Update exercice_fr.Rmd
parent 33c48e14
title: "Votre titre"
author: "Votre nom"
date: "La date du jour"
title: "Exercice 2"
author: "Elia Perennes"
date: "26 aout 2020"
output: html_document
......@@ -10,24 +10,25 @@ output: html_document
## Quelques explications
## Question 1
```{r, echo = FALSE}
x = c(14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0)
```{r pressure, echo=FALSE}
plot(pressure)
summary(x)
sd(x)
## Question 2
plot(x, type = "l", panel.first=grid(), col = "blue", xlab = "", ylab = "")
hist(x, panel.first=grid(), col = "blue", xlab = "", ylab = "", main = "", breaks = 10, xlim = c(0,25))
