Exercices 2.2 et 2.3, Barnier S., 13/12/2021
parent 08bb6089
"cells": [], "cells": [
"# Exercice 2.2 : Savoir faire un calcul simple soi-même\n",
"Calcul de l'écart type, le minimum, la médiane et le maximum d'une série de données."
"execution_count": 5,
"[14. 7.6 11.2 12.8 12.5 9.9 14.9 9.4 16.9 10.2 14.9 18.1 7.3 9.8\n",
" 10.9 12.2 9.9 2.9 2.8 15.4 15.7 9.7 13.1 13.2 12.3 11.7 16. 12.4\n",
" 17.9 12.2 16.2 18.7 8.9 11.9 12.1 14.6 12.1 4.7 3.9 16.9 16.8 11.3\n",
" 14.4 15.7 14. 13.6 18. 13.6 19.9 13.7 17. 20.5 9.9 12.5 13.2 16.1\n",
" 13.5 6.3 6.4 17.6 19.1 12.8 15.5 16.3 15.2 14.6 19.1 14.4 21.4 15.1\n",
" 19.6 21.7 11.3 15. 14.3 16.8 14. 6.8 8.2 19.9 20.4 14.6 16.4 18.7\n",
" 16.8 15.8 20.4 15.8 22.4 16.2 20.3 23.4 12.1 15.5 15.4 18.4 15.7 10.2\n",
" 8.9 21. ]\n"
"import numpy as np\n",
"x=np.array([14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0])\n",
"print(x)"
"execution_count": 6,
"xmin = np.min(x) # calcul du minimum\n",
"xmax = np.max(x) # calcul du maximum\n",
"xmed = np.median(x) # calcul de la méoiane\n",
"xstd = np.std(x,ddof=1) # calcul de l'écart type"
"L'écart type de la série de données est :"
"execution_count": 9,
"4.334094455301447\n"
"print(xstd)"
"Le minimum de la série de données est :"
"execution_count": 10,
"2.8\n"
"print(xmin)"
"La médiane de la série de données est :"
"execution_count": 11,
"14.5\n"
"print(xmed)"
"Le maximum de la série de données est :"
"execution_count": 12,
"23.4\n"
"print(xmax)"
"metadata": { "metadata": {
...@@ -16,10 +161,9 @@ ...@@ -16,10 +161,9 @@
"nbformat": 4, "nbformat": 4,
This diff is collapsed.
