3e6bf7b47a05a05ae3d6af86121dcb5d
ee3c40ac
ee3c40ac
François Févotte
Ex 4-1: meilleure manière de traiter les poids dans la régression
b1342638
3
Expand all
3 changed files
274 additions
287 deletions
+274
-287
challenger.html
module4/challenger.html
+258
-265
challenger.jmd
module4/challenger.jmd
+16
-22
challenger.pdf
module4/challenger.pdf
+0
ee3c40ac
This diff is collapsed.
ee3c40ac
@@ -99,32 +99,23 @@ This corresponds to the values from the article of Dalal et al. The standard
errors
are
s_
hat
alpha
j
printf
"%.3f"
σα
s_
hat
beta
j
printf
"%.3f"
σβ
which
is
different
from
the
3.052
0.047
reported
Dallal
et
al
The
deviance
is
G
2
j
printf
"%.3f"
G
²
j
nDOF
degrees
of
freedom
which
is
different
from
the
3.052
0.047
reported
Dallal
et
al
I
cannot
find
any
value
similar
to
the
Goodness
of
fit
G
2
18.086
reported
Dalal
et
al
However
the
number
of
degrees
of
freedom
is
similar
to
theirs
21
The
deviance
is
G
2
j
printf
"%.3f"
G
²
j
nDOF
degrees
of
freedom
I
cannot
find
any
value
similar
to
the
Goodness
of
fitreported
Dalal
et
al
G
2
18.086
However
the
number
of
degrees
of
freedom
is
different
but
at
least
similar
to
theirs
21
There
seems
to
be
something
wrong
Oh
I
know
I
haven
't indicated that my
observations are actually the result of 6 observations for each rocket
launch. The correct way to do this would be to weight the data using the `Count`
column. Since I don'
t
know
how
to
do
that
the
GLM
https
github
com
JuliaStats
GLM
jl
package
I
'm using, I will simply
duplicate the data:
launch. Let'
s
indicate
these
weights
since
the
weights
are
always
the
same
throughout
all
experiments
it
does
not
change
the
estimates
of
the
fit
but
it
does
influence
de
variance
estimate
julia
wrap
false
hold
true
weighted_data = DataFrame(Temperature=Int[], Frequency=Float64[])
for row in eachrow(data)
for _ in 1:row.Count
push!(weighted_data, (Temperature=row.Temperature,
Frequency=row.Frequency))
model = glm(@formula(Frequency ~ Temperature), weighted_data,
Binomial(), LogitLink())
model
glm
formula
Frequency
Temperature
Binomial
LogitLink
wts
Count
α
β
coef
model
σα
σβ
stderror
model
@@ -142,8 +133,11 @@ $s_{\hat{\beta}} = `j @printf "%.3f" σβ`$,
The
Goodness
of
fit
Deviance
indicated
for
this
model
is
G
2
j
printf
"%.3f"
G
²
j
nDOF
degrees
of
freedom
Now
G
2
is
in
good
accordance
to
the
results
of
the
Dalal
et
al
article
but
the
number
of
degrees of freedom is 6 times larger than i should, due to my tampering of the
data to duplicate them instead of weighting them.
degrees
of
freedom
is
approximately
6
times
larger
than
that
of
Dalal
et
al
Note
that
even
removing
this
factor
which
is
probably
due
to
the
way
the
number
of
residual
degrees
of
freedom
are
defined
in
both
libraries
in
the
presence
of
weights
the
values
are
similar
but
still
differ
j
printf
"%2.0f"
100
nDOF
6
21
Predicting
failure
probability
ee3c40ac
No preview for this file type
