a possible analysis
parent caaa4b95
title: "Analysis of the risk of failure of the O-rings on the Challenger shuttle"
author: "Gkiouzepi Eleni"
date: "24/7/2021"
output: html_document
On January 27, 1986, the day before the takeoff of the shuttle _Challenger_, had
# Loading the data
data = read.csv("shuttle.csv",header=T)
# Graphical inspection
~~Flights without incidents do not provide any information
We thus focus on the experiments in which at least one O-ring was defective.~~ **Wrong assumption**
# mal = data[data$Malfunction>0,]
plot(data=data, Malfunction/Count ~ Temperature, ylim=c(0,1))
# Estimation of the temperature influence
logistic_reg = glm(data=data, Malfunction/Count ~ Temperature, weights=Count,
family=binomial(link='logit'))
summary(logistic_reg)
# mal_logistic_reg = glm(data=mal, Malfunction/Count ~ Temperature, weights=Count,
# family=binomial(link='logit'))
# summary(mal_logistic_reg)
The most likely estimator of the temperature parameter is ~~0.001416~~ __-0.11560__
and the standard error of this estimator is 0.047, in other words
**WRONG** ~~we
cannot distinguish any particular impact~~
_it is inverse-dependent on temperature, if temperature decreases by 1 degree, the probability of O-ring malfunction increases by 0.1156,_ and we must take our
# Estimation of the probability of O-ring malfunction
# shuttle=shuttle[shuttle$r!=0,]
tempv = seq(from=30, to=90, by = .5)
# rmv_mal <- predict(mal_logistic_reg,list(Temperature=tempv),type="response")
# plot(tempv,rmv_mal,type="l",ylim=c(0,1))
# points(data=mal, Malfunction/Count ~ Temperature)
rmv <- predict(logistic_reg,list(Temperature=tempv),se.fit=T,type="response")
plot(tempv,rmv$fit,type="l",ylim=c(0,1))
lines(tempv,rmv$fit+rmv$se.fit,col="red")
lines(tempv,rmv$fit-rmv$se.fit,col="red")
points(data=data, Malfunction/Count ~ Temperature)
~~As expected from the initial data~~, the
temperature has **VERY** ~~no~~ significant impact on the probability of failure of the
O-rings. It will be ~~about 0.2~~ **in average over 0.8 to as high as more than 1.0 (certain)**,~~as in the tests
where we had a failure of at least one joint~~ **so we are expecting a failure of at least 4 joints**. Let's ~~get back to the initial dataset to~~ estimate the probability of failure:
# data_full = read.csv("shuttle.csv",header=T)
# sum(data_full$Malfunction)/sum(data_full$Count)
estim = predict(logistic_reg,list(Temperature=31),se.fit=T,type="response")
estim
This probability is thus about $p=`r round(estim$fit, digits = 5)`\pm`r round(estim$se.fit, digits = 5)`$. Knowing that there is
is $p^2 \approx `r round((estim$fit+estim$se.fit)^2, digits = 2)`\pm`r round(2*estim$se.fit*estim$fit, digits = 2)`$. The probability of failure of any one of the
launchers is $1-(1-p^2)^3 \approx `r (1-(1-round((estim$fit+estim$se.fit)^2, digits = 0))^3)*100`\%$. ~~That would really be
tomorrow as planned~~.**ABORT! ABORT! ABORT THE MISSION!**
*Unfortunately, none of the above analysis was carried out properly and* the next day, the Challenger shuttle exploded and took away
includes (at least) a small problem.
