solution2
parent 04125f1e
...@@ -4,14 +4,14 @@ ...@@ -4,14 +4,14 @@
"cell_type": "markdown", "cell_type": "markdown",
"source": [ "source": [
"# 1 On the computation of $\\pi$" "# On the computation of $\\pi$"
"## 1.1 Asking the maths library" "## Asking the maths library"
...@@ -43,19 +43,19 @@ ...@@ -43,19 +43,19 @@
"## 1.2 Buffalo's needle" "## Buffalo's needle"
"Applying the method of [Buffon’s needle](https://en.wikipedia.org/wiki/Buffon%27s_needle_problem), we get the **approximation**" "Applying the method of [Buffon’s needle](https://en.wikipedia.org/wiki/Buffon%27s_needle_problem), we get the __approximation__"
"execution_count": 2, "execution_count": 5,
"outputs": [ "outputs": [
...@@ -64,13 +64,13 @@ ...@@ -64,13 +64,13 @@
"3.128911138923655" "3.128911138923655"
"output_type": "execute_result" "output_type": "execute_result"
"In [2]: import numpy as np\n", "import numpy as np\n",
"np.random.seed(seed=42)\n", "np.random.seed(seed=42)\n",
"N = 10000\n", "N = 10000\n",
"x = np.random.uniform(size=N, low=0, high=1)\n", "x = np.random.uniform(size=N, low=0, high=1)\n",
...@@ -89,12 +89,12 @@ ...@@ -89,12 +89,12 @@
"A method that is easier to understand and does not make use of the sin function is based on the fact that if $X$ $\\sim$ $U$(0, 1) and $Y$ $\\sim$ $U$(0, 1), then $P$[$X^2$ + $Y^2$ $\\le$ 1] = $\\pi$/4 (see [\"Monte Carlo method\" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:" "A method that is easier to understand and does not make use of the sin function is based on the fact that if $X\\sim U(0, 1)$ and $Y\\sim U(0, 1)$, then $P[X^2+Y^2\\leq 1] = \\pi/4$ (see [\"Monte Carlo method\" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:"
"execution_count": 3, "execution_count": 6,
...@@ -113,29 +113,31 @@ ...@@ -113,29 +113,31 @@
"%matplotlib inline\n", "%matplotlib inline\n",
"import matplotlib.pyplot as plt\n", "import matplotlib.pyplot as plt\n",
"N = 1000\n", "N = 1000\n",
"y = np.random.uniform(size=N, low=0, high=1)\n", "y = np.random.uniform(size=N, low=0, high=1)\n",
"1\n", "\n",
"accept = (x*x+y*y) <= 1\n", "accept = (x*x+y*y) <= 1\n",
"reject = np.logical_not(accept)\n", "reject = np.logical_not(accept)\n",
"fig, ax = plt.subplots(1)\n", "fig, ax = plt.subplots(1)\n",
"ax.scatter(x[accept], y[accept], c='b', alpha=0.2, edgecolor=None)\n", "ax.scatter(x[accept], y[accept], c='b', alpha=0.2, edgecolor=None)\n",
"ax.scatter(x[reject], y[reject], c='r', alpha=0.2, edgecolor=None)\n", "ax.scatter(x[reject], y[reject], c='r', alpha=0.2, edgecolor=None)\n",
"ax.set_aspect('equal')\n" "ax.set_aspect('equal')"
"It is then straightforward to obtain a (not really good) approximation to $\\pi$ by counting how many times, on average, $X^2$ + $Y^2$ is smaller than 1:" "It is then straightforward to obtain a (not really good) approximation to $\\pi$ by counting how many times, on average, $X^2 + Y^2$ is smaller than 1:"
"execution_count": 4, "execution_count": 7,
...@@ -144,7 +146,7 @@ ...@@ -144,7 +146,7 @@
"3.112" "3.112"
