1d461b90
1d461b90
Init.org / init.el management trick
83f03484
2
2 changed files
10 additions
3 deletions
+10
-3
emacs_orgmode.org
module2/ressources/emacs_orgmode.org
+10
-3
rr_org_archive.tgz
module2/ressources/rr_org_archive.tgz
+0
1d461b90
@@ -177,7 +177,7 @@ their user name.
** Step 1: Download our configuration
#+begin_src shell :results output :exports none
export FILE_LIST="rr_org/init.el rr_org/journal.org"
rr_org/init.org
tar zcf rr_org_archive.tgz $FILE_LIST
@@ -191,8 +191,15 @@ tar tzf rr_org_archive.tgz
: rr_org/init.el
: rr_org/init.el
: rr_org/journal.org
: rr_org/init.org
Alternatively, [[file:rr_org/][the files you are looking for are available here]].
Alternatively, [[file:rr_org/][the files you are looking for are available here]]. As
you may notice, the configuration (=init.el= in emacs lisp) is hard to
follow, which is why we manage it through an =init.org=, file, which is
really nice for readability. This is a trick you may want to adopt
too (i.e., modify the =init.org= and regenerate the =init.el= by simply
/tangling/ the file --with =M-x org-babel-tangle=, see instructions in the
beginning of =init.org=).
If you use Windows, and if you use a desktop shortcut to start Emacs,
you must include the path to the file =init.el= in the command for the
1d461b90
No preview for this file type
