e431e0d6
e431e0d6
Jupyter resources completed
b8db2e1f
2
2 changed files
57 additions
59 deletions
+57
-59
jupyter.html
module2/ressources/jupyter.html
+51
-52
jupyter.org
module2/ressources/jupyter.org
+6
-7
e431e0d6
@@ -4,34 +4,34 @@
<h2>
Table of Contents
</h2>
<div
id=
"text-table-of-contents"
<ul
style=
"margin:0 0;"
<li
style=
"margin-bottom:0;"
><a
href=
"#org
975cdde
Additional Jupyter resources or tricks
</a>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
8ad7af5
</a>
<ul
style=
"margin:0 0;"
<li
style=
"margin-bottom:0;"
><a
href=
"#org2
7d1582
Tips and tricks
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
4f5f0e8
Running R and Python in the same notebook
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
6e2f783
Exporting a notebook
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org2
2d89f4
Tips and tricks
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
0420686
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
468b24f
</a></li>
</ul>
</li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
75409e5
Installing Jupyter on your own machine
</a>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
2c7ad73
</a>
<ul
style=
"margin:0 0;"
<li
style=
"margin-bottom:0;"
><a
href=
"#org
73474e0
Installing jupyter
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
5dcb2d4
Using R
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
919a045
Exporting your notebooks with latex
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
3bdebf
b"
Interacting with gitlab
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
ee218a0
Interesting extensions to improve notebook readability
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
b4b3874
Installing jupyter
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
f5ae3b1
Using R
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
f90bf40
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
77f31c
b"
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
0c2d49c
</a></li>
</ul>
</li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
4ee7491
Installing JupyterHub
<span
class=
"tag"
><span
class=
"Benoit"
Benoit
</span></span></a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
acebcf9
<span
class=
"tag"
><span
class=
"Benoit"
Benoit
</ul>
</div>
</div>
<div
id=
"outline-container-org
975cdde
class=
"outline-2"
<h2
id=
"org
975cdde
</h2>
<div
class=
"outline-text-2"
id=
"text-org
975cdde
<div
id=
8ad7af5
class=
"outline-2"
<h2
id=
"org
8ad7af5
</h2>
<div
class=
"outline-text-2"
id=
"text-org
8ad7af5
</div>
<div
id=
"outline-container-org2
7d1582
class=
"outline-3"
<h3
id=
"org2
7d1582
Tips and tricks
</h3>
<div
class=
"outline-text-3"
id=
"text-org2
7d1582
<div
id=
2d89f4
class=
"outline-3"
<h3
id=
"org2
2d89f4
Tips and tricks
</h3>
<div
class=
"outline-text-3"
id=
"text-org2
2d89f4
<p>
The following
<a
href=
"https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/"
webpage
</a>
lists several Jupyter tricks (in particular, it
illustrates many
<code>
Ipython magic
</code>
commands) that should improve your
@@ -41,9 +41,9 @@ now).
</p>
</div>
</div>
<div
id=
4f5f0e8
class=
"outline-3"
<h3
id=
"org
4f5f0e8
</h3>
<div
class=
"outline-text-3"
id=
"text-org
4f5f0e8
<div
id=
0420686
class=
"outline-3"
<h3
id=
"org
0420686
</h3>
<div
class=
"outline-text-3"
id=
"text-org
0420686
<p>
The best solution to this is to install rpy2. On my machine, I have
installed the
<code>
python3-rpy2
</code>
debian package with
<code>
apt-get install
</code>
. An
@@ -74,20 +74,20 @@ summary(cars)
</pre>
</div>
<p>
Python objects can then even be passed to R as follows (assuming
df
is a pandas dataframe:
<code>
df
</code>
</p>
<div
class=
"org-src-container"
<pre
style=
"padding-left: 30px; background-color: #f6f8fa;"
class=
"src src-python"
%%R -i df
plot(
df)
plot(df)
</pre>
</div></li>
</ol>
</div>
</div>
<div
id=
6e2f783
class=
"outline-3"
<h3
id=
"org
6e2f783
</h3>
<div
class=
"outline-text-3"
id=
"text-org
6e2f783
<div
id=
468b24f
class=
"outline-3"
<h3
id=
"org
468b24f
</h3>
<div
class=
"outline-text-3"
id=
"text-org
468b24f
<p>
Obviously, you can convert to html or pdf using the using the
<code>
File
Download as
HTML
</code>
(or
<code>
PDF
</code>
) menu option. This can also be done from
@@ -114,13 +114,13 @@ taste.
</div>
</div>
</div>
<div
id=
75409e5
class=
"outline-2"
<h2
id=
"org
75409e5
</h2>
<div
class=
"outline-text-2"
id=
"text-org
75409e5
<div
id=
2c7ad73
class=
"outline-2"
<h2
id=
"org
2c7ad73
</h2>
<div
class=
"outline-text-2"
id=
"text-org
2c7ad73
</div>
<div
id=
73474e0
class=
"outline-3"
<h3
id=
"org
73474e0
Installing jupyter
</h3>
<div
class=
"outline-text-3"
id=
"text-org
73474e0
<div
id=
b4b3874
class=
"outline-3"
<h3
id=
"org
b4b3874
Installing jupyter
</h3>
<div
class=
"outline-text-3"
id=
"text-org
b4b3874
<p>
Here is what you should install:
</p>
@@ -151,16 +151,15 @@ The ipython notebook can then be run with the following command:
</div>
</div>
</div>
<div
id=
5dcb2d4
class=
"outline-3"
<h3
id=
"org
5dcb2d4
Using R
</h3>
<div
class=
"outline-text-3"
id=
"text-org
5dcb2d4
<div
id=
f5ae3b1
class=
"outline-3"
<h3
id=
"org
f5ae3b1
Using R
</h3>
<div
class=
"outline-text-3"
id=
"text-org
f5ae3b1
<p>
If you also want to have the R kernel in jupyter, follow
<a
href=
"https://github.com/IRkernel/IRkernel#installation"
these
instructions
</a>
If you want to use the R kernel in jupyter, follow
<a
href=
these instructions
</a>
</p>
<p>
Alternatively, you can install
<code>
rpy2
</code>
(see the
<a
href=
"#org
4f5f0e8
<code>
rpy2
</code>
(see the
<a
href=
"#org
0420686
the same notebook
</a>
section).
</p>
<div
class=
"org-src-container"
@@ -169,12 +168,12 @@ the same notebook</a> section).
</div>
</div>
</div>
<div
id=
919a045
class=
"outline-3"
<h3
id=
"org
919a045
</h3>
<div
class=
"outline-text-3"
id=
"text-org
919a045
<div
id=
f90bf40
class=
"outline-3"
<h3
id=
"org
f90bf40
</h3>
<div
class=
"outline-text-3"
id=
"text-org
f90bf40
<p>
Here is what I had to install
to make sure the notebook export via
latex works:
on my recent debian machine to make sure
latex works:
</p>
<div
class=
"org-src-container"
<pre
style=
class=
"src src-shell"
sudo apt-get install wkhtmltopdf
@@ -183,9 +182,9 @@ sudo apt-get install texlive-xetex
</div>
</div>
</div>
<div
id=
3bdebf
b"
class=
"outline-3"
<h3
id=
"org
3bdebf
b"
</h3>
<div
class=
"outline-text-3"
id=
"text-org
3bdebf
b"
<div
id=
77f31c
b"
class=
"outline-3"
<h3
id=
"org
77f31c
b"
</h3>
<div
class=
"outline-text-3"
id=
"text-org
77f31c
b"
<p>
Here is our
<a
href=
"https://github.com/brospars/nb-git"
jupyter extension that allows to git push/pull from the
notebooks
</a>
@@ -197,9 +196,9 @@ jupyter nbextension enable nb-git
</div>
</div>
</div>
<div
id=
ee218a0
class=
"outline-3"
<h3
id=
"org
ee218a0
</h3>
<div
class=
"outline-text-3"
id=
"text-org
ee218a0
<div
id=
0c2d49c
class=
"outline-3"
<h3
id=
"org
0c2d49c
</h3>
<div
class=
"outline-text-3"
id=
"text-org
0c2d49c
<p>
Here are two interesting extensions that can improve readability:
</p>
@@ -226,9 +225,9 @@ jupyter-serverextension enable --py hide_code
</div>
</div>
</div>
<div
id=
4ee7491
class=
"outline-2"
<h2
id=
"org
4ee7491
<span
class=
"tag"
><span
class=
"Benoit"
Benoit
</span></span></h2>
<div
class=
"outline-text-2"
id=
"text-org
4ee7491
<div
id=
acebcf9
class=
"outline-2"
<h2
id=
"org
acebcf9
<span
class=
"tag"
><span
class=
"Benoit"
Benoit
</span></span></h2>
<div
class=
"outline-text-2"
id=
"text-org
acebcf9
<blockquote>
<p>
Benoit may give a few hints on this.
e431e0d6
@@ -31,11 +31,11 @@ Then you'll be able to use both languages in the same notebook by:
%R
df
=df=
%%R -i df
plot(
df)
plot(df)
** Exporting a notebook
Obviously, you can convert to html or pdf using the using the =File >
@@ -74,8 +74,7 @@ The ipython notebook can then be run with the following command:
jupyter-notebook
** Using R
If you also want to have the R kernel in jupyter, follow [[https://github.com/IRkernel/IRkernel#installation][these
instructions]].
If you want to use the R kernel in jupyter, follow [[https://github.com/IRkernel/IRkernel#installation][these instructions]].
Alternatively, you can install =rpy2= (see the [[*Running R and Python in the same notebook][Running R and Python in
the same notebook]] section).
@@ -83,8 +82,8 @@ the same notebook]] section).
sudo apt-get python3-rpy2
** Exporting your notebooks with latex
latex works:
latex works:
