upd
parent 32813e94
This diff is collapsed.
"cells": [],
"cells": [
"cell_type": "markdown",
"metadata": {},
"source": [
"Enregistrement des données de base :"
"cell_type": "code",
"execution_count": 3,
"metadata": {},
"outputs": [
"name": "stdout",
"output_type": "stream",
"text": [
"[14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9, 12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]\n"
"source": [
"data = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]\n",
"print(data)"
"metadata": {},
"source": [
"Calculs sur les données :"
"execution_count": 8,
"metadata": {},
"outputs": [],
"source": [
"import numpy as np"
"metadata": {},
"source": [
"Moyenne :"
"execution_count": 9,
"metadata": {},
"outputs": [
"name": "stdout",
"text": [
"14.113000000000001\n"
"source": [
"average = np.average(data)\n",
"print(average)"
"metadata": {},
"source": [
"Ecart-type :"
"execution_count": 11,
"metadata": {},
"outputs": [
"name": "stdout",
"text": [
"4.334094455301447\n"
"source": [
"std = np.std(data, ddof=1)\n",
"print(std)"
"metadata": {},
"source": [
"Min :"
"execution_count": 12,
"metadata": {},
"outputs": [
"name": "stdout",
"text": [
"2.8\n"
"source": [
"mini = np.min(data)\n",
"print(mini)"
"metadata": {},
"source": [
"Médiane : "
"execution_count": 15,
"metadata": {},
"outputs": [
"name": "stdout",
"text": [
"14.5\n"
"source": [
"med = np.median(data)\n",
"print(med)"
"metadata": {},
"source": [
"Max :"
"execution_count": 14,
"metadata": {},
"outputs": [
"name": "stdout",
"text": [
"23.4\n"
"source": [
"maxi = np.max(data)\n",
"print(maxi)"
"metadata": {
"kernelspec": {
"display_name": "Python 3",
......@@ -16,10 +183,9 @@
"name": "python",
"nbconvert_exporter": "python",
"pygments_lexer": "ipython3",
"version": "3.6.3"
"version": "3.6.4"
"nbformat": 4,
"nbformat_minor": 2
Markdown is supported
0% or
You are about to add 0 people to the discussion. Proceed with caution.
Finish editing this message first!
Please register or to comment
