exercice de calcul
parent 6f8e34db
"cells": [], "cells": [
"# Exercice de Calcul"
"execution_count": 2,
"import numpy\n",
"x = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]"
"## Calcul de la moyenne"
"execution_count": 3,
"14.113000000000001\n"
"moy = numpy.average(x)\n",
"print(moy)"
"## Calcul de l'écart-type"
"execution_count": 4,
"4.334094455301447\n"
"e_t = numpy.std(x, 0, ddof = 1)\n",
"print(e_t)"
"## Calcul du minimum"
"execution_count": 5,
"2.8\n"
"min_x = numpy.min(x)\n",
"print(min_x)"
"## Calcul de la mediane"
"execution_count": 6,
"14.5\n"
"med_x = numpy.median(x)\n",
"print(med_x)"
"## Calcul du maximum"
"execution_count": 7,
"23.4\n"
"max_x = numpy.max(x)\n",
"print(max_x)"
"metadata": { "metadata": {
...@@ -16,10 +159,9 @@ ...@@ -16,10 +159,9 @@
"nbformat": 4, "nbformat": 4,
