2992438755465b7fe3afd7856bde0599
2e2ccaad
2e2ccaad
Adam Taheraly
reponse devoir
b0db00a7
3
Expand all
3 changed files
753 additions
207 deletions
+753
-207
exercice_R_fr.html
module3/exo3/exercice_R_fr.html
+267
-101
exercice_R_fr.html~
module3/exo3/exercice_R_fr.html~
+427
exercice_R_fr.org
module3/exo3/exercice_R_fr.org
+59
-106
2e2ccaad
This diff is collapsed.
2e2ccaad
2e2ccaad
@@ -17,6 +17,7 @@ library(devtools) # Obtention des informations sur la session R
library(dplyr) # Manipulation des données
library(tidyverse) # Collection de packages pour la data science
library(knitr) # Génération de rapports dynamique
library(forcats)
library(broman) # Function intéressante pour R
library(RColorBrewer) # Couleur des figures
library(ggplot2) # Création des figures
@@ -25,41 +26,6 @@ library(xtable) # Jolie tableau
library(kableExtra) # Création de tableau
Le chargement a nécessité le package : usethis
Attachement du package : ‘dplyr’
The following objects are masked from ‘package:stats’:
filter, lag
The following objects are masked from ‘package:base’:
intersect, setdiff, setequal, union
── [1mAttaching packages[22m ─────────────────────────────────────── tidyverse 1.3.0 ──
[32m✔[39m [34mggplot2[39m 3.3.0 [32m✔[39m [34mpurrr [39m 0.3.3
[32m✔[39m [34mtibble [39m 3.0.0 [32m✔[39m [34mstringr[39m 1.4.0
[32m✔[39m [34mtidyr [39m 1.0.2 [32m✔[39m [34mforcats[39m 0.5.0
[32m✔[39m [34mreadr [39m 1.3.1
── [1mConflicts[22m ────────────────────────────────────────── tidyverse_conflicts() ──
[31m✖[39m [34mdplyr[39m::[32mfilter()[39m masks [34mstats[39m::filter()
[31m✖[39m [34mdplyr[39m::[32mlag()[39m masks [34mstats[39m::lag()
Attachement du package : ‘broman’
The following object is masked from ‘package:purrr’:
done
Attachement du package : ‘kableExtra’
The following object is masked from ‘package:dplyr’:
group_rows
* Mise en place des données :noexport:
** Chargement
@@ -67,8 +33,6 @@ The following object is masked from ‘package:dplyr’:
simpson_data <- read.csv("Subject6_smoking.csv")
Les données sont sous la forme :
| Libellé | Description |
@@ -86,35 +50,12 @@ head(simpson_data)
tail(simpson_data)
Smoker Status Age
1 Yes Alive 21.0
2 Yes Alive 19.3
3 No Dead 57.5
4 No Alive 47.1
5 Yes Alive 81.4
6 No Alive 36.8
Smoker Status Age
1309 No Alive 42.1
1310 Yes Alive 35.9
1311 No Alive 22.3
1312 Yes Dead 62.1
1313 No Dead 88.6
1314 No Alive 39.1
Vérification de la présence de données manquante.
na_records <- apply(simpson_data, 1, function(x) any(is.na(x)))
simpson_data[na_records,]
: [1] Smoker Status Age
: <0 lignes> (ou 'row.names' de longueur nulle)
Vérification de la classe des données et du nombre de data.
@@ -124,14 +65,6 @@ class(simpson_data$Status)
class(simpson_data$Age)
: [1] 1314
: [1] "factor"
: [1] "factor"
: [1] "numeric"
* Analyse des données
** Question 1
@@ -142,18 +75,10 @@ summarise(Number = n(), Alive = sum(Status == "Alive"), Dead = sum(Status == "De
dead_or_alive$mortality <- round(dead_or_alive$mortality, 2)
#+begin_src R :results table :colnames yes :session *R* :exports results
xtable(dead_or_alive)
| Smoker | Number | Alive | Dead | mortality |
| No | 732 | 502 | 230 | 31.42 |
| Yes | 582 | 443 | 139 | 23.88 |
#+begin_src R :results output graphics :file (org-babel-temp-file "figure" ".png") :exports both :width 600 :height 400 :session *R*
mortality <- ggplot(dead_or_alive, aes(x = Smoker, y = mortality, fill = Smoker)) + geom_bar(stat = "identity") +
@@ -161,13 +86,9 @@ mortality <- ggplot(dead_or_alive, aes(x = Smoker, y = mortality, fill = Smoker)
mortality
[[file:/tmp/babel-pNwaHh/figureO5jUUE.png]]
Le résultat est surprenant car on observe un plus fort taux de
mortalité chez les non-fumeur que chez les fumeur.
** Question 2
On recrée un data-frame pour ne pas interagir avec les résultats
précédent.
@@ -176,17 +97,13 @@ simpson_data_q2 <- simpson_data
simpson_data_q2$Age <- as.numeric(simpson_data_q2$Age)
On regroupe les ages en catégories
simpson_data_q2$Age <- cut(simpson_data_q2$Age, c(18, 34, 54, 64, 200), include.lowest = TRUE, labels = c("18-34", "35-54", "55-64", "plus de 65"))
table(simpson_data_q2$Age)
: 18-34 35-54 55-64 plus de 65
: 400 436 236 242
dead_or_alive2 <- simpson_data_q2%>%
@@ -198,23 +115,9 @@ mutate(mortality = (Dead/sum(Number))*100)
xtable(dead_or_alive2)
| Smoker | Age | Number | Alive | Dead | mortality |
| No | 18-34 | 219 | 213 | 6 | 0.819672131147541 |
| No | 35-54 | 199 | 180 | 19 | 2.59562841530055 |
| No | 55-64 | 121 | 81 | 40 | 5.46448087431694 |
| No | plus de 65 | 193 | 28 | 165 | 22.5409836065574 |
| Yes | 18-34 | 181 | 176 | 5 | 0.859106529209622 |
| Yes | 35-54 | 237 | 196 | 41 | 7.0446735395189 |
| Yes | 55-64 | 115 | 64 | 51 | 8.76288659793814 |
| Yes | plus de 65 | 49 | 7 | 42 | 7.21649484536082 |
mortality2 <- ggplot(dead_or_alive2, aes(x = Smoker, y = mortality, fill = Age))+ geom_bar(stat = "identity", position = position_dodge()) +
@@ -222,15 +125,65 @@ mortality2 <- ggplot(dead_or_alive2, aes(x = Smoker, y = mortality, fill = Age))
mortality2
[[file:/tmp/babel-fRQzWg/figureR2aE0F.png]]
On observe une diminution du taux de mortalité chez les moins de 65
ans parmis les non fumeur par rapport au fumeur. Cependant, chez les
plus de 65 ans, la tendence s'inverse avec un plus grande mortalité
chez les fumeurs par rappor au non fumeur (3 fois plus).
Cela peut s'expliquer par le fait que le corps des fumeurs se soit
habituer aux toxines alors que les non-fumeur subissant le tabagisme
passif et ayant atteint un age où ils sont plus à risque soit plus à
même de décédé à cause des toxines du tabac.
L'inversion de ces proportions peut s'expliquer par un enrichissement
en personnes agées chez les non fumeurs.
** Question 3
précédent.
simpson_data_q3 <- simpson_data
simpson_data_q3$Death <- factor(simpson_data_q3$Status)
simpson_data_q3$Death <- fct_recode(simpson_data_q3$Death, "1"="Alive", "0"="Dead")
simpson_data_q3$Death <- as.numeric(as.character(simpson_data_q3$Death))
simpson_data_q3$Age <- as.numeric(as.character(simpson_data_q3$Age))
head(simpson_data_q3)
reg_log_total <- ggplot(simpson_data_q3, aes(x=Age,y=Death)) + geom_point(alpha=.3,size=3) +
theme_bw() +
geom_smooth(method = "glm",
method.args = list(family = "binomial"),fullrange = TRUE)
reg_log_fumeur <- ggplot(simpson_data_q3[simpson_data_q3$Smoker == "Yes",], aes(x=Age,y=Death)) + geom_point(alpha=.3,size=3) +
theme_bw() +
reg_log_non_fumeur <- ggplot(simpson_data_q3[simpson_data_q3$Smoker == "No",], aes(x=Age,y=Death)) + geom_point(alpha=.3,size=3) +
theme_bw() +
reg_log_total
reg_log_fumeur
reg_log_non_fumeur
Passer 60 ans, bien que les courbes soient semblable, on voit que l'intervalle de confiance chez les fumeurs
est plus grands que chez les non fumeur. Cela s'explique bien par une
plus faible population de personne agée chez les fumeurs.
