78f4b088
78f4b088
Konrad Hinsen
Comment gérer des éventuelles erreurs lors du téléchargment des paquets Emacs
85d49849
10 additions
5 deletions
+10
-5
emacs_orgmode.org
module2/ressources/emacs_orgmode.org
+10
-5
78f4b088
@@ -239,12 +239,17 @@ There are two situations in which it might be necessary to modify
If you do have to modify =init.el=, check the comments at the
beginning of the file for instructions.
** Step 5: Check whether the installation is working or not
Quit Emacs if it is running, and start it again. This first start
will
take a bit of time because Emacs will download a few add-on
will
packages. For that reason, please make sure that you have a working
internet connection for this step.
Then open a file =foo.org=. Copy the following lines into this file:
internet connection for this step. Note also that the download can
fail for other reasons, such as the package servers being overloaded.
Such situations do not last very long, so we recommend that you just
quit Emacs (=C-x C-c=, meaning =Ctrl + x= followed by =Ctrl + c=) and
restart it. At worst, repeat this until you get no more errors on
startup.
Next, open a file =foo.org=. Copy the following lines into this file:
: #+begin_src shell :session foo :results output :exports both
: ls -la # or dir under windows
: #+end_src
