cc9347a2
cc9347a2
Marie-Gabrielle Dondon
Réorganisation
d00cea82
47 additions
44 deletions
+47
-44
jupyter.org
module2/ressources/jupyter.org
+47
-44
cc9347a2
@@ -6,25 +6,14 @@
@@ -6,25 +6,14 @@
#+OPTIONS: num:nil toc:t
#+PROPERTY: header-args :eval never-export
* Additional Jupyter resources or tricks
* 1. Tips and tricks
** Tips and tricks
The following [[https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/][webpage]] lists several Jupyter tricks (in particular, it
illustrates many =Ipython magic= commands) that should improve your
efficiency (note that this blog post is about two years old so some of
the tricks may have been integrated in the default behavior of Jupyter
now).
now).
** Running R and Python in the same notebook
The best solution to this is to install rpy2. On my machine, I have
=rpy2= package allows to use both languages in the same notebook by:
installed the =python3-rpy2= debian package with =apt-get install=. E.g.,
sudo apt-get install python3-rpy2 python3-tzlocal
An other (not really recommended if the first one is available)
alternative consists in going through the python package manager with
pip3 install rpy2
Then you'll be able to use both languages in the same notebook by:
1. Loading =rpy2=:
1. Loading =rpy2=:
%load_ext rpy2.ipython
@@ -44,7 +33,18 @@ Note that this =%%R= notation allows you to use R for the whole cell but
an other possibility is to use =%R= to have a single line of R within a
python cell.
python cell.
*** Windows
* 2. Installing and configuring Jupyter on your machine
** 2.1 Installing =rpy2= on an existing install of Jupyter
pip3 install rpy2
**** /Windows/
Download =rpy2= [[https://www.lfd.uci.edu/~gohlke/pythonlibs/#rpy2][binary file]] by choosing the right operating system.
Open a DOS console and type the following command:
@@ -57,24 +57,7 @@ Install also =tzlocal=:
python -m pip install tzlocal
** Exporting a notebook
** 2.2 New install of Jupyter
Obviously, you can convert to html or pdf using the using the =File > Download as > HTML= (or =PDF=) menu option. This can also be done from
the command line with the following command:
#+begin_src sh :results output :exports both
ipython3 nbconvert --to pdf Untitled.ipynb
If you want to use a specific style, then the =nbconvert= exporter
should be customized. This is discussed and demoed [[http://markus-beuckelmann.de/blog/customizing-nbconvert-pdf.html][here]]. We encourage
you to simply read the [[https://nbconvert.readthedocs.io/en/latest/][doc of nbconvert]].
Instead of going directly through LaTeX and playing too much with the
=nbconvert= exporter, an other option consists in exporting to Markdown
and playing with [[https://pandoc.org/][pandoc]]. Both approaches work, it's rather a matter of
taste.
* Installing Jupyter on your own machine
** Installing Jupyter
Follow these instructions if you wish to have a Jupyter environment on
your own machine similar to the one we set up for this MOOC.
@@ -95,27 +78,46 @@ source activate mooc_rr
jupyter notebook
jupyter notebook
** Side note about Jupyter, JupyterLab, JupyterHub...
Note that Jupyter notebooks are only a small part of the picture and
** 2.3 Additional tips
that Jupyter is now part of a bigger project: [[https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906][JupyterLab]], which allows
you to mix various components (including notebooks) in your
*** Exporting a notebook
browser. In the context of this MOOC, our time frame was too short to
benefit from JupyterLab which was still under active development but
this is probably the best option now if you want to benefit from
cutting-edge Jupyter notebooks.
** Exporting your notebooks with latex
Here is what we had to install on our recent debian machine to make sure
the notebook export via latex works:
sudo apt-get install texlive-xetex wkhtmltopdf
*** Windows
taste.
**** /Windows/
Download and install MiKTeX from the [[https://miktex.org/download][MiKTeX webpage]]
by choosing the right operating system. You will be prompted to install some specific
packages when exporting to pdf.
** Jupyter extensions/plugins
*** Side note about Jupyter, JupyterLab, JupyterHub...
*** Improving notebook readability
Here are a few extensions that can ease your life:
- [[https://stackoverflow.com/questions/33159518/collapse-cell-in-jupyter-notebook][Code folding]] to improve readability when browsing the notebook.
@@ -130,6 +132,7 @@ Here are a few extensions that can ease your life:
jupyter-nbextension enable --py hide_code
jupyter-serverextension enable --py hide_code
*** Interacting with GitLab and GitHub
To ease your experience, we added some pull/push buttons that allow
you to commit and sync with GitLab. This development was specific to
@@ -152,4 +155,4 @@ Last but not least, remember that Jupyter notebooks are only a small
part of the picture and that Jupyter is now part of a bigger project:
[[https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906][JupyterLab]], which allows you to mix various components (including
notebooks) in your browser. A specific [[https://github.com/jupyterlab/jupyterlab-git][JupyterLab git plugin]] has been
developed to offer a nice version control experience.
\ No newline at end of file
