title: "Exercice 2.3 : Réaliser un affichage graphique"
author: "Julien Quénon"
date: "01/04/2021"
output: html_document
@@ -10,24 +10,28 @@ output: html_document
## Quelques explications
## Créer le dataset
## Sequence plot
```{r sequence plot, echo=FALSE}
plot(df$valeurs,
type = "l", col = "blue", panel.first = grid(),
xlim = c(0,100), ylim = c(0,25),
xlab = "", ylab = "")
## Histogram plot
```{r pressure, echo=FALSE}
plot(pressure)
hist(df$valeurs,
main = "", panel.first = grid(),
breaks = 9,
col = "blue",
xlim = c(0,25), ylim = c(0,25),
xlab ="", ylab = "")
