final
parent 1809a237
......@@ -495,7 +495,7 @@
"cell_type": "code",
"execution_count": 17,
"execution_count": 4,
"metadata": {},
"outputs": [
......@@ -504,10 +504,10 @@
"<table class=\"simpletable\">\n",
"<caption>Generalized Linear Model Regression Results</caption>\n",
"<tr>\n",
" <th>Dep. Variable:</th> <td>Frequency</td> <th> No. Observations: </th> <td> 23</td> \n",
" <th>Dep. Variable:</th> <td>Frequency</td> <th> No. Observations: </th> <td> 7</td> \n",
"</tr>\n",
"<tr>\n",
" <th>Model:</th> <td>GLM</td> <th> Df Residuals: </th> <td> 21</td> \n",
" <th>Model:</th> <td>GLM</td> <th> Df Residuals: </th> <td> 5</td> \n",
"</tr>\n",
"<tr>\n",
" <th>Model Family:</th> <td>Binomial</td> <th> Df Model: </th> <td> 1</td> \n",
......@@ -516,16 +516,16 @@
" <th>Link Function:</th> <td>logit</td> <th> Scale: </th> <td> 1.0000</td> \n",
"</tr>\n",
"<tr>\n",
" <th>Method:</th> <td>IRLS</td> <th> Log-Likelihood: </th> <td> -3.9210</td> \n",
" <th>Method:</th> <td>IRLS</td> <th> Log-Likelihood: </th> <td> -2.5250</td> \n",
"</tr>\n",
"<tr>\n",
" <th>Date:</th> <td>Thu, 22 Oct 2020</td> <th> Deviance: </th> <td> 3.0144</td> \n",
" <th>Date:</th> <td>Thu, 05 Nov 2020</td> <th> Deviance: </th> <td> 0.22231</td> \n",
"</tr>\n",
"<tr>\n",
" <th>Time:</th> <td>11:23:38</td> <th> Pearson chi2: </th> <td> 5.00</td> \n",
" <th>Time:</th> <td>02:29:10</td> <th> Pearson chi2: </th> <td> 0.236</td> \n",
"</tr>\n",
"<tr>\n",
" <th>No. Iterations:</th> <td>6</td> <th> Covariance Type: </th> <td>nonrobust</td>\n",
" <th>No. Iterations:</th> <td>4</td> <th> Covariance Type: </th> <td>nonrobust</td>\n",
"</tr>\n",
"</table>\n",
......@@ -533,10 +533,10 @@
" <td></td> <th>coef</th> <th>std err</th> <th>z</th> <th>P>|z|</th> <th>[0.025</th> <th>0.975]</th> \n",
"</tr>\n",
"<tr>\n",
" <th>Intercept</th> <td> 5.0850</td> <td> 7.477</td> <td> 0.680</td> <td> 0.496</td> <td> -9.570</td> <td> 19.740</td>\n",
" <th>Intercept</th> <td> -1.3895</td> <td> 7.828</td> <td> -0.178</td> <td> 0.859</td> <td> -16.732</td> <td> 13.953</td>\n",
"</tr>\n",
"<tr>\n",
" <th>Temperature</th> <td> -0.1156</td> <td> 0.115</td> <td> -1.004</td> <td> 0.316</td> <td> -0.341</td> <td> 0.110</td>\n",
" <th>Temperature</th> <td> 0.0014</td> <td> 0.122</td> <td> 0.012</td> <td> 0.991</td> <td> -0.238</td> <td> 0.240</td>\n",
"</tr>\n",
"</table>"
......@@ -545,24 +545,24 @@
"\"\"\"\n",
" Generalized Linear Model Regression Results \n",
"==============================================================================\n",
"Dep. Variable: Frequency No. Observations: 23\n",
"Model: GLM Df Residuals: 21\n",
"Dep. Variable: Frequency No. Observations: 7\n",
"Model: GLM Df Residuals: 5\n",
"Model Family: Binomial Df Model: 1\n",
"Link Function: logit Scale: 1.0000\n",
"Method: IRLS Log-Likelihood: -3.9210\n",
"Date: Thu, 22 Oct 2020 Deviance: 3.0144\n",
"Time: 11:23:38 Pearson chi2: 5.00\n",
"No. Iterations: 6 Covariance Type: nonrobust\n",
"Method: IRLS Log-Likelihood: -2.5250\n",
"Date: Thu, 05 Nov 2020 Deviance: 0.22231\n",
"Time: 02:29:10 Pearson chi2: 0.236\n",
"No. Iterations: 4 Covariance Type: nonrobust\n",
"===============================================================================\n",
" coef std err z P>|z| [0.025 0.975]\n",
"-------------------------------------------------------------------------------\n",
"Intercept 5.0850 7.477 0.680 0.496 -9.570 19.740\n",
"Temperature -0.1156 0.115 -1.004 0.316 -0.341 0.110\n",
"Intercept -1.3895 7.828 -0.178 0.859 -16.732 13.953\n",
"Temperature 0.0014 0.122 0.012 0.991 -0.238 0.240\n",
"metadata": {},
"output_type": "execute_result"
......@@ -691,7 +691,7 @@
"execution_count": 21,
"execution_count": 7,
"metadata": {},
"outputs": [
......@@ -721,12 +721,12 @@
"cell_type": "markdown",
"metadata": {},
"source": [
"<p>As we can see using visual inspection there is some tendency the tests with temperatures between 65 and 90 have less failure. Of course we can't really conclude using only this observation, however at least we know that ... </p>"
"<p>As we can see using visual inspection there is some tendency the tests with temperatures between 65 and 90 have less failure. Of course we can't really conclude using only this observation since we don't have enough data for the lower temperatures. However, we can see clearly that there were 2 failures occured on the lowest temperature which is 53, and there is no successful experiment below 65. This visual inspection should have raised suspicion before launching the challenger shuttle.</p>"
"execution_count": 23,
"execution_count": 8,
"metadata": {},
"outputs": [
......@@ -743,6 +743,10 @@
"source": [
"data[\"Success\"]=data.Count-data.Malfunction\n",
"data[\"Intercept\"]=1\n",
"logmodel=sm.GLM(data['Frequency'], data[['Intercept','Temperature']], family=sm.families.Binomial(sm.families.links.logit)).fit()\n",
"\n",
"%matplotlib inline\n",
"data_pred = pd.DataFrame({'Temperature': np.linspace(start=30, stop=90, num=121), 'Intercept': 1})\n",
"data_pred['Frequency'] = logmodel.predict(data_pred[['Intercept','Temperature']])\n",
......@@ -755,7 +759,7 @@
"metadata": {},
"source": [
"<p> Also when we plot the regression now we can see that lower temperatures seem to have more ...</p>"
"<p>Now on the plot above we reuse the same regression technique, however, this time we include all of dataset. Now we can see clearly that the temperature of the experiment indeed has an influence on the probability of the failure. From the corresponding plot we can see the probability is arround 80 percent which is pretty high.</p>"
Markdown is supported
0% or
You are about to add 0 people to the discussion. Proceed with caution.
Finish editing this message first!
Please register or to comment
