c2a72beb
c2a72beb
Konrad Hinsen
Always use a named session for shell commands under Windows
a5c9bbaf
2
2 changed files
14 additions
4 deletions
+14
-4
init.el
module2/ressources/rr_org/init.el
+7
-2
init.org
module2/ressources/rr_org/init.org
+7
-2
c2a72beb
@@ -232,8 +232,13 @@ Entered on %U
add-to-list
'org-structure-template-alist
add-to-list
"PP"
"#+begin_src python :results file :session :var matplot_lib_filename=(org-babel-temp-file \"figure\" \".png\") :exports both\nimport matplotlib.pyplot as plt\n\nimport numpy\nx=numpy.linspace(-15,15)\nplt.figure(figsize=(10,5))\nplt.plot(x,numpy.cos(x)/x)\nplt.tight_layout()\n\nplt.savefig(matplot_lib_filename)\nmatplot_lib_filename\n#+end_src"
"<src lang=\"python\">\n\n</src>"
"PP"
add-to-list
if
memq
system-type
windows-nt
ms-dos
"b"
"#+begin_src shell :results output :exports both\n\n#+end_src"
"<src lang=\"sh\">\n\n</src>"
;; Non-session shell execution does not seem to work under Windows, so we use
;; a named session just like for B.
add-to-list
"b"
"#+begin_src shell :session session :results output :exports both\n\n#+end_src"
add-to-list
"b"
add-to-list
add-to-list
"B"
"#+begin_src shell :session *shell* :results output :exports both \n\n#+end_src"
"B"
c2a72beb
@@ -395,8 +395,13 @@ To use this type <p and then TAB
*** Bash "sh" code:
*** Bash "sh" code:
To use this type <b and then TAB
#+begin_src emacs-lisp :tangle init.el
(add-to-list 'org-structure-template-alist
(if (memq system-type '(windows-nt ms-dos))
'("b" "#+begin_src shell :results output :exports both\n\n#+end_src" "<src lang=\"sh\">\n\n</src>"))
'("b" "#+begin_src shell :session session :results output :exports both\n\n#+end_src" "<src lang=\"sh\">\n\n</src>"))
'("b" "#+begin_src shell :results output :exports both\n\n#+end_src" "<src lang=\"sh\">\n\n</src>")))
To use this type <B and then TAB. This comes with a session argument
