Asking the maths library
My computer tells me that π is approximatively
{r}
pi
Buffon's needle
```{r pressure, echo=FALSE}
Applying the method of Buffon's needle, we get the approximation
plot(pressure)
{r}
set.seed(42)
N = 100000
x = runif(N)
theta = pi/2*runif(N)
2/(mean(x+sin(theta)>1))
Using a surface fraction argument
A method that is easier to understand and does not make use of the sin function is based on the fact that if X∼U(0,1) and Y∼U(0,1), then P[X2+Y2≤1]=π/4 (see "Monte Carlo method" on Wikipedia). The following code uses this approach:
