Commit 87c91ec4 authored by amarell's avatar amarell
Additional minor corrections to module2/exo1/toy_document_en.Rmd
parent b4d52d43
...@@ -28,7 +28,7 @@ theta = pi/2*runif(N) ...@@ -28,7 +28,7 @@ theta = pi/2*runif(N)
## Using a surface fraction argument ## Using a surface fraction argument
A method that is easier to understand and does not make use of the $sin$ function is based on the fact that if $X\sim U(0,1)$ and $Y\sim U(0,1)$, then $P[X2+Y2\leq 1]= \pi/4$ (see ["Monte Carlo method" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach: A method that is easier to understand and does not make use of the $\sin$ function is based on the fact that if $X\sim U(0,1)$ and $Y\sim U(0,1)$, then $P[X^2+Y^2\leq 1] = \pi/4$ (see ["Monte Carlo method" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:
```{r} ```{r}
set.seed(42) set.seed(42)
...@@ -39,7 +39,7 @@ library(ggplot2) ...@@ -39,7 +39,7 @@ library(ggplot2)
ggplot(df, aes(x=X,y=Y,color=Accept)) + geom_point(alpha=.2) + coord_fixed() + theme_bw() ggplot(df, aes(x=X,y=Y,color=Accept)) + geom_point(alpha=.2) + coord_fixed() + theme_bw()
It is then straightforward to obtain a (not really good) approximation to $\pi$ by counting how many times, on average, $X^2 + Y^2$ is smaller than 1 : It is then straightforward to obtain a (not really good) approximation to $\pi$ by counting how many times, on average, $X^2 + Y^2$ is smaller than 1:
```{r} ```{r}
4*mean(df$Accept) 4*mean(df$Accept)
