# Buffon's Needle
Applying the method of [Buffon's needle](https://en.wikipedia.org/wiki/Buffon%27s_needle_problem), we get the **approximation**
set.seed(42)
N = 100000
x = runif(N)
theta = pi/2*runif(N)
2/(mean(x+sin(theta)>1))
# Using a surface fraction argument
```{r pressure, echo=FALSE}
plot(pressure)
A method that is easier to understand and does not make use of the $sin$ function is based on the fact that if $X ~ U(0,1)$ and $Y ~ U(0,1)$, then $P[X^2 + Y^2 <= 1] = π/4$ (see ["Monte Carlo method" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:
