuqloG3A3MBzYCs1V1vYg8JiIj6rtAEzjREU5m3JpG02g341/JZG+u3cXJmFDh03XuqvqBqnZR1XNV9QnvvIdVdV41bQfbUXv4aBUfxczb0zleXM7tL2WSV2SXSBoTCuwTqqZG3VrH8/zYfmw5kM9db6yySySNCQEW7sYnP+7Skieu6cFnmw/y8Lvr7DZ9xgQ5GzjM+Gx0Rgd2Hy3g+U+2kdwshruGnBfokowxp2Hhbs7Kry/rStbRQqbM30SbhCiu65cc6JKMMdWwcDdnxeEQpozszcG8Yn7z9hpaxUVxUUqLQJdljKnCzrmbsxbhcvDiuFTOaxXLz19fyfo9tb8Gfu6qbAb95WM6P/gfBv3lY+auyvZjpaa+2f4LXhbuplbio9y8fHsG8VEubnspk91HCs56HXNXZTP5nbVk5xSiQHZOIZPfWWsBESJs/wU3C3dTa60Tonh1fAYlZRXcMnM5x0rO7gqaKfM3UVhafsq8wtJypszf5M8yTT2x/RfcLNxNnZzXKo6Zt6WxN7eQJ1cUkV9c5vOye3Kq/8Tr6eab4GL7L7hZuJs6S+3YnL+P7cd3eRVMfHUFxWXlNS8EtG0afVbzTXCx/RfcLNyNX1zSLYnxPSL4ctth7pu1mvKKmk/RTBrWlWi385R50W4nk4Z1ra8yjR/Z/gtuFu7Gbwa1c/P7K7vzf+v2MfmdNTV+ivWavu3483U9adc0GgHaNY3mz9f15Jq+7RqmYFMntv+Cm13nbvxq/EWdyS0s5ZlFW4iPcvPfPz3/jHdyuqZvOwuDEGb7L3hZuBu/+9WlKRwrLGX6FzuIi3Lzy0tTAl2SMY2OhbvxOxHh4Su7k19cxpMLNxMT4eSOi88JdFnGNCoW7qZeOBzCX6/vRWFpOU98sJEot4NxAzsFuixjGg0Ld1NvnA7hyRv7UFRSzu/fXU+Ey8Go9A6BLsuYRsGuljH1KsLl4Pmx/bi4S0sefGct/16ZFeiSjGkULNxNvYtyO5k2LpULz01k0tvf8O5qG3vEmPpm4W4aRJTbyfRb0sno3JxfvbXaBpcypp5ZuJsGEx3hZOZt6fTvnMj9s1czZ5WdojGmvli4mwYVE+Fi5m3pDDgnkftnf8PsFbsDXZIxYcnC3TS46AgnM25N56LzWvCbt9fw+lffBbokY8KOhbsJiOgIJ/+4JY2fdGvFQ3PXMeOLHYEuyZiwYuFuAibK7eSFm1O5vEdr/vj+Bp5euKXGwcaMMb6xcDcBFeFy8OyYvlzfL5knF27mif9stIA3xg/sE6om4FxOB1NG9iIuysX0L3aQW1jKn6/rictpxx7G1JaFuwkKDofwyFXdSYh28/SiLRwtKOW5m/oSVeVmEMYY39ihkQkaIsKvLuvCH0ZcwKJv9zNuxjJyCkoCXZYxIcnC3QSdWy/sxDOj+/LN7lxGvriUrKMFgS7JmJBj4W6C0lW92/LKzzLYf6yI6/7+JeuycwNdkjEhxcLdBK2B5yby9s8vxOkQbpy6lI+/3R/okowJGRbuJqh1bR3H3LsG0blFEya8soJXvtwZ6JKMCQkW7iboJcVHMfvOgVzSrRWPzFvPw++uo6y8ItBlGRPUfAp3ERkuIptEZKuIPFjN8/eLyAYRWSMii0Sko/9LNY1Zk0gXU8elMfHic3h16Xfc9lImuQWlgS7LmKBVY7iLiBN4Hrgc6A6MEZHuVZqtAtJUtRfwNvA//i7UGKdD+N0V5zNlZC+W7TjMiOe/YPP+vECXZUxQ8uXIPQPYqqrbVbUEmAVcXbmBqn6iqieuV/sKSPZvmcZ874a09syaOICCknKufX4JH67bG+iSjAk6UtM4HiIyEhiuqhO80+OA/qp692naPwfsU9XHq3luIjARICkpKXXWrFm1Kjo/P5/Y2NhaLRtsrC+1d7SogmdXFbM9t4IrOru5PsWN0yF1Xq/tk+BkffEYMmTISlVNq7Ghqp7xC7gBmF5pehzw7Gna3oznyD2ypvWmpqZqbX3yySe1XjbYWF/qpqi0TCe/s0Y7/vZ9HT11qR7MK6rzOm2fBCfriwewQmvIV1X16bRMFtC+0nQysKdqIxG5FPhvYISqFvuwXmPqLNLl5E/X9uRvN/Tm611HueLpz1m67XCgyzIm4HwJ90wgRUQ6i0gEMBqYV7mBiPQFpuIJ9gP+L9OYMxuZmszcuwYRG+li7PSveGbRFsorbOhg03jVGO6qWgbcDcwHNgKzVXW9iDwmIiO8zaYAscC/RGS1iMw7zeqMqTfnt4ln3j0XMaJ3W/7fR5sZO/0r9uYWBrosYwLCpyF/VfUD4IMq8x6u9PhSP9dlTK0s3LCf5TuOALBs+xF+8r+fMjq9PfPX72dPTiFtm0YzaVhXrunbzu/bnrsqmynzN9X7dnzx0Ny1vLlsN/f1KGX85A8Y0789j1/TMyC1mMCw8dxN2Ji7KpvJ76ylsLQcAAUKS8qZuWTnyTbZOYVMfmctgF+Dt+q262s7vnho7lpe/2rXyely1ZPTFvCNhw0/YMLGlPmbTobrCdWddS8sLWfK/E31vu362I4v3ly2+6zmm/Bk4W7Cxp4c38+vZ59F27ps+2xq8pfy03x25XTzTXiycDdho23TaJ/bOh3CF1sO1fu2z6Ymf3FK9R/kOt18E54s3E3YmDSsK9FV7rnqdghu56mhFuF00LxJBDfPWMYD//qGI8frfiu/6rYd7XYyaVjXOq/7bI3p3/6s5pvwZG+omrBx4o3LqlesVDdveI/WPLNoC9M+286ijfv53RXnMzI1Ganl0e3pth2Iq2VOvGl64hy7U8SulmmELNxNWLmmb7tqA7W6eb8Z3o0Rfdry0Jx1THp7DbNX7OYPI3r4fduB8Pg1PXn8mp4sXryYbWMHB7ocEwB2WsY0at1axzP7zoH89fqebDt4nCuf/ZzXNhSTU1D3UzXGBJKFu2n0HA5hVHoHPvn1YG4e0JGPd5Xx4ymLeWnJDkrtjk8mRFm4G+OVEOPmsat78NigaHq0i+cP721g2JOf8eG6fSdGPTUmZFi4G1NF+zgHr4/vz/Rb0nA4hJ+/vpKRLy5l2XYbbdKEDgt3Y6ohIlzaPYkPf/kj/nxdT3YfKWDUtK+4ZeZy1mTlBLo8Y2pk4W7MGbicDsZkdODTSUP43RXdWJOVw4jnljD+5UwLeRPULNyN8UF0hJOJF5/L578ZwgNDu7Diu6OMeG4Jt720nMydRwJdnjE/YOFuzFmIi3Jz9yUpfPHbIUwa1pW1Wbnc8OJSbnxxKQs37KfCbhBigoSFuzG1EBfl5q4h5/HFby/h4Su7k51TyIRXV3DZk5/yxrJdFJaU17wSY+qRhbsxdRAd4eRnF3Vm8aTBPD26D1FuJ7+bs5aBf1nEX/7vW3YfKQh0iaaRsuEHjPEDt9PB1X3aMaJ3WzJ3HuWlJTuY9tk2pn62jUu6tmLsgA78uEsrnA4bmdE0DAt3Y/xIRMjo3JyMzs3Zk1PIm8t38eby3Sx6eQVtE6K4Ia09I1OTad88JtClmjBn4W5MPWnbNJpfD+3KPZeksGjjft5YvotnPt7C04u2MPCcRK5PTWZ4j9bERtqfofE/+60ypp5FuBxc3rMNl/dsQ9bRAt75Opu3V2bxwL++4aG5a7mse2tG9G7LxV1aEOly1rxCY3xg4W5MA0puFsO9P0nhnkvO4+tdR5mzKpv31+zlvW/2EBflYmj31lzeozUXpbQgym1Bb2rPwt2YABARUjs2J7Vjcx656gKWbD3Ee9/s5aMN+/j311nERrr4cdeWDO2exOCurUiIdge6ZBNiLNyNCTC308Hgrq0Y3LUVJWU9+XLbIT5ct4+FGw/wnzV7cTqE9E7NuKSbp01Kq9ha3zHKNB4W7sYEkQjX90FfUaGs2p3Dx9/uZ9HGA/zpg2/50wff0iYhih+ltOCilJZceG4iLWIjA122CUIW7sbIwl0aAAANK0lEQVQEKYdDSO3YjNSOzZg0rBt7cgr5bPNBPt18kA/X7WP2iiwAurWOY8A5iQw4J5H0Ts1ItLA3WLgbEzLaNo1mdEYHRmd0oLxCWZudy5Kth1i67TCzMnfx8pc7ATivVSxp3heF8uMVqKqdxmmELNyNCUFOh9CnfVP6tG/KXUPOo7isnLVZuSzfeYTMHUf4YO1eZmXuBuAvKz+id3JTerdvSu/kBHomJ9AqLirAPTD1zcLdmDAQ6XKS1qk5aZ2aw2CoqFC2HcznjQVfURiTxOrdOTz38RZODFrZKi6SHu0S6N4mnu5t4zm/TTwdmsfY8AhhxMLdmDDkcAgpSXH8uL2bwYN7AVBQUsb6PcdYk5XL+j25rMvO5dPNByn3Jn6U20FKqzi6JMXRJSmWlKRYzmsZR7tm0Rb6IcjC3ZhGIibCRXqn5qR3an5yXlFpOVsP5LNh7zE27ctj0748Pt9ykH9/nXWyTaTLQecWTejcogmdWjShc2ITOibG0KlFE1rGRuKw4A9KFu7GNGJRbic92iXQo13CKfNzCkrYeiCfbQfz2Xognx2HjrNpfx4fbdhPWaUbkkS6HLRvHkNys2jaN4uhXbNo2jWNPvm9RWykHfUHiIW7MeYHmsZEfH8Ov5Ky8gr25BSx4/Bxdh0pYPeRAr47fJyso4Ws2pVDbmHpKe1dDiEpPorWCVG0jo8iKT6KpPhIWsVH0iouilZxkbSIjaRpjNuu6PEzC3djjM9cTgcdEmPokFj9kMV5RaVk5xSSfbSQPblF7M0pZF9uEfuOFbFx7zE+2XSAgmruUuV2ColNIkmMjSAxNpLEJhE0r/TVLCaC746U02ZfHs1i3MRHu23snRpYuBtj/CYuyk231m66tY4/bZv84jL2HyviwLFiDuQVcSi/hEP5xRzMK+bIcc/j7QfzOXK85AcvBH9e/tnJx1FuBwnRbuKj3J7v0W7io1zERbmJ836PjXIRF+miSaSLWO9Xk0gnsZEuYiJdxLidYfuegU/hLiLDgacBJzBdVf9S5flI4FUgFTgMjFLVnf4t1ZjwNXdVNlPmb2JPTiFtm0YzaVhX/rViF0u2HTnZZtC5zbkhrcMP2gE/mLfiuyO8uWw39/UoZfzkDxjTvz2PX9PTp+1Wt75r+rbzue4T2y5XxSnyg23HRrqIbRnL2qzcGrf96FUp/KhLC44cL+HTpSvokHI+RwtK+WrbYT7dfJD9x4q9p4JiKCwtZ+uBMo4VlZJXVHbyKqCaRLudxEQ4iY448d1FtNtBTISLaLeTSLeDaLeTKLeTKLeDKNf3jyNdnucjXd7HLgeRbgcRTicRLsf3X87vv7udgmr930i9xnAXESfwPHAZkAVkisg8Vd1Qqdl44Kiqnicio4G/AqPqo2Bjws3cVdlMfmcthaWeo9TsnELue2v1D9ot2XbklLDPzilk0tvfgEKpN8iycwq5/63VVFRarlyV17/aBXBKyFa33Un/+gYESsu/X9/kd9YC/CDgq1ve39t+ZN56/nxdT67p246DiU4G92rL3FXZfPztgZPLFpVWkHW08GQ7AFWlqLSCvOJS8ovKyC/2fhWVUVBSzvGSMo4Xl3G8uJzjxWUUlJZTWFJOQUkZhaUVFJaUcTCvmELv/KLScgpLPd99fM04o3HdIxhS99WckS9H7hnAVlXdDiAis4CrgcrhfjXwqPfx28BzIiLaEC9PxoS4KfM3nQyqs3UiCCurqKYdwJvLdp8SsNVtt7Sa5CosLWfK/E0/CPfqlm+IbVe3bNV2IkK092i8VdxpiqoFVaW0XCkqK6e4tIKi0nJKyisoLq2guKyckrIKissqKCmr8MwvK6e0TCku98wrLa+gtKyCuPxd/ivqNKSm/BWRkcBwVZ3gnR4H9FfVuyu1Wedtk+Wd3uZtc6jKuiYCE72TXYFNtay7BXCoxlahwfoSfBq0HxGtz0utr3WXF+TijPn+MseSfVtX1na7lZet6/K1XLYFcOhMy1atMYjV5Xeso6q2rKmRL0fu1b3bUPUVwZc2qOo0YJoP2zxzQSIrVDWtrusJBtaX4BMu/QBPX8pyD4RNX8Jpv9R3Xxw+tMkC2leaTgb2nK6NiLiABOAIxhhjAsKXcM8EUkSks4hEAKOBeVXazANu9T4eCXxs59uNMSZwajwto6plInI3MB/PpZAzVXW9iDwGrFDVecAM4DUR2YrniH10fRaNH07tBBHrS/AJl36A9SVY1XtfanxD1RhjTOjx5bSMMcaYEGPhbowxYSjow11EokRkuYh8IyLrReQP3vmdRWSZiGwRkbe8b/YGPRFxisgqEXnfOx2q/dgpImtFZLWIrPDOay4iH3n78pGINAt0nb4QkaYi8raIfCsiG0VkYCj2RUS6evfHia9jInJfiPblV96/93Ui8qY3B0L1b+WX3n6sF5H7vPPqfZ8EfbgDxcAlqtob6AMMF5EBeIY4eFJVU4CjeIZACAW/BDZWmg7VfgAMUdU+la7XfRBY5O3LIu90KHga+FBVuwG98eyfkOuLqm7y7o8+eMZ5KgDmEGJ9EZF2wL1Amqr2wHMhx4lhTULqb0VEegB34Pmkf2/gShFJoSH2iaqGzBcQA3wN9Mfz6S6Xd/5AYH6g6/Oh/mTvjrwEeB/Ph79Crh/eWncCLarM2wS08T5uA2wKdJ0+9CMe2IH34oJQ7kuV+ocCS0KxL0A7YDfQHM8Vfe8Dw0LxbwW4Ac9giyemfw/8piH2SSgcuZ84lbEaOAB8BGwDclS1zNskC88vRLB7Cs+OPTEERyKh2Q/wfAJ5gYis9A4rAZCkqnsBvN9bBaw6350DHARe8p4umy4iTQjNvlQ2GnjT+zik+qKq2cDfgF3AXiAXWElo/q2sAy4WkUQRiQGuwPOBz3rfJyER7qparp5/NZPx/HtzfnXNGraqsyMiVwIHVLXy2Bc+DdsQpAapaj/gcuAuEbk40AXVkgvoB7ygqn2B4wT5aYuaeM9FjwD+FehaasN7/vlqoDPQFmiC5/esqqD/W1HVjXhOJ30EfAh8A5SdcSE/CYlwP0FVc4DFwACgqXeoA6h+SIRgMwgYISI7gVl4Ts08Rej1AwBV3eP9fgDPed0MYL+ItAHwfj8QuAp9lgVkqeoy7/TbeMI+FPtywuXA16q63zsdan25FNihqgdVtRR4B7iQ0P1bmaGq/VT1Yjwf8txCA+yToA93EWkpIk29j6Px7PiNwCd4hjoAz9AH7wamQt+o6mRVTVbVTnj+Zf5YVccSYv0AEJEmIhJ34jGe87vrOHUYipDoi6ruA3aLSFfvrJ/gGc465PpSyRi+PyUDodeXXcAAEYkREeH7fRJyfysAItLK+70DcB2efVPv+yToP6EqIr2AV/C8Y+4AZqvqYyJyDp4j4ObAKuBmVS0OXKW+E5HBwAOqemUo9sNb8xzvpAt4Q1WfEJFEYDbQAc8f6A2qGvQDyIlIH2A6EAFsB27H+7tG6PUlBs+bkeeoaq53XsjtF+8lz6PwnMJYBUzAc449pP5WAETkczzvr5UC96vqoobYJ0Ef7sYYY85e0J+WMcYYc/Ys3I0xJgxZuBtjTBiycDfGmDBk4W6MMWHIlxtkG9OgvJeJLfJOtgbK8QwRAJChqiUBKewMRORnwAfe6+aNCTi7FNIENRF5FMhX1b8FQS1OVS0/zXNfAHer6uqzWJ+r0lgpxviVnZYxIUVEbhXP+P6rReTvIuIQEZeI5IjIFBH5WkTmi0h/EflURLaLyBXeZSeIyBzv85tE5CEf1/u4iCwHMkTkDyKS6R2f+0XxGIVnOOq3vMtHiEhWpU9WDxCRhd7Hj4vIVBH5CM9gZS4R+X/eba8RkQkN/1M14cjC3YQM79jY1wIXegeSc/H9zdgTgAXewcxKgEfxfGz9BuCxSqvJ8C7TD7hJRPr4sN6vVTVDVZcCT6tqOtDT+9xwVX0LWA2MUs946jWdNuoLXKWq44CJeAaUywDS8QzC1qE2Px9jKrNz7iaUXIonAFd4hhwhGs9H7QEKVfUj7+O1QK6qlonIWqBTpXXMV9WjACIyF7gIz9/B6dZbwvdDLQD8REQmAVFACzxD0f7fWfbjXVUt8j4eCpwvIpVfTFLwfCTdmFqzcDehRICZqvr7U2Z6RgqsfLRcgecOXiceV/49r/omk9aw3kL1vjHlHbflOaCfqmaLyON4Qr46ZXz/n3HVNser9OkXqroIY/zITsuYULIQuFFEWoDnqppanMIYKp57psbgGTN8yVmsNxrPi8Uh76iY11d6Lg+IqzS9E8+t7qjSrqr5wC9ODGUrnvugRp9ln4z5ATtyNyFDVdd6RwtcKCIOPKPs/ZyzG9f7C+AN4FzgtRNXt/iyXlU9LCKv4Bne+DtgWaWnXwKmi0ghnvP6jwL/EJF9wPIz1DMVz8iAq72nhA7gedExpk7sUkjTaHivROmhqvcFuhZj6pudljHGmDBkR+7GGBOG7MjdGGPCkIW7McaEIQt3Y4wJQxbuxhgThizcjTEmDP1/pGenSMj5bcYAAAAASUVORK5CYII=\n", + "text/plain": [ + "
" + ] + }, + "metadata": {}, + "output_type": "display_data" + } + ], + "source": [ + "%matplotlib inline\n", + "data_pred = pd.DataFrame({'Temperature': np.linspace(start=30, stop=90, num=121), 'Intercept': 1})\n", + "data_pred['Frequency'] = logmodel.predict(data_pred)\n", + "data_pred.plot(x=\"Temperature\",y=\"Frequency\",kind=\"line\",ylim=[0,1])\n", + "plt.scatter(x=data[\"Temperature\"],y=data[\"Frequency\"])\n", + "plt.grid(True)" + ] + }, + { + "cell_type": "markdown", + "metadata": { + "hideCode": false, + "hidePrompt": false, + "scrolled": true + }, + "source": [ + "This figure is very similar to the Figure 4 of Dalal *et al.* **I have managed to replicate the Figure 4 of the Dalal *et al.* article.**" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "## Computing and plotting uncertainty" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Following the documentation of [Seaborn](https://seaborn.pydata.org/generated/seaborn.regplot.html), I use regplot." + ] + }, + { + "cell_type": "code", + "execution_count": 7, + "metadata": {}, + "outputs": [ + { + "data": { + "image/png": "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\n", + "text/plain": [ + "
" + ] + }, + "metadata": {}, + "output_type": "display_data" + } + ], + "source": [ + "sns.set(color_codes=True)\n", + "plt.xlim(30,90)\n", + "plt.ylim(0,1)\n", + "sns.regplot(x='Temperature', y='Frequency', data=data, logistic=True)\n", + "plt.show()" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "**I think I have managed to correctly compute and plot the uncertainty of my prediction.** Although the shaded area seems very similar to [the one obtained by with R](https://app-learninglab.inria.fr/moocrr/gitlab/moocrr-session3/moocrr-reproducibility-study/tree/master/challenger.pdf), I can spot a few differences (e.g., the blue point for temperature 63 is outside)... Could this be a numerical error ? Or a difference in the statistical method ? It is not clear which one is \"right\"." + ] + } + ], + "metadata": { + "celltoolbar": "Hide code", + "kernelspec": { + "display_name": "Python 3", + "language": "python", + "name": "python3" + }, + "language_info": { + "codemirror_mode": { + "name": "ipython", + "version": 3 + }, + "file_extension": ".py", + "mimetype": "text/x-python", + "name": "python", + "nbconvert_exporter": "python", + "pygments_lexer": "ipython3", + "version": "3.8.8" + } + }, + "nbformat": 4, + "nbformat_minor": 2 +}
