Commit 26ec6fd5 authored by Dadier Remy's avatar Dadier Remy
Réalisation de l'exercice 3
parent 5e977089
...@@ -6,28 +6,24 @@ output: html_document ...@@ -6,28 +6,24 @@ output: html_document
```{r setup, include=FALSE} ```{r}
knitr::opts_chunk$set(echo = TRUE) df = c(14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0)
# Convertir df en un data frame
df <- data.frame(index = 1:length(df), values = df)
library(ggplot2)
#Créer un séquence plot avec les données
ggplot(df, aes(x = index, y = values)) +
geom_line(color = "blue", size = 1) +
labs(title = "Séquence Plot", x = "Index", y = "Valeurs") +
theme_bw() +
ylim(0, 25)
#Créer un histogramme des données
ggplot(df, aes(x = values)) +
geom_histogram(binwidth = 2, fill = "blue", color = "black") +
labs(title = "Histogramme des valeurs", x = "Valeurs", y = "Fréquence") +
theme_bw()
## Quelques explications
```{r pressure, echo=FALSE}
plot(pressure)
