Commit 0be13543 authored by Jamal KHAN's avatar Jamal KHAN
Exercise 3 Part 2
parent 09ae2950
This diff is collapsed.
#+TITLE: Your title #+TITLE: Analysis of the incidence of chickenpox
#+AUTHOR: Your name #+AUTHOR: Jamal KHAN
#+DATE: Today's date #+DATE: 2020-09-16
#+LANGUAGE: en #+LANGUAGE: en
# #+PROPERTY: header-args :eval never-export # #+PROPERTY: header-args :session *python* :exports both
#+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/htmlize.css"/> #+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/htmlize.css"/>
#+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/readtheorg.css"/> #+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/readtheorg.css"/>
...@@ -11,84 +11,106 @@ ...@@ -11,84 +11,106 @@
#+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/lib/js/jquery.stickytableheaders.js"></script> #+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/lib/js/jquery.stickytableheaders.js"></script>
#+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/readtheorg/js/readtheorg.js"></script> #+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/readtheorg/js/readtheorg.js"></script>
* Some explanations * Data download
#+NAME: data-url
https://www.sentiweb.fr/datasets/incidence-PAY-7.csv
This is an org-mode document with code examples in R. Once opened in #+BEGIN_SRC python :session *python* :results output :var data_url=data-url
Emacs, this document can easily be exported to HTML, PDF, and Office data_file = 'chickenpox_incidence.csv'
https://orgmode.org/guide/.
When you type the shortcut =C-c C-e h o=, this document will be import datetime
exported as HTML. All the code in it will be re-executed, and the from urllib.request import urlretrieve
results will be retrieved and included into the exported document. If import os
Like we showed in the video, Python code is included as follows (and if not os.path.exists(data_file):
is exxecuted by typing ~C-c C-c~): urlretrieve(data_url, data_file)
#+begin_src python :results output :exports both print(f'Data is retrieved at {datetime.datetime.utcnow()} UTC')
print("Hello world!") #+END_SRC
#+RESULTS: #+RESULTS:
: Hello world! :
: Data is retrieved at 2020-09-16 22:07:31.650075 UTC
And now the same but in an Python session. With a session, Python's Now we extract the interesting part of the data. from the format of the file The week is column 0, incidence is column 4. We took Monday as the first day of the week so '%W' code in python/pandas.
C-c~.
#+begin_src python :results output :session :exports both #+BEGIN_SRC python :session *python* :results outputs :export both
import numpy import pandas as pd
x=numpy.linspace(-15,15) data = pd.read_csv(data_file, skiprows=2, header=None)
print(x) data = data.loc[:, [0, 2]].rename(columns={0:'Datetime', 2:'Incidence'})
#+end_src data.Datetime = pd.to_datetime(data.Datetime*10+1, format='%Y%W%w')
data = data.sort_values(by='Datetime')
data = data.set_index('Datetime')
data.describe()
#+END_SRC
#+begin_example : Incidence
[-15. -14.3877551 -13.7755102 -13.16326531 -12.55102041 : count 1554.000000
-11.93877551 -11.32653061 -10.71428571 -10.10204082 -9.48979592 : mean 12647.119691
-8.87755102 -8.26530612 -7.65306122 -7.04081633 -6.42857143 : std 6657.542827
-5.81632653 -5.20408163 -4.59183673 -3.97959184 -3.36734694 : min 161.000000
-2.75510204 -2.14285714 -1.53061224 -0.91836735 -0.30612245 : 25% 7326.750000
0.30612245 0.91836735 1.53061224 2.14285714 2.75510204 : 50% 12627.000000
3.36734694 3.97959184 4.59183673 5.20408163 5.81632653 : 75% 17155.000000
6.42857143 7.04081633 7.65306122 8.26530612 8.87755102 : max 36298.000000
12.55102041 13.16326531 13.7755102 14.3877551 15. ] Now check for missing data. Pandas automatically handles the missing data, so we will check for na value in the dataframe.
#+end_example #+BEGIN_SRC python :session *python* :results outputs :export both
data.is_na()
Finally, an example for graphical output: #+END_SRC
Looks ok. Now time to plot a timeseries of the chicken pox incidence.
#+BEGIN_SRC python :session *python* :results output file :var ts_plot="chickepox_timeseries.png" :export file
fig, ax = plt.subplots(figsize=(6, 3))
data.plot(ax=ax)
plt.savefig(ts_plot)
print(ts_plot)
#+END_SRC
[[file:chickepox_timeseries.png]]
Additionally, the data starts at the beginning of 1991 and ends at the beginning of the 2020. The monthly evolution is not clear from the long timeseries. Plotting a shorter version.
#+BEGIN_SRC python :session *python* :results output file :var ts_plot="chickepox_timeseries_short.png" :export file
data['1991-01-01':'1994-01-01'].plot(ax=ax)
print(ts_plot)
#+END_SRC
[[file:chickepox_timeseries_short.png]]
It appears that the dip is in november. So I need to group the yearly data starting from November.
#+BEGIN_SRC python :session *python* :results output file :var ts_plot="chickepox_timeseries_yearly.png" :export both
data_yearly = data.groupby(data.index.shift(8, freq='m').year).sum()
data_yearly = data_yearly.iloc[1:-2]
import matplotlib.pyplot as plt import matplotlib.pyplot as plt
data_yearly.plot(ax=ax)
print(data_yearly.sort_values(by='Incidence'))
print(ts_plot)
#+END_SRC
plt.figure(figsize=(10,5)) #+RESULTS:
plt.plot(x,numpy.cos(x)/x)
plt.tight_layout()
plt.savefig(matplot_lib_filename) Plot of the aggregated values.
print(matplot_lib_filename) #+BEGIN_SRC python :session *python* :results output file :var ts_plot="chickepox_timeseries_yearly.png" :export both
#+end_src import matplotlib.pyplot as plt
print(ts_plot)
#+END_SRC
[[file:./cosxsx.png]] [[file:chickepox_timeseries_yearly.png]]
transparent and reproducible.
understandable on GitLab.
followed by ~Tab~.
