Commit 25c67878 authored by Anthony Scemama's avatar Anthony Scemama
Fin Module 2
parent ffd9ed50
# -*- coding: utf-8 -*-
# -*- mode: org -*-
#+TITLE: Reproducible Research Notes
#+AUTHOR: Anthony Scemama
#+CATEGORY: Notes
#+TAGS: [ TOOLS : ORGMODE(o) EMACS(e) SPACEMACS(s) R(r) PYTHON(p) ]
#+STARTUP: content
* Emacs installation :EMACS:
** Install Emacs via miniconda:
#+begin_src bash
conda update -n base -c defaults conda
conda install -c conda-forge emacs r-parsedate
** Install Spacemacs :SPACEMACS:
[[https://www.spacemacs.org/][Spacemacs website]]
#+begin_src bash
git clone https://github.com/syl20bnr/spacemacs ~/.emacs.d
and activate the *org* layer.
** Install
* Spacemacs memo :SPACEMACS:
- Open ~/.spacemacs file : SPC f e d
* Org-mode memo :ORGMODE:
[[https://orgmode.org/manual][Org-mode Manual]]
** General
- C-c / : Sparse tree
- Drawers contain info we don't normally want to see
:DRAWERNAME:
Hidden info
:END:
** Tables
- Move table columns with M-LEFT
- Insert column with M-S-RIGHT
- Kill column with M-S-LEFT
- org-table-export : possible latex export
- Formulas
| x | y |
| 1 | 2 |
| 2 | 4 |
#+TBLFM: $2=$1*1
#+TBLFM: $2=$1*2
| Task 1 | Task 2 | Total |
| 2:12 | 1:00 | 03:12:00 |
| 2:15 | 1:47 | 04:02 |
| 3:02:20 | -2:07:00 | 0.92 |
#+TBLFM: @2$3=$1+$2;T::@3$3=$1+$2;U::@4$3=$1+$2;t
** Plots
#+PLOT: title:"Citas" ind:1 deps:(3) type:2d with:histograms set:"yrange [0:]"
| Sede | Max cites | H-index |
| Chile | 257.72 | 21.39 |
| Leeds | 165.77 | 19.68 |
| Sao Paolo | 71.00 | 11.50 |
| Stockholm | 134.19 | 14.33 |
| Morelia | 257.56 | 17.67 |
M-x org-plot/gnuplot
* Resources
** Links
* [[http://kitchingroup.cheme.cmu.edu/blog/][Blog]]
* [[https://www.youtube.com/watch?v=IsSMs-4GlT8&list=FLQp2VLAOlvq142YN3JO3y8w&app=desktop][Video]]
* Models for LaTex: [[https://github.com/schnorr/ieeeorg][IEEE]], [[https://github.com/schnorr/wileyorg][Wiley]], [[https://github.com/schnorr/acmorg][ACM]], [[https://github.com/schnorr/llncsorg][LNCS]]
** Examples
* [[https://github.com/norvig/pytudes/blob/master/ipynb/Economics.ipynb][Jupyter]], [[https://github.com/jupyter/jupyter/wiki/A-gallery-of-interesting-Jupyter-Notebooks][Gallery]], [[https://nbviewer.jupyter.org/url/www.inp.nsk.su/~grozin/python/sympy.ipynb][SymPy tutorial]]
* Git configuration
login: 27c0641acb9e5727b9680a9b3481db8e
password: ce21b85a28
* Nice HTML rendering
#+begin_src html
#+TITLE: Votre titre
#+AUTHOR: Votre nom
#+DATE: La date du jour
#+TITLE: Savoir faire un calcul simple soi-même
#+DATE: Wed Apr 1 21:55:23 CEST 2020
......@@ -11,83 +11,24 @@
* Quelques explications
document.
print("Hello world!")
: Hello world!
~C-c C-c~).
import numpy
x=numpy.linspace(-15,15)
print(x)
raw_data = [ 14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0 ]
data = np.array(raw_data)
mu = np.mean(data)
sigma = np.std(data,ddof=1)
print ("mu = ", mu)
print ("min = ", np.min(data))
print ("max = ", np.max(data))
print ("median = ", np.median(data))
print ("sigma = ", sigma)
plt.figure(figsize=(10,5))
plt.plot(x,numpy.cos(x)/x)
plt.tight_layout()
[[file:./cosxsx.png]]
compréhensible sur GitLab.
: mu = 14.113000000000001
: min = 2.8
: max = 23.4
: median = 14.5
: sigma = 4.334094455301447
#+AUTHOR: Votre nom
......@@ -11,83 +11,50 @@
document.
: Hello world!
~C-c C-c~).
import numpy
print(x)
mu = np.mean(data)
print ("mu = ", mu)
: min = 2.8
: max = 23.4
: median = 14.5
#+begin_src python :results output file :session :var matplot_lib_filename="./seq.png" :exports both
plt.tight_layout()
plt.plot(data)
[[file:./seq.png]]
* Histogram
#+begin_src python :results output file :session :var matplot_lib_filename="./hist.png" :exports both
plt.hist(data)
[[file:./hist.png]]
......@@ -42,30 +42,30 @@ data
17 7/29/85 6 81 200 0
Le jeu de données nous indique la date de l'essai, le nombre de joints
......@@ -73,6 +73,7 @@ toriques mesurés (il y en a 6 sur le lançeur principal), la
température (en Fahrenheit) et la pression (en psi), et enfin le
nombre de dysfonctionnements relevés.
* Inspection graphique des données
Les vols où aucun incident n'est relevé n'apportant aucune information
sur l'influence de la température ou de la pression sur les
......@@ -80,19 +81,37 @@ dysfonctionnements, nous nous concentrons sur les expériences où au
moins un joint a été défectueux.
data = data[data.Malfunction>-1]
Très bien, nous avons une variabilité de température importante mais
la pression est quasiment toujours égale à 200, ce qui devrait
......@@ -142,24 +161,6 @@ logmodel.summary()
L'estimateur le plus probable du paramètre de température est 0.0014
et l'erreur standard de cet estimateur est de 0.122, autrement dit on
......@@ -185,7 +186,11 @@ print(matplot_lib_filename)
[[file:Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "/tmp/babel-xmrEcl/python-KfQu22", line 5, in <module>
data_pred['Frequency'] = logmodel.predict(data_pred[['Intercept','Temperature']])
NameError: name 'logmodel' is not defined]]
Comme on pouvait s'attendre au vu des données initiales, la
température n'a pas d'impact notable sur la probabilité d'échec des
module2/exo5/freq_temp_python.png
12.3 KB | W: | H:
13 KB | W: | H:
  • 2-up
  • Swipe
  • Onion skin
