0db2f0554d3b3bbdf0f34a0c1240bdef
c1d825a7
c1d825a7
no commit message
6c52b8e9
48 additions
10 deletions
+48
-10
exercice.ipynb
module2/exo2/exercice.ipynb
+48
-10
c1d825a7
@@ -4,7 +4,7 @@
"# Savoir faire un calcul simple soi-même\n",
par
soi-même\n",
"Je vais calculer la moyenne et l'écart-type, le min, la médiane et le max des données suivantes :\n",
"14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0\n",
@@ -26,7 +26,7 @@
"import numpy as np\n",
"val
ue
s=np.array([14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0])\n",
"val
eur
"#print(values[2])"
@@ -46,13 +46,13 @@
"14.113000000000001\n"
moyenne des valeurs =
moyenne=value
s.mean()\n",
"print (moyenne)\n"
valeurs_moyenne = valeur
s.mean()\n",
"print (
'moyenne des valeurs =',valeurs_
moyenne)\n"
@@ -65,20 +65,55 @@
"execution_count":
5
"execution_count":
3
"4.334094455301447\n"
écart-type des valeurs =
"ecart_type=np.std(values, 0, ddof = 1)\n",
"print (ecart_type)"
"valeurs_ecart_type = np.std(valeurs, 0, ddof = 1)\n",
"print ('écart-type des valeurs = ', valeurs_ecart_type)"
"## Calcul du min et du max"
"execution_count": 4,
"minimum des valeurs = 2.8\n",
"maximum des valeurs = 23.4\n"
"valeurs_min = valeurs.min()\n",
"valeurs_max = valeurs.max()\n",
"print('minimum des valeurs = ', valeurs_min)\n",
"print('maximum des valeurs = ', valeurs_max)"
"## Calcul de la médiane"
@@ -86,7 +121,10 @@
"execution_count": null,
"source": []
"Valeurs_med = np.median(valeurs, 0)\n",
"Print( 'médiane des valeurs = ', Valeurs_med)"
