small edits
parent ae038e18
...@@ -4,7 +4,13 @@ ...@@ -4,7 +4,13 @@
"cell_type": "markdown", "cell_type": "markdown",
"source": [ "source": [
"# On the computation of $\\pi$\n", "# On the computation of $\\pi$"
"## Asking the maths library\n", "## Asking the maths library\n",
"\n", "\n",
"My computer tells me that $\\pi$ is *approximatively*" "My computer tells me that $\\pi$ is *approximatively*"
...@@ -32,8 +38,8 @@ ...@@ -32,8 +38,8 @@
"## Buffon’s needle\n", "## Buffon's needle\n",
"Applying the method of [Buffon’s needle](https://en.wikipedia.org/wiki/Buffon%27s_needle_problem), we get the __approximation__" "Applying the method of [Buffon's needle](https://en.wikipedia.org/wiki/Buffon%27s_needle_problem), we get the __approximation__"
...@@ -65,7 +71,7 @@ ...@@ -65,7 +71,7 @@
"## Using a surface fraction argument\n", "## Using a surface fraction argument\n",
"A method that is easier to understand and does not make use of the sin function is based on the fact that if $X\\sim U(0,1)$ and $Y\\sim U(0,1)$, then $P[X^2+Y^2\\leq 1] = \\pi/4$ (see [\"Monte Carlo method\" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:" "A method that is easier to understand and does not make use of the sin function is based on the fact that if $X\\sim U(0,1)$ and $Y\\sim U(0,1)$, then $P[X^2+Y^2\\leq 1] = \\pi/4$ (see [\"Monte Carlo method\" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:"
