001794a2845aaaaa5f4e3eb9aca8fb36
568c798e
Commit
568c798e
by
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
Exercice 2 du module 2
parent
95b3ab15
Changes
1
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
with
256 additions
and
3 deletions
+256
-3
exercice.ipynb
module2/exo2/exercice.ipynb
+256
-3
No files found.
View file @
568c798e
"cells": [],
"cells": [
"cell_type": "markdown",
"metadata": {
"hideCode": true,
"hidePrompt": true
"source": [
"# Exercice 2 du module 2"
"metadata": {
"hideCode": true,
"hidePrompt": true
"source": [
"Liste des données pour l'exercice"
"cell_type": "code",
"execution_count": 1,
"metadata": {},
"outputs": [],
"source": [
"import numpy as np\n",
"data = np.array([14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9, 12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0])"
"metadata": {},
"source": [
"## Calcul de la moyenne"
"metadata": {},
"source": [
"A chaque fois on peut écrire la commande de deux manières, mais je pense que np.xxx est la meilleure façon"
"execution_count": 2,
"metadata": {},
"outputs": [
"data": {
"text/plain": [
"14.113000000000001"
"metadata": {},
"output_type": "execute_result"
"source": [
"data.mean()"
"execution_count": 3,
"metadata": {},
"outputs": [
"data": {
"text/plain": [
"metadata": {},
"source": [
"np.mean(data)"
"metadata": {},
"source": [
"## Calcul du minimum"
"execution_count": 4,
"metadata": {},
"outputs": [
"data": {
"text/plain": [
"2.8"
"metadata": {},
"source": [
"data.min()"
"execution_count": 5,
"metadata": {},
"outputs": [
"data": {
"text/plain": [
"2.8"
"metadata": {},
"source": [
"np.min(data)"
"metadata": {},
"source": [
"## Calcul du maximum"
"execution_count": 6,
"metadata": {},
"outputs": [
"data": {
"text/plain": [
"23.4"
"metadata": {},
"source": [
"data.max()"
"execution_count": 7,
"metadata": {},
"outputs": [
"data": {
"text/plain": [
"23.4"
"metadata": {},
"source": [
"np.max(data)"
"metadata": {},
"source": [
"## Calcul de la médiane"
"execution_count": 8,
"metadata": {},
"outputs": [
"data": {
"text/plain": [
"14.5"
"metadata": {},
"source": [
"np.median(data)"
"metadata": {},
"source": [
"## Calcul de l'écart-type"
"execution_count": 9,
"metadata": {},
"outputs": [
"data": {
"text/plain": [
"4.334094455301447"
"metadata": {},
"source": [
"data.std(ddof=1)"
"execution_count": 10,
"metadata": {},
"outputs": [
"data": {
"text/plain": [
"4.334094455301447"
"metadata": {},
"source": [
"np.std(data, ddof=1)"
"metadata": {
"metadata": {
"hide_code_all_hidden": true,
"kernelspec": {
"kernelspec": {
"display_name": "Python 3",
"language": "python",
@@ -16,10 +270,9 @@
@@ -16,10 +270,9 @@
"name": "python",
"name": "python",
"nbconvert_exporter": "python",
"pygments_lexer": "ipython3",
"version": "3.6.
3
"version": "3.6.
4
"nbformat": 4,
"nbformat": 4,
"nbformat_minor": 2
"nbformat_minor": 2
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
You are about to add
people
to the discussion. Proceed with caution.
Finish editing this message first!
Please
register
or
sign in
to comment
