Commits (12)
test # Partie 1
\ No newline at end of file ## Sous-partie 1 : texte
Une phrase sans rien
*Une phrase en italique*
**Une phrase en gras**
Un lien vers [fun-mooc.fr](https://www.fun-mooc.fr/)
Une ligne de `code`
## Sous-partie 2 : listes
**Liste à puce**
- item
- sous-item
- sous-item
- item
- item
**Liste numérotée**
1. item
2. item
3. item
## Sous-partie 3 : code
# Extrait de code
This diff is collapsed.
"cells": [], "cells": [
"execution_count": 1,
"data = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]"
"execution_count": 4,
"14.113000000000001\n"
"import numpy as np\n",
"moyenne = np.mean(data)\n",
"print(moyenne)"
"execution_count": 12,
"4.334094455301447\n"
"ecartType = np.std(data, ddof=1)\n",
"print(ecartType)"
"execution_count": 8,
"2.8\n"
"mini = np.min(data)\n",
"print(mini)"
"execution_count": 10,
"14.5\n"
"mediane = np.median(data)\n",
"print(mediane)"
"execution_count": 11,
"23.4\n"
"maxi = np.max(data)\n",
"print(maxi)"
"metadata": { "metadata": {
...@@ -16,10 +117,9 @@ ...@@ -16,10 +117,9 @@
"nbformat": 4, "nbformat": 4,
"execution_count": null,
"hideCode": true,
"hidePrompt": true
"source": []
"hide_code_all_hidden": true,
...@@ -16,10 +28,9 @@ ...@@ -16,10 +28,9 @@
"","Year","Wheat","Wages"
"1",1565,41,5
"2",1570,45,5.05
"3",1575,42,5.08
"4",1580,49,5.12
"5",1585,41.5,5.15
"6",1590,47,5.25
"7",1595,64,5.54
"8",1600,27,5.61
"9",1605,33,5.69
"10",1610,32,5.78
"11",1615,33,5.94
"12",1620,35,6.01
"13",1625,33,6.12
"14",1630,45,6.22
"15",1635,33,6.3
"16",1640,39,6.37
"17",1645,53,6.45
"18",1650,42,6.5
"19",1655,40.5,6.6
"20",1660,46.5,6.75
"21",1665,32,6.8
"22",1670,37,6.9
"23",1675,43,7
"24",1680,35,7.3
"25",1685,27,7.6
"26",1690,40,8
"27",1695,50,8.5
"28",1700,30,9
"29",1705,32,10
"30",1710,44,11
"31",1715,33,11.75
"32",1720,29,12.5
"33",1725,39,13
"34",1730,26,13.3
"35",1735,32,13.6
"36",1740,27,14
"37",1745,27.5,14.5
"38",1750,31,15
"39",1755,35.5,15.7
"40",1760,31,16.5
"41",1765,43,17.6
"42",1770,47,18.5
"43",1775,44,19.5
"44",1780,46,21
"45",1785,42,23
"46",1790,47.5,25.5
"47",1795,76,27.5
"48",1800,79,28.5
"49",1805,81,29.5
"50",1810,99,30
"51",1815,78,NA
"52",1820,54,NA
"53",1821,54,NA
