Commit 9072d514 authored by Renaud Marti's avatar Renaud Marti
Mooc_RR_Epidemie_Cholera
Travail personnel
parent 80ce5f28
This diff is collapsed.
PROJCS["OSGB 1936 / British National Grid",GEOGCS["OSGB 1936",DATUM["OSGB 1936",SPHEROID["Airy 1830",6377563.396,299.3249646]],PRIMEM["Greenwich",0.0],UNIT["degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["false_easting",400000.0],PARAMETER["false_northing",-100000.0],PARAMETER["central_meridian",-2.0],PARAMETER["scale_factor",0.9996012717],PARAMETER["latitude_of_origin",49.0],UNIT["m",1.0]]
\ No newline at end of file
"type": "FeatureCollection",
"crs": { "type": "name", "properties": { "name": "urn:ogc:def:crs:OGC:1.3:CRS84" } },
"features": [
{ "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.136667835223584, 51.51334111057735 ] } },
{ "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.139586127564204, 51.513875984363544 ] } },
{ "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.139670981202765, 51.514905566064378 ] } },
{ "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.131629815245003, 51.512354016927958 ] } },
{ "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.133594369998168, 51.512138872501581 ] } },
{ "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.135919106184737, 51.511542311994639 ] } },
{ "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.13396169462483, 51.510019341447595 ] } },
{ "type": "Feature", "properties": { "Id": 0 }, "geometry": { "type": "Point", "coordinates": [ -0.138198726552408, 51.511295219582664 ] } }
Markdown is supported
0% or
You are about to add 0 people to the discussion. Proceed with caution.
Finish editing this message first!
Please register or to comment
