7e0ec266
7e0ec266
Many additional information on how to deploy a specific R or python package.
e1b27f41
153 additions
6 deletions
+153
-6
resources.org
module4/ressources/resources.org
+153
-6
7e0ec266
@@ -90,7 +90,9 @@ This topic is discussed on [[https://stackoverflow.com/questions/20180543/how-to
package
installer
within
a
shell
command
it
is
easy
to
query
the
package
installer
within
a
shell
command
it
is
easy
to
query
the
version
of
all
installed
packages
note
that
on
your
system
you
may
version
of
all
installed
packages
note
that
on
your
system
you
may
have
to
use
either
pip
pip3
depending
on
how
it
is
named
which
have
to
use
either
pip
pip3
depending
on
how
it
is
named
which
versions
of
Python
are
available
on
your
machine
versions
of
Python
are
available
on
your
machine
Here
for
example
how
I
get
these
information
on
my
machine
begin_src
shell
results
output
exports
both
begin_src
shell
results
output
exports
both
pip3
freeze
pip3
freeze
end_src
end_src
@@ -116,14 +118,45 @@ wcwidth==0.1.7
webencodings
0.5
webencodings
0.5
end_example
end_example
In
a
Jupyter
notebook
this
can
easily
be
done
using
the
sh
magic
Here
is
for
example
what
you
could
do
get
on
the
Jupyter
notebooks
we
deployed
for
the
MOOC
note
that
here
you
should
simply
use
the
pip
command
begin_src
python
results
output
exports
both
sh
pip
freeze
end_src
results
begin_example
alembic
0.9.9
asn1crypto
0.24.0
attrs
18.1.0
Automat
0.0.0
numpy
1.13.3
olefile
0.45.1
packaging
17.1
pamela
0.3.0
pandas
0.22.0
webencodings
0.5
widgetsnbextension
3.2.1
xlrd
1.1.0
zope
interface
4.5.0
end_example
In
the
rest
of
this
document
I
will
assume
the
correct
command
is
pip
I
will
not
systematically
insert
the
sh
magic
Once
you
know
which
packages
are
installed
you
can
easily
get
Once
you
know
which
packages
are
installed
you
can
easily
get
additional
information
about
a
given
package
in
particular
check
additional
information
about
a
given
package
in
particular
check
whether
it
was
installed
"locally"
through
pip
whether
it
is
whether
it
was
installed
"locally"
through
pip
whether
it
is
installed
system
wide
Again
in
a
shell
command
installed
system
wide
Again
in
a
shell
command
begin_src
shell
results
output
exports
both
begin_src
shell
results
output
exports
both
pip
3
show
pandas
pip
show
pandas
echo
echo
pip
3
show
statsmodels
pip
show
statsmodels
end_src
end_src
RESULTS
RESULTS
@@ -148,7 +181,6 @@ License: BSD License
Location
home
alegrand
local
lib
python3
.6
site
packages
Location
home
alegrand
local
lib
python3
.6
site
packages
Requires
patsy
pandas
Requires
patsy
pandas
end_example
end_example
How
to
list
imported
modules
How
to
list
imported
modules
Without
resorting
to
pip
that
will
list
all
available
packages
you
Without
resorting
to
pip
that
will
list
all
available
packages
you
may
want
to
know
which
modules
are
loaded
in
a
Python
session
as
well
may
want
to
know
which
modules
are
loaded
in
a
Python
session
as
well
@@ -216,8 +248,63 @@ pip3 install -r requirements.txt # to install the previous list of packages, pos
If
you
want
to
have
several
installed
Python
environments
you
may
If
you
want
to
have
several
installed
Python
environments
you
may
want
to
use
https
docs
pipenv
org
Pipenv
I
doubt
it
allows
to
track
correctly
FORTRAN
C
want
to
use
https
docs
pipenv
org
Pipenv
I
doubt
it
allows
to
track
correctly
FORTRAN
C
dynamic
libraries
that
are
wrapped
Python
though
dynamic
libraries
that
are
wrapped
Python
though
Installing
a
new
package
a
specific
version
The
Jupyter
environment
we
deployed
on
our
servers
for
the
MOOC
is
based
on
the
version
4.5.4
of
Miniconda
Python
3.6
In
this
environment
you
should
simply
use
the
pip
command
remember
on
your
machine
you
may
have
to
use
pip3
If
I
query
the
current
version
of
statsmodels
in
a
shell
command
here
is
what
I
will
get
begin_src
shell
results
output
exports
both
pip
show
statsmodels
end_src
RESULTS
BEGIN_EXAMPLE
Name
statsmodels
Version
0.8.0
Summary
Statistical
computations
models
for
Python
Home
page
http
www
statsmodels
org
Author
Skipper
Seabold
Josef
Perktold
Author
email
pystatsmodels
googlegroups
com
License
BSD
License
Location
opt
conda
lib
python3
.6
site
packages
Requires
scipy
patsy
pandas
END_EXAMPLE
I
can
then
easily
upgrade
statsmodels
begin_src
shell
results
output
exports
both
pip
install
upgrade
statsmodels
end_src
Then
the
new
version
should
then
be
begin_src
shell
results
output
exports
both
pip
show
statsmodels
end_src
RESULTS
BEGIN_EXAMPLE
Name
statsmodels
Version
0.9.0
Summary
Statistical
computations
models
for
Python
Home
page
http
www
statsmodels
org
Author
Skipper
Seabold
Josef
Perktold
Author
email
pystatsmodels
googlegroups
com
License
BSD
License
Location
opt
conda
lib
python3
.6
site
packages
Requires
scipy
patsy
pandas
END_EXAMPLE
It
is
even
possible
to
install
a
specific
possibly
much
older
version
e
g
begin_src
shell
results
output
exports
both
pip
install
statsmodels
0.6.1
end_src
Getting
information
about
R
libraries
Getting
information
about
R
libraries
The
best
way
seems
to
be
to
rely
on
the
devtools
package
Getting
the
list
imported
modules
their
version
The
best
way
seems
to
be
to
rely
on
the
devtools
package
if
this
package
is
not
installed
you
should
install
it
first
running
in
R
the
command
install
packages
"devtools"
begin_src
R
results
output
session
R
exports
both
begin_src
R
results
output
session
R
exports
both
sessionInfo
sessionInfo
@@ -276,7 +363,7 @@ Packages ----------------------------------------------------------------------
Some
actually
advocate
that
https
github
com
ropensci
rrrpkg
writing
a
reproducible
research
compendium
Some
actually
advocate
that
https
github
com
ropensci
rrrpkg
writing
a
reproducible
research
compendium
can
be
done
writing
an
R
package
Those
of
you
willing
to
have
a
can
be
done
writing
an
R
package
Those
of
you
willing
to
have
a
clean
R
dependency
management
should
thus
have
a
look
at
https
rstudio
github
io
packrat
Packrat
clean
R
dependency
management
should
thus
have
a
look
at
https
rstudio
github
io
packrat
Packrat
Getting
the
list
of
installed
packages
their
version
Finally
it
is
good
to
know
that
there
is
a
built
in
R
command
Finally
it
is
good
to
know
that
there
is
a
built
in
R
command
installed
packages
allowing
to
retrieve
list
the
details
of
all
installed
packages
allowing
to
retrieve
list
the
details
of
all
packages
installed
packages
installed
@@ -296,3 +383,63 @@ head(installed.packages())
Matrix
home
alegrand
R
x86_64
pc
linux
gnu
library
3.5
1.2
14
recommended
R
3.2.0
methods
graphics
grid
stats
utils
lattice
nil
expm
MASS
MatrixModels
graph
SparseM
sfsmisc
GPL
2
file
LICENCE
nil
nil
nil
nil
yes
3.5.1
Matrix
home
alegrand
R
x86_64
pc
linux
gnu
library
3.5
1.2
14
recommended
R
3.2.0
methods
graphics
grid
stats
utils
lattice
nil
expm
MASS
MatrixModels
graph
SparseM
sfsmisc
GPL
2
file
LICENCE
nil
nil
nil
nil
yes
3.5.1
StanHeaders
home
alegrand
R
x86_64
pc
linux
gnu
library
3.5
2.17.2
nil
nil
nil
nil
RcppEigen
BH
nil
BSD_3_clause
file
LICENSE
nil
nil
nil
nil
yes
3.5.1
StanHeaders
home
alegrand
R
x86_64
pc
linux
gnu
library
3.5
2.17.2
nil
nil
nil
nil
RcppEigen
BH
nil
BSD_3_clause
file
LICENSE
nil
nil
nil
nil
yes
3.5.1
acepack
home
alegrand
R
x86_64
pc
linux
gnu
library
3.5
1.4.1
nil
nil
nil
nil
testthat
nil
MIT
file
LICENSE
nil
nil
nil
nil
yes
3.5.1
acepack
home
alegrand
R
x86_64
pc
linux
gnu
library
3.5
1.4.1
nil
nil
nil
nil
testthat
nil
MIT
file
LICENSE
nil
nil
nil
nil
yes
3.5.1
Installing
a
new
package
a
specific
version
This
section
is
mostly
a
cut
paste
from
the
https
support
rstudio
com
hc
en
us
articles
219949047
Installing
older
versions
of
packages
recent
post
Ian
Pylvainen
on
this
topic
It
comprises
a
very
clear
explanation
on
how
to
proceed
Installing
a
pre
compiled
version
If
you
're on a Debian or a Ubuntu system, it may be difficult to
access a specific version without breaking your system. So unless you
are moving to the latest version available in your Linux distribution,
*we strongly recommend you to build from source*. In this case, you'
ll
need
to
make
sure
you
have
the
necessary
toolchain
to
build
packages
from
source
e
g
gcc
FORTRAN
etc
On
Windows
this
may
require
you
to
install
https
cran
r
project
org
bin
windows
Rtools
Rtools
If
you
're on Windows or OS X and looking for a package for an *older
version of R* (R 2.1 or below), you can check the [[https://cran-archive.r-project.org/bin/][CRAN binary
archive]]. Once you have the URL, you can install it using a command
similar to the example below:
packageurl <- "https://cran-archive.r-project.org/bin/windows/contrib/2.13/BBmisc_1.0-58.zip"
install.packages(packageurl, repos=NULL, type="binary")
*** Using devtools
The simplest method to install the version you need is to use the
=install_version()= function of the =devtools= package (obviously, you
need to install =devtools= first, which can be done by running in =R= the
command =install.packages("devtools")=). For instance:
require(devtools)
install_version("ggplot2", version = "0.9.1", repos = "http://cran.us.r-project.org")
*** Alternatively, you may want to install an older package from source
If you devtools fails or if you do not want to depend on it, you can
install it from source via =install.packages()= directed to the right
URL. This URL can be obtained by browsing the [[https://cran.r-project.org/src/contrib/Archive][CRAN Package Archive]].
Once you have the URL, you can install it using a command similar to
the example below:
packageurl <- "http://cran.r-project.org/src/contrib/Archive/ggplot2/ggplot2_0.9.1.tar.gz"
install.packages(packageurl, repos=NULL, type="source")
If you know the URL, you can also install from source via the command
line outside of R. For instance (in bash):
wget http://cran.r-project.org/src/contrib/Archive/ggplot2/ggplot2_0.9.1.tar.gz
R CMD INSTALL ggplot2_0.9.1.tar.gz
*** Potential issues
There are a few potential issues that may arise with installing older
versions of packages:
- You may be losing functionality or bug fixes that are only present
in the newer versions of the packages.
- The older package version needed may not be compatible with the
version of R you have installed. In this case, you will either need
to downgrade R to a compatible version or update your R code to work
with a newer version of the package.
