Commit 15de0e25 authored by Renaud Marti's avatar Renaud Marti
Cholera
Travaux sur la cartographie des cas Choléra.
parent 70d71c0d
This source diff could not be displayed because it is too large. You can view the blob instead.
This diff is collapsed.
...@@ -2,13 +2,13 @@ ...@@ -2,13 +2,13 @@
"type": "FeatureCollection", "type": "FeatureCollection",
"crs": { "type": "name", "properties": { "name": "urn:ogc:def:crs:OGC:1.3:CRS84" } }, "crs": { "type": "name", "properties": { "name": "urn:ogc:def:crs:OGC:1.3:CRS84" } },
"features": [ "features": [
{ "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.136667835223584, 51.51334111057735 ] } }, { "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.135062137391632, 51.512831534914525 ] } },
{ "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.139586127564204, 51.513875984363544 ] } }, { "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.137980739989555, 51.513366517201163 ] } },
{ "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.139670981202765, 51.514905566064378 ] } }, { "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.138065561074478, 51.514396219439909 ] } },
{ "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.131629815245003, 51.512354016927958 ] } }, { "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.130023584438775, 51.511844246562092 ] } },
{ "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.133594369998168, 51.512138872501581 ] } }, { "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.13198837162727, 51.511629108601461 ] } },
{ "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.135919106184737, 51.511542311994639 ] } }, { "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.134313396885604, 51.511032516155275 ] } },
{ "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.13396169462483, 51.510019341447595 ] } }, { "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.132355824978361, 51.509509338065222 ] } },
{ "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.138198726552408, 51.511295219582664 ] } } { "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.136593286858317, 51.51078543153146 ] } }
Markdown is supported
0% or
You are about to add 0 people to the discussion. Proceed with caution.
Finish editing this message first!
Please register or to comment
