Commit 4e5f9a93 authored by gallayfl's avatar gallayfl
Complete exercise 3 in R
parent 93a4c8e5
title: "Votre titre" title: "Module 2, exercise 3"
author: "Votre nom" author: "GALLAY Florian"
date: "La date du jour" date: "19/10/2021"
output: html_document output: pdf_document
...@@ -10,24 +10,15 @@ output: html_document ...@@ -10,24 +10,15 @@ output: html_document
## Quelques explications ```{r}
values <- c(14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0)
Ceci est un document R markdown que vous pouvez aisément exporter au format HTML, PDF, et MS Word. Pour plus de détails sur R Markdown consultez <http://rmarkdown.rstudio.com>. plot(0:99, values, xlim = c(0, 100), type="l", col="blue", xaxs="i", yaxs="i")
grid (NULL,NULL, lty = "dotted", col="darkgrey")
Et on peut aussi aisément inclure des figures. Par exemple: ```{r}
hist(values, breaks=seq(1, 25, 2), xlim=c(0,25), xaxs="i", yaxs="i", col="blue")
```{r pressure, echo=FALSE} grid (NULL,NULL, col="darkgrey", lty="dotted")
plot(pressure)
