new try
parent daf3137c
...@@ -17,8 +17,10 @@ ...@@ -17,8 +17,10 @@
"execution_count": 12, "execution_count": 14,
"metadata": {}, "metadata": {
"scrolled": true
"outputs": [ "outputs": [
"name": "stdout", "name": "stdout",
...@@ -43,7 +45,40 @@ ...@@ -43,7 +45,40 @@
"execution_count": 13, "execution_count": 17,
"3.128911138923655"
"import numpy as np\n",
"np.random.seed(seed=42)\n",
"N = 10000\n",
"## Avec un argument \"frésuentiel\" de surface\n",
"Sinon, une méthode plus simple à comprendre et ne faisant pas intervenir d'appel à la fonction sinus se base sur le fait que si $X \\sim \\mathcal{U}(0,1)$ et $Y \\sim \\mathcal{U}(0,1)$ alors $P\\left[X^2 + Y^2 \\leq 1\\right] = \\pi/4$\n"
"execution_count": 20,
...@@ -68,13 +103,14 @@ ...@@ -68,13 +103,14 @@
"N=1000\n", "N=1000\n",
"x = np.random.uniform(size=N, low=0, high=1)\n", "x = np.random.uniform(size=N, low=0, high=1)\n",
"y = np.random.uniform(size=N, low=0, high=1)\n", "y = np.random.uniform(size=N, low=0, high=1)\n",
"accept = (x*x+y*y) <= 1\n", "accept = (x*x+y*y) <= 1\n",
"reject = np.logical_not(accept)\n", "reject = np.logical_not(accept)\n",
"\n", "\n",
"fig, ax = plt.subplots(1)\n", "fig, ax = plt.subplots(1)\n",
"ax.scatter(x[accept], y[accept], c='b', alpha=0.2, edgecolor=None)\n", "ax.scatter(x[accept], y[accept], c='b', alpha=0.2, edgecolor=None)\n",
"ax.scatter(x[reject], y[reject], c='r', alpha=0.2, edgecolor=None)\n", "ax.scatter(x[reject], y[reject], c='r', alpha=0.2, edgecolor=None)\n",
"ax.set_aspect('equal')\n" "ax.set_aspect('equal')"
...@@ -86,7 +122,7 @@ ...@@ -86,7 +122,7 @@
"execution_count": 9, "execution_count": 21,
...@@ -95,7 +131,7 @@ ...@@ -95,7 +131,7 @@
"3.112" "3.112"
"output_type": "execute_result" "output_type": "execute_result"
...@@ -103,13 +139,6 @@ ...@@ -103,13 +139,6 @@
"source": [ "source": [
"4*np.mean(accept)" "4*np.mean(accept)"
"execution_count": null,
"source": []
"metadata": { "metadata": {
