My computer tells me that $\pi$ is /approximatively/
@@ -35,7 +35,7 @@ theta = pi/2*runif(N)
: [1] 3.14327
: [1] 3.14327
* Using a surface fraction argument
A method that is easier to understand and does not make use of the $\sin$ function is based on the fact that if $X\simU(0,1)$ and $Y\simU(0,1)$, then $P[X^2+Y^2\leq 1] = \pi/4$ (see [[https://en.wikipedia.org/wiki/Monte_Carlo_method]["Monte Carlo method" on Wikipedia]]). The following code uses this approach:
A method that is easier to understand and does not make use of the $\sin$ function is based on the fact that if $X\sim U(0,1)$ and $Y\sim U(0,1)$, then $P[X^2+Y^2\leq 1] = \pi/4$ (see [[https://en.wikipedia.org/wiki/Monte_Carlo_method]["Monte Carlo method" on Wikipedia]]). The following code uses this approach:
#+begin_src R :results output graphics :file figure_pi_mc1.png :exports both :width 600 :height 400 :session *R*
A method that is easier to understand and does not make use of the $\sin$ function is based on the fact that if $X\simU(0,1)$ and $Y\simU(0,1)$, then $P[X^2+Y^2 \le1]=\pi/4$ (see [[https://en.wikipedia.org/wiki/Monte_Carlo_method]["Monte Carlo method" on Wikipedia]]). The following code uses this approach:
#+begin_src python :results output :session *python* :var matplot_lib_filename="figure_pi_mc2.png" :exports both
np.random.seed(seed=42)
N = 1000
C-c~.
