exercise 2 module 2
parent 01bf46f9
"cells": [], "cells": [
"execution_count": 14,
"data = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]"
"execution_count": 15,
"import numpy as np"
"execution_count": 16,
"data = np.asarray(data)"
"# moyenne"
"execution_count": 17,
"moyenne = data.mean()"
"execution_count": 18,
"14.11"
"np.around(moyenne, decimals=2)"
"# minimum"
"execution_count": 20,
"minimum = data.min()"
"execution_count": 21,
"2.8"
"np.around(minimum, decimals=2)"
"# maximum"
"execution_count": 22,
"maximum = data.max()"
"execution_count": 23,
"23.4"
"np.around(maximum, decimals=2)"
"# médiane"
"execution_count": 24,
"median = np.median(data)"
"execution_count": 25,
"14.5"
"np.around(median, decimals=2)"
"# écart-type"
"execution_count": 26,
"std = np.std(data, ddof=1)"
"execution_count": 27,
"4.33"
"np.around(std, decimals=2)"
"metadata": { "metadata": {
...@@ -16,10 +224,9 @@ ...@@ -16,10 +224,9 @@
"nbformat": 4, "nbformat": 4,
"execution_count": 1,
"execution_count": null,
"source": []
...@@ -16,10 +33,9 @@ ...@@ -16,10 +33,9 @@
