Commit 400e6aeb authored by Adam Taheraly's avatar Adam Taheraly
réponse
parent 0196a258
...@@ -16,5 +16,5 @@ knitr::opts_chunk$set(echo = TRUE) ...@@ -16,5 +16,5 @@ knitr::opts_chunk$set(echo = TRUE)
df = data.frame(x = c(14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0)) df = data.frame(x = c(14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0))
library(prettyR) library(prettyR)
describe(df, num.desc = c("sd", "min", "median", "max")) describe(df, num.desc = c("sd", "min", "mean", "median", "max"))
...@@ -10,24 +10,16 @@ output: html_document ...@@ -10,24 +10,16 @@ output: html_document
## Quelques explications # Réaliser un affichage graphique
Ceci est un document R markdown que vous pouvez aisément exporter au format HTML, PDF, et MS Word. Pour plus de détails sur R Markdown consultez <http://rmarkdown.rstudio.com>. ```{r}
Lorsque vous cliquerez sur le bouton **Knit** ce document sera compilé afin de ré-exécuter le code R et d'inclure les résultats dans un document final. Comme nous vous l'avons montré dans la vidéo, on inclue du code R de la façon suivante: df$y <- seq(1, 100, 1)
```{r cars} library(ggplot2)
summary(cars) ggplot(df, aes(x = y , y = x)) + geom_line(color = "blue")
```{r pressure, echo=FALSE} ggplot(df, aes(x = x)) + geom_histogram(bins = 10, color="black", fill="blue")
plot(pressure)
...@@ -44,7 +44,7 @@ Voici l'explication des colonnes donnée sur le [sur le site d'origine](https:// ...@@ -44,7 +44,7 @@ Voici l'explication des colonnes donnée sur le [sur le site d'origine](https://
La première ligne du fichier CSV est un commentaire, que nous ignorons en précisant `skip=1`. La première ligne du fichier CSV est un commentaire, que nous ignorons en précisant `skip=1`.
### Téléchargement ### Téléchargement
```{r} ```{r}
data = read.csv(data_url, skip=1) data = read.csv("incidence-PAY-3.csv", skip=1)
Regardons ce que nous avons obtenu: Regardons ce que nous avons obtenu:
